    4. Update/Installation von zigbee 1.7.0 schlägt fehl
      Thomas Braun Most Active last edited by Thomas Braun
      $ iobroker add zigbee auto --host chet
      NPM version: 8.9.0
      Installing iobroker.zigbee@1.7.0... (System call)
      added 39 packages in 28s66 packages are looking for funding run `npm fund` for details
      host.chet install adapter zigbee
      host.chet error: reading io-package.json /opt/iobroker/node_modules/iobroker.zigbee/io-package.json: Unexpected token o in JSON at position 10271
      ERROR: Process exited with code 27
      bwz. im log:
      2022-05-28 17:12:37.002  - info: host.chet iobroker add zigbee auto --host chet
      2022-05-28 17:12:40.536  - info: host.chet iobroker NPM version: 8.9.0
      2022-05-28 17:12:40.542  - info: host.chet iobroker Installing iobroker.zigbee@1.7.0... (System call)
      2022-05-28 17:13:09.706  - info: host.chet iobroker
      2022-05-28 17:13:09.715  - info: host.chet iobroker added 39 packages in 28s66 packages are looking for funding  run `npm fund` for details
      2022-05-28 17:13:09.758  - info: host.chet iobroker host.chet install adapter zigbee
      2022-05-28 17:13:09.762  - error: host.chet iobroker host.chet error: reading io-package.json /opt/iobroker/node_modules/iobroker.zigbee/io-package.json: Unexpected token o in JSON at position 10271
      2022-05-28 17:13:10.795  - info: host.chet iobroker exit 27
      Was ist eigentlich mit 'token at position 10271' gemeint? Das 10271 Zeichen im Text ist ein e...
      Edit: Da schau guck...
      https://github.com/ioBroker/ioBroker.zigbee/issues/1457
      BernhardLinz created this issue in ioBroker/ioBroker.zigbee
      closed Upgrade from v1.6.18 to v1.7.0: Cannot find io-package.json #1457
      frankthegreat 1 Reply Last reply Reply Quote 0
      • frankthegreat
        frankthegreat @Thomas Braun last edited by
        Wollte auch auf die Version 1.7.0 updaten. Update abgebrochen und starten will er auch nicht mehr 😞
        Dämlich...ich weis, aber irgendwer muß ja testen 😬
        Log:
        host.raspberrypi
        	2022-05-28 17:54:24.125	info	Do not restart adapter system.adapter.zigbee.0 because disabled or deleted
        host.raspberrypi
        	2022-05-28 17:54:24.124	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        host.raspberrypi
        	2022-05-28 17:54:24.124	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12)
        host.raspberrypi
        	2022-05-28 17:54:24.124	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
        host.raspberrypi
        	2022-05-28 17:54:24.123	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
        host.raspberrypi
        	2022-05-28 17:54:24.123	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
        host.raspberrypi
        	2022-05-28 17:54:24.123	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
        host.raspberrypi
        	2022-05-28 17:54:24.123	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/main.js:904:5)
        host.raspberrypi
        	2022-05-28 17:54:24.122	error	Caught by controller[0]: at new Zigbee (/opt/iobroker/node_modules/iobroker.zigbee/main.js:63:9)
        host.raspberrypi
        	2022-05-28 17:54:24.122	error	Caught by controller[0]: at new Adapter (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:289:30)
        host.raspberrypi
        	2022-05-28 17:54:24.122	error	Caught by controller[0]: at Object.readFileSync (/opt/iobroker/node_modules/jsonfile/index.js:52:17)
        host.raspberrypi
        	2022-05-28 17:54:24.121	error	Caught by controller[0]: at JSON.parse (<anonymous>)
        host.raspberrypi
        	2022-05-28 17:54:24.121	error	Caught by controller[0]: SyntaxError: /opt/iobroker/node_modules/iobroker.zigbee/io-package.json: Unexpected token o in JSON at position 10271
        host.raspberrypi
        	2022-05-28 17:54:24.121	error	Caught by controller[0]: ^
        host.raspberrypi
        	2022-05-28 17:54:24.120	error	Caught by controller[0]: throw err
        host.raspberrypi
        	2022-05-28 17:54:24.115	error	Caught by controller[0]: /opt/iobroker/node_modules/jsonfile/index.js:56
        host.raspberrypi
        	2022-05-28 17:54:08.089	info	"system.adapter.zigbee.0" disabled
        host.raspberrypi
        	2022-05-28 17:53:50.499	info	Restart adapter system.adapter.zigbee.0 because enabled
          Thomas Braun Most Active @frankthegreat last edited by
          @frankthegreat
          Da hat @arteck wohl das io-package.json kaputt gemacht! 😄
          Der Schlingel!
          • frankthegreat
            Kann man das fixen? Und wenn ja, wie?
            Hab ausgerechnet gestern mein System auf Bullseye hochgeprügelt und war froh, das alles einigermaßen läuft.
            Notfalls werf ich das alte System noch mal an ✌
              Thomas Braun Most Active @frankthegreat last edited by Thomas Braun
              @frankthegreat
              Ich hab die 1.6.18 wieder drauf geworfen.
              cd /opt/iobroker
              sudo -H -u iobroker npm install iobroker.zigbee@1.6.18 --loglevel error --prefix "/opt/iobroker"
              frankthegreat 1 Reply Last reply Reply Quote 2
              • frankthegreat
                @thomas-braun sagte in Update/Installation von zigbee 1.7.0 schlägt fehl:
                @frankthegreat
                cd /opt/iobroker
                Boah Ey!...Hab ich schon erwähnt, das mein Zigbee wieder läuft 🤘
                Thomas B. - wie gewohnt, der Retter in der Not.
                DANKE
                @arteck
                Eventuell die Version 1.7.0 nochmal checken...die zickt definitiv rum 😎
                  1.7.1 ist da..
                  Thomas Braun frankthegreat 2 Replies Last reply Reply Quote 1
                    Thomas Braun Most Active @arteck last edited by
                    @arteck
                    Juhu!
                    Läuft!
                    2022-05-28 18:29:05.523  - info: zigbee.0 (13349) starting. Version 1.7.1 (non-npm: ioBroker/ioBroker.zigbee#a68170f00c76dc216c66d64404c374dc768a02b1) in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.2.0, js-controller: 4.0.23
                    2022-05-28 18:29:05.763  - info: zigbee.0 (13349) delete old Backup files. keep only last 10
                    2022-05-28 18:29:05.842  - info: zigbee.0 (13349) Starting Zigbee  npm ...
                    2022-05-28 18:29:06.366  - info: zigbee.0 (13349) Installed Version: ioBroker/ioBroker.zigbee#a68170f00c76dc216c66d64404c374dc768a02b1
                    2022-05-28 18:29:17.169  - info: zigbee.0 (13349) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20220507}}
                    2022-05-28 18:29:17.178  - info: zigbee.0 (13349) Unable to disable LED, unsupported function.
                    2022-05-28 18:29:17.192  - info: zigbee.0 (13349)   --> transmitPower : normal
                    2022-05-28 18:29:17.200  - info: zigbee.0 (13349) Currently no devices.
                    2022-05-28 18:29:17.202  - info: zigbee.0 (13349) Zigbee started
                    • frankthegreat
                      frankthegreat @arteck last edited by
                      @arteck sagte in Update/Installation von zigbee 1.7.0 schlägt fehl:
                      1.7.1 ist da..
                      Das nenn' ich definitiv schnell 👏
                      Juhu!
                      Läuft!
                      Werd' ich mir morgen geben...da sollte mein Puls wieder normal sein 😁
                        Jan1 last edited by
                        Von wo habt Ihr die 1.7.1 geladen? Weder von NPN noch von GIT läuft das bei mir
                        022-05-28 19:52:34.899 - info: zigbee.0 (2036953) Zigbee started
                        2022-05-28 19:52:34.988 - info: zigbee.0 (2036953) debug devices set to ["null"]
                        2022-05-28 19:52:35.190 - error: zigbee.0 (2036953) uncaught exception: error is not defined
                        2022-05-28 19:52:35.190 - error: zigbee.0 (2036953) ReferenceError: error is not defined
                        at WriteStream. (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:523:46)
                        at WriteStream.emit (events.js:412:35)
                        at WriteStream.emit (domain.js:475:12)
                        at internal/fs/streams.js:335:14
                        at FSReqCallback.oncomplete (fs.js:180:23)
                        2022-05-28 19:52:35.191 - error: zigbee.0 (2036953) error is not defined
                        2022-05-28 19:52:35.240 - info: zigbee.0 (2036953) cleaned everything up...
                        2022-05-28 19:52:35.290 - info: zigbee.0 (2036953) Zigbee: disabling joining new devices.
                        2022-05-28 19:52:35.741 - info: zigbee.0 (2036953) terminating
                        2022-05-28 19:52:35.743 - warn: zigbee.0 (2036953) Terminated (UNCAUGHT_EXCEPTION): Without reason
                        2022-05-28 19:52:36.389 - error: host.Beelink Caught by controller[0]: ReferenceError: error is not defined
                        2022-05-28 19:52:36.390 - error: host.Beelink Caught by controller[0]: at WriteStream. (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:523:46)
                        2022-05-28 19:52:36.390 - error: host.Beelink Caught by controller[0]: at WriteStream.emit (events.js:412:35)
                        2022-05-28 19:52:36.390 - error: host.Beelink Caught by controller[0]: at WriteStream.emit (domain.js:475:12)
                        2022-05-28 19:52:36.390 - error: host.Beelink Caught by controller[0]: at internal/fs/streams.js:335:14
                        2022-05-28 19:52:36.390 - error: host.Beelink Caught by controller[0]: at FSReqCallback.oncomplete (fs.js:180:23)
                        2022-05-28 19:52:36.390 - error: host.Beelink Caught by controller[1]: SentryError: HTTP Error (429)
                        2022-05-28 19:52:36.391 - error: host.Beelink Caught by controller[1]: at new SentryError (/opt/iobroker/node_modules/@sentry/utils/src/error.ts:9:5)
                        2022-05-28 19:52:36.391 - error: host.Beelink Caught by controller[1]: at ClientRequest. (/opt/iobroker/node_modules/@sentry/node/src/transports/base/index.ts:252:22)
                        2022-05-28 19:52:36.391 - error: host.Beelink Caught by controller[1]: at Object.onceWrapper (events.js:520:26)
                        2022-05-28 19:52:36.391 - error: host.Beelink Caught by controller[1]: at ClientRequest.emit (events.js:400:28)
                        2022-05-28 19:52:36.391 - error: host.Beelink Caught by controller[1]: at ClientRequest.emit (domain.js:475:12)
                        2022-05-28 19:52:36.391 - error: host.Beelink Caught by controller[1]: at HTTPParser.parserOnIncomingClient (_http_client.js:647:27)
                        2022-05-28 19:52:36.391 - error: host.Beelink Caught by controller[1]: at HTTPParser.parserOnHeadersComplete (_http_common.js:127:17)
                        2022-05-28 19:52:36.391 - error: host.Beelink Caught by controller[1]: at TLSSocket.socketOnData (_http_client.js:515:22)
                        2022-05-28 19:52:36.391 - error: host.Beelink Caught by controller[1]: at TLSSocket.emit (events.js:400:28)
                        2022-05-28 19:52:36.392 - error: host.Beelink Caught by controller[1]: at TLSSocket.emit (domain.js:475:12)
                        2022-05-28 19:52:36.392 - error: host.Beelink instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                        2022-05-28 19:52:36.392 - info: host.Beelink Restart adapter system.adapter.zigbee.0 because enabled
                        2022-05-28 19:52:37.532 - info: host.Beelink instance system.adapter.zigbee.0 started with pid 2037186
                          Thomas Braun Most Active @Jan1 last edited by
                          @jan1 sagte in Update/Installation von zigbee 1.7.0 schlägt fehl:
                          Ganz normal aus git gezogen.
                          • crunchip
                            crunchip Forum Testing Most Active @Thomas Braun last edited by crunchip
                            dito
                            aber wie bekannt, dauert es ein wenig
                            Thomas Braun J 2 Replies Last reply Reply Quote 0
                              Thomas Braun Most Active @crunchip last edited by
                              @crunchip sagte in Update/Installation von zigbee 1.7.0 schlägt fehl:
                              unter npm@6
                              crunchip O 2 Replies Last reply Reply Quote 0
                              • crunchip
                                @thomas-braun ja
                                • O
                                  oFbEQnpoLKKl6mbY5e13 @Thomas Braun last edited by
                                  Auch wenn's offtopic ist, du nutzt ja nun schon länger NPM8. Gibt es irgendwelche Probleme damit?
                                    Jan1 @crunchip last edited by
                                    @crunchip
                                    Es wird ja installiert, nur habe ich ständige Restarts mit der oben geposteten Fehlermeldung. NPM 6 ist klar.
                                      Thomas Braun Most Active @oFbEQnpoLKKl6mbY5e13 last edited by Thomas Braun
                                      @ofbeqnpolkkl6mby5e13 sagte in Update/Installation von zigbee 1.7.0 schlägt fehl:
                                      OT: Mittlerweile hab ich da keine großen Auffälligkeiten mehr. Ein paar Befehle werden umgestellt und führen zu anderen Ausgaben, aber eigentlich läuft das. Jedenfalls zusammen mit entsprechend höhreren Versionen von nodeJS zusammen. Aber bei nodeJS gibt es noch einige Baustellen, das ist noch nicht empfehlenswert, wenn man nicht gewillt ist zu basteln.
                                        Kueppert last edited by Kueppert
                                        Hab eben auf die 1.7.1 upgedated...jetzt stürzt mir der Adapter laufend ab - wie beim Jan:
                                        host.ioBroker2 2022-05-28 20:59:18.384	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                        host.ioBroker2 2022-05-28 20:59:18.384	error	Caught by controller[2]: at processImmediate (internal/timers.js:466:21)
                                        host.ioBroker2 2022-05-28 20:59:18.384	error	Caught by controller[2]: at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/groups.js:325:29)
                                        host.ioBroker2 2022-05-28 20:59:18.384	error	Caught by controller[2]: at Array.forEach (<anonymous>)
                                        host.ioBroker2 2022-05-28 20:59:18.383	error	Caught by controller[2]: at /opt/iobroker/node_modules/iobroker.zigbee/lib/groups.js:329:51
                                        host.ioBroker2 2022-05-28 20:59:18.383	error	Caught by controller[2]: TypeError: Cannot read property 'deleteDeviceStates' of undefined
                                        host.ioBroker2 2022-05-28 20:59:18.383	error	Caught by controller[1]: at FSReqCallback.oncomplete (fs.js:179:23)
                                        host.ioBroker2 2022-05-28 20:59:18.383	error	Caught by controller[1]: at /opt/iobroker/node_modules/graceful-fs/graceful-fs.js:258:16
                                        host.ioBroker2 2022-05-28 20:59:18.383	error	Caught by controller[1]: at /opt/iobroker/node_modules/graceful-fs/graceful-fs.js:228:14
                                        host.ioBroker2 2022-05-28 20:59:18.383	error	Caught by controller[1]: at WriteStream.emit (domain.js:475:12)
                                        host.ioBroker2 2022-05-28 20:59:18.383	error	Caught by controller[1]: at WriteStream.emit (events.js:412:35)
                                        host.ioBroker2 2022-05-28 20:59:18.382	error	Caught by controller[1]: at WriteStream.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:523:46)
                                        host.ioBroker2 2022-05-28 20:59:18.382	error	Caught by controller[1]: ReferenceError: error is not defined
                                        host.ioBroker2 2022-05-28 20:59:18.382	error	Caught by controller[0]: at FSReqCallback.oncomplete (fs.js:179:23)
                                        host.ioBroker2 2022-05-28 20:59:18.382	error	Caught by controller[0]: at /opt/iobroker/node_modules/graceful-fs/graceful-fs.js:258:16
                                        host.ioBroker2 2022-05-28 20:59:18.382	error	Caught by controller[0]: at /opt/iobroker/node_modules/graceful-fs/graceful-fs.js:228:14
                                        host.ioBroker2 2022-05-28 20:59:18.382	error	Caught by controller[0]: at WriteStream.emit (domain.js:475:12)
                                        host.ioBroker2 2022-05-28 20:59:18.381	error	Caught by controller[0]: at WriteStream.emit (events.js:412:35)
                                        host.ioBroker2 2022-05-28 20:59:18.381	error	Caught by controller[0]: at WriteStream.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:523:46)
                                        host.ioBroker2 2022-05-28 20:59:18.381	error	Caught by controller[0]: ReferenceError: error is not defined
                                        zigbee.0 2022-05-28 20:59:17.875	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                        zigbee.0 2022-05-28 20:59:17.874	info	terminating
                                        zigbee.0 2022-05-28 20:59:17.606	error	Cannot read property 'deleteDeviceStates' of undefined
                                        zigbee.0 2022-05-28 20:59:17.606	error	TypeError: Cannot read property 'deleteDeviceStates' of undefined at /opt/iobroker/node_modules/iobroker.zigbee/lib/groups.js:329:51 at Array.forEach (<anonymous>) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/groups.js:325:29) at processImmediate (internal/timers.js:466:21)
                                        zigbee.0 2022-05-28 20:59:17.605	error	uncaught exception: Cannot read property 'deleteDeviceStates' of undefined
                                        zigbee.0 2022-05-28 20:59:17.486	info	Zigbee: disabling joining new devices.
                                        zigbee.0 2022-05-28 20:59:17.335	info	cleaned everything up...
                                        zigbee.0 2022-05-28 20:59:17.320	error	error is not defined
                                        zigbee.0 2022-05-28 20:59:17.320	error	ReferenceError: error is not defined at WriteStream.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:523:46) at WriteStream.emit (events.js:412:35) at WriteStream.emit (domain.js:475:12) at /opt/iobroker/node_modules/graceful-fs/graceful-fs.js:228:14 at /opt/iobroker/node_modules/graceful-fs/graceful-fs.js:258:16 at FSReqCallback.oncomplete (fs.js:179:23)
                                        zigbee.0 2022-05-28 20:59:17.319	error	uncaught exception: error is not defined
                                        zigbee.0 2022-05-28 20:59:17.308	error	error is not defined
                                        zigbee.0 2022-05-28 20:59:17.307	error	ReferenceError: error is not defined at WriteStream.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:523:46) at WriteStream.emit (events.js:412:35) at WriteStream.emit (domain.js:475:12) at /opt/iobroker/node_modules/graceful-fs/graceful-fs.js:228:14 at /opt/iobroker/node_modules/graceful-fs/graceful-fs.js:258:16 at FSReqCallback.oncomplete (fs.js:179:23)
                                        zigbee.0 2022-05-28 20:59:17.303	error	uncaught exception: error is not defined
                                        zigbee.0 2022-05-28 20:59:17.209	info	debug devices set to []
                                        zigbee.0 2022-05-28 20:59:17.048	info	Zigbee started
                                        zigbee.0 2022-05-28 20:59:16.875	info	Currently 45 devices are joined:
                                        zigbee.0 2022-05-28 20:59:16.863	info	--> transmitPower : normal
                                        zigbee.0 2022-05-28 20:59:16.852	info	Unable to disable LED, unsupported function.
                                        zigbee.0 2022-05-28 20:59:16.844	info	Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20220219}}
                                        zigbee.0 2022-05-28 20:59:16.476	info	Installed Version: iobroker.zigbee@1.7.1
                                        zigbee.0 2022-05-28 20:59:16.085	info	Starting Zigbee npm ...
                                        zigbee.0 2022-05-28 20:59:16.083	info	delete old Backup files. keep only last 10
                                        zigbee.0 2022-05-28 20:59:16.004	info	starting. Version 1.7.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.1, js-controller: 4.0.23
                                        NACHTRAG: von Git installiert, Backups im Adapter abgeschaltet führt zu noch mehr Fehlermeldungen 😕 Bin zurück auf die 1.6.18. Thx @Thomas Braun für den Code-Schnipsel 😉
                                          @kueppert
                                          Hast du ein Issue angelegt?
                                            rotamint last edited by
                                            Nach dem Update auf 1.7.1 läuft der Adapter bei mir nicht mehr 😢
                                            zigbee.0
                                            	2022-05-28 21:45:07.560	info	Zigbee: disabling joining new devices.
                                            zigbee.0
                                            	2022-05-28 21:45:07.339	info	cleaned everything up...
                                            zigbee.0
                                            	2022-05-28 21:45:06.795	error	error is not defined
                                            zigbee.0
                                            	2022-05-28 21:45:06.794	error	ReferenceError: error is not defined at WriteStream.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:523:46) at WriteStream.emit (events.js:412:35) at WriteStream.emit (domain.js:475:12) at internal/fs/streams.js:335:14 at FSReqCallback.oncomplete (fs.js:180:23)
                                            zigbee.0
                                            	2022-05-28 21:45:06.793	error	uncaught exception: error is not defined
                                            zigbee.0
                                            	2022-05-28 21:45:06.654	info	deregister device Ping for deactivated device "0x00158d0006ba8545"
                                            zigbee.0
                                            	2022-05-28 21:45:06.652	info	deregister device Ping for deactivated device "0x00158d0006ba5980"
                                            zigbee.0
                                            	2022-05-28 21:45:06.650	info	deregister device Ping for deactivated device "0x00158d0006ba9a90"
                                            zigbee.0
                                            	2022-05-28 21:45:06.649	info	deregister device Ping for deactivated device "0x00158d0006baa96d"
                                            zigbee.0
                                            	2022-05-28 21:45:06.642	info	deregister device Ping for deactivated device "0x00158d0006ba7afb"
                                            zigbee.0
                                            	2022-05-28 21:45:06.225	info	Zigbee started
                                            zigbee.0
                                            	2022-05-28 21:45:06.224	info	0x04cf8cdf3c78a785 (addr 36469): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:45:06.222	info	0x54ef4410000a2de9 (addr 53487): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:45:06.219	info	0x54ef4410000a2d4e (addr 53026): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:45:06.217	info	0x54ef4410000c18e4 (addr 45999): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:45:06.214	info	0x00158d0006ba8545 (addr 5552): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:45:06.212	info	0x00158d0006ba5980 (addr 18329): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:45:06.208	info	0x00158d0006ba9a90 (addr 17783): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:45:06.206	info	0x00158d0006baa96d (addr 64333): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:45:06.204	info	0x00158d0006ba9a00 (addr 39815): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:45:06.202	info	0x00158d0006ba7c33 (addr 24728): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:45:06.200	info	0x04cf8cdf3c7d4b90 (addr 10759): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:45:06.198	info	0x54ef4410001c4c66 (addr 60112): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:45:06.196	info	0x842e14fffe3676b1 (addr 65488): TS0502A - TuYa Light controller (Router)
                                            zigbee.0
                                            	2022-05-28 21:45:06.192	info	0x54ef4410000a2946 (addr 27490): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:45:06.191	info	0x680ae2fffead7a75 (addr 33928): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:45:06.190	info	0x00158d0006ba7afb (addr 13517): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:45:06.189	info	0x00158d0006ba51c2 (addr 36534): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:45:06.187	info	0x00158d0004a03e4c (addr 15394): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:45:06.186	info	0x00158d00047d628b (addr 35609): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:45:06.185	info	0x00158d00047d3bb5 (addr 40034): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:45:06.184	info	0x00158d00049da7d0 (addr 43006): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:45:06.182	info	0x04cf8cdf3c7d9620 (addr 58978): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:45:06.181	info	0x842e14fffe37c623 (addr 34027): 14147206L - Lidl Livarno Lux ceiling light (Router)
                                            zigbee.0
                                            	2022-05-28 21:45:06.179	info	0x842e14fffe1d9e28 (addr 15593): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:45:06.178	info	0x588e81fffee38ec2 (addr 56236): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:45:06.176	info	0x588e81fffef771f4 (addr 57637): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:45:06.175	info	0x842e14fffe15da08 (addr 33156): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:45:06.173	info	0x842e14fffe23076c (addr 56959): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:45:06.172	info	0x842e14fffe230848 (addr 50651): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:45:06.170	info	0x588e81fffef77a2f (addr 49811): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:45:06.168	info	0x842e14fffe1b9c91 (addr 38189): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:45:06.167	info	0x588e81fffeff6340 (addr 41064): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:45:06.164	info	0xec1bbdfffe91cdf4 (addr 18751): HG06335/HG07310 - Lidl Silvercrest smart motion sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:45:06.163	info	0xbc33acfffe5ede11 (addr 15735): FB20-002 - Lidl Livarno Lux switch and dimming light remote control (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:45:06.160	info	0xbc33acfffe6328d8 (addr 11726): FB20-002 - Lidl Livarno Lux switch and dimming light remote control (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:45:06.158	info	0x588e81fffe655d96 (addr 9183): LED1903C5/LED1835C6 - IKEA TRADFRI bulb E12/E14/E17 WS 450/470/440 lumen, dimmable, white spectrum, opal white (Router)
                                            zigbee.0
                                            	2022-05-28 21:45:06.155	info	0x04cf8cdf3c7b5527 (addr 11619): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:45:06.152	info	0x04cf8cdf3c7d4182 (addr 10828): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:45:06.146	info	0x001788010410074e (addr 49249): 8718696449691 - Philips Hue White A60 Single bulb E27/B22 (Router)
                                            zigbee.0
                                            	2022-05-28 21:45:06.016	info	Currently 39 devices are joined:
                                            zigbee.0
                                            	2022-05-28 21:45:06.012	info	Unable to set transmit power, unsupported function.
                                            zigbee.0
                                            	2022-05-28 21:45:05.867	info	--> transmitPower : normal
                                            zigbee.0
                                            	2022-05-28 21:45:05.851	info	Unable to disable LED, unsupported function.
                                            zigbee.0
                                            	2022-05-28 21:45:05.782	info	debug devices set to []
                                            zigbee.0
                                            	2022-05-28 21:45:05.676	info	Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":114,"maintrel":0,"revision":"0x26720700"}}
                                            zigbee.0
                                            	2022-05-28 21:45:05.635	info	Installed Version: iobroker.zigbee@1.7.1
                                            zigbee.0
                                            	2022-05-28 21:45:05.128	info	Starting Zigbee npm ...
                                            zigbee.0
                                            	2022-05-28 21:45:05.126	info	delete old Backup files. keep only last 10
                                            zigbee.0
                                            	2022-05-28 21:45:05.015	info	starting. Version 1.7.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.3, js-controller: 4.0.23
                                            zigbee.0
                                            	2022-05-28 21:44:30.318	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                            zigbee.0
                                            	2022-05-28 21:44:30.316	info	terminating
                                            zigbee.0
                                            	2022-05-28 21:44:29.884	info	Zigbee: disabling joining new devices.
                                            zigbee.0
                                            	2022-05-28 21:44:29.642	info	cleaned everything up...
                                            zigbee.0
                                            	2022-05-28 21:44:29.504	error	error is not defined
                                            zigbee.0
                                            	2022-05-28 21:44:29.503	error	ReferenceError: error is not defined at WriteStream.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:523:46) at WriteStream.emit (events.js:412:35) at WriteStream.emit (domain.js:475:12) at internal/fs/streams.js:335:14 at FSReqCallback.oncomplete (fs.js:180:23)
                                            zigbee.0
                                            	2022-05-28 21:44:29.502	error	uncaught exception: error is not defined
                                            zigbee.0
                                            	2022-05-28 21:44:29.332	info	deregister device Ping for deactivated device "0x00158d0006ba8545"
                                            zigbee.0
                                            	2022-05-28 21:44:29.331	info	deregister device Ping for deactivated device "0x00158d0006ba5980"
                                            zigbee.0
                                            	2022-05-28 21:44:29.330	info	deregister device Ping for deactivated device "0x00158d0006ba9a90"
                                            zigbee.0
                                            	2022-05-28 21:44:29.329	info	deregister device Ping for deactivated device "0x00158d0006baa96d"
                                            zigbee.0
                                            	2022-05-28 21:44:29.326	info	deregister device Ping for deactivated device "0x00158d0006ba7afb"
                                            zigbee.0
                                            	2022-05-28 21:44:29.304	info	debug devices set to []
                                            zigbee.0
                                            	2022-05-28 21:44:28.999	info	Zigbee started
                                            zigbee.0
                                            	2022-05-28 21:44:28.998	info	0x04cf8cdf3c78a785 (addr 36469): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:44:28.997	info	0x54ef4410000a2de9 (addr 53487): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:44:28.995	info	0x54ef4410000a2d4e (addr 53026): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:44:28.994	info	0x54ef4410000c18e4 (addr 45999): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:44:28.992	info	0x00158d0006ba8545 (addr 5552): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:44:28.990	info	0x00158d0006ba5980 (addr 18329): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:44:28.988	info	0x00158d0006ba9a90 (addr 17783): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:44:28.986	info	0x00158d0006baa96d (addr 64333): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:44:28.984	info	0x00158d0006ba9a00 (addr 39815): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:44:28.982	info	0x00158d0006ba7c33 (addr 24728): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:44:28.980	info	0x04cf8cdf3c7d4b90 (addr 10759): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:44:28.978	info	0x54ef4410001c4c66 (addr 60112): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:44:28.976	info	0x842e14fffe3676b1 (addr 65488): TS0502A - TuYa Light controller (Router)
                                            zigbee.0
                                            	2022-05-28 21:44:28.974	info	0x54ef4410000a2946 (addr 27490): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:44:28.973	info	0x680ae2fffead7a75 (addr 33928): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:44:28.969	info	0x00158d0006ba7afb (addr 13517): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:44:28.968	info	0x00158d0006ba51c2 (addr 36534): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:44:28.966	info	0x00158d0004a03e4c (addr 15394): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:44:28.965	info	0x00158d00047d628b (addr 35609): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:44:28.964	info	0x00158d00047d3bb5 (addr 40034): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:44:28.963	info	0x00158d00049da7d0 (addr 43006): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:44:28.961	info	0x04cf8cdf3c7d9620 (addr 58978): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:44:28.951	info	0x842e14fffe37c623 (addr 34027): 14147206L - Lidl Livarno Lux ceiling light (Router)
                                            zigbee.0
                                            	2022-05-28 21:44:28.949	info	0x842e14fffe1d9e28 (addr 15593): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:44:28.948	info	0x588e81fffee38ec2 (addr 56236): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:44:28.946	info	0x588e81fffef771f4 (addr 57637): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:44:28.945	info	0x842e14fffe15da08 (addr 33156): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:44:28.943	info	0x842e14fffe23076c (addr 56959): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:44:28.940	info	0x842e14fffe230848 (addr 50651): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:44:28.938	info	0x588e81fffef77a2f (addr 49811): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:44:28.936	info	0x842e14fffe1b9c91 (addr 38189): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:44:28.934	info	0x588e81fffeff6340 (addr 41064): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:44:28.933	info	0xec1bbdfffe91cdf4 (addr 18751): HG06335/HG07310 - Lidl Silvercrest smart motion sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:44:28.931	info	0xbc33acfffe5ede11 (addr 15735): FB20-002 - Lidl Livarno Lux switch and dimming light remote control (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:44:28.930	info	0xbc33acfffe6328d8 (addr 11726): FB20-002 - Lidl Livarno Lux switch and dimming light remote control (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:44:28.928	info	0x588e81fffe655d96 (addr 9183): LED1903C5/LED1835C6 - IKEA TRADFRI bulb E12/E14/E17 WS 450/470/440 lumen, dimmable, white spectrum, opal white (Router)
                                            zigbee.0
                                            	2022-05-28 21:44:28.926	info	0x04cf8cdf3c7b5527 (addr 11619): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:44:28.924	info	0x04cf8cdf3c7d4182 (addr 10828): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:44:28.916	info	0x001788010410074e (addr 49249): 8718696449691 - Philips Hue White A60 Single bulb E27/B22 (Router)
                                            zigbee.0
                                            	2022-05-28 21:44:28.775	info	Currently 39 devices are joined:
                                            zigbee.0
                                            	2022-05-28 21:44:28.769	info	Unable to set transmit power, unsupported function.
                                            zigbee.0
                                            	2022-05-28 21:44:28.615	info	--> transmitPower : normal
                                            zigbee.0
                                            	2022-05-28 21:44:28.589	info	Unable to disable LED, unsupported function.
                                            zigbee.0
                                            	2022-05-28 21:44:28.563	info	Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":114,"maintrel":0,"revision":"0x26720700"}}
                                            zigbee.0
                                            	2022-05-28 21:44:28.502	info	Installed Version: iobroker.zigbee@1.7.1
                                            zigbee.0
                                            	2022-05-28 21:44:27.912	info	Starting Zigbee npm ...
                                            zigbee.0
                                            	2022-05-28 21:44:27.910	info	delete old Backup files. keep only last 10
                                            zigbee.0
                                            	2022-05-28 21:44:27.796	info	starting. Version 1.7.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.3, js-controller: 4.0.23
                                            zigbee.0
                                            	2022-05-28 21:43:53.241	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                            zigbee.0
                                            	2022-05-28 21:43:53.240	info	terminating
                                            zigbee.0
                                            	2022-05-28 21:43:52.854	info	Zigbee: disabling joining new devices.
                                            zigbee.0
                                            	2022-05-28 21:43:52.599	info	cleaned everything up...
                                            zigbee.0
                                            	2022-05-28 21:43:52.517	error	error is not defined
                                            zigbee.0
                                            	2022-05-28 21:43:52.517	error	ReferenceError: error is not defined at WriteStream.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:523:46) at WriteStream.emit (events.js:412:35) at WriteStream.emit (domain.js:475:12) at internal/fs/streams.js:335:14 at FSReqCallback.oncomplete (fs.js:180:23)
                                            zigbee.0
                                            	2022-05-28 21:43:52.516	error	uncaught exception: error is not defined
                                            zigbee.0
                                            	2022-05-28 21:43:52.321	info	deregister device Ping for deactivated device "0x00158d0006ba8545"
                                            zigbee.0
                                            	2022-05-28 21:43:52.320	info	deregister device Ping for deactivated device "0x00158d0006ba5980"
                                            zigbee.0
                                            	2022-05-28 21:43:52.319	info	deregister device Ping for deactivated device "0x00158d0006ba9a90"
                                            zigbee.0
                                            	2022-05-28 21:43:52.318	info	deregister device Ping for deactivated device "0x00158d0006baa96d"
                                            zigbee.0
                                            	2022-05-28 21:43:52.313	info	deregister device Ping for deactivated device "0x00158d0006ba7afb"
                                            zigbee.0
                                            	2022-05-28 21:43:52.259	info	debug devices set to []
                                            zigbee.0
                                            	2022-05-28 21:43:51.986	info	Zigbee started
                                            zigbee.0
                                            	2022-05-28 21:43:51.985	info	0x04cf8cdf3c78a785 (addr 36469): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:43:51.984	info	0x54ef4410000a2de9 (addr 53487): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:43:51.982	info	0x54ef4410000a2d4e (addr 53026): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:43:51.980	info	0x54ef4410000c18e4 (addr 45999): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:43:51.978	info	0x00158d0006ba8545 (addr 5552): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:43:51.977	info	0x00158d0006ba5980 (addr 18329): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:43:51.975	info	0x00158d0006ba9a90 (addr 17783): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:43:51.973	info	0x00158d0006baa96d (addr 64333): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:43:51.971	info	0x00158d0006ba9a00 (addr 39815): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:43:51.969	info	0x00158d0006ba7c33 (addr 24728): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:43:51.967	info	0x04cf8cdf3c7d4b90 (addr 10759): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:43:51.965	info	0x54ef4410001c4c66 (addr 60112): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:43:51.963	info	0x842e14fffe3676b1 (addr 65488): TS0502A - TuYa Light controller (Router)
                                            zigbee.0
                                            	2022-05-28 21:43:51.961	info	0x54ef4410000a2946 (addr 27490): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:43:51.960	info	0x680ae2fffead7a75 (addr 33928): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:43:51.956	info	0x00158d0006ba7afb (addr 13517): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:43:51.955	info	0x00158d0006ba51c2 (addr 36534): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:43:51.953	info	0x00158d0004a03e4c (addr 15394): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:43:51.952	info	0x00158d00047d628b (addr 35609): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:43:51.951	info	0x00158d00047d3bb5 (addr 40034): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:43:51.950	info	0x00158d00049da7d0 (addr 43006): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:43:51.949	info	0x04cf8cdf3c7d9620 (addr 58978): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:43:51.947	info	0x842e14fffe37c623 (addr 34027): 14147206L - Lidl Livarno Lux ceiling light (Router)
                                            zigbee.0
                                            	2022-05-28 21:43:51.945	info	0x842e14fffe1d9e28 (addr 15593): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:43:51.935	info	0x588e81fffee38ec2 (addr 56236): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:43:51.934	info	0x588e81fffef771f4 (addr 57637): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:43:51.932	info	0x842e14fffe15da08 (addr 33156): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:43:51.930	info	0x842e14fffe23076c (addr 56959): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:43:51.927	info	0x842e14fffe230848 (addr 50651): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:43:51.926	info	0x588e81fffef77a2f (addr 49811): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:43:51.924	info	0x842e14fffe1b9c91 (addr 38189): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:43:51.922	info	0x588e81fffeff6340 (addr 41064): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:43:51.920	info	0xec1bbdfffe91cdf4 (addr 18751): HG06335/HG07310 - Lidl Silvercrest smart motion sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:43:51.919	info	0xbc33acfffe5ede11 (addr 15735): FB20-002 - Lidl Livarno Lux switch and dimming light remote control (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:43:51.917	info	0xbc33acfffe6328d8 (addr 11726): FB20-002 - Lidl Livarno Lux switch and dimming light remote control (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:43:51.915	info	0x588e81fffe655d96 (addr 9183): LED1903C5/LED1835C6 - IKEA TRADFRI bulb E12/E14/E17 WS 450/470/440 lumen, dimmable, white spectrum, opal white (Router)
                                            zigbee.0
                                            	2022-05-28 21:43:51.913	info	0x04cf8cdf3c7b5527 (addr 11619): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:43:51.911	info	0x04cf8cdf3c7d4182 (addr 10828): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:43:51.903	info	0x001788010410074e (addr 49249): 8718696449691 - Philips Hue White A60 Single bulb E27/B22 (Router)
                                            zigbee.0
                                            	2022-05-28 21:43:51.764	info	Currently 39 devices are joined:
                                            zigbee.0
                                            	2022-05-28 21:43:51.758	info	Unable to set transmit power, unsupported function.
                                            zigbee.0
                                            	2022-05-28 21:43:51.619	info	--> transmitPower : normal
                                            zigbee.0
                                            	2022-05-28 21:43:51.605	info	Unable to disable LED, unsupported function.
                                            zigbee.0
                                            	2022-05-28 21:43:51.584	info	Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":114,"maintrel":0,"revision":"0x26720700"}}
                                            zigbee.0
                                            	2022-05-28 21:43:51.543	info	Installed Version: iobroker.zigbee@1.7.1
                                            zigbee.0
                                            	2022-05-28 21:43:50.973	info	Starting Zigbee npm ...
                                            zigbee.0
                                            	2022-05-28 21:43:50.970	info	delete old Backup files. keep only last 10
                                            zigbee.0
                                            	2022-05-28 21:43:50.858	info	starting. Version 1.7.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.3, js-controller: 4.0.23
                                            zigbee.0
                                            	2022-05-28 21:43:13.965	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                            zigbee.0
                                            	2022-05-28 21:43:13.963	info	terminating
                                            zigbee.0
                                            	2022-05-28 21:43:13.275	info	Zigbee: disabling joining new devices.
                                            zigbee.0
                                            	2022-05-28 21:43:13.103	info	cleaned everything up...
                                            zigbee.0
                                            	2022-05-28 21:43:13.008	error	error is not defined
                                            zigbee.0
                                            	2022-05-28 21:43:13.007	error	ReferenceError: error is not defined at WriteStream.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:523:46) at WriteStream.emit (events.js:412:35) at WriteStream.emit (domain.js:475:12) at internal/fs/streams.js:335:14 at FSReqCallback.oncomplete (fs.js:180:23)
                                            zigbee.0
                                            	2022-05-28 21:43:13.006	error	uncaught exception: error is not defined
                                            zigbee.0
                                            	2022-05-28 21:43:12.883	info	deregister device Ping for deactivated device "0x00158d0006ba8545"
                                            zigbee.0
                                            	2022-05-28 21:43:12.882	info	deregister device Ping for deactivated device "0x00158d0006ba5980"
                                            zigbee.0
                                            	2022-05-28 21:43:12.881	info	deregister device Ping for deactivated device "0x00158d0006ba9a90"
                                            zigbee.0
                                            	2022-05-28 21:43:12.880	info	deregister device Ping for deactivated device "0x00158d0006baa96d"
                                            zigbee.0
                                            	2022-05-28 21:43:12.876	info	deregister device Ping for deactivated device "0x00158d0006ba7afb"
                                            zigbee.0
                                            	2022-05-28 21:43:12.845	info	debug devices set to []
                                            zigbee.0
                                            	2022-05-28 21:43:12.597	info	Zigbee started
                                            zigbee.0
                                            	2022-05-28 21:43:12.596	info	0x04cf8cdf3c78a785 (addr 36469): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:43:12.594	info	0x54ef4410000a2de9 (addr 53487): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:43:12.592	info	0x54ef4410000a2d4e (addr 53026): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:43:12.590	info	0x54ef4410000c18e4 (addr 45999): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:43:12.589	info	0x00158d0006ba8545 (addr 5552): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:43:12.587	info	0x00158d0006ba5980 (addr 18329): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:43:12.585	info	0x00158d0006ba9a90 (addr 17783): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:43:12.583	info	0x00158d0006baa96d (addr 64333): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:43:12.581	info	0x00158d0006ba9a00 (addr 39815): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:43:12.579	info	0x00158d0006ba7c33 (addr 24728): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:43:12.577	info	0x04cf8cdf3c7d4b90 (addr 10759): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:43:12.575	info	0x54ef4410001c4c66 (addr 60112): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:43:12.574	info	0x842e14fffe3676b1 (addr 65488): TS0502A - TuYa Light controller (Router)
                                            zigbee.0
                                            	2022-05-28 21:43:12.572	info	0x54ef4410000a2946 (addr 27490): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:43:12.570	info	0x680ae2fffead7a75 (addr 33928): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:43:12.566	info	0x00158d0006ba7afb (addr 13517): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:43:12.565	info	0x00158d0006ba51c2 (addr 36534): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:43:12.563	info	0x00158d0004a03e4c (addr 15394): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:43:12.562	info	0x00158d00047d628b (addr 35609): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:43:12.561	info	0x00158d00047d3bb5 (addr 40034): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:43:12.560	info	0x00158d00049da7d0 (addr 43006): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:43:12.559	info	0x04cf8cdf3c7d9620 (addr 58978): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:43:12.557	info	0x842e14fffe37c623 (addr 34027): 14147206L - Lidl Livarno Lux ceiling light (Router)
                                            zigbee.0
                                            	2022-05-28 21:43:12.556	info	0x842e14fffe1d9e28 (addr 15593): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:43:12.546	info	0x588e81fffee38ec2 (addr 56236): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:43:12.544	info	0x588e81fffef771f4 (addr 57637): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:43:12.543	info	0x842e14fffe15da08 (addr 33156): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:43:12.541	info	0x842e14fffe23076c (addr 56959): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:43:12.538	info	0x842e14fffe230848 (addr 50651): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:43:12.536	info	0x588e81fffef77a2f (addr 49811): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:43:12.534	info	0x842e14fffe1b9c91 (addr 38189): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:43:12.532	info	0x588e81fffeff6340 (addr 41064): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:43:12.531	info	0xec1bbdfffe91cdf4 (addr 18751): HG06335/HG07310 - Lidl Silvercrest smart motion sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:43:12.529	info	0xbc33acfffe5ede11 (addr 15735): FB20-002 - Lidl Livarno Lux switch and dimming light remote control (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:43:12.528	info	0xbc33acfffe6328d8 (addr 11726): FB20-002 - Lidl Livarno Lux switch and dimming light remote control (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:43:12.526	info	0x588e81fffe655d96 (addr 9183): LED1903C5/LED1835C6 - IKEA TRADFRI bulb E12/E14/E17 WS 450/470/440 lumen, dimmable, white spectrum, opal white (Router)
                                            zigbee.0
                                            	2022-05-28 21:43:12.523	info	0x04cf8cdf3c7b5527 (addr 11619): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:43:12.522	info	0x04cf8cdf3c7d4182 (addr 10828): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:43:12.514	info	0x001788010410074e (addr 49249): 8718696449691 - Philips Hue White A60 Single bulb E27/B22 (Router)
                                            zigbee.0
                                            	2022-05-28 21:43:12.375	info	Currently 39 devices are joined:
                                            zigbee.0
                                            	2022-05-28 21:43:12.369	info	Unable to set transmit power, unsupported function.
                                            zigbee.0
                                            	2022-05-28 21:43:12.232	info	--> transmitPower : normal
                                            zigbee.0
                                            	2022-05-28 21:43:12.218	info	Unable to disable LED, unsupported function.
                                            zigbee.0
                                            	2022-05-28 21:43:12.192	info	Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":114,"maintrel":0,"revision":"0x26720700"}}
                                            zigbee.0
                                            	2022-05-28 21:43:12.153	info	Installed Version: iobroker.zigbee@1.7.1
                                            zigbee.0
                                            	2022-05-28 21:43:11.625	info	Starting Zigbee npm ...
                                            zigbee.0
                                            	2022-05-28 21:43:11.623	info	delete old Backup files. keep only last 10
                                            zigbee.0
                                            	2022-05-28 21:43:11.509	info	starting. Version 1.7.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.3, js-controller: 4.0.23
                                            zigbee.0
                                            	2022-05-28 21:42:36.201	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                            zigbee.0
                                            	2022-05-28 21:42:36.199	info	terminating
                                            zigbee.0
                                            	2022-05-28 21:42:35.764	error	Cannot read property 'deleteDeviceStates' of undefined
                                            zigbee.0
                                            	2022-05-28 21:42:35.763	error	TypeError: Cannot read property 'deleteDeviceStates' of undefined at /opt/iobroker/node_modules/iobroker.zigbee/lib/groups.js:329:51 at Array.forEach (<anonymous>) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/groups.js:325:29) at processImmediate (internal/timers.js:466:21)
                                            zigbee.0
                                            	2022-05-28 21:42:35.762	error	uncaught exception: Cannot read property 'deleteDeviceStates' of undefined
                                            zigbee.0
                                            	2022-05-28 21:42:35.743	info	Zigbee: disabling joining new devices.
                                            zigbee.0
                                            	2022-05-28 21:42:35.490	info	cleaned everything up...
                                            zigbee.0
                                            	2022-05-28 21:42:35.395	error	error is not defined
                                            zigbee.0
                                            	2022-05-28 21:42:35.394	error	ReferenceError: error is not defined at WriteStream.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:523:46) at WriteStream.emit (events.js:412:35) at WriteStream.emit (domain.js:475:12) at internal/fs/streams.js:335:14 at FSReqCallback.oncomplete (fs.js:180:23)
                                            zigbee.0
                                            	2022-05-28 21:42:35.393	error	uncaught exception: error is not defined
                                            zigbee.0
                                            	2022-05-28 21:42:35.243	info	deregister device Ping for deactivated device "0x00158d0006ba8545"
                                            zigbee.0
                                            	2022-05-28 21:42:35.242	info	deregister device Ping for deactivated device "0x00158d0006ba5980"
                                            zigbee.0
                                            	2022-05-28 21:42:35.242	info	deregister device Ping for deactivated device "0x00158d0006ba9a90"
                                            zigbee.0
                                            	2022-05-28 21:42:35.241	info	deregister device Ping for deactivated device "0x00158d0006baa96d"
                                            zigbee.0
                                            	2022-05-28 21:42:35.237	info	deregister device Ping for deactivated device "0x00158d0006ba7afb"
                                            zigbee.0
                                            	2022-05-28 21:42:34.920	info	Zigbee started
                                            zigbee.0
                                            	2022-05-28 21:42:34.918	info	0x04cf8cdf3c78a785 (addr 36469): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:42:34.917	info	0x54ef4410000a2de9 (addr 53487): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:42:34.915	info	0x54ef4410000a2d4e (addr 53026): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:42:34.914	info	0x54ef4410000c18e4 (addr 45999): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:42:34.912	info	0x00158d0006ba8545 (addr 5552): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:42:34.910	info	0x00158d0006ba5980 (addr 18329): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:42:34.908	info	0x00158d0006ba9a90 (addr 17783): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:42:34.906	info	0x00158d0006baa96d (addr 64333): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:42:34.904	info	0x00158d0006ba9a00 (addr 39815): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:42:34.903	info	0x00158d0006ba7c33 (addr 24728): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:42:34.901	info	0x04cf8cdf3c7d4b90 (addr 10759): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:42:34.899	info	0x54ef4410001c4c66 (addr 60112): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:42:34.897	info	0x842e14fffe3676b1 (addr 65488): TS0502A - TuYa Light controller (Router)
                                            zigbee.0
                                            	2022-05-28 21:42:34.894	info	0x54ef4410000a2946 (addr 27490): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:42:34.893	info	0x680ae2fffead7a75 (addr 33928): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:42:34.891	info	0x00158d0006ba7afb (addr 13517): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:42:34.890	info	0x00158d0006ba51c2 (addr 36534): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:42:34.888	info	0x00158d0004a03e4c (addr 15394): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:42:34.887	info	0x00158d00047d628b (addr 35609): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:42:34.886	info	0x00158d00047d3bb5 (addr 40034): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:42:34.885	info	0x00158d00049da7d0 (addr 43006): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:42:34.884	info	0x04cf8cdf3c7d9620 (addr 58978): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:42:34.882	info	0x842e14fffe37c623 (addr 34027): 14147206L - Lidl Livarno Lux ceiling light (Router)
                                            zigbee.0
                                            	2022-05-28 21:42:34.880	info	0x842e14fffe1d9e28 (addr 15593): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:42:34.878	info	0x588e81fffee38ec2 (addr 56236): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:42:34.877	info	0x588e81fffef771f4 (addr 57637): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:42:34.875	info	0x842e14fffe15da08 (addr 33156): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:42:34.874	info	0x842e14fffe23076c (addr 56959): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:42:34.872	info	0x842e14fffe230848 (addr 50651): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:42:34.871	info	0x588e81fffef77a2f (addr 49811): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:42:34.869	info	0x842e14fffe1b9c91 (addr 38189): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:42:34.867	info	0x588e81fffeff6340 (addr 41064): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:42:34.866	info	0xec1bbdfffe91cdf4 (addr 18751): HG06335/HG07310 - Lidl Silvercrest smart motion sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:42:34.864	info	0xbc33acfffe5ede11 (addr 15735): FB20-002 - Lidl Livarno Lux switch and dimming light remote control (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:42:34.862	info	0xbc33acfffe6328d8 (addr 11726): FB20-002 - Lidl Livarno Lux switch and dimming light remote control (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:42:34.860	info	0x588e81fffe655d96 (addr 9183): LED1903C5/LED1835C6 - IKEA TRADFRI bulb E12/E14/E17 WS 450/470/440 lumen, dimmable, white spectrum, opal white (Router)
                                            zigbee.0
                                            	2022-05-28 21:42:34.858	info	0x04cf8cdf3c7b5527 (addr 11619): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:42:34.856	info	0x04cf8cdf3c7d4182 (addr 10828): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:42:34.852	info	0x001788010410074e (addr 49249): 8718696449691 - Philips Hue White A60 Single bulb E27/B22 (Router)
                                            zigbee.0
                                            	2022-05-28 21:42:34.714	info	Currently 39 devices are joined:
                                            zigbee.0
                                            	2022-05-28 21:42:34.710	info	Unable to set transmit power, unsupported function.
                                            zigbee.0
                                            	2022-05-28 21:42:34.573	info	--> transmitPower : normal
                                            zigbee.0
                                            	2022-05-28 21:42:34.560	info	Unable to disable LED, unsupported function.
                                            zigbee.0
                                            	2022-05-28 21:42:34.495	info	debug devices set to []
                                            zigbee.0
                                            	2022-05-28 21:42:34.426	info	Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":114,"maintrel":0,"revision":"0x26720700"}}
                                            zigbee.0
                                            	2022-05-28 21:42:34.376	info	Installed Version: iobroker.zigbee@1.7.1
                                            zigbee.0
                                            	2022-05-28 21:42:33.803	info	Starting Zigbee npm ...
                                            zigbee.0
                                            	2022-05-28 21:42:33.801	info	delete old Backup files. keep only last 10
                                            zigbee.0
                                            	2022-05-28 21:42:33.672	info	starting. Version 1.7.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.3, js-controller: 4.0.23
                                            zigbee.0
                                            	2022-05-28 21:41:58.742	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                            zigbee.0
                                            	2022-05-28 21:41:58.740	info	terminating
                                            zigbee.0
                                            	2022-05-28 21:41:58.243	info	Zigbee: disabling joining new devices.
                                            zigbee.0
                                            	2022-05-28 21:41:57.990	info	cleaned everything up...
                                            zigbee.0
                                            	2022-05-28 21:41:57.844	error	error is not defined
                                            zigbee.0
                                            	2022-05-28 21:41:57.843	error	ReferenceError: error is not defined at WriteStream.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:523:46) at WriteStream.emit (events.js:412:35) at WriteStream.emit (domain.js:475:12) at internal/fs/streams.js:335:14 at FSReqCallback.oncomplete (fs.js:180:23)
                                            zigbee.0
                                            	2022-05-28 21:41:57.842	error	uncaught exception: error is not defined
                                            zigbee.0
                                            	2022-05-28 21:41:57.667	info	deregister device Ping for deactivated device "0x00158d0006ba8545"
                                            zigbee.0
                                            	2022-05-28 21:41:57.666	info	deregister device Ping for deactivated device "0x00158d0006ba5980"
                                            zigbee.0
                                            	2022-05-28 21:41:57.665	info	deregister device Ping for deactivated device "0x00158d0006ba9a90"
                                            zigbee.0
                                            	2022-05-28 21:41:57.664	info	deregister device Ping for deactivated device "0x00158d0006baa96d"
                                            zigbee.0
                                            	2022-05-28 21:41:57.662	info	deregister device Ping for deactivated device "0x00158d0006ba7afb"
                                            zigbee.0
                                            	2022-05-28 21:41:57.638	info	debug devices set to []
                                            zigbee.0
                                            	2022-05-28 21:41:57.394	info	Zigbee started
                                            zigbee.0
                                            	2022-05-28 21:41:57.392	info	0x04cf8cdf3c78a785 (addr 36469): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:41:57.390	info	0x54ef4410000a2de9 (addr 53487): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:41:57.388	info	0x54ef4410000a2d4e (addr 53026): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:41:57.386	info	0x54ef4410000c18e4 (addr 45999): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:41:57.383	info	0x00158d0006ba8545 (addr 5552): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:41:57.381	info	0x00158d0006ba5980 (addr 18329): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:41:57.379	info	0x00158d0006ba9a90 (addr 17783): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:41:57.377	info	0x00158d0006baa96d (addr 64333): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:41:57.375	info	0x00158d0006ba9a00 (addr 39815): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:41:57.373	info	0x00158d0006ba7c33 (addr 24728): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:41:57.371	info	0x04cf8cdf3c7d4b90 (addr 10759): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:41:57.369	info	0x54ef4410001c4c66 (addr 60112): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:41:57.367	info	0x842e14fffe3676b1 (addr 65488): TS0502A - TuYa Light controller (Router)
                                            zigbee.0
                                            	2022-05-28 21:41:57.366	info	0x54ef4410000a2946 (addr 27490): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:41:57.364	info	0x680ae2fffead7a75 (addr 33928): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:41:57.360	info	0x00158d0006ba7afb (addr 13517): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:41:57.359	info	0x00158d0006ba51c2 (addr 36534): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:41:57.357	info	0x00158d0004a03e4c (addr 15394): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:41:57.356	info	0x00158d00047d628b (addr 35609): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:41:57.355	info	0x00158d00047d3bb5 (addr 40034): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:41:57.354	info	0x00158d00049da7d0 (addr 43006): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:41:57.352	info	0x04cf8cdf3c7d9620 (addr 58978): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:41:57.351	info	0x842e14fffe37c623 (addr 34027): 14147206L - Lidl Livarno Lux ceiling light (Router)
                                            zigbee.0
                                            	2022-05-28 21:41:57.350	info	0x842e14fffe1d9e28 (addr 15593): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:41:57.348	info	0x588e81fffee38ec2 (addr 56236): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:41:57.346	info	0x588e81fffef771f4 (addr 57637): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:41:57.336	info	0x842e14fffe15da08 (addr 33156): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:41:57.334	info	0x842e14fffe23076c (addr 56959): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:41:57.332	info	0x842e14fffe230848 (addr 50651): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:41:57.330	info	0x588e81fffef77a2f (addr 49811): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:41:57.328	info	0x842e14fffe1b9c91 (addr 38189): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:41:57.326	info	0x588e81fffeff6340 (addr 41064): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:41:57.324	info	0xec1bbdfffe91cdf4 (addr 18751): HG06335/HG07310 - Lidl Silvercrest smart motion sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:41:57.322	info	0xbc33acfffe5ede11 (addr 15735): FB20-002 - Lidl Livarno Lux switch and dimming light remote control (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:41:57.321	info	0xbc33acfffe6328d8 (addr 11726): FB20-002 - Lidl Livarno Lux switch and dimming light remote control (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:41:57.319	info	0x588e81fffe655d96 (addr 9183): LED1903C5/LED1835C6 - IKEA TRADFRI bulb E12/E14/E17 WS 450/470/440 lumen, dimmable, white spectrum, opal white (Router)
                                            zigbee.0
                                            	2022-05-28 21:41:57.317	info	0x04cf8cdf3c7b5527 (addr 11619): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:41:57.315	info	0x04cf8cdf3c7d4182 (addr 10828): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:41:57.307	info	0x001788010410074e (addr 49249): 8718696449691 - Philips Hue White A60 Single bulb E27/B22 (Router)
                                            zigbee.0
                                            	2022-05-28 21:41:57.145	info	Currently 39 devices are joined:
                                            zigbee.0
                                            	2022-05-28 21:41:57.140	info	Unable to set transmit power, unsupported function.
                                            zigbee.0
                                            	2022-05-28 21:41:57.000	info	--> transmitPower : normal
                                            zigbee.0
                                            	2022-05-28 21:41:56.986	info	Unable to disable LED, unsupported function.
                                            zigbee.0
                                            	2022-05-28 21:41:56.960	info	Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":114,"maintrel":0,"revision":"0x26720700"}}
                                            zigbee.0
                                            	2022-05-28 21:41:56.920	info	Installed Version: iobroker.zigbee@1.7.1
                                            zigbee.0
                                            	2022-05-28 21:41:56.392	info	Starting Zigbee npm ...
                                            zigbee.0
                                            	2022-05-28 21:41:56.390	info	delete old Backup files. keep only last 10
                                            zigbee.0
                                            	2022-05-28 21:41:56.276	info	starting. Version 1.7.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.3, js-controller: 4.0.23
                                            zigbee.0
                                            	2022-05-28 21:41:21.467	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                            zigbee.0
                                            	2022-05-28 21:41:21.466	info	terminating
                                            zigbee.0
                                            	2022-05-28 21:41:21.025	info	Zigbee: disabling joining new devices.
                                            zigbee.0
                                            	2022-05-28 21:41:20.859	info	cleaned everything up...
                                            zigbee.0
                                            	2022-05-28 21:41:20.498	error	error is not defined
                                            zigbee.0
                                            	2022-05-28 21:41:20.498	error	ReferenceError: error is not defined at WriteStream.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:523:46) at WriteStream.emit (events.js:412:35) at WriteStream.emit (domain.js:475:12) at internal/fs/streams.js:335:14 at FSReqCallback.oncomplete (fs.js:180:23)
                                            zigbee.0
                                            	2022-05-28 21:41:20.496	error	uncaught exception: error is not defined
                                            zigbee.0
                                            	2022-05-28 21:41:20.183	info	deregister device Ping for deactivated device "0x00158d0006ba8545"
                                            zigbee.0
                                            	2022-05-28 21:41:20.183	info	deregister device Ping for deactivated device "0x00158d0006ba5980"
                                            zigbee.0
                                            	2022-05-28 21:41:20.182	info	deregister device Ping for deactivated device "0x00158d0006ba9a90"
                                            zigbee.0
                                            	2022-05-28 21:41:20.181	info	deregister device Ping for deactivated device "0x00158d0006baa96d"
                                            zigbee.0
                                            	2022-05-28 21:41:20.178	info	deregister device Ping for deactivated device "0x00158d0006ba7afb"
                                            zigbee.0
                                            	2022-05-28 21:41:20.150	info	debug devices set to []
                                            zigbee.0
                                            	2022-05-28 21:41:19.898	info	Zigbee started
                                            zigbee.0
                                            	2022-05-28 21:41:19.897	info	0x04cf8cdf3c78a785 (addr 36469): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:41:19.895	info	0x54ef4410000a2de9 (addr 53487): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:41:19.893	info	0x54ef4410000a2d4e (addr 53026): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:41:19.891	info	0x54ef4410000c18e4 (addr 45999): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:41:19.890	info	0x00158d0006ba8545 (addr 5552): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:41:19.888	info	0x00158d0006ba5980 (addr 18329): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:41:19.886	info	0x00158d0006ba9a90 (addr 17783): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:41:19.884	info	0x00158d0006baa96d (addr 64333): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:41:19.882	info	0x00158d0006ba9a00 (addr 39815): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:41:19.880	info	0x00158d0006ba7c33 (addr 24728): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:41:19.878	info	0x04cf8cdf3c7d4b90 (addr 10759): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:41:19.876	info	0x54ef4410001c4c66 (addr 60112): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:41:19.874	info	0x842e14fffe3676b1 (addr 65488): TS0502A - TuYa Light controller (Router)
                                            zigbee.0
                                            	2022-05-28 21:41:19.872	info	0x54ef4410000a2946 (addr 27490): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:41:19.871	info	0x680ae2fffead7a75 (addr 33928): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:41:19.867	info	0x00158d0006ba7afb (addr 13517): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:41:19.866	info	0x00158d0006ba51c2 (addr 36534): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:41:19.864	info	0x00158d0004a03e4c (addr 15394): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:41:19.863	info	0x00158d00047d628b (addr 35609): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:41:19.862	info	0x00158d00047d3bb5 (addr 40034): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:41:19.861	info	0x00158d00049da7d0 (addr 43006): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:41:19.859	info	0x04cf8cdf3c7d9620 (addr 58978): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:41:19.858	info	0x842e14fffe37c623 (addr 34027): 14147206L - Lidl Livarno Lux ceiling light (Router)
                                            zigbee.0
                                            	2022-05-28 21:41:19.856	info	0x842e14fffe1d9e28 (addr 15593): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:41:19.855	info	0x588e81fffee38ec2 (addr 56236): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:41:19.853	info	0x588e81fffef771f4 (addr 57637): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:41:19.843	info	0x842e14fffe15da08 (addr 33156): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:41:19.841	info	0x842e14fffe23076c (addr 56959): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:41:19.838	info	0x842e14fffe230848 (addr 50651): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:41:19.836	info	0x588e81fffef77a2f (addr 49811): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:41:19.834	info	0x842e14fffe1b9c91 (addr 38189): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:41:19.833	info	0x588e81fffeff6340 (addr 41064): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:41:19.831	info	0xec1bbdfffe91cdf4 (addr 18751): HG06335/HG07310 - Lidl Silvercrest smart motion sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:41:19.829	info	0xbc33acfffe5ede11 (addr 15735): FB20-002 - Lidl Livarno Lux switch and dimming light remote control (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:41:19.828	info	0xbc33acfffe6328d8 (addr 11726): FB20-002 - Lidl Livarno Lux switch and dimming light remote control (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:41:19.826	info	0x588e81fffe655d96 (addr 9183): LED1903C5/LED1835C6 - IKEA TRADFRI bulb E12/E14/E17 WS 450/470/440 lumen, dimmable, white spectrum, opal white (Router)
                                            zigbee.0
                                            	2022-05-28 21:41:19.824	info	0x04cf8cdf3c7b5527 (addr 11619): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:41:19.822	info	0x04cf8cdf3c7d4182 (addr 10828): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:41:19.814	info	0x001788010410074e (addr 49249): 8718696449691 - Philips Hue White A60 Single bulb E27/B22 (Router)
                                            zigbee.0
                                            	2022-05-28 21:41:19.674	info	Currently 39 devices are joined:
                                            zigbee.0
                                            	2022-05-28 21:41:19.669	info	Unable to set transmit power, unsupported function.
                                            zigbee.0
                                            	2022-05-28 21:41:19.533	info	--> transmitPower : normal
                                            zigbee.0
                                            	2022-05-28 21:41:19.519	info	Unable to disable LED, unsupported function.
                                            zigbee.0
                                            	2022-05-28 21:41:19.499	info	Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":114,"maintrel":0,"revision":"0x26720700"}}
                                            zigbee.0
                                            	2022-05-28 21:41:19.458	info	Installed Version: iobroker.zigbee@1.7.1
                                            zigbee.0
                                            	2022-05-28 21:41:18.924	info	Starting Zigbee npm ...
                                            zigbee.0
                                            	2022-05-28 21:41:18.922	info	delete old Backup files. keep only last 10
                                            zigbee.0
                                            	2022-05-28 21:41:18.813	info	starting. Version 1.7.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.3, js-controller: 4.0.23
                                            zigbee.0
                                            	2022-05-28 21:40:44.131	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                            zigbee.0
                                            	2022-05-28 21:40:44.129	info	terminating
                                            zigbee.0
                                            	2022-05-28 21:40:43.691	info	Zigbee: disabling joining new devices.
                                            zigbee.0
                                            	2022-05-28 21:40:43.418	info	cleaned everything up...
                                            zigbee.0
                                            	2022-05-28 21:40:43.288	error	error is not defined
                                            zigbee.0
                                            	2022-05-28 21:40:43.287	error	ReferenceError: error is not defined at WriteStream.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:523:46) at WriteStream.emit (events.js:412:35) at WriteStream.emit (domain.js:475:12) at internal/fs/streams.js:335:14 at FSReqCallback.oncomplete (fs.js:180:23)
                                            zigbee.0
                                            	2022-05-28 21:40:43.286	error	uncaught exception: error is not defined
                                            zigbee.0
                                            	2022-05-28 21:40:43.114	info	deregister device Ping for deactivated device "0x00158d0006ba8545"
                                            zigbee.0
                                            	2022-05-28 21:40:43.113	info	deregister device Ping for deactivated device "0x00158d0006ba5980"
                                            zigbee.0
                                            	2022-05-28 21:40:43.112	info	deregister device Ping for deactivated device "0x00158d0006ba9a90"
                                            zigbee.0
                                            	2022-05-28 21:40:43.111	info	deregister device Ping for deactivated device "0x00158d0006baa96d"
                                            zigbee.0
                                            	2022-05-28 21:40:43.108	info	deregister device Ping for deactivated device "0x00158d0006ba7afb"
                                            zigbee.0
                                            	2022-05-28 21:40:43.083	info	debug devices set to []
                                            zigbee.0
                                            	2022-05-28 21:40:42.800	info	Zigbee started
                                            zigbee.0
                                            	2022-05-28 21:40:42.799	info	0x04cf8cdf3c78a785 (addr 36469): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:40:42.797	info	0x54ef4410000a2de9 (addr 53487): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:40:42.796	info	0x54ef4410000a2d4e (addr 53026): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:40:42.794	info	0x54ef4410000c18e4 (addr 45999): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:40:42.792	info	0x00158d0006ba8545 (addr 5552): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:40:42.790	info	0x00158d0006ba5980 (addr 18329): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:40:42.788	info	0x00158d0006ba9a90 (addr 17783): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:40:42.786	info	0x00158d0006baa96d (addr 64333): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:40:42.785	info	0x00158d0006ba9a00 (addr 39815): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:40:42.783	info	0x00158d0006ba7c33 (addr 24728): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:40:42.781	info	0x04cf8cdf3c7d4b90 (addr 10759): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:40:42.779	info	0x54ef4410001c4c66 (addr 60112): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:40:42.777	info	0x842e14fffe3676b1 (addr 65488): TS0502A - TuYa Light controller (Router)
                                            zigbee.0
                                            	2022-05-28 21:40:42.775	info	0x54ef4410000a2946 (addr 27490): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:40:42.773	info	0x680ae2fffead7a75 (addr 33928): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:40:42.770	info	0x00158d0006ba7afb (addr 13517): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:40:42.768	info	0x00158d0006ba51c2 (addr 36534): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:40:42.767	info	0x00158d0004a03e4c (addr 15394): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:40:42.766	info	0x00158d00047d628b (addr 35609): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:40:42.765	info	0x00158d00047d3bb5 (addr 40034): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:40:42.764	info	0x00158d00049da7d0 (addr 43006): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:40:42.762	info	0x04cf8cdf3c7d9620 (addr 58978): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:40:42.760	info	0x842e14fffe37c623 (addr 34027): 14147206L - Lidl Livarno Lux ceiling light (Router)
                                            zigbee.0
                                            	2022-05-28 21:40:42.758	info	0x842e14fffe1d9e28 (addr 15593): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:40:42.749	info	0x588e81fffee38ec2 (addr 56236): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:40:42.747	info	0x588e81fffef771f4 (addr 57637): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:40:42.745	info	0x842e14fffe15da08 (addr 33156): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:40:42.744	info	0x842e14fffe23076c (addr 56959): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:40:42.739	info	0x842e14fffe230848 (addr 50651): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:40:42.737	info	0x588e81fffef77a2f (addr 49811): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:40:42.736	info	0x842e14fffe1b9c91 (addr 38189): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:40:42.734	info	0x588e81fffeff6340 (addr 41064): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:40:42.732	info	0xec1bbdfffe91cdf4 (addr 18751): HG06335/HG07310 - Lidl Silvercrest smart motion sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:40:42.730	info	0xbc33acfffe5ede11 (addr 15735): FB20-002 - Lidl Livarno Lux switch and dimming light remote control (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:40:42.729	info	0xbc33acfffe6328d8 (addr 11726): FB20-002 - Lidl Livarno Lux switch and dimming light remote control (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:40:42.727	info	0x588e81fffe655d96 (addr 9183): LED1903C5/LED1835C6 - IKEA TRADFRI bulb E12/E14/E17 WS 450/470/440 lumen, dimmable, white spectrum, opal white (Router)
                                            zigbee.0
                                            	2022-05-28 21:40:42.725	info	0x04cf8cdf3c7b5527 (addr 11619): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:40:42.723	info	0x04cf8cdf3c7d4182 (addr 10828): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:40:42.715	info	0x001788010410074e (addr 49249): 8718696449691 - Philips Hue White A60 Single bulb E27/B22 (Router)
                                            zigbee.0
                                            	2022-05-28 21:40:42.575	info	Currently 39 devices are joined:
                                            zigbee.0
                                            	2022-05-28 21:40:42.570	info	Unable to set transmit power, unsupported function.
                                            zigbee.0
                                            	2022-05-28 21:40:42.435	info	--> transmitPower : normal
                                            zigbee.0
                                            	2022-05-28 21:40:42.421	info	Unable to disable LED, unsupported function.
                                            zigbee.0
                                            	2022-05-28 21:40:42.398	info	Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":114,"maintrel":0,"revision":"0x26720700"}}
                                            zigbee.0
                                            	2022-05-28 21:40:42.358	info	Installed Version: iobroker.zigbee@1.7.1
                                            zigbee.0
                                            	2022-05-28 21:40:41.827	info	Starting Zigbee npm ...
                                            zigbee.0
                                            	2022-05-28 21:40:41.824	info	delete old Backup files. keep only last 10
                                            zigbee.0
                                            	2022-05-28 21:40:41.714	info	starting. Version 1.7.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.3, js-controller: 4.0.23
                                            zigbee.0
                                            	2022-05-28 21:40:04.622	warn	get state error: DB closed
                                            zigbee.0
                                            	2022-05-28 21:40:04.621	warn	get state error: DB closed
                                            zigbee.0
                                            zigbee.0
                                            zigbee.0
                                            	2022-05-28 21:40:04.620	warn	get state error: DB closed
                                            zigbee.0
                                            zigbee.0
                                            zigbee.0
                                            	2022-05-28 21:40:04.619	warn	get state error: DB closed
                                            zigbee.0
                                            zigbee.0
                                            zigbee.0
                                            	2022-05-28 21:40:04.618	warn	get state error: DB closed
                                            zigbee.0
                                            zigbee.0
                                            zigbee.0
                                            	2022-05-28 21:40:04.617	warn	get state error: DB closed
                                            zigbee.0
                                            zigbee.0
                                            zigbee.0
                                            	2022-05-28 21:40:04.616	warn	get state error: DB closed
                                            zigbee.0
                                            zigbee.0
                                            zigbee.0
                                            	2022-05-28 21:40:04.615	warn	get state error: DB closed
                                            zigbee.0
                                            zigbee.0
                                            zigbee.0
                                            	2022-05-28 21:40:04.614	warn	get state error: DB closed
                                            zigbee.0
                                            zigbee.0
                                            	2022-05-28 21:40:04.613	warn	get state error: DB closed
                                            zigbee.0
                                            zigbee.0
                                            zigbee.0
                                            	2022-05-28 21:40:04.612	warn	get state error: DB closed
                                            zigbee.0
                                            zigbee.0
                                            zigbee.0
                                            	2022-05-28 21:40:04.611	warn	get state error: DB closed
                                            zigbee.0
                                            zigbee.0
                                            zigbee.0
                                            	2022-05-28 21:40:04.610	warn	get state error: DB closed
                                            zigbee.0
                                            zigbee.0
                                            	2022-05-28 21:40:04.609	warn	get state error: DB closed
                                            zigbee.0
                                            zigbee.0
                                            	2022-05-28 21:40:04.608	warn	get state error: DB closed
                                            zigbee.0
                                            zigbee.0
                                            	2022-05-28 21:40:04.607	warn	get state error: DB closed
                                            zigbee.0
                                            zigbee.0
                                            	2022-05-28 21:40:04.606	warn	get state error: DB closed
                                            zigbee.0
                                            zigbee.0
                                            	2022-05-28 21:40:04.605	warn	get state error: DB closed
                                            zigbee.0
                                            zigbee.0
                                            	2022-05-28 21:40:04.604	warn	get state error: DB closed
                                            zigbee.0
                                            zigbee.0
                                            zigbee.0
                                            	2022-05-28 21:40:04.603	warn	get state error: DB closed
                                            zigbee.0
                                            zigbee.0
                                            zigbee.0
                                            	2022-05-28 21:40:04.602	warn	get state error: DB closed
                                            zigbee.0
                                            zigbee.0
                                            zigbee.0
                                            	2022-05-28 21:40:04.601	warn	get state error: DB closed
                                            zigbee.0
                                            zigbee.0
                                            	2022-05-28 21:40:04.600	warn	get state error: DB closed
                                            zigbee.0
                                            zigbee.0
                                            zigbee.0
                                            	2022-05-28 21:40:04.599	warn	get state error: DB closed
                                            zigbee.0
                                            zigbee.0
                                            	2022-05-28 21:40:04.598	warn	get state error: DB closed
                                            zigbee.0
                                            zigbee.0
                                            	2022-05-28 21:40:04.597	warn	get state error: DB closed
                                            zigbee.0
                                            zigbee.0
                                            	2022-05-28 21:40:04.596	warn	get state error: Connection is closed.
                                            zigbee.0
                                            	2022-05-28 21:40:03.784	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                            zigbee.0
                                            	2022-05-28 21:40:03.781	info	terminating
                                            zigbee.0
                                            	2022-05-28 21:40:03.342	info	Zigbee: disabling joining new devices.
                                            zigbee.0
                                            	2022-05-28 21:40:03.120	info	cleaned everything up...
                                            zigbee.0
                                            	2022-05-28 21:40:03.048	error	error is not defined
                                            zigbee.0
                                            	2022-05-28 21:40:03.048	error	ReferenceError: error is not defined at WriteStream.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:523:46) at WriteStream.emit (events.js:412:35) at WriteStream.emit (domain.js:475:12) at internal/fs/streams.js:335:14 at FSReqCallback.oncomplete (fs.js:180:23)
                                            zigbee.0
                                            	2022-05-28 21:40:03.047	error	uncaught exception: error is not defined
                                            zigbee.0
                                            	2022-05-28 21:40:02.917	info	deregister device Ping for deactivated device "0x00158d0006ba8545"
                                            zigbee.0
                                            	2022-05-28 21:40:02.916	info	deregister device Ping for deactivated device "0x00158d0006ba5980"
                                            zigbee.0
                                            	2022-05-28 21:40:02.915	info	deregister device Ping for deactivated device "0x00158d0006ba9a90"
                                            zigbee.0
                                            	2022-05-28 21:40:02.915	info	deregister device Ping for deactivated device "0x00158d0006baa96d"
                                            zigbee.0
                                            	2022-05-28 21:40:02.912	info	deregister device Ping for deactivated device "0x00158d0006ba7afb"
                                            zigbee.0
                                            	2022-05-28 21:40:02.887	info	debug devices set to []
                                            zigbee.0
                                            	2022-05-28 21:40:02.492	info	Zigbee started
                                            zigbee.0
                                            	2022-05-28 21:40:02.491	info	0x04cf8cdf3c78a785 (addr 36469): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:40:02.489	info	0x54ef4410000a2de9 (addr 53487): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:40:02.487	info	0x54ef4410000a2d4e (addr 53026): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:40:02.485	info	0x54ef4410000c18e4 (addr 45999): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:40:02.483	info	0x00158d0006ba8545 (addr 5552): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:40:02.482	info	0x00158d0006ba5980 (addr 18329): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:40:02.480	info	0x00158d0006ba9a90 (addr 17783): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:40:02.478	info	0x00158d0006baa96d (addr 64333): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:40:02.476	info	0x00158d0006ba9a00 (addr 39815): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:40:02.474	info	0x00158d0006ba7c33 (addr 24728): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:40:02.472	info	0x04cf8cdf3c7d4b90 (addr 10759): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:40:02.470	info	0x54ef4410001c4c66 (addr 60112): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:40:02.468	info	0x842e14fffe3676b1 (addr 65488): TS0502A - TuYa Light controller (Router)
                                            zigbee.0
                                            	2022-05-28 21:40:02.466	info	0x54ef4410000a2946 (addr 27490): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:40:02.463	info	0x680ae2fffead7a75 (addr 33928): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:40:02.457	info	0x00158d0006ba7afb (addr 13517): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:40:02.454	info	0x00158d0006ba51c2 (addr 36534): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:40:02.450	info	0x00158d0004a03e4c (addr 15394): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:40:02.446	info	0x00158d00047d628b (addr 35609): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:40:02.444	info	0x00158d00047d3bb5 (addr 40034): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:40:02.441	info	0x00158d00049da7d0 (addr 43006): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:40:02.437	info	0x04cf8cdf3c7d9620 (addr 58978): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:40:02.434	info	0x842e14fffe37c623 (addr 34027): 14147206L - Lidl Livarno Lux ceiling light (Router)
                                            zigbee.0
                                            	2022-05-28 21:40:02.431	info	0x842e14fffe1d9e28 (addr 15593): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:40:02.428	info	0x588e81fffee38ec2 (addr 56236): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:40:02.426	info	0x588e81fffef771f4 (addr 57637): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:40:02.417	info	0x842e14fffe15da08 (addr 33156): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:40:02.415	info	0x842e14fffe23076c (addr 56959): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:40:02.410	info	0x842e14fffe230848 (addr 50651): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:40:02.409	info	0x588e81fffef77a2f (addr 49811): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:40:02.407	info	0x842e14fffe1b9c91 (addr 38189): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:40:02.405	info	0x588e81fffeff6340 (addr 41064): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
                                            zigbee.0
                                            	2022-05-28 21:40:02.403	info	0xec1bbdfffe91cdf4 (addr 18751): HG06335/HG07310 - Lidl Silvercrest smart motion sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:40:02.402	info	0xbc33acfffe5ede11 (addr 15735): FB20-002 - Lidl Livarno Lux switch and dimming light remote control (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:40:02.400	info	0xbc33acfffe6328d8 (addr 11726): FB20-002 - Lidl Livarno Lux switch and dimming light remote control (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:40:02.399	info	0x588e81fffe655d96 (addr 9183): LED1903C5/LED1835C6 - IKEA TRADFRI bulb E12/E14/E17 WS 450/470/440 lumen, dimmable, white spectrum, opal white (Router)
                                            zigbee.0
                                            	2022-05-28 21:40:02.396	info	0x04cf8cdf3c7b5527 (addr 11619): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:40:02.394	info	0x04cf8cdf3c7d4182 (addr 10828): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice)
                                            zigbee.0
                                            	2022-05-28 21:40:02.387	info	0x001788010410074e (addr 49249): 8718696449691 - Philips Hue White A60 Single bulb E27/B22 (Router)
                                            zigbee.0
                                            	2022-05-28 21:40:02.247	info	Currently 39 devices are joined:
                                            zigbee.0
                                            	2022-05-28 21:40:02.237	info	Unable to set transmit power, unsupported function.
                                            zigbee.0
                                            	2022-05-28 21:40:02.097	info	--> transmitPower : normal
                                            zigbee.0
                                            	2022-05-28 21:40:02.071	info	Unable to disable LED, unsupported function.
                                            zigbee.0
                                            	2022-05-28 21:40:02.043	info	Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":114,"maintrel":0,"revision":"0x26720700"}}
                                            zigbee.0
                                            	2022-05-28 21:40:01.996	info	Installed Version: iobroker.zigbee@1.7.1
                                            zigbee.0
                                            	2022-05-28 21:40:01.441	info	Starting Zigbee npm ...
                                            zigbee.0
                                            	2022-05-28 21:40:01.439	info	delete old Backup files. keep only last 10
                                            zigbee.0
                                            	2022-05-28 21:40:01.323	info	starting. Version 1.7.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.3, js-controller: 4.0.23
                                            81.1k
                                            159
                                            19288
