    4. Error 25 bei Adapterupdates nach Node.JS 16.15.1 Update
    • surfer09
      surfer09 last edited by surfer09
      seitdem ich meinen IO-Broker auf Node.JS Version 16.15.1 upgedatet habe, bekomme ich keine Adapterupdates mehr installiert. Ich habe hier mal zwei Beispiele von Updates angehangen:
      Flot Adapter Update
      2022-06-20 15:25:05.813 - info: host.IO-Broker-Server iobroker upgrade flot@1.11.0
      2022-06-20 15:25:06.811 - info: host.IO-Broker-Server iobroker Update flot from @1.10.7 to @1.11.0
      2022-06-20 15:25:07.692 - error: host.IO-Broker-Server iobroker npm WARN config global `--global`, `--local` are deprecated. Use `--location=global` instead.
      2022-06-20 15:25:07.692 - info: host.IO-Broker-Server iobroker NPM version: 8.11.0
      2022-06-20 15:25:07.693 - info: host.IO-Broker-Server iobroker Installing iobroker.flot@1.11.0... (System call)
      2022-06-20 15:25:56.496 - error: host.IO-Broker-Server iobroker host.IO-Broker-Server Cannot install iobroker.flot@1.11.0: 4294963214
      2022-06-20 15:25:57.519 - info: host.IO-Broker-Server iobroker exit 25
      Telegram Adapter Update
      2022-06-20 15:26:58.012 - info: host.IO-Broker-Server iobroker upgrade telegram@1.13.0
      2022-06-20 15:26:58.986 - info: host.IO-Broker-Server iobroker Update telegram from @1.12.6 to @1.13.0
      2022-06-20 15:26:58.994 - info: host.IO-Broker-Server iobroker host.IO-Broker-Server Adapter "system.adapter.telegram.2" is stopped.
      2022-06-20 15:26:59.018 - info: host.IO-Broker-Server "system.adapter.telegram.2" disabled
      2022-06-20 15:26:59.018 - info: host.IO-Broker-Server stopInstance system.adapter.telegram.2 (force=false, process=true)
      2022-06-20 15:26:59.036 - info: host.IO-Broker-Server stopInstance system.adapter.telegram.2 send kill signal
      2022-06-20 15:26:59.869 - error: host.IO-Broker-Server iobroker npm WARN config global `--global`, `--local` are deprecated. Use `--location=global` instead.
      2022-06-20 15:26:59.869 - info: host.IO-Broker-Server iobroker NPM version: 8.11.0
      2022-06-20 15:26:59.870 - info: host.IO-Broker-Server iobroker Installing iobroker.telegram@1.13.0... (System call)
      2022-06-20 15:27:00.054 - info: host.IO-Broker-Server stopInstance system.adapter.telegram.2 killing pid 10324
      2022-06-20 15:27:00.091 - warn: host.IO-Broker-Server instance system.adapter.telegram.2 terminated due to SIGTERM
      2022-06-20 15:27:00.091 - info: host.IO-Broker-Server instance system.adapter.telegram.2 terminated with code null ()
      2022-06-20 15:27:11.826 - error: host.IO-Broker-Server iobroker host.IO-Broker-Server Cannot install iobroker.telegram@1.13.0: 4294963214
      2022-06-20 15:27:12.845 - info: host.IO-Broker-Server iobroker exit 25
      Alles andere läuft bis jetzt ohne Probleme.
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Intel NUC
      Arbeitsspeicher: 12GB
      Betriebssystem: Windows 10 64bit
      Nodejs-Version: 16.15.1
      NPM-Version: 8.11.0
      js-controller: 4.0.23
      • crunchip
        crunchip Forum Testing Most Active @surfer09 last edited by
        @surfer09 sagte in Error 25 bei Adapterupdates nach Node.JS 16.15.1 Update:
        iobroker npm WARN config global --global, --local are deprecated. Use --location=global instead.
        https://stackoverflow.com/questions/72401421/npm-warn-config-global-global-local-are-deprecated-use-location-glo
        • surfer09
          surfer09 @crunchip last edited by
          @crunchip Danke dir für den Beitrag. Ich hatte zuerst versucht die 4 Dateien zu bearbeiten und den Parameter anzupassen. Die Anpassung an sich war kein Problem, der Fehler blieb aber genauso, wie vorher.
          Anschließend hatte ich gelesen, das man NPM auf die aktuellste Version 8.12.2 hochziehen soll. Auch das habe ich gemacht, leider besteht das Problem immer noch weiterhin. 😞
          2022-06-20 19:09:34.491 - info: host.IO-Broker-Server iobroker upgrade telegram@1.13.0
          2022-06-20 19:09:35.467 - info: host.IO-Broker-Server iobroker Update telegram from @1.12.6 to @1.13.0
          2022-06-20 19:09:36.307 - info: host.IO-Broker-Server iobroker NPM version: 8.12.2
          2022-06-20 19:09:36.308 - info: host.IO-Broker-Server iobroker Installing iobroker.telegram@1.13.0... (System call)
          2022-06-20 19:09:48.262 - error: host.IO-Broker-Server iobroker host.IO-Broker-Server Cannot install iobroker.telegram@1.13.0: 4294963214
          2022-06-20 19:09:49.280 - info: host.IO-Broker-Server iobroker exit 25
          crunchip Thomas Braun 2 Replies Last reply Reply Quote 0
          • crunchip
            @surfer09 wenn du es mit nem --debug per Konsole probierst, was wird dann angezeigt
            iobroker upgrade telegram@1.13.0 --debug
            • surfer09
              @crunchip
              I:\iobroker>iobroker upgrade telegram@1.13.0 --debug
              I:\iobroker>node node_modules/iobroker.js-controller/iobroker.js upgrade telegram@1.13.0 --debug
              This upgrade of "telegram" will introduce the following changes:
              -> 1.13.0:
              Added Admin 5 UI config
              Added rule block for javascript as plugin
              Would you like to upgrade telegram from @1.12.6 to @1.13.0 now? [(y)es, (n)o]: y
              NPM version: 8.12.2
              npm ERR! code EBUSY
              npm ERR! syscall rename
              npm ERR! path I:\iobroker\node_modules\iobroker.admin
              npm ERR! dest I:\iobroker\node_modules\.iobroker.admin-VLZaPCsC
              npm ERR! errno -4082
              npm ERR! EBUSY: resource busy or locked, rename 'I:\iobroker\node_modules\iobroker.admin' -> 'I:\iobroker\node_modules\.iobroker.admin-VLZaPCsC'
              npm ERR!     C:\Users\io-broker\AppData\Local\npm-cache\_logs\2022-06-20T17_19_16_322Z-debug-0.log
              crunchip apollon77 2 Replies Last reply Reply Quote 0
              • crunchip
                rename 'I:\iobroker\node_modules\iobroker.admin' -> 'I:\iobroker\node_modules.iobroker.admin-VLZaPCsC'
                vermute das du dies manuell ausführen musst
                  Thomas Braun Most Active @surfer09 last edited by
                  Wo steht denn das? Am besten lässt man die Zusammenstellung so, wie sie auch im Upstream vorgesehen sind:
                  • surfer09
                    @crunchip Also nur das ich das jetzt richtig verstehe... Ich soll den Ordner iobroker.admin in iobroker.admin-VLZaPCsC umbenennen?
                    • surfer09
                      surfer09 @Thomas Braun last edited by
                      @thomas-braun sagte in Error 25 bei Adapterupdates nach Node.JS 16.15.1 Update:
                      Hallo Thomas,
                      ich hatte das auf der Seite gelesen, die crunchip vorhin gepostet hatte.
                      2022-06-20 19_29_56-node.js - npm WARN config global ,  are deprecated. Use `--lo.jpg
                        @surfer09
                        Riecht längerfristig nach Komplikationen, behaupte ich mal.
                        • surfer09
                          Aber so wie ich das jetzt verstehe, liegt das Problem an einem Fehler in der NPM Version, richtig? Also habe ich nichts falsch gemacht... Dann gibts halt erst einmal keine Adapter-Updates 🙂
                          Alles anderes läuft ja noch bei mir.
                            Nein, es liegt nicht an der Version von npm sondern vermutlich an Fehlern in deinem npm tree.
                            • crunchip
                              @surfer09 ich zitiere mal was ich an anderer ähnlichen Stelle gelesen habe
                              Das ist ein npm-Problem und hängt nicht speziell mit dem Adapter zusammen - hab ich auch ab und an beim Entwickeln auf Windows. Stelle sicher, dass der Adapterprozess wirklich nicht mehr läuft und probier es nochmal. Manchmal hängt ein Skript im Timeout oder sowas.
                              surfer09 1 Reply Last reply Reply Quote 1
                              • surfer09
                                .. die wie behoben werden?? Gibt es dafür eine Anleitung, wie man da vorgehen muss? Ich weiß nicht einmal, wo ich diesen NPM-Tree finde und soll ihn schon reparieren. Das kann ja spaßig werden.
                                • surfer09
                                  @crunchip Okay, also doch abwarten, bis das Problem behoben ist, wenn ich das jetzt richtig verstehe.
                                  Ich fummel ungerne jetzt an den Ordnern oder Sonstigem rum, wenn das etwas ganz anderes ist. Nicht das ich nachher alles durcheinander habe...
                                  • crunchip
                                    @surfer09 hast du denn mal geprüft, ob der Prozess auch wirklich beendet ist und nochmal versucht das Update zu machen
                                      Das kann nicht 'von außen' behoben werden. Da musst du schon selber schauen wo es da genau klemmt. Hinweise was zu tun ist stehen ja schon in den Meldungen drin.
                                      Unter Windows kann ich dir aber nicht sagen wie man sich den npm tree anschaut, unter einem Betriebssystem ginge es im iobroker-Verzeichnis mittels npm ls | grep ERR
                                      • surfer09
                                        surfer09 @Thomas Braun last edited by surfer09
                                        Ich hoffe mal, das ich dennoch nicht mit der Fehlerbehebung alleine gelassen werde...
                                        Ich hätte einmal diese Ausgabe (was mir hier auffällt, meine installierten Adapter haben kein "extraneous" hinten anstehen):
                                        I:\iobroker>npm ls
                                        iobroker.inst@2.0.3 I:\iobroker
                                        +-- @serialport/parser-byte-length@1.0.5 extraneous
                                        +-- @serialport/parser-cctalk@1.0.5 extraneous
                                        +-- @serialport/parser-delimiter@1.0.5 extraneous
                                        +-- @serialport/parser-readline@1.0.5 extraneous
                                        +-- @serialport/parser-ready@1.0.5 extraneous
                                        +-- @serialport/parser-regex@1.0.5 extraneous
                                        +-- @sinonjs/commons@1.7.1 extraneous
                                        +-- @sinonjs/formatio@4.0.1 extraneous
                                        +-- @sinonjs/samsam@4.2.2 extraneous
                                        +-- @sinonjs/text-encoding@0.7.1 extraneous
                                        +-- acorn-jsx@3.0.1 extraneous
                                        +-- ajv-keywords@2.1.1 extraneous
                                        +-- ansi-bgblack@0.1.1 extraneous
                                        +-- ansi-bgblue@0.1.1 extraneous
                                        +-- ansi-bgcyan@0.1.1 extraneous
                                        +-- ansi-bggreen@0.1.1 extraneous
                                        +-- ansi-bgmagenta@0.1.1 extraneous
                                        +-- ansi-bgred@0.1.1 extraneous
                                        +-- ansi-bgwhite@0.1.1 extraneous
                                        +-- ansi-bgyellow@0.1.1 extraneous
                                        +-- ansi-black@0.1.1 extraneous
                                        +-- ansi-blue@0.1.1 extraneous
                                        +-- ansi-bold@0.1.1 extraneous
                                        +-- ansi-colors@0.2.0 extraneous
                                        +-- ansi-cyan@0.1.1 extraneous
                                        +-- ansi-dim@0.1.1 extraneous
                                        +-- ansi-escapes@3.2.0 extraneous
                                        +-- ansi-gray@0.1.1 extraneous
                                        +-- ansi-green@0.1.1 extraneous
                                        +-- ansi-grey@0.1.1 extraneous
                                        +-- ansi-hidden@0.1.1 extraneous
                                        +-- ansi-inverse@0.1.1 extraneous
                                        +-- ansi-italic@0.1.1 extraneous
                                        +-- ansi-magenta@0.1.1 extraneous
                                        +-- ansi-red@0.1.1 extraneous
                                        +-- ansi-reset@0.1.1 extraneous
                                        +-- ansi-strikethrough@0.1.1 extraneous
                                        +-- ansi-underline@0.1.1 extraneous
                                        +-- ansi-white@0.1.1 extraneous
                                        +-- ansi-wrap@0.1.0 extraneous
                                        +-- ansi-yellow@0.1.1 extraneous
                                        +-- arr-flatten@1.1.0 extraneous
                                        +-- arr-swap@1.0.1 extraneous
                                        +-- axios@0.18.1 extraneous
                                        +-- babel-code-frame@6.26.0 extraneous
                                        +-- buffer-alloc-unsafe@1.1.0 extraneous
                                        +-- buffer-alloc@1.2.0 extraneous
                                        +-- buffer-fill@1.0.0 extraneous
                                        +-- caller-path@0.1.0 extraneous
                                        +-- callsites@0.2.0 extraneous
                                        +-- chalk@2.4.2 extraneous
                                        +-- chardet@0.4.2 extraneous
                                        +-- charenc@0.0.2 extraneous
                                        +-- choices-separator@2.0.0 extraneous
                                        +-- circular-json@0.3.3 extraneous
                                        +-- cli-cursor@2.1.0 extraneous
                                        +-- cli-width@2.2.0 extraneous
                                        +-- clone-deep@1.0.0 extraneous
                                        +-- co@4.6.0 extraneous
                                        +-- collection-visit@1.0.0 extraneous
                                        +-- colors@1.3.3
                                        +-- copy-descriptor@0.1.1 extraneous
                                        +-- cross-spawn@5.1.0 extraneous
                                        +-- crypt@0.0.2 extraneous
                                        +-- deep-is@0.1.3 extraneous
                                        +-- define-property@1.0.0 extraneous
                                        +-- diff@4.0.2 extraneous
                                        +-- doctrine@2.1.0 extraneous
                                        +-- engine.io-client@1.8.2 extraneous
                                        +-- engine.io@1.8.2 extraneous
                                        +-- error-symbol@0.1.0 extraneous
                                        +-- escape-string-regexp@1.0.5 extraneous
                                        +-- eslint-find-rules@3.4.0 extraneous
                                        +-- eslint-plugin-json@1.4.0 extraneous
                                        +-- eslint-plugin-mocha@4.12.1 extraneous
                                        +-- eslint-rule-documentation@1.0.23 extraneous
                                        +-- eslint-scope@3.7.3 extraneous
                                        +-- eslint-visitor-keys@1.1.0 extraneous
                                        +-- esquery@1.1.0 extraneous
                                        +-- esrecurse@4.2.1 extraneous
                                        +-- estraverse@4.3.0 extraneous
                                        +-- esutils@2.0.3 extraneous
                                        +-- execa@0.7.0 extraneous
                                        +-- expand-template@1.1.1 extraneous
                                        +-- extend-shallow@2.0.1 extraneous
                                        +-- external-editor@2.2.0 extraneous
                                        +-- fast-levenshtein@2.0.6 extraneous
                                        +-- figures@2.0.0 extraneous
                                        +-- file-entry-cache@2.0.0 extraneous
                                        +-- flat-cache@1.3.4 extraneous
                                        +-- for-in@1.0.2 extraneous
                                        +-- for-own@1.0.0 extraneous
                                        +-- fs-constants@1.0.0 extraneous
                                        +-- fs-extra@7.0.1
                                        +-- functional-red-black-tree@1.0.1 extraneous
                                        +-- get-stream@3.0.0 extraneous
                                        +-- globals@11.12.0 extraneous
                                        +-- has-ansi@2.0.0 extraneous
                                        +-- has-flag@3.0.0 extraneous
                                        +-- ignore@3.3.10 extraneous
                                        +-- info-symbol@0.1.0 extraneous
                                        +-- inquirer@3.3.0 extraneous
                                        +-- iobroker.admin@5.3.8
                                        +-- iobroker.coronavirus-statistics@0.8.7
                                        +-- iobroker.deconz@2.0.5
                                        +-- iobroker.discovery@3.0.3
                                        +-- iobroker.fb-checkpresence@ extraneous
                                        +-- iobroker.flot@1.10.7
                                        +-- iobroker.fritzbox@0.2.1 extraneous
                                        +-- iobroker.hm-rega@3.0.40
                                        +-- iobroker.hm-rpc@1.15.12
                                        +-- iobroker.hs100@2.0.7
                                        +-- iobroker.ical@1.12.1
                                        +-- iobroker.info@1.9.19
                                        +-- iobroker.javascript@5.7.0
                                        +-- iobroker.js-controller@4.0.23
                                        +-- iobroker.logparser@1.1.0
                                        +-- iobroker.mielecloudservice@6.3.2
                                        +-- iobroker.mihome-vacuum@3.3.3
                                        +-- iobroker.nina@0.0.25
                                        +-- iobroker.node-red@3.3.0
                                        +-- iobroker.nuki-extended@2.4.0
                                        +-- iobroker.objects-redis@2.0.5 extraneous
                                        +-- iobroker.ping@1.5.3
                                        +-- iobroker.sayit@1.12.3
                                        +-- iobroker.simple-api@2.6.5
                                        +-- iobroker.socketio@4.2.0
                                        +-- iobroker.sony-bravia@1.0.3
                                        +-- iobroker.sql@1.16.2
                                        +-- iobroker.squeezebox@1.0.0
                                        +-- iobroker.squeezeboxrpc@1.3.9
                                        +-- iobroker.synology@2.1.7
                                        +-- iobroker.telegram@1.12.6
                                        +-- iobroker.tr-064@4.2.16
                                        +-- iobroker.upnp@1.0.21
                                        +-- iobroker.vis-hqwidgets@1.2.0
                                        +-- iobroker.vis-metro@1.2.0
                                        +-- iobroker.vis@1.4.15
                                        +-- iobroker.web@4.3.0
                                        +-- iobroker.yahka@0.13.1
                                        +-- iobroker@2.0.3 extraneous
                                        +-- ioredis@4.16.2 extraneous
                                        +-- is-accessor-descriptor@1.0.0 extraneous
                                        +-- is-arrayish@0.2.1 extraneous
                                        +-- is-buffer@1.1.6 extraneous
                                        +-- is-data-descriptor@1.0.0 extraneous
                                        +-- is-descriptor@1.0.2 extraneous
                                        +-- is-extendable@0.1.1 extraneous
                                        +-- is-number@6.0.0 extraneous
                                        +-- is-plain-object@2.0.4 extraneous
                                        +-- is-resolvable@1.1.0 extraneous
                                        +-- is-windows@1.0.2 extraneous
                                        +-- isobject@3.0.1 extraneous
                                        +-- jayson@ extraneous
                                        +-- js-tokens@3.0.2 extraneous
                                        +-- jsonc-parser@2.2.1 extraneous
                                        +-- just-extend@4.1.0 extraneous
                                        +-- kind-of@3.2.2 extraneous
                                        +-- koalas@1.0.2 extraneous
                                        +-- lazy-cache@2.0.2 extraneous
                                        +-- levn@0.3.0 extraneous
                                        +-- log-ok@0.1.1 extraneous
                                        +-- log-utils@0.2.1 extraneous
                                        +-- lolex@5.1.2 extraneous
                                        +-- map-visit@1.0.0 extraneous
                                        +-- md5@2.2.1 extraneous
                                        +-- mem@1.1.0 extraneous
                                        +-- mimic-fn@1.2.0 extraneous
                                        +-- mixin-object@2.0.1 extraneous
                                        +-- natural-compare@1.4.0 extraneous
                                        +-- nise@3.0.1 extraneous
                                        +-- node-sonos-http-api-master@npm:sonos-http-api@1.6.9 extraneous
                                        +-- node-windows@0.1.14 extraneous
                                        +-- npm-run-path@2.0.2 extraneous
                                        +-- object-copy@0.1.0 extraneous
                                        +-- object-visit@1.0.1 extraneous
                                        +-- onetime@2.0.1 extraneous
                                        +-- optionator@0.8.3 extraneous
                                        +-- p-finally@1.0.0 extraneous
                                        +-- path-is-inside@1.0.2 extraneous
                                        +-- path-key@2.0.1 extraneous
                                        +-- pm2-master@npm:pm2@4.2.3 extraneous
                                        +-- pointer-symbol@1.0.0 extraneous
                                        +-- prelude-ls@1.1.2 extraneous
                                        +-- promirepl@1.0.1 extraneous
                                        +-- prompt-actions@3.0.2 extraneous
                                        +-- prompt-base@4.1.0 extraneous
                                        +-- prompt-checkbox@2.2.0 extraneous
                                        +-- prompt-choices@4.1.0 extraneous
                                        +-- prompt-list@3.2.0 extraneous
                                        +-- prompt-question@5.0.2 extraneous
                                        +-- prompt-radio@1.2.1 extraneous
                                        +-- radio-symbol@2.0.0 extraneous
                                        +-- ramda@0.25.0 extraneous
                                        +-- read-pkg-up@2.0.0 extraneous
                                        +-- read-pkg@2.0.0 extraneous
                                        +-- readline-ui@2.2.3 extraneous
                                        +-- readline-utils@2.2.3 extraneous
                                        +-- regexpp@1.1.0 extraneous
                                        +-- require-uncached@1.0.3 extraneous
                                        +-- resolve-from@1.0.1 extraneous
                                        +-- restore-cursor@2.0.0 extraneous
                                        +-- run-async@2.4.1 extraneous
                                        +-- rx-lite-aggregates@4.0.8 extraneous
                                        +-- rx-lite@4.0.8 extraneous
                                        +-- semver@5.7.1
                                        +-- set-getter@0.1.0 extraneous
                                        +-- set-value@3.0.2 extraneous
                                        +-- shallow-clone@1.0.0 extraneous
                                        +-- shebang-command@1.2.0 extraneous
                                        +-- shebang-regex@1.0.0 extraneous
                                        +-- simple-get@2.8.1 extraneous
                                        +-- sinon@8.1.1 extraneous
                                        +-- slice-ansi@1.0.0 extraneous
                                        +-- socket.io-client@1.7.2 extraneous
                                        +-- socket.io@1.7.2 extraneous
                                        +-- source-map@0.5.7 extraneous
                                        +-- static-extend@0.1.2 extraneous
                                        +-- streamifier@0.1.1 extraneous
                                        +-- strip-color@0.1.0 extraneous
                                        +-- strip-eof@1.0.0 extraneous
                                        +-- success-symbol@0.1.0 extraneous
                                        +-- supports-color@2.0.0 extraneous
                                        +-- systeminformation@4.23.3 extraneous
                                        +-- table@4.0.2 extraneous
                                        +-- tar-fs@1.16.3 extraneous
                                        +-- tar-stream@1.6.2 extraneous
                                        +-- tar@5.0.5 extraneous
                                        +-- terminal-paginator@2.0.2 extraneous
                                        +-- text-table@0.2.0 extraneous
                                        +-- time-stamp@1.1.0 extraneous
                                        +-- tmp@0.0.33 extraneous
                                        +-- to-buffer@1.1.1 extraneous
                                        +-- to-object-path@0.3.0 extraneous
                                        +-- toggle-array@1.0.1 extraneous
                                        +-- type-check@0.3.2 extraneous
                                        +-- type-detect@4.0.8 extraneous
                                        +-- vinyl-sourcemaps-apply@0.2.1 extraneous
                                        +-- vows@0.8.3 extraneous
                                        +-- vscode-json-languageservice@3.5.1 extraneous
                                        +-- vscode-languageserver-textdocument@1.0.1 extraneous
                                        +-- vscode-languageserver-types@3.15.1 extraneous
                                        +-- vscode-nls@4.1.1 extraneous
                                        +-- vscode-uri@2.1.1 extraneous
                                        +-- warning-symbol@0.1.0 extraneous
                                        +-- window-size@1.1.1 extraneous
                                        +-- word-wrap@1.2.3 extraneous
                                        +-- write@0.2.1 extraneous
                                        +-- xmlhttprequest-ssl@1.5.3 extraneous
                                        `-- yargs@7.1.0
                                        Und einmal diese hier:
                                        I:\iobroker>npm ls grep ERR
                                        `-- (empty)
                                        Der Befehl npm ls | grep ERR zeigt nur an, dass es "grep" nicht gibt.
                                          Ist ja auch ein Linux/Unix-Kommando. Würde mich wundern, wenn Windows sowas kennen würde.
                                          • surfer09
                                            Kann mir vielleicht jemand sagen, was ich machen muss, damit das Problem behoben ist? Ich möchte ungerne das ganze System neu installieren, nur weil ein Update irgendwie alles auf den Kopf stellt.
                                            errormeldung nodejs 16.15.1
                                            15
                                            169
                                            22059
