Update/Installation von zigbee 1.7.0 schlägt fehl
$ iobroker add zigbee auto --host chet NPM version: 8.9.0 Installing iobroker.zigbee@1.7.0... (System call) added 39 packages in 28s66 packages are looking for funding run `npm fund` for details host.chet install adapter zigbee host.chet error: reading io-package.json /opt/iobroker/node_modules/iobroker.zigbee/io-package.json: Unexpected token o in JSON at position 10271 ERROR: Process exited with code 27bwz. im log:
2022-05-28 17:12:37.002 - info: host.chet iobroker add zigbee auto --host chet 2022-05-28 17:12:40.536 - info: host.chet iobroker NPM version: 8.9.0 2022-05-28 17:12:40.542 - info: host.chet iobroker Installing iobroker.zigbee@1.7.0... (System call) 2022-05-28 17:13:09.706 - info: host.chet iobroker 2022-05-28 17:13:09.715 - info: host.chet iobroker added 39 packages in 28s66 packages are looking for funding run `npm fund` for details 2022-05-28 17:13:09.758 - info: host.chet iobroker host.chet install adapter zigbee 2022-05-28 17:13:09.762 - error: host.chet iobroker host.chet error: reading io-package.json /opt/iobroker/node_modules/iobroker.zigbee/io-package.json: Unexpected token o in JSON at position 10271 2022-05-28 17:13:10.795 - info: host.chet iobroker exit 27Was ist eigentlich mit 'token at position 10271' gemeint? Das 10271 Zeichen im Text ist ein
e...Edit: Da schau guck...
https://github.com/ioBroker/ioBroker.zigbee/issues/1457 -
Wollte auch auf die Version 1.7.0 updaten. Update abgebrochen und starten will er auch nicht mehr
Dämlich...ich weis, aber irgendwer muß ja testen
Log:
host.raspberrypi 2022-05-28 17:54:24.125 info Do not restart adapter system.adapter.zigbee.0 because disabled or deleted host.raspberrypi 2022-05-28 17:54:24.124 error instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED) host.raspberrypi 2022-05-28 17:54:24.124 error Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12) host.raspberrypi 2022-05-28 17:54:24.124 error Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12) host.raspberrypi 2022-05-28 17:54:24.123 error Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32) host.raspberrypi 2022-05-28 17:54:24.123 error Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10) host.raspberrypi 2022-05-28 17:54:24.123 error Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14) host.raspberrypi 2022-05-28 17:54:24.123 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/main.js:904:5) host.raspberrypi 2022-05-28 17:54:24.122 error Caught by controller[0]: at new Zigbee (/opt/iobroker/node_modules/iobroker.zigbee/main.js:63:9) host.raspberrypi 2022-05-28 17:54:24.122 error Caught by controller[0]: at new Adapter (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:289:30) host.raspberrypi 2022-05-28 17:54:24.122 error Caught by controller[0]: at Object.readFileSync (/opt/iobroker/node_modules/jsonfile/index.js:52:17) host.raspberrypi 2022-05-28 17:54:24.121 error Caught by controller[0]: at JSON.parse (<anonymous>) host.raspberrypi 2022-05-28 17:54:24.121 error Caught by controller[0]: SyntaxError: /opt/iobroker/node_modules/iobroker.zigbee/io-package.json: Unexpected token o in JSON at position 10271 host.raspberrypi 2022-05-28 17:54:24.121 error Caught by controller[0]: ^ host.raspberrypi 2022-05-28 17:54:24.120 error Caught by controller[0]: throw err host.raspberrypi 2022-05-28 17:54:24.115 error Caught by controller[0]: /opt/iobroker/node_modules/jsonfile/index.js:56 host.raspberrypi 2022-05-28 17:54:08.089 info "system.adapter.zigbee.0" disabled host.raspberrypi 2022-05-28 17:53:50.499 info Restart adapter system.adapter.zigbee.0 because enabled -
Kann man das fixen? Und wenn ja, wie?Hab ausgerechnet gestern mein System auf Bullseye hochgeprügelt und war froh, das alles einigermaßen läuft.
Notfalls werf ich das alte System noch mal an
Ich hab die 1.6.18 wieder drauf geworfen.
cd /opt/iobroker sudo -H -u iobroker npm install iobroker.zigbee@1.6.18 --loglevel error --prefix "/opt/iobroker" -
@thomas-braun sagte in Update/Installation von zigbee 1.7.0 schlägt fehl:
cd /opt/iobroker sudo -H -u iobroker npm install iobroker.zigbee@1.6.18 --loglevel error --prefix "/opt/iobroker"Boah Ey!...Hab ich schon erwähnt, das mein Zigbee wieder läuft
Thomas B. - wie gewohnt, der Retter in der Not.
DANKE@arteck
Eventuell die Version 1.7.0 nochmal checken...die zickt definitiv rum
1.7.1 ist da..
Juhu!
Läuft!2022-05-28 18:29:05.523 - info: zigbee.0 (13349) starting. Version 1.7.1 (non-npm: ioBroker/ioBroker.zigbee#a68170f00c76dc216c66d64404c374dc768a02b1) in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.2.0, js-controller: 4.0.23 2022-05-28 18:29:05.763 - info: zigbee.0 (13349) delete old Backup files. keep only last 10 2022-05-28 18:29:05.842 - info: zigbee.0 (13349) Starting Zigbee npm ... 2022-05-28 18:29:06.366 - info: zigbee.0 (13349) Installed Version: ioBroker/ioBroker.zigbee#a68170f00c76dc216c66d64404c374dc768a02b1 2022-05-28 18:29:17.169 - info: zigbee.0 (13349) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20220507}} 2022-05-28 18:29:17.178 - info: zigbee.0 (13349) Unable to disable LED, unsupported function. 2022-05-28 18:29:17.192 - info: zigbee.0 (13349) --> transmitPower : normal 2022-05-28 18:29:17.200 - info: zigbee.0 (13349) Currently no devices. 2022-05-28 18:29:17.202 - info: zigbee.0 (13349) Zigbee started -
@arteck sagte in Update/Installation von zigbee 1.7.0 schlägt fehl:
1.7.1 ist da..
Das nenn' ich definitiv schnell
Juhu!
Läuft!Werd' ich mir morgen geben...da sollte mein Puls wieder normal sein
Von wo habt Ihr die 1.7.1 geladen? Weder von NPN noch von GIT läuft das bei mir
022-05-28 19:52:34.899 - info: zigbee.0 (2036953) Zigbee started 2022-05-28 19:52:34.988 - info: zigbee.0 (2036953) debug devices set to ["null"] 2022-05-28 19:52:35.190 - error: zigbee.0 (2036953) uncaught exception: error is not defined 2022-05-28 19:52:35.190 - error: zigbee.0 (2036953) ReferenceError: error is not defined at WriteStream. (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:523:46) at WriteStream.emit (events.js:412:35) at WriteStream.emit (domain.js:475:12) at internal/fs/streams.js:335:14 at FSReqCallback.oncomplete (fs.js:180:23) 2022-05-28 19:52:35.191 - error: zigbee.0 (2036953) error is not defined 2022-05-28 19:52:35.240 - info: zigbee.0 (2036953) cleaned everything up... 2022-05-28 19:52:35.290 - info: zigbee.0 (2036953) Zigbee: disabling joining new devices. 2022-05-28 19:52:35.741 - info: zigbee.0 (2036953) terminating 2022-05-28 19:52:35.743 - warn: zigbee.0 (2036953) Terminated (UNCAUGHT_EXCEPTION): Without reason 2022-05-28 19:52:36.389 - error: host.Beelink Caught by controller[0]: ReferenceError: error is not defined 2022-05-28 19:52:36.390 - error: host.Beelink Caught by controller[0]: at WriteStream. (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:523:46) 2022-05-28 19:52:36.390 - error: host.Beelink Caught by controller[0]: at WriteStream.emit (events.js:412:35) 2022-05-28 19:52:36.390 - error: host.Beelink Caught by controller[0]: at WriteStream.emit (domain.js:475:12) 2022-05-28 19:52:36.390 - error: host.Beelink Caught by controller[0]: at internal/fs/streams.js:335:14 2022-05-28 19:52:36.390 - error: host.Beelink Caught by controller[0]: at FSReqCallback.oncomplete (fs.js:180:23) 2022-05-28 19:52:36.390 - error: host.Beelink Caught by controller[1]: SentryError: HTTP Error (429) 2022-05-28 19:52:36.391 - error: host.Beelink Caught by controller[1]: at new SentryError (/opt/iobroker/node_modules/@sentry/utils/src/error.ts:9:5) 2022-05-28 19:52:36.391 - error: host.Beelink Caught by controller[1]: at ClientRequest. (/opt/iobroker/node_modules/@sentry/node/src/transports/base/index.ts:252:22) 2022-05-28 19:52:36.391 - error: host.Beelink Caught by controller[1]: at Object.onceWrapper (events.js:520:26) 2022-05-28 19:52:36.391 - error: host.Beelink Caught by controller[1]: at ClientRequest.emit (events.js:400:28) 2022-05-28 19:52:36.391 - error: host.Beelink Caught by controller[1]: at ClientRequest.emit (domain.js:475:12) 2022-05-28 19:52:36.391 - error: host.Beelink Caught by controller[1]: at HTTPParser.parserOnIncomingClient (_http_client.js:647:27) 2022-05-28 19:52:36.391 - error: host.Beelink Caught by controller[1]: at HTTPParser.parserOnHeadersComplete (_http_common.js:127:17) 2022-05-28 19:52:36.391 - error: host.Beelink Caught by controller[1]: at TLSSocket.socketOnData (_http_client.js:515:22) 2022-05-28 19:52:36.391 - error: host.Beelink Caught by controller[1]: at TLSSocket.emit (events.js:400:28) 2022-05-28 19:52:36.392 - error: host.Beelink Caught by controller[1]: at TLSSocket.emit (domain.js:475:12) 2022-05-28 19:52:36.392 - error: host.Beelink instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION) 2022-05-28 19:52:36.392 - info: host.Beelink Restart adapter system.adapter.zigbee.0 because enabled 2022-05-28 19:52:37.532 - info: host.Beelink instance system.adapter.zigbee.0 started with pid 2037186 -
@jan1 sagte in Update/Installation von zigbee 1.7.0 schlägt fehl:
Ganz normal aus git gezogen.
dito
aber wie bekannt, dauert es ein wenig -
@crunchip sagte in Update/Installation von zigbee 1.7.0 schlägt fehl:
unter npm@6
Auch wenn's offtopic ist, du nutzt ja nun schon länger NPM8. Gibt es irgendwelche Probleme damit?
@crunchip
Es wird ja installiert, nur habe ich ständige Restarts mit der oben geposteten Fehlermeldung. NPM 6 ist klar. -
@ofbeqnpolkkl6mby5e13 sagte in Update/Installation von zigbee 1.7.0 schlägt fehl:
OT: Mittlerweile hab ich da keine großen Auffälligkeiten mehr. Ein paar Befehle werden umgestellt und führen zu anderen Ausgaben, aber eigentlich läuft das. Jedenfalls zusammen mit entsprechend höhreren Versionen von nodeJS zusammen. Aber bei nodeJS gibt es noch einige Baustellen, das ist noch nicht empfehlenswert, wenn man nicht gewillt ist zu basteln.
Hab eben auf die 1.7.1 upgedated...jetzt stürzt mir der Adapter laufend ab - wie beim Jan:
host.ioBroker2 2022-05-28 20:59:18.384 error instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED) host.ioBroker2 2022-05-28 20:59:18.384 error Caught by controller[2]: at processImmediate (internal/timers.js:466:21) host.ioBroker2 2022-05-28 20:59:18.384 error Caught by controller[2]: at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/groups.js:325:29) host.ioBroker2 2022-05-28 20:59:18.384 error Caught by controller[2]: at Array.forEach (<anonymous>) host.ioBroker2 2022-05-28 20:59:18.383 error Caught by controller[2]: at /opt/iobroker/node_modules/iobroker.zigbee/lib/groups.js:329:51 host.ioBroker2 2022-05-28 20:59:18.383 error Caught by controller[2]: TypeError: Cannot read property 'deleteDeviceStates' of undefined host.ioBroker2 2022-05-28 20:59:18.383 error Caught by controller[1]: at FSReqCallback.oncomplete (fs.js:179:23) host.ioBroker2 2022-05-28 20:59:18.383 error Caught by controller[1]: at /opt/iobroker/node_modules/graceful-fs/graceful-fs.js:258:16 host.ioBroker2 2022-05-28 20:59:18.383 error Caught by controller[1]: at /opt/iobroker/node_modules/graceful-fs/graceful-fs.js:228:14 host.ioBroker2 2022-05-28 20:59:18.383 error Caught by controller[1]: at WriteStream.emit (domain.js:475:12) host.ioBroker2 2022-05-28 20:59:18.383 error Caught by controller[1]: at WriteStream.emit (events.js:412:35) host.ioBroker2 2022-05-28 20:59:18.382 error Caught by controller[1]: at WriteStream.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:523:46) host.ioBroker2 2022-05-28 20:59:18.382 error Caught by controller[1]: ReferenceError: error is not defined host.ioBroker2 2022-05-28 20:59:18.382 error Caught by controller[0]: at FSReqCallback.oncomplete (fs.js:179:23) host.ioBroker2 2022-05-28 20:59:18.382 error Caught by controller[0]: at /opt/iobroker/node_modules/graceful-fs/graceful-fs.js:258:16 host.ioBroker2 2022-05-28 20:59:18.382 error Caught by controller[0]: at /opt/iobroker/node_modules/graceful-fs/graceful-fs.js:228:14 host.ioBroker2 2022-05-28 20:59:18.382 error Caught by controller[0]: at WriteStream.emit (domain.js:475:12) host.ioBroker2 2022-05-28 20:59:18.381 error Caught by controller[0]: at WriteStream.emit (events.js:412:35) host.ioBroker2 2022-05-28 20:59:18.381 error Caught by controller[0]: at WriteStream.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:523:46) host.ioBroker2 2022-05-28 20:59:18.381 error Caught by controller[0]: ReferenceError: error is not defined zigbee.0 2022-05-28 20:59:17.875 warn Terminated (UNCAUGHT_EXCEPTION): Without reason zigbee.0 2022-05-28 20:59:17.874 info terminating zigbee.0 2022-05-28 20:59:17.606 error Cannot read property 'deleteDeviceStates' of undefined zigbee.0 2022-05-28 20:59:17.606 error TypeError: Cannot read property 'deleteDeviceStates' of undefined at /opt/iobroker/node_modules/iobroker.zigbee/lib/groups.js:329:51 at Array.forEach (<anonymous>) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/groups.js:325:29) at processImmediate (internal/timers.js:466:21) zigbee.0 2022-05-28 20:59:17.605 error uncaught exception: Cannot read property 'deleteDeviceStates' of undefined zigbee.0 2022-05-28 20:59:17.486 info Zigbee: disabling joining new devices. zigbee.0 2022-05-28 20:59:17.335 info cleaned everything up... zigbee.0 2022-05-28 20:59:17.320 error error is not defined zigbee.0 2022-05-28 20:59:17.320 error ReferenceError: error is not defined at WriteStream.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:523:46) at WriteStream.emit (events.js:412:35) at WriteStream.emit (domain.js:475:12) at /opt/iobroker/node_modules/graceful-fs/graceful-fs.js:228:14 at /opt/iobroker/node_modules/graceful-fs/graceful-fs.js:258:16 at FSReqCallback.oncomplete (fs.js:179:23) zigbee.0 2022-05-28 20:59:17.319 error uncaught exception: error is not defined zigbee.0 2022-05-28 20:59:17.308 error error is not defined zigbee.0 2022-05-28 20:59:17.307 error ReferenceError: error is not defined at WriteStream.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:523:46) at WriteStream.emit (events.js:412:35) at WriteStream.emit (domain.js:475:12) at /opt/iobroker/node_modules/graceful-fs/graceful-fs.js:228:14 at /opt/iobroker/node_modules/graceful-fs/graceful-fs.js:258:16 at FSReqCallback.oncomplete (fs.js:179:23) zigbee.0 2022-05-28 20:59:17.303 error uncaught exception: error is not defined zigbee.0 2022-05-28 20:59:17.209 info debug devices set to [] zigbee.0 2022-05-28 20:59:17.048 info Zigbee started ... zigbee.0 2022-05-28 20:59:16.875 info Currently 45 devices are joined: zigbee.0 2022-05-28 20:59:16.863 info --> transmitPower : normal zigbee.0 2022-05-28 20:59:16.852 info Unable to disable LED, unsupported function. zigbee.0 2022-05-28 20:59:16.844 info Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20220219}} zigbee.0 2022-05-28 20:59:16.476 info Installed Version: iobroker.zigbee@1.7.1 zigbee.0 2022-05-28 20:59:16.085 info Starting Zigbee npm ... zigbee.0 2022-05-28 20:59:16.083 info delete old Backup files. keep only last 10 zigbee.0 2022-05-28 20:59:16.004 info starting. Version 1.7.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.1, js-controller: 4.0.23NACHTRAG: von Git installiert, Backups im Adapter abgeschaltet führt zu noch mehr Fehlermeldungen
Bin zurück auf die 1.6.18. Thx @Thomas Braun für den Code-Schnipsel
Hast du ein Issue angelegt?
Nach dem Update auf 1.7.1 läuft der Adapter bei mir nicht mehr
zigbee.0 2022-05-28 21:45:07.560 info Zigbee: disabling joining new devices. zigbee.0 2022-05-28 21:45:07.339 info cleaned everything up... zigbee.0 2022-05-28 21:45:06.795 error error is not defined zigbee.0 2022-05-28 21:45:06.794 error ReferenceError: error is not defined at WriteStream.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:523:46) at WriteStream.emit (events.js:412:35) at WriteStream.emit (domain.js:475:12) at internal/fs/streams.js:335:14 at FSReqCallback.oncomplete (fs.js:180:23) zigbee.0 2022-05-28 21:45:06.793 error uncaught exception: error is not defined zigbee.0 2022-05-28 21:45:06.654 info deregister device Ping for deactivated device "0x00158d0006ba8545" zigbee.0 2022-05-28 21:45:06.652 info deregister device Ping for deactivated device "0x00158d0006ba5980" zigbee.0 2022-05-28 21:45:06.650 info deregister device Ping for deactivated device "0x00158d0006ba9a90" zigbee.0 2022-05-28 21:45:06.649 info deregister device Ping for deactivated device "0x00158d0006baa96d" zigbee.0 2022-05-28 21:45:06.642 info deregister device Ping for deactivated device "0x00158d0006ba7afb" zigbee.0 2022-05-28 21:45:06.225 info Zigbee started zigbee.0 2022-05-28 21:45:06.224 info 0x04cf8cdf3c78a785 (addr 36469): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice) zigbee.0 2022-05-28 21:45:06.222 info 0x54ef4410000a2de9 (addr 53487): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice) zigbee.0 2022-05-28 21:45:06.219 info 0x54ef4410000a2d4e (addr 53026): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice) zigbee.0 2022-05-28 21:45:06.217 info 0x54ef4410000c18e4 (addr 45999): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice) zigbee.0 2022-05-28 21:45:06.214 info 0x00158d0006ba8545 (addr 5552): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:45:06.212 info 0x00158d0006ba5980 (addr 18329): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:45:06.208 info 0x00158d0006ba9a90 (addr 17783): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:45:06.206 info 0x00158d0006baa96d (addr 64333): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:45:06.204 info 0x00158d0006ba9a00 (addr 39815): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:45:06.202 info 0x00158d0006ba7c33 (addr 24728): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:45:06.200 info 0x04cf8cdf3c7d4b90 (addr 10759): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice) zigbee.0 2022-05-28 21:45:06.198 info 0x54ef4410001c4c66 (addr 60112): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice) zigbee.0 2022-05-28 21:45:06.196 info 0x842e14fffe3676b1 (addr 65488): TS0502A - TuYa Light controller (Router) zigbee.0 2022-05-28 21:45:06.192 info 0x54ef4410000a2946 (addr 27490): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice) zigbee.0 2022-05-28 21:45:06.191 info 0x680ae2fffead7a75 (addr 33928): E1524/E1810 - IKEA TRADFRI remote control (EndDevice) zigbee.0 2022-05-28 21:45:06.190 info 0x00158d0006ba7afb (addr 13517): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:45:06.189 info 0x00158d0006ba51c2 (addr 36534): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:45:06.187 info 0x00158d0004a03e4c (addr 15394): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice) zigbee.0 2022-05-28 21:45:06.186 info 0x00158d00047d628b (addr 35609): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice) zigbee.0 2022-05-28 21:45:06.185 info 0x00158d00047d3bb5 (addr 40034): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice) zigbee.0 2022-05-28 21:45:06.184 info 0x00158d00049da7d0 (addr 43006): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice) zigbee.0 2022-05-28 21:45:06.182 info 0x04cf8cdf3c7d9620 (addr 58978): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice) zigbee.0 2022-05-28 21:45:06.181 info 0x842e14fffe37c623 (addr 34027): 14147206L - Lidl Livarno Lux ceiling light (Router) zigbee.0 2022-05-28 21:45:06.179 info 0x842e14fffe1d9e28 (addr 15593): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:45:06.178 info 0x588e81fffee38ec2 (addr 56236): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:45:06.176 info 0x588e81fffef771f4 (addr 57637): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:45:06.175 info 0x842e14fffe15da08 (addr 33156): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:45:06.173 info 0x842e14fffe23076c (addr 56959): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:45:06.172 info 0x842e14fffe230848 (addr 50651): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:45:06.170 info 0x588e81fffef77a2f (addr 49811): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:45:06.168 info 0x842e14fffe1b9c91 (addr 38189): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:45:06.167 info 0x588e81fffeff6340 (addr 41064): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:45:06.164 info 0xec1bbdfffe91cdf4 (addr 18751): HG06335/HG07310 - Lidl Silvercrest smart motion sensor (EndDevice) zigbee.0 2022-05-28 21:45:06.163 info 0xbc33acfffe5ede11 (addr 15735): FB20-002 - Lidl Livarno Lux switch and dimming light remote control (EndDevice) zigbee.0 2022-05-28 21:45:06.160 info 0xbc33acfffe6328d8 (addr 11726): FB20-002 - Lidl Livarno Lux switch and dimming light remote control (EndDevice) zigbee.0 2022-05-28 21:45:06.158 info 0x588e81fffe655d96 (addr 9183): LED1903C5/LED1835C6 - IKEA TRADFRI bulb E12/E14/E17 WS 450/470/440 lumen, dimmable, white spectrum, opal white (Router) zigbee.0 2022-05-28 21:45:06.155 info 0x04cf8cdf3c7b5527 (addr 11619): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice) zigbee.0 2022-05-28 21:45:06.152 info 0x04cf8cdf3c7d4182 (addr 10828): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice) zigbee.0 2022-05-28 21:45:06.146 info 0x001788010410074e (addr 49249): 8718696449691 - Philips Hue White A60 Single bulb E27/B22 (Router) zigbee.0 2022-05-28 21:45:06.016 info Currently 39 devices are joined: zigbee.0 2022-05-28 21:45:06.012 info Unable to set transmit power, unsupported function. zigbee.0 2022-05-28 21:45:05.867 info --> transmitPower : normal zigbee.0 2022-05-28 21:45:05.851 info Unable to disable LED, unsupported function. zigbee.0 2022-05-28 21:45:05.782 info debug devices set to [] zigbee.0 2022-05-28 21:45:05.676 info Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":114,"maintrel":0,"revision":"0x26720700"}} zigbee.0 2022-05-28 21:45:05.635 info Installed Version: iobroker.zigbee@1.7.1 zigbee.0 2022-05-28 21:45:05.128 info Starting Zigbee npm ... zigbee.0 2022-05-28 21:45:05.126 info delete old Backup files. keep only last 10 zigbee.0 2022-05-28 21:45:05.015 info starting. Version 1.7.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.3, js-controller: 4.0.23 zigbee.0 2022-05-28 21:44:30.318 warn Terminated (UNCAUGHT_EXCEPTION): Without reason zigbee.0 2022-05-28 21:44:30.316 info terminating zigbee.0 2022-05-28 21:44:29.884 info Zigbee: disabling joining new devices. zigbee.0 2022-05-28 21:44:29.642 info cleaned everything up... zigbee.0 2022-05-28 21:44:29.504 error error is not defined zigbee.0 2022-05-28 21:44:29.503 error ReferenceError: error is not defined at WriteStream.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:523:46) at WriteStream.emit (events.js:412:35) at WriteStream.emit (domain.js:475:12) at internal/fs/streams.js:335:14 at FSReqCallback.oncomplete (fs.js:180:23) zigbee.0 2022-05-28 21:44:29.502 error uncaught exception: error is not defined zigbee.0 2022-05-28 21:44:29.332 info deregister device Ping for deactivated device "0x00158d0006ba8545" zigbee.0 2022-05-28 21:44:29.331 info deregister device Ping for deactivated device "0x00158d0006ba5980" zigbee.0 2022-05-28 21:44:29.330 info deregister device Ping for deactivated device "0x00158d0006ba9a90" zigbee.0 2022-05-28 21:44:29.329 info deregister device Ping for deactivated device "0x00158d0006baa96d" zigbee.0 2022-05-28 21:44:29.326 info deregister device Ping for deactivated device "0x00158d0006ba7afb" zigbee.0 2022-05-28 21:44:29.304 info debug devices set to [] zigbee.0 2022-05-28 21:44:28.999 info Zigbee started zigbee.0 2022-05-28 21:44:28.998 info 0x04cf8cdf3c78a785 (addr 36469): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice) zigbee.0 2022-05-28 21:44:28.997 info 0x54ef4410000a2de9 (addr 53487): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice) zigbee.0 2022-05-28 21:44:28.995 info 0x54ef4410000a2d4e (addr 53026): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice) zigbee.0 2022-05-28 21:44:28.994 info 0x54ef4410000c18e4 (addr 45999): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice) zigbee.0 2022-05-28 21:44:28.992 info 0x00158d0006ba8545 (addr 5552): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:44:28.990 info 0x00158d0006ba5980 (addr 18329): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:44:28.988 info 0x00158d0006ba9a90 (addr 17783): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:44:28.986 info 0x00158d0006baa96d (addr 64333): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:44:28.984 info 0x00158d0006ba9a00 (addr 39815): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:44:28.982 info 0x00158d0006ba7c33 (addr 24728): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:44:28.980 info 0x04cf8cdf3c7d4b90 (addr 10759): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice) zigbee.0 2022-05-28 21:44:28.978 info 0x54ef4410001c4c66 (addr 60112): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice) zigbee.0 2022-05-28 21:44:28.976 info 0x842e14fffe3676b1 (addr 65488): TS0502A - TuYa Light controller (Router) zigbee.0 2022-05-28 21:44:28.974 info 0x54ef4410000a2946 (addr 27490): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice) zigbee.0 2022-05-28 21:44:28.973 info 0x680ae2fffead7a75 (addr 33928): E1524/E1810 - IKEA TRADFRI remote control (EndDevice) zigbee.0 2022-05-28 21:44:28.969 info 0x00158d0006ba7afb (addr 13517): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:44:28.968 info 0x00158d0006ba51c2 (addr 36534): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:44:28.966 info 0x00158d0004a03e4c (addr 15394): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice) zigbee.0 2022-05-28 21:44:28.965 info 0x00158d00047d628b (addr 35609): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice) zigbee.0 2022-05-28 21:44:28.964 info 0x00158d00047d3bb5 (addr 40034): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice) zigbee.0 2022-05-28 21:44:28.963 info 0x00158d00049da7d0 (addr 43006): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice) zigbee.0 2022-05-28 21:44:28.961 info 0x04cf8cdf3c7d9620 (addr 58978): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice) zigbee.0 2022-05-28 21:44:28.951 info 0x842e14fffe37c623 (addr 34027): 14147206L - Lidl Livarno Lux ceiling light (Router) zigbee.0 2022-05-28 21:44:28.949 info 0x842e14fffe1d9e28 (addr 15593): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:44:28.948 info 0x588e81fffee38ec2 (addr 56236): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:44:28.946 info 0x588e81fffef771f4 (addr 57637): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:44:28.945 info 0x842e14fffe15da08 (addr 33156): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:44:28.943 info 0x842e14fffe23076c (addr 56959): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:44:28.940 info 0x842e14fffe230848 (addr 50651): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:44:28.938 info 0x588e81fffef77a2f (addr 49811): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:44:28.936 info 0x842e14fffe1b9c91 (addr 38189): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:44:28.934 info 0x588e81fffeff6340 (addr 41064): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:44:28.933 info 0xec1bbdfffe91cdf4 (addr 18751): HG06335/HG07310 - Lidl Silvercrest smart motion sensor (EndDevice) zigbee.0 2022-05-28 21:44:28.931 info 0xbc33acfffe5ede11 (addr 15735): FB20-002 - Lidl Livarno Lux switch and dimming light remote control (EndDevice) zigbee.0 2022-05-28 21:44:28.930 info 0xbc33acfffe6328d8 (addr 11726): FB20-002 - Lidl Livarno Lux switch and dimming light remote control (EndDevice) zigbee.0 2022-05-28 21:44:28.928 info 0x588e81fffe655d96 (addr 9183): LED1903C5/LED1835C6 - IKEA TRADFRI bulb E12/E14/E17 WS 450/470/440 lumen, dimmable, white spectrum, opal white (Router) zigbee.0 2022-05-28 21:44:28.926 info 0x04cf8cdf3c7b5527 (addr 11619): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice) zigbee.0 2022-05-28 21:44:28.924 info 0x04cf8cdf3c7d4182 (addr 10828): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice) zigbee.0 2022-05-28 21:44:28.916 info 0x001788010410074e (addr 49249): 8718696449691 - Philips Hue White A60 Single bulb E27/B22 (Router) zigbee.0 2022-05-28 21:44:28.775 info Currently 39 devices are joined: zigbee.0 2022-05-28 21:44:28.769 info Unable to set transmit power, unsupported function. zigbee.0 2022-05-28 21:44:28.615 info --> transmitPower : normal zigbee.0 2022-05-28 21:44:28.589 info Unable to disable LED, unsupported function. zigbee.0 2022-05-28 21:44:28.563 info Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":114,"maintrel":0,"revision":"0x26720700"}} zigbee.0 2022-05-28 21:44:28.502 info Installed Version: iobroker.zigbee@1.7.1 zigbee.0 2022-05-28 21:44:27.912 info Starting Zigbee npm ... zigbee.0 2022-05-28 21:44:27.910 info delete old Backup files. keep only last 10 zigbee.0 2022-05-28 21:44:27.796 info starting. Version 1.7.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.3, js-controller: 4.0.23 zigbee.0 2022-05-28 21:43:53.241 warn Terminated (UNCAUGHT_EXCEPTION): Without reason zigbee.0 2022-05-28 21:43:53.240 info terminating zigbee.0 2022-05-28 21:43:52.854 info Zigbee: disabling joining new devices. zigbee.0 2022-05-28 21:43:52.599 info cleaned everything up... zigbee.0 2022-05-28 21:43:52.517 error error is not defined zigbee.0 2022-05-28 21:43:52.517 error ReferenceError: error is not defined at WriteStream.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:523:46) at WriteStream.emit (events.js:412:35) at WriteStream.emit (domain.js:475:12) at internal/fs/streams.js:335:14 at FSReqCallback.oncomplete (fs.js:180:23) zigbee.0 2022-05-28 21:43:52.516 error uncaught exception: error is not defined zigbee.0 2022-05-28 21:43:52.321 info deregister device Ping for deactivated device "0x00158d0006ba8545" zigbee.0 2022-05-28 21:43:52.320 info deregister device Ping for deactivated device "0x00158d0006ba5980" zigbee.0 2022-05-28 21:43:52.319 info deregister device Ping for deactivated device "0x00158d0006ba9a90" zigbee.0 2022-05-28 21:43:52.318 info deregister device Ping for deactivated device "0x00158d0006baa96d" zigbee.0 2022-05-28 21:43:52.313 info deregister device Ping for deactivated device "0x00158d0006ba7afb" zigbee.0 2022-05-28 21:43:52.259 info debug devices set to [] zigbee.0 2022-05-28 21:43:51.986 info Zigbee started zigbee.0 2022-05-28 21:43:51.985 info 0x04cf8cdf3c78a785 (addr 36469): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice) zigbee.0 2022-05-28 21:43:51.984 info 0x54ef4410000a2de9 (addr 53487): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice) zigbee.0 2022-05-28 21:43:51.982 info 0x54ef4410000a2d4e (addr 53026): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice) zigbee.0 2022-05-28 21:43:51.980 info 0x54ef4410000c18e4 (addr 45999): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice) zigbee.0 2022-05-28 21:43:51.978 info 0x00158d0006ba8545 (addr 5552): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:43:51.977 info 0x00158d0006ba5980 (addr 18329): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:43:51.975 info 0x00158d0006ba9a90 (addr 17783): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:43:51.973 info 0x00158d0006baa96d (addr 64333): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:43:51.971 info 0x00158d0006ba9a00 (addr 39815): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:43:51.969 info 0x00158d0006ba7c33 (addr 24728): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:43:51.967 info 0x04cf8cdf3c7d4b90 (addr 10759): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice) zigbee.0 2022-05-28 21:43:51.965 info 0x54ef4410001c4c66 (addr 60112): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice) zigbee.0 2022-05-28 21:43:51.963 info 0x842e14fffe3676b1 (addr 65488): TS0502A - TuYa Light controller (Router) zigbee.0 2022-05-28 21:43:51.961 info 0x54ef4410000a2946 (addr 27490): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice) zigbee.0 2022-05-28 21:43:51.960 info 0x680ae2fffead7a75 (addr 33928): E1524/E1810 - IKEA TRADFRI remote control (EndDevice) zigbee.0 2022-05-28 21:43:51.956 info 0x00158d0006ba7afb (addr 13517): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:43:51.955 info 0x00158d0006ba51c2 (addr 36534): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:43:51.953 info 0x00158d0004a03e4c (addr 15394): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice) zigbee.0 2022-05-28 21:43:51.952 info 0x00158d00047d628b (addr 35609): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice) zigbee.0 2022-05-28 21:43:51.951 info 0x00158d00047d3bb5 (addr 40034): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice) zigbee.0 2022-05-28 21:43:51.950 info 0x00158d00049da7d0 (addr 43006): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice) zigbee.0 2022-05-28 21:43:51.949 info 0x04cf8cdf3c7d9620 (addr 58978): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice) zigbee.0 2022-05-28 21:43:51.947 info 0x842e14fffe37c623 (addr 34027): 14147206L - Lidl Livarno Lux ceiling light (Router) zigbee.0 2022-05-28 21:43:51.945 info 0x842e14fffe1d9e28 (addr 15593): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:43:51.935 info 0x588e81fffee38ec2 (addr 56236): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:43:51.934 info 0x588e81fffef771f4 (addr 57637): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:43:51.932 info 0x842e14fffe15da08 (addr 33156): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:43:51.930 info 0x842e14fffe23076c (addr 56959): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:43:51.927 info 0x842e14fffe230848 (addr 50651): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:43:51.926 info 0x588e81fffef77a2f (addr 49811): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:43:51.924 info 0x842e14fffe1b9c91 (addr 38189): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:43:51.922 info 0x588e81fffeff6340 (addr 41064): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:43:51.920 info 0xec1bbdfffe91cdf4 (addr 18751): HG06335/HG07310 - Lidl Silvercrest smart motion sensor (EndDevice) zigbee.0 2022-05-28 21:43:51.919 info 0xbc33acfffe5ede11 (addr 15735): FB20-002 - Lidl Livarno Lux switch and dimming light remote control (EndDevice) zigbee.0 2022-05-28 21:43:51.917 info 0xbc33acfffe6328d8 (addr 11726): FB20-002 - Lidl Livarno Lux switch and dimming light remote control (EndDevice) zigbee.0 2022-05-28 21:43:51.915 info 0x588e81fffe655d96 (addr 9183): LED1903C5/LED1835C6 - IKEA TRADFRI bulb E12/E14/E17 WS 450/470/440 lumen, dimmable, white spectrum, opal white (Router) zigbee.0 2022-05-28 21:43:51.913 info 0x04cf8cdf3c7b5527 (addr 11619): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice) zigbee.0 2022-05-28 21:43:51.911 info 0x04cf8cdf3c7d4182 (addr 10828): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice) zigbee.0 2022-05-28 21:43:51.903 info 0x001788010410074e (addr 49249): 8718696449691 - Philips Hue White A60 Single bulb E27/B22 (Router) zigbee.0 2022-05-28 21:43:51.764 info Currently 39 devices are joined: zigbee.0 2022-05-28 21:43:51.758 info Unable to set transmit power, unsupported function. zigbee.0 2022-05-28 21:43:51.619 info --> transmitPower : normal zigbee.0 2022-05-28 21:43:51.605 info Unable to disable LED, unsupported function. zigbee.0 2022-05-28 21:43:51.584 info Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":114,"maintrel":0,"revision":"0x26720700"}} zigbee.0 2022-05-28 21:43:51.543 info Installed Version: iobroker.zigbee@1.7.1 zigbee.0 2022-05-28 21:43:50.973 info Starting Zigbee npm ... zigbee.0 2022-05-28 21:43:50.970 info delete old Backup files. keep only last 10 zigbee.0 2022-05-28 21:43:50.858 info starting. Version 1.7.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.3, js-controller: 4.0.23 zigbee.0 2022-05-28 21:43:13.965 warn Terminated (UNCAUGHT_EXCEPTION): Without reason zigbee.0 2022-05-28 21:43:13.963 info terminating zigbee.0 2022-05-28 21:43:13.275 info Zigbee: disabling joining new devices. zigbee.0 2022-05-28 21:43:13.103 info cleaned everything up... zigbee.0 2022-05-28 21:43:13.008 error error is not defined zigbee.0 2022-05-28 21:43:13.007 error ReferenceError: error is not defined at WriteStream.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:523:46) at WriteStream.emit (events.js:412:35) at WriteStream.emit (domain.js:475:12) at internal/fs/streams.js:335:14 at FSReqCallback.oncomplete (fs.js:180:23) zigbee.0 2022-05-28 21:43:13.006 error uncaught exception: error is not defined zigbee.0 2022-05-28 21:43:12.883 info deregister device Ping for deactivated device "0x00158d0006ba8545" zigbee.0 2022-05-28 21:43:12.882 info deregister device Ping for deactivated device "0x00158d0006ba5980" zigbee.0 2022-05-28 21:43:12.881 info deregister device Ping for deactivated device "0x00158d0006ba9a90" zigbee.0 2022-05-28 21:43:12.880 info deregister device Ping for deactivated device "0x00158d0006baa96d" zigbee.0 2022-05-28 21:43:12.876 info deregister device Ping for deactivated device "0x00158d0006ba7afb" zigbee.0 2022-05-28 21:43:12.845 info debug devices set to [] zigbee.0 2022-05-28 21:43:12.597 info Zigbee started zigbee.0 2022-05-28 21:43:12.596 info 0x04cf8cdf3c78a785 (addr 36469): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice) zigbee.0 2022-05-28 21:43:12.594 info 0x54ef4410000a2de9 (addr 53487): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice) zigbee.0 2022-05-28 21:43:12.592 info 0x54ef4410000a2d4e (addr 53026): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice) zigbee.0 2022-05-28 21:43:12.590 info 0x54ef4410000c18e4 (addr 45999): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice) zigbee.0 2022-05-28 21:43:12.589 info 0x00158d0006ba8545 (addr 5552): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:43:12.587 info 0x00158d0006ba5980 (addr 18329): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:43:12.585 info 0x00158d0006ba9a90 (addr 17783): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:43:12.583 info 0x00158d0006baa96d (addr 64333): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:43:12.581 info 0x00158d0006ba9a00 (addr 39815): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:43:12.579 info 0x00158d0006ba7c33 (addr 24728): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:43:12.577 info 0x04cf8cdf3c7d4b90 (addr 10759): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice) zigbee.0 2022-05-28 21:43:12.575 info 0x54ef4410001c4c66 (addr 60112): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice) zigbee.0 2022-05-28 21:43:12.574 info 0x842e14fffe3676b1 (addr 65488): TS0502A - TuYa Light controller (Router) zigbee.0 2022-05-28 21:43:12.572 info 0x54ef4410000a2946 (addr 27490): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice) zigbee.0 2022-05-28 21:43:12.570 info 0x680ae2fffead7a75 (addr 33928): E1524/E1810 - IKEA TRADFRI remote control (EndDevice) zigbee.0 2022-05-28 21:43:12.566 info 0x00158d0006ba7afb (addr 13517): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:43:12.565 info 0x00158d0006ba51c2 (addr 36534): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:43:12.563 info 0x00158d0004a03e4c (addr 15394): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice) zigbee.0 2022-05-28 21:43:12.562 info 0x00158d00047d628b (addr 35609): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice) zigbee.0 2022-05-28 21:43:12.561 info 0x00158d00047d3bb5 (addr 40034): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice) zigbee.0 2022-05-28 21:43:12.560 info 0x00158d00049da7d0 (addr 43006): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice) zigbee.0 2022-05-28 21:43:12.559 info 0x04cf8cdf3c7d9620 (addr 58978): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice) zigbee.0 2022-05-28 21:43:12.557 info 0x842e14fffe37c623 (addr 34027): 14147206L - Lidl Livarno Lux ceiling light (Router) zigbee.0 2022-05-28 21:43:12.556 info 0x842e14fffe1d9e28 (addr 15593): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:43:12.546 info 0x588e81fffee38ec2 (addr 56236): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:43:12.544 info 0x588e81fffef771f4 (addr 57637): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:43:12.543 info 0x842e14fffe15da08 (addr 33156): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:43:12.541 info 0x842e14fffe23076c (addr 56959): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:43:12.538 info 0x842e14fffe230848 (addr 50651): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:43:12.536 info 0x588e81fffef77a2f (addr 49811): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:43:12.534 info 0x842e14fffe1b9c91 (addr 38189): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:43:12.532 info 0x588e81fffeff6340 (addr 41064): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:43:12.531 info 0xec1bbdfffe91cdf4 (addr 18751): HG06335/HG07310 - Lidl Silvercrest smart motion sensor (EndDevice) zigbee.0 2022-05-28 21:43:12.529 info 0xbc33acfffe5ede11 (addr 15735): FB20-002 - Lidl Livarno Lux switch and dimming light remote control (EndDevice) zigbee.0 2022-05-28 21:43:12.528 info 0xbc33acfffe6328d8 (addr 11726): FB20-002 - Lidl Livarno Lux switch and dimming light remote control (EndDevice) zigbee.0 2022-05-28 21:43:12.526 info 0x588e81fffe655d96 (addr 9183): LED1903C5/LED1835C6 - IKEA TRADFRI bulb E12/E14/E17 WS 450/470/440 lumen, dimmable, white spectrum, opal white (Router) zigbee.0 2022-05-28 21:43:12.523 info 0x04cf8cdf3c7b5527 (addr 11619): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice) zigbee.0 2022-05-28 21:43:12.522 info 0x04cf8cdf3c7d4182 (addr 10828): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice) zigbee.0 2022-05-28 21:43:12.514 info 0x001788010410074e (addr 49249): 8718696449691 - Philips Hue White A60 Single bulb E27/B22 (Router) zigbee.0 2022-05-28 21:43:12.375 info Currently 39 devices are joined: zigbee.0 2022-05-28 21:43:12.369 info Unable to set transmit power, unsupported function. zigbee.0 2022-05-28 21:43:12.232 info --> transmitPower : normal zigbee.0 2022-05-28 21:43:12.218 info Unable to disable LED, unsupported function. zigbee.0 2022-05-28 21:43:12.192 info Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":114,"maintrel":0,"revision":"0x26720700"}} zigbee.0 2022-05-28 21:43:12.153 info Installed Version: iobroker.zigbee@1.7.1 zigbee.0 2022-05-28 21:43:11.625 info Starting Zigbee npm ... zigbee.0 2022-05-28 21:43:11.623 info delete old Backup files. keep only last 10 zigbee.0 2022-05-28 21:43:11.509 info starting. Version 1.7.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.3, js-controller: 4.0.23 zigbee.0 2022-05-28 21:42:36.201 warn Terminated (UNCAUGHT_EXCEPTION): Without reason zigbee.0 2022-05-28 21:42:36.199 info terminating zigbee.0 2022-05-28 21:42:35.764 error Cannot read property 'deleteDeviceStates' of undefined zigbee.0 2022-05-28 21:42:35.763 error TypeError: Cannot read property 'deleteDeviceStates' of undefined at /opt/iobroker/node_modules/iobroker.zigbee/lib/groups.js:329:51 at Array.forEach (<anonymous>) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/groups.js:325:29) at processImmediate (internal/timers.js:466:21) zigbee.0 2022-05-28 21:42:35.762 error uncaught exception: Cannot read property 'deleteDeviceStates' of undefined zigbee.0 2022-05-28 21:42:35.743 info Zigbee: disabling joining new devices. zigbee.0 2022-05-28 21:42:35.490 info cleaned everything up... zigbee.0 2022-05-28 21:42:35.395 error error is not defined zigbee.0 2022-05-28 21:42:35.394 error ReferenceError: error is not defined at WriteStream.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:523:46) at WriteStream.emit (events.js:412:35) at WriteStream.emit (domain.js:475:12) at internal/fs/streams.js:335:14 at FSReqCallback.oncomplete (fs.js:180:23) zigbee.0 2022-05-28 21:42:35.393 error uncaught exception: error is not defined zigbee.0 2022-05-28 21:42:35.243 info deregister device Ping for deactivated device "0x00158d0006ba8545" zigbee.0 2022-05-28 21:42:35.242 info deregister device Ping for deactivated device "0x00158d0006ba5980" zigbee.0 2022-05-28 21:42:35.242 info deregister device Ping for deactivated device "0x00158d0006ba9a90" zigbee.0 2022-05-28 21:42:35.241 info deregister device Ping for deactivated device "0x00158d0006baa96d" zigbee.0 2022-05-28 21:42:35.237 info deregister device Ping for deactivated device "0x00158d0006ba7afb" zigbee.0 2022-05-28 21:42:34.920 info Zigbee started zigbee.0 2022-05-28 21:42:34.918 info 0x04cf8cdf3c78a785 (addr 36469): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice) zigbee.0 2022-05-28 21:42:34.917 info 0x54ef4410000a2de9 (addr 53487): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice) zigbee.0 2022-05-28 21:42:34.915 info 0x54ef4410000a2d4e (addr 53026): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice) zigbee.0 2022-05-28 21:42:34.914 info 0x54ef4410000c18e4 (addr 45999): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice) zigbee.0 2022-05-28 21:42:34.912 info 0x00158d0006ba8545 (addr 5552): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:42:34.910 info 0x00158d0006ba5980 (addr 18329): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:42:34.908 info 0x00158d0006ba9a90 (addr 17783): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:42:34.906 info 0x00158d0006baa96d (addr 64333): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:42:34.904 info 0x00158d0006ba9a00 (addr 39815): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:42:34.903 info 0x00158d0006ba7c33 (addr 24728): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:42:34.901 info 0x04cf8cdf3c7d4b90 (addr 10759): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice) zigbee.0 2022-05-28 21:42:34.899 info 0x54ef4410001c4c66 (addr 60112): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice) zigbee.0 2022-05-28 21:42:34.897 info 0x842e14fffe3676b1 (addr 65488): TS0502A - TuYa Light controller (Router) zigbee.0 2022-05-28 21:42:34.894 info 0x54ef4410000a2946 (addr 27490): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice) zigbee.0 2022-05-28 21:42:34.893 info 0x680ae2fffead7a75 (addr 33928): E1524/E1810 - IKEA TRADFRI remote control (EndDevice) zigbee.0 2022-05-28 21:42:34.891 info 0x00158d0006ba7afb (addr 13517): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:42:34.890 info 0x00158d0006ba51c2 (addr 36534): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:42:34.888 info 0x00158d0004a03e4c (addr 15394): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice) zigbee.0 2022-05-28 21:42:34.887 info 0x00158d00047d628b (addr 35609): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice) zigbee.0 2022-05-28 21:42:34.886 info 0x00158d00047d3bb5 (addr 40034): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice) zigbee.0 2022-05-28 21:42:34.885 info 0x00158d00049da7d0 (addr 43006): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice) zigbee.0 2022-05-28 21:42:34.884 info 0x04cf8cdf3c7d9620 (addr 58978): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice) zigbee.0 2022-05-28 21:42:34.882 info 0x842e14fffe37c623 (addr 34027): 14147206L - Lidl Livarno Lux ceiling light (Router) zigbee.0 2022-05-28 21:42:34.880 info 0x842e14fffe1d9e28 (addr 15593): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:42:34.878 info 0x588e81fffee38ec2 (addr 56236): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:42:34.877 info 0x588e81fffef771f4 (addr 57637): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:42:34.875 info 0x842e14fffe15da08 (addr 33156): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:42:34.874 info 0x842e14fffe23076c (addr 56959): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:42:34.872 info 0x842e14fffe230848 (addr 50651): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:42:34.871 info 0x588e81fffef77a2f (addr 49811): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:42:34.869 info 0x842e14fffe1b9c91 (addr 38189): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:42:34.867 info 0x588e81fffeff6340 (addr 41064): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:42:34.866 info 0xec1bbdfffe91cdf4 (addr 18751): HG06335/HG07310 - Lidl Silvercrest smart motion sensor (EndDevice) zigbee.0 2022-05-28 21:42:34.864 info 0xbc33acfffe5ede11 (addr 15735): FB20-002 - Lidl Livarno Lux switch and dimming light remote control (EndDevice) zigbee.0 2022-05-28 21:42:34.862 info 0xbc33acfffe6328d8 (addr 11726): FB20-002 - Lidl Livarno Lux switch and dimming light remote control (EndDevice) zigbee.0 2022-05-28 21:42:34.860 info 0x588e81fffe655d96 (addr 9183): LED1903C5/LED1835C6 - IKEA TRADFRI bulb E12/E14/E17 WS 450/470/440 lumen, dimmable, white spectrum, opal white (Router) zigbee.0 2022-05-28 21:42:34.858 info 0x04cf8cdf3c7b5527 (addr 11619): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice) zigbee.0 2022-05-28 21:42:34.856 info 0x04cf8cdf3c7d4182 (addr 10828): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice) zigbee.0 2022-05-28 21:42:34.852 info 0x001788010410074e (addr 49249): 8718696449691 - Philips Hue White A60 Single bulb E27/B22 (Router) zigbee.0 2022-05-28 21:42:34.714 info Currently 39 devices are joined: zigbee.0 2022-05-28 21:42:34.710 info Unable to set transmit power, unsupported function. zigbee.0 2022-05-28 21:42:34.573 info --> transmitPower : normal zigbee.0 2022-05-28 21:42:34.560 info Unable to disable LED, unsupported function. zigbee.0 2022-05-28 21:42:34.495 info debug devices set to [] zigbee.0 2022-05-28 21:42:34.426 info Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":114,"maintrel":0,"revision":"0x26720700"}} zigbee.0 2022-05-28 21:42:34.376 info Installed Version: iobroker.zigbee@1.7.1 zigbee.0 2022-05-28 21:42:33.803 info Starting Zigbee npm ... zigbee.0 2022-05-28 21:42:33.801 info delete old Backup files. keep only last 10 zigbee.0 2022-05-28 21:42:33.672 info starting. Version 1.7.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.3, js-controller: 4.0.23 zigbee.0 2022-05-28 21:41:58.742 warn Terminated (UNCAUGHT_EXCEPTION): Without reason zigbee.0 2022-05-28 21:41:58.740 info terminating zigbee.0 2022-05-28 21:41:58.243 info Zigbee: disabling joining new devices. zigbee.0 2022-05-28 21:41:57.990 info cleaned everything up... zigbee.0 2022-05-28 21:41:57.844 error error is not defined zigbee.0 2022-05-28 21:41:57.843 error ReferenceError: error is not defined at WriteStream.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:523:46) at WriteStream.emit (events.js:412:35) at WriteStream.emit (domain.js:475:12) at internal/fs/streams.js:335:14 at FSReqCallback.oncomplete (fs.js:180:23) zigbee.0 2022-05-28 21:41:57.842 error uncaught exception: error is not defined zigbee.0 2022-05-28 21:41:57.667 info deregister device Ping for deactivated device "0x00158d0006ba8545" zigbee.0 2022-05-28 21:41:57.666 info deregister device Ping for deactivated device "0x00158d0006ba5980" zigbee.0 2022-05-28 21:41:57.665 info deregister device Ping for deactivated device "0x00158d0006ba9a90" zigbee.0 2022-05-28 21:41:57.664 info deregister device Ping for deactivated device "0x00158d0006baa96d" zigbee.0 2022-05-28 21:41:57.662 info deregister device Ping for deactivated device "0x00158d0006ba7afb" zigbee.0 2022-05-28 21:41:57.638 info debug devices set to [] zigbee.0 2022-05-28 21:41:57.394 info Zigbee started zigbee.0 2022-05-28 21:41:57.392 info 0x04cf8cdf3c78a785 (addr 36469): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice) zigbee.0 2022-05-28 21:41:57.390 info 0x54ef4410000a2de9 (addr 53487): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice) zigbee.0 2022-05-28 21:41:57.388 info 0x54ef4410000a2d4e (addr 53026): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice) zigbee.0 2022-05-28 21:41:57.386 info 0x54ef4410000c18e4 (addr 45999): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice) zigbee.0 2022-05-28 21:41:57.383 info 0x00158d0006ba8545 (addr 5552): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:41:57.381 info 0x00158d0006ba5980 (addr 18329): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:41:57.379 info 0x00158d0006ba9a90 (addr 17783): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:41:57.377 info 0x00158d0006baa96d (addr 64333): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:41:57.375 info 0x00158d0006ba9a00 (addr 39815): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:41:57.373 info 0x00158d0006ba7c33 (addr 24728): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:41:57.371 info 0x04cf8cdf3c7d4b90 (addr 10759): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice) zigbee.0 2022-05-28 21:41:57.369 info 0x54ef4410001c4c66 (addr 60112): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice) zigbee.0 2022-05-28 21:41:57.367 info 0x842e14fffe3676b1 (addr 65488): TS0502A - TuYa Light controller (Router) zigbee.0 2022-05-28 21:41:57.366 info 0x54ef4410000a2946 (addr 27490): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice) zigbee.0 2022-05-28 21:41:57.364 info 0x680ae2fffead7a75 (addr 33928): E1524/E1810 - IKEA TRADFRI remote control (EndDevice) zigbee.0 2022-05-28 21:41:57.360 info 0x00158d0006ba7afb (addr 13517): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:41:57.359 info 0x00158d0006ba51c2 (addr 36534): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:41:57.357 info 0x00158d0004a03e4c (addr 15394): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice) zigbee.0 2022-05-28 21:41:57.356 info 0x00158d00047d628b (addr 35609): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice) zigbee.0 2022-05-28 21:41:57.355 info 0x00158d00047d3bb5 (addr 40034): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice) zigbee.0 2022-05-28 21:41:57.354 info 0x00158d00049da7d0 (addr 43006): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice) zigbee.0 2022-05-28 21:41:57.352 info 0x04cf8cdf3c7d9620 (addr 58978): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice) zigbee.0 2022-05-28 21:41:57.351 info 0x842e14fffe37c623 (addr 34027): 14147206L - Lidl Livarno Lux ceiling light (Router) zigbee.0 2022-05-28 21:41:57.350 info 0x842e14fffe1d9e28 (addr 15593): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:41:57.348 info 0x588e81fffee38ec2 (addr 56236): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:41:57.346 info 0x588e81fffef771f4 (addr 57637): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:41:57.336 info 0x842e14fffe15da08 (addr 33156): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:41:57.334 info 0x842e14fffe23076c (addr 56959): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:41:57.332 info 0x842e14fffe230848 (addr 50651): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:41:57.330 info 0x588e81fffef77a2f (addr 49811): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:41:57.328 info 0x842e14fffe1b9c91 (addr 38189): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:41:57.326 info 0x588e81fffeff6340 (addr 41064): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:41:57.324 info 0xec1bbdfffe91cdf4 (addr 18751): HG06335/HG07310 - Lidl Silvercrest smart motion sensor (EndDevice) zigbee.0 2022-05-28 21:41:57.322 info 0xbc33acfffe5ede11 (addr 15735): FB20-002 - Lidl Livarno Lux switch and dimming light remote control (EndDevice) zigbee.0 2022-05-28 21:41:57.321 info 0xbc33acfffe6328d8 (addr 11726): FB20-002 - Lidl Livarno Lux switch and dimming light remote control (EndDevice) zigbee.0 2022-05-28 21:41:57.319 info 0x588e81fffe655d96 (addr 9183): LED1903C5/LED1835C6 - IKEA TRADFRI bulb E12/E14/E17 WS 450/470/440 lumen, dimmable, white spectrum, opal white (Router) zigbee.0 2022-05-28 21:41:57.317 info 0x04cf8cdf3c7b5527 (addr 11619): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice) zigbee.0 2022-05-28 21:41:57.315 info 0x04cf8cdf3c7d4182 (addr 10828): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice) zigbee.0 2022-05-28 21:41:57.307 info 0x001788010410074e (addr 49249): 8718696449691 - Philips Hue White A60 Single bulb E27/B22 (Router) zigbee.0 2022-05-28 21:41:57.145 info Currently 39 devices are joined: zigbee.0 2022-05-28 21:41:57.140 info Unable to set transmit power, unsupported function. zigbee.0 2022-05-28 21:41:57.000 info --> transmitPower : normal zigbee.0 2022-05-28 21:41:56.986 info Unable to disable LED, unsupported function. zigbee.0 2022-05-28 21:41:56.960 info Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":114,"maintrel":0,"revision":"0x26720700"}} zigbee.0 2022-05-28 21:41:56.920 info Installed Version: iobroker.zigbee@1.7.1 zigbee.0 2022-05-28 21:41:56.392 info Starting Zigbee npm ... zigbee.0 2022-05-28 21:41:56.390 info delete old Backup files. keep only last 10 zigbee.0 2022-05-28 21:41:56.276 info starting. Version 1.7.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.3, js-controller: 4.0.23 zigbee.0 2022-05-28 21:41:21.467 warn Terminated (UNCAUGHT_EXCEPTION): Without reason zigbee.0 2022-05-28 21:41:21.466 info terminating zigbee.0 2022-05-28 21:41:21.025 info Zigbee: disabling joining new devices. zigbee.0 2022-05-28 21:41:20.859 info cleaned everything up... zigbee.0 2022-05-28 21:41:20.498 error error is not defined zigbee.0 2022-05-28 21:41:20.498 error ReferenceError: error is not defined at WriteStream.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:523:46) at WriteStream.emit (events.js:412:35) at WriteStream.emit (domain.js:475:12) at internal/fs/streams.js:335:14 at FSReqCallback.oncomplete (fs.js:180:23) zigbee.0 2022-05-28 21:41:20.496 error uncaught exception: error is not defined zigbee.0 2022-05-28 21:41:20.183 info deregister device Ping for deactivated device "0x00158d0006ba8545" zigbee.0 2022-05-28 21:41:20.183 info deregister device Ping for deactivated device "0x00158d0006ba5980" zigbee.0 2022-05-28 21:41:20.182 info deregister device Ping for deactivated device "0x00158d0006ba9a90" zigbee.0 2022-05-28 21:41:20.181 info deregister device Ping for deactivated device "0x00158d0006baa96d" zigbee.0 2022-05-28 21:41:20.178 info deregister device Ping for deactivated device "0x00158d0006ba7afb" zigbee.0 2022-05-28 21:41:20.150 info debug devices set to [] zigbee.0 2022-05-28 21:41:19.898 info Zigbee started zigbee.0 2022-05-28 21:41:19.897 info 0x04cf8cdf3c78a785 (addr 36469): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice) zigbee.0 2022-05-28 21:41:19.895 info 0x54ef4410000a2de9 (addr 53487): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice) zigbee.0 2022-05-28 21:41:19.893 info 0x54ef4410000a2d4e (addr 53026): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice) zigbee.0 2022-05-28 21:41:19.891 info 0x54ef4410000c18e4 (addr 45999): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice) zigbee.0 2022-05-28 21:41:19.890 info 0x00158d0006ba8545 (addr 5552): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:41:19.888 info 0x00158d0006ba5980 (addr 18329): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:41:19.886 info 0x00158d0006ba9a90 (addr 17783): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:41:19.884 info 0x00158d0006baa96d (addr 64333): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:41:19.882 info 0x00158d0006ba9a00 (addr 39815): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:41:19.880 info 0x00158d0006ba7c33 (addr 24728): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:41:19.878 info 0x04cf8cdf3c7d4b90 (addr 10759): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice) zigbee.0 2022-05-28 21:41:19.876 info 0x54ef4410001c4c66 (addr 60112): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice) zigbee.0 2022-05-28 21:41:19.874 info 0x842e14fffe3676b1 (addr 65488): TS0502A - TuYa Light controller (Router) zigbee.0 2022-05-28 21:41:19.872 info 0x54ef4410000a2946 (addr 27490): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice) zigbee.0 2022-05-28 21:41:19.871 info 0x680ae2fffead7a75 (addr 33928): E1524/E1810 - IKEA TRADFRI remote control (EndDevice) zigbee.0 2022-05-28 21:41:19.867 info 0x00158d0006ba7afb (addr 13517): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:41:19.866 info 0x00158d0006ba51c2 (addr 36534): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:41:19.864 info 0x00158d0004a03e4c (addr 15394): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice) zigbee.0 2022-05-28 21:41:19.863 info 0x00158d00047d628b (addr 35609): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice) zigbee.0 2022-05-28 21:41:19.862 info 0x00158d00047d3bb5 (addr 40034): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice) zigbee.0 2022-05-28 21:41:19.861 info 0x00158d00049da7d0 (addr 43006): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice) zigbee.0 2022-05-28 21:41:19.859 info 0x04cf8cdf3c7d9620 (addr 58978): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice) zigbee.0 2022-05-28 21:41:19.858 info 0x842e14fffe37c623 (addr 34027): 14147206L - Lidl Livarno Lux ceiling light (Router) zigbee.0 2022-05-28 21:41:19.856 info 0x842e14fffe1d9e28 (addr 15593): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:41:19.855 info 0x588e81fffee38ec2 (addr 56236): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:41:19.853 info 0x588e81fffef771f4 (addr 57637): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:41:19.843 info 0x842e14fffe15da08 (addr 33156): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:41:19.841 info 0x842e14fffe23076c (addr 56959): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:41:19.838 info 0x842e14fffe230848 (addr 50651): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:41:19.836 info 0x588e81fffef77a2f (addr 49811): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:41:19.834 info 0x842e14fffe1b9c91 (addr 38189): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:41:19.833 info 0x588e81fffeff6340 (addr 41064): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:41:19.831 info 0xec1bbdfffe91cdf4 (addr 18751): HG06335/HG07310 - Lidl Silvercrest smart motion sensor (EndDevice) zigbee.0 2022-05-28 21:41:19.829 info 0xbc33acfffe5ede11 (addr 15735): FB20-002 - Lidl Livarno Lux switch and dimming light remote control (EndDevice) zigbee.0 2022-05-28 21:41:19.828 info 0xbc33acfffe6328d8 (addr 11726): FB20-002 - Lidl Livarno Lux switch and dimming light remote control (EndDevice) zigbee.0 2022-05-28 21:41:19.826 info 0x588e81fffe655d96 (addr 9183): LED1903C5/LED1835C6 - IKEA TRADFRI bulb E12/E14/E17 WS 450/470/440 lumen, dimmable, white spectrum, opal white (Router) zigbee.0 2022-05-28 21:41:19.824 info 0x04cf8cdf3c7b5527 (addr 11619): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice) zigbee.0 2022-05-28 21:41:19.822 info 0x04cf8cdf3c7d4182 (addr 10828): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice) zigbee.0 2022-05-28 21:41:19.814 info 0x001788010410074e (addr 49249): 8718696449691 - Philips Hue White A60 Single bulb E27/B22 (Router) zigbee.0 2022-05-28 21:41:19.674 info Currently 39 devices are joined: zigbee.0 2022-05-28 21:41:19.669 info Unable to set transmit power, unsupported function. zigbee.0 2022-05-28 21:41:19.533 info --> transmitPower : normal zigbee.0 2022-05-28 21:41:19.519 info Unable to disable LED, unsupported function. zigbee.0 2022-05-28 21:41:19.499 info Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":114,"maintrel":0,"revision":"0x26720700"}} zigbee.0 2022-05-28 21:41:19.458 info Installed Version: iobroker.zigbee@1.7.1 zigbee.0 2022-05-28 21:41:18.924 info Starting Zigbee npm ... zigbee.0 2022-05-28 21:41:18.922 info delete old Backup files. keep only last 10 zigbee.0 2022-05-28 21:41:18.813 info starting. Version 1.7.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.3, js-controller: 4.0.23 zigbee.0 2022-05-28 21:40:44.131 warn Terminated (UNCAUGHT_EXCEPTION): Without reason zigbee.0 2022-05-28 21:40:44.129 info terminating zigbee.0 2022-05-28 21:40:43.691 info Zigbee: disabling joining new devices. zigbee.0 2022-05-28 21:40:43.418 info cleaned everything up... zigbee.0 2022-05-28 21:40:43.288 error error is not defined zigbee.0 2022-05-28 21:40:43.287 error ReferenceError: error is not defined at WriteStream.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:523:46) at WriteStream.emit (events.js:412:35) at WriteStream.emit (domain.js:475:12) at internal/fs/streams.js:335:14 at FSReqCallback.oncomplete (fs.js:180:23) zigbee.0 2022-05-28 21:40:43.286 error uncaught exception: error is not defined zigbee.0 2022-05-28 21:40:43.114 info deregister device Ping for deactivated device "0x00158d0006ba8545" zigbee.0 2022-05-28 21:40:43.113 info deregister device Ping for deactivated device "0x00158d0006ba5980" zigbee.0 2022-05-28 21:40:43.112 info deregister device Ping for deactivated device "0x00158d0006ba9a90" zigbee.0 2022-05-28 21:40:43.111 info deregister device Ping for deactivated device "0x00158d0006baa96d" zigbee.0 2022-05-28 21:40:43.108 info deregister device Ping for deactivated device "0x00158d0006ba7afb" zigbee.0 2022-05-28 21:40:43.083 info debug devices set to [] zigbee.0 2022-05-28 21:40:42.800 info Zigbee started zigbee.0 2022-05-28 21:40:42.799 info 0x04cf8cdf3c78a785 (addr 36469): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice) zigbee.0 2022-05-28 21:40:42.797 info 0x54ef4410000a2de9 (addr 53487): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice) zigbee.0 2022-05-28 21:40:42.796 info 0x54ef4410000a2d4e (addr 53026): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice) zigbee.0 2022-05-28 21:40:42.794 info 0x54ef4410000c18e4 (addr 45999): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice) zigbee.0 2022-05-28 21:40:42.792 info 0x00158d0006ba8545 (addr 5552): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:40:42.790 info 0x00158d0006ba5980 (addr 18329): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:40:42.788 info 0x00158d0006ba9a90 (addr 17783): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:40:42.786 info 0x00158d0006baa96d (addr 64333): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:40:42.785 info 0x00158d0006ba9a00 (addr 39815): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:40:42.783 info 0x00158d0006ba7c33 (addr 24728): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:40:42.781 info 0x04cf8cdf3c7d4b90 (addr 10759): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice) zigbee.0 2022-05-28 21:40:42.779 info 0x54ef4410001c4c66 (addr 60112): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice) zigbee.0 2022-05-28 21:40:42.777 info 0x842e14fffe3676b1 (addr 65488): TS0502A - TuYa Light controller (Router) zigbee.0 2022-05-28 21:40:42.775 info 0x54ef4410000a2946 (addr 27490): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice) zigbee.0 2022-05-28 21:40:42.773 info 0x680ae2fffead7a75 (addr 33928): E1524/E1810 - IKEA TRADFRI remote control (EndDevice) zigbee.0 2022-05-28 21:40:42.770 info 0x00158d0006ba7afb (addr 13517): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:40:42.768 info 0x00158d0006ba51c2 (addr 36534): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:40:42.767 info 0x00158d0004a03e4c (addr 15394): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice) zigbee.0 2022-05-28 21:40:42.766 info 0x00158d00047d628b (addr 35609): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice) zigbee.0 2022-05-28 21:40:42.765 info 0x00158d00047d3bb5 (addr 40034): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice) zigbee.0 2022-05-28 21:40:42.764 info 0x00158d00049da7d0 (addr 43006): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice) zigbee.0 2022-05-28 21:40:42.762 info 0x04cf8cdf3c7d9620 (addr 58978): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice) zigbee.0 2022-05-28 21:40:42.760 info 0x842e14fffe37c623 (addr 34027): 14147206L - Lidl Livarno Lux ceiling light (Router) zigbee.0 2022-05-28 21:40:42.758 info 0x842e14fffe1d9e28 (addr 15593): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:40:42.749 info 0x588e81fffee38ec2 (addr 56236): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:40:42.747 info 0x588e81fffef771f4 (addr 57637): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:40:42.745 info 0x842e14fffe15da08 (addr 33156): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:40:42.744 info 0x842e14fffe23076c (addr 56959): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:40:42.739 info 0x842e14fffe230848 (addr 50651): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:40:42.737 info 0x588e81fffef77a2f (addr 49811): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:40:42.736 info 0x842e14fffe1b9c91 (addr 38189): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:40:42.734 info 0x588e81fffeff6340 (addr 41064): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:40:42.732 info 0xec1bbdfffe91cdf4 (addr 18751): HG06335/HG07310 - Lidl Silvercrest smart motion sensor (EndDevice) zigbee.0 2022-05-28 21:40:42.730 info 0xbc33acfffe5ede11 (addr 15735): FB20-002 - Lidl Livarno Lux switch and dimming light remote control (EndDevice) zigbee.0 2022-05-28 21:40:42.729 info 0xbc33acfffe6328d8 (addr 11726): FB20-002 - Lidl Livarno Lux switch and dimming light remote control (EndDevice) zigbee.0 2022-05-28 21:40:42.727 info 0x588e81fffe655d96 (addr 9183): LED1903C5/LED1835C6 - IKEA TRADFRI bulb E12/E14/E17 WS 450/470/440 lumen, dimmable, white spectrum, opal white (Router) zigbee.0 2022-05-28 21:40:42.725 info 0x04cf8cdf3c7b5527 (addr 11619): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice) zigbee.0 2022-05-28 21:40:42.723 info 0x04cf8cdf3c7d4182 (addr 10828): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice) zigbee.0 2022-05-28 21:40:42.715 info 0x001788010410074e (addr 49249): 8718696449691 - Philips Hue White A60 Single bulb E27/B22 (Router) zigbee.0 2022-05-28 21:40:42.575 info Currently 39 devices are joined: zigbee.0 2022-05-28 21:40:42.570 info Unable to set transmit power, unsupported function. zigbee.0 2022-05-28 21:40:42.435 info --> transmitPower : normal zigbee.0 2022-05-28 21:40:42.421 info Unable to disable LED, unsupported function. zigbee.0 2022-05-28 21:40:42.398 info Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":114,"maintrel":0,"revision":"0x26720700"}} zigbee.0 2022-05-28 21:40:42.358 info Installed Version: iobroker.zigbee@1.7.1 zigbee.0 2022-05-28 21:40:41.827 info Starting Zigbee npm ... zigbee.0 2022-05-28 21:40:41.824 info delete old Backup files. keep only last 10 zigbee.0 2022-05-28 21:40:41.714 info starting. Version 1.7.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.3, js-controller: 4.0.23 zigbee.0 2022-05-28 21:40:04.622 warn get state error: DB closed zigbee.0 2022-05-28 21:40:04.621 warn get state error: DB closed zigbee.0 2022-05-28 21:40:04.621 warn get state error: DB closed zigbee.0 2022-05-28 21:40:04.621 warn get state error: DB closed zigbee.0 2022-05-28 21:40:04.620 warn get state error: DB closed zigbee.0 2022-05-28 21:40:04.620 warn get state error: DB closed zigbee.0 2022-05-28 21:40:04.620 warn get state error: DB closed zigbee.0 2022-05-28 21:40:04.619 warn get state error: DB closed zigbee.0 2022-05-28 21:40:04.619 warn get state error: DB closed zigbee.0 2022-05-28 21:40:04.619 warn get state error: DB closed zigbee.0 2022-05-28 21:40:04.618 warn get state error: DB closed zigbee.0 2022-05-28 21:40:04.618 warn get state error: DB closed zigbee.0 2022-05-28 21:40:04.618 warn get state error: DB closed zigbee.0 2022-05-28 21:40:04.617 warn get state error: DB closed zigbee.0 2022-05-28 21:40:04.617 warn get state error: DB closed zigbee.0 2022-05-28 21:40:04.617 warn get state error: DB closed zigbee.0 2022-05-28 21:40:04.616 warn get state error: DB closed zigbee.0 2022-05-28 21:40:04.616 warn get state error: DB closed zigbee.0 2022-05-28 21:40:04.616 warn get state error: DB closed zigbee.0 2022-05-28 21:40:04.615 warn get state error: DB closed zigbee.0 2022-05-28 21:40:04.615 warn get state error: DB closed zigbee.0 2022-05-28 21:40:04.615 warn get state error: DB closed zigbee.0 2022-05-28 21:40:04.614 warn get state error: DB closed zigbee.0 2022-05-28 21:40:04.614 warn get state error: DB closed zigbee.0 2022-05-28 21:40:04.613 warn get state error: DB closed zigbee.0 2022-05-28 21:40:04.613 warn get state error: DB closed zigbee.0 2022-05-28 21:40:04.613 warn get state error: DB closed zigbee.0 2022-05-28 21:40:04.612 warn get state error: DB closed zigbee.0 2022-05-28 21:40:04.612 warn get state error: DB closed zigbee.0 2022-05-28 21:40:04.612 warn get state error: DB closed zigbee.0 2022-05-28 21:40:04.611 warn get state error: DB closed zigbee.0 2022-05-28 21:40:04.611 warn get state error: DB closed zigbee.0 2022-05-28 21:40:04.611 warn get state error: DB closed zigbee.0 2022-05-28 21:40:04.610 warn get state error: DB closed zigbee.0 2022-05-28 21:40:04.610 warn get state error: DB closed zigbee.0 2022-05-28 21:40:04.609 warn get state error: DB closed zigbee.0 2022-05-28 21:40:04.609 warn get state error: DB closed zigbee.0 2022-05-28 21:40:04.608 warn get state error: DB closed zigbee.0 2022-05-28 21:40:04.608 warn get state error: DB closed zigbee.0 2022-05-28 21:40:04.607 warn get state error: DB closed zigbee.0 2022-05-28 21:40:04.607 warn get state error: DB closed zigbee.0 2022-05-28 21:40:04.606 warn get state error: DB closed zigbee.0 2022-05-28 21:40:04.606 warn get state error: DB closed zigbee.0 2022-05-28 21:40:04.605 warn get state error: DB closed zigbee.0 2022-05-28 21:40:04.605 warn get state error: DB closed zigbee.0 2022-05-28 21:40:04.604 warn get state error: DB closed zigbee.0 2022-05-28 21:40:04.604 warn get state error: DB closed zigbee.0 2022-05-28 21:40:04.604 warn get state error: DB closed zigbee.0 2022-05-28 21:40:04.603 warn get state error: DB closed zigbee.0 2022-05-28 21:40:04.603 warn get state error: DB closed zigbee.0 2022-05-28 21:40:04.603 warn get state error: DB closed zigbee.0 2022-05-28 21:40:04.602 warn get state error: DB closed zigbee.0 2022-05-28 21:40:04.602 warn get state error: DB closed zigbee.0 2022-05-28 21:40:04.602 warn get state error: DB closed zigbee.0 2022-05-28 21:40:04.601 warn get state error: DB closed zigbee.0 2022-05-28 21:40:04.601 warn get state error: DB closed zigbee.0 2022-05-28 21:40:04.600 warn get state error: DB closed zigbee.0 2022-05-28 21:40:04.600 warn get state error: DB closed zigbee.0 2022-05-28 21:40:04.600 warn get state error: DB closed zigbee.0 2022-05-28 21:40:04.599 warn get state error: DB closed zigbee.0 2022-05-28 21:40:04.599 warn get state error: DB closed zigbee.0 2022-05-28 21:40:04.598 warn get state error: DB closed zigbee.0 2022-05-28 21:40:04.598 warn get state error: DB closed zigbee.0 2022-05-28 21:40:04.597 warn get state error: DB closed zigbee.0 2022-05-28 21:40:04.597 warn get state error: DB closed zigbee.0 2022-05-28 21:40:04.596 warn get state error: Connection is closed. zigbee.0 2022-05-28 21:40:03.784 warn Terminated (UNCAUGHT_EXCEPTION): Without reason zigbee.0 2022-05-28 21:40:03.781 info terminating zigbee.0 2022-05-28 21:40:03.342 info Zigbee: disabling joining new devices. zigbee.0 2022-05-28 21:40:03.120 info cleaned everything up... zigbee.0 2022-05-28 21:40:03.048 error error is not defined zigbee.0 2022-05-28 21:40:03.048 error ReferenceError: error is not defined at WriteStream.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:523:46) at WriteStream.emit (events.js:412:35) at WriteStream.emit (domain.js:475:12) at internal/fs/streams.js:335:14 at FSReqCallback.oncomplete (fs.js:180:23) zigbee.0 2022-05-28 21:40:03.047 error uncaught exception: error is not defined zigbee.0 2022-05-28 21:40:02.917 info deregister device Ping for deactivated device "0x00158d0006ba8545" zigbee.0 2022-05-28 21:40:02.916 info deregister device Ping for deactivated device "0x00158d0006ba5980" zigbee.0 2022-05-28 21:40:02.915 info deregister device Ping for deactivated device "0x00158d0006ba9a90" zigbee.0 2022-05-28 21:40:02.915 info deregister device Ping for deactivated device "0x00158d0006baa96d" zigbee.0 2022-05-28 21:40:02.912 info deregister device Ping for deactivated device "0x00158d0006ba7afb" zigbee.0 2022-05-28 21:40:02.887 info debug devices set to [] zigbee.0 2022-05-28 21:40:02.492 info Zigbee started zigbee.0 2022-05-28 21:40:02.491 info 0x04cf8cdf3c78a785 (addr 36469): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice) zigbee.0 2022-05-28 21:40:02.489 info 0x54ef4410000a2de9 (addr 53487): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice) zigbee.0 2022-05-28 21:40:02.487 info 0x54ef4410000a2d4e (addr 53026): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice) zigbee.0 2022-05-28 21:40:02.485 info 0x54ef4410000c18e4 (addr 45999): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice) zigbee.0 2022-05-28 21:40:02.483 info 0x00158d0006ba8545 (addr 5552): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:40:02.482 info 0x00158d0006ba5980 (addr 18329): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:40:02.480 info 0x00158d0006ba9a90 (addr 17783): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:40:02.478 info 0x00158d0006baa96d (addr 64333): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:40:02.476 info 0x00158d0006ba9a00 (addr 39815): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:40:02.474 info 0x00158d0006ba7c33 (addr 24728): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:40:02.472 info 0x04cf8cdf3c7d4b90 (addr 10759): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice) zigbee.0 2022-05-28 21:40:02.470 info 0x54ef4410001c4c66 (addr 60112): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice) zigbee.0 2022-05-28 21:40:02.468 info 0x842e14fffe3676b1 (addr 65488): TS0502A - TuYa Light controller (Router) zigbee.0 2022-05-28 21:40:02.466 info 0x54ef4410000a2946 (addr 27490): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice) zigbee.0 2022-05-28 21:40:02.463 info 0x680ae2fffead7a75 (addr 33928): E1524/E1810 - IKEA TRADFRI remote control (EndDevice) zigbee.0 2022-05-28 21:40:02.457 info 0x00158d0006ba7afb (addr 13517): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:40:02.454 info 0x00158d0006ba51c2 (addr 36534): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice) zigbee.0 2022-05-28 21:40:02.450 info 0x00158d0004a03e4c (addr 15394): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice) zigbee.0 2022-05-28 21:40:02.446 info 0x00158d00047d628b (addr 35609): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice) zigbee.0 2022-05-28 21:40:02.444 info 0x00158d00047d3bb5 (addr 40034): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice) zigbee.0 2022-05-28 21:40:02.441 info 0x00158d00049da7d0 (addr 43006): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice) zigbee.0 2022-05-28 21:40:02.437 info 0x04cf8cdf3c7d9620 (addr 58978): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice) zigbee.0 2022-05-28 21:40:02.434 info 0x842e14fffe37c623 (addr 34027): 14147206L - Lidl Livarno Lux ceiling light (Router) zigbee.0 2022-05-28 21:40:02.431 info 0x842e14fffe1d9e28 (addr 15593): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:40:02.428 info 0x588e81fffee38ec2 (addr 56236): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:40:02.426 info 0x588e81fffef771f4 (addr 57637): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:40:02.417 info 0x842e14fffe15da08 (addr 33156): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:40:02.415 info 0x842e14fffe23076c (addr 56959): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:40:02.410 info 0x842e14fffe230848 (addr 50651): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:40:02.409 info 0x588e81fffef77a2f (addr 49811): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:40:02.407 info 0x842e14fffe1b9c91 (addr 38189): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:40:02.405 info 0x588e81fffeff6340 (addr 41064): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router) zigbee.0 2022-05-28 21:40:02.403 info 0xec1bbdfffe91cdf4 (addr 18751): HG06335/HG07310 - Lidl Silvercrest smart motion sensor (EndDevice) zigbee.0 2022-05-28 21:40:02.402 info 0xbc33acfffe5ede11 (addr 15735): FB20-002 - Lidl Livarno Lux switch and dimming light remote control (EndDevice) zigbee.0 2022-05-28 21:40:02.400 info 0xbc33acfffe6328d8 (addr 11726): FB20-002 - Lidl Livarno Lux switch and dimming light remote control (EndDevice) zigbee.0 2022-05-28 21:40:02.399 info 0x588e81fffe655d96 (addr 9183): LED1903C5/LED1835C6 - IKEA TRADFRI bulb E12/E14/E17 WS 450/470/440 lumen, dimmable, white spectrum, opal white (Router) zigbee.0 2022-05-28 21:40:02.396 info 0x04cf8cdf3c7b5527 (addr 11619): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice) zigbee.0 2022-05-28 21:40:02.394 info 0x04cf8cdf3c7d4182 (addr 10828): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice) zigbee.0 2022-05-28 21:40:02.387 info 0x001788010410074e (addr 49249): 8718696449691 - Philips Hue White A60 Single bulb E27/B22 (Router) zigbee.0 2022-05-28 21:40:02.247 info Currently 39 devices are joined: zigbee.0 2022-05-28 21:40:02.237 info Unable to set transmit power, unsupported function. zigbee.0 2022-05-28 21:40:02.097 info --> transmitPower : normal zigbee.0 2022-05-28 21:40:02.071 info Unable to disable LED, unsupported function. zigbee.0 2022-05-28 21:40:02.043 info Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":114,"maintrel":0,"revision":"0x26720700"}} zigbee.0 2022-05-28 21:40:01.996 info Installed Version: iobroker.zigbee@1.7.1 zigbee.0 2022-05-28 21:40:01.441 info Starting Zigbee npm ... zigbee.0 2022-05-28 21:40:01.439 info delete old Backup files. keep only last 10 zigbee.0 2022-05-28 21:40:01.323 info starting. Version 1.7.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.3, js-controller: 4.0.23
