    2. English
    3. ioBroker general
    4. Javascripts update 5.7 - scripts lost...?
    • E
      erwinberlin last edited by erwinberlin
      I just upgraded to javascript 5.7 and now I lost all my scripts. I read the warning about javascript mirror, I have never any of those settings. mirror script to file path is JS
      I tried to restore a back up and got this error:
      {"errno":-1,"code":"EPERM","syscall":"utime","path":"/opt/iobroker/backups/tmpScripts/"}
      Any one any clue on what is going on here?
      I am searching the forum for solutions, but have not found anything yet
      thanks,
      Erwin
        Thomas Braun Most Active @erwinberlin last edited by
        @erwinberlin sagte in Javascripts update 5.7 - scripts lost...?:
        Ich vermute mit einem Erwin aus Berlin kann man auch Deutsch schreiben.
        Wie wurde das Backup angelegt und wie wieder zurückgespielt?
        Und wie ist das 'Spiegelverzeichnis' im javascript-Adapter angelegt?
        • E
          erwinberlin @Thomas Braun last edited by
          I noticed that the javascript stops running after a restore attempt.
          Deutsch schreiben geht, und noch viel besser mit Google translate.
            @erwinberlin
            JS
            is not a valid entry. Either put the correct full path to your skripts or leave it empty.
            • E
              Leaving it empty does not result in my scripts appearing again.
              And the back up issue still exists. Backups are stored on the file server and can be read. However, when decompressing there seems to be an issue. Could be rights or location. Right now I am searching for the javascript folder.
                @erwinberlin
                How do you create backups and how do you put the backup files back into your system?
                • E
                  backups to a synology (SMB3.0). Restoring on a clean install works fine.
                    Why don't you do this then?
                    • E
                      that is a last resort option. It is weird that the javascript update breaks the system.
                        I think it's your faulty setup of the mirror directory.
                        • E
                          @thomas-braun that may well be faulty. Now the question is how to fix it.
                            @erwinberlin
                            iobroker stop
                            iobroker fix
                            iobroker start
                            Then pull back in your javaskript-Backup:
                            • E
                              @thomas-braun I did that already. Unfortunately, it does not help.
                              • E
                                erwinberlin @erwinberlin last edited by
                                So I ended up doing a full clean install RPI4 3Gb with Bullseye 64 bit. Restoring worked for adapters and javascript; zigbee and history both came with errors:
                                Still it all worked, so it is just a finding.
                                • E
                                  My solution (which I did tried 4x today) is to do a clean install. And then do the following in this order:
                                  1. restore history, java scripts and zigbee data
                                  2. install VIS via the adapters
                                  3. do an ioBroker restore
                                  And then the history data is still missing unfortunately. at least the system is up and running again in 10 mins. Did it 4x to get the Tuya devices to connect. unfortunately to no avail... (separate thread)
                                  BTW I changed from RPI to docker on Ubuntu server running on a Fujitsu Futro s740 with 8Gb and 128Gb SSD. That is a bit more stable and flexible than the RPi system.
                                  1.2k
                                  2038
