    4. Legacy Adapter schmiert ab
      klassisch Most Active last edited by
      wenn ich den Legacy Adapter aktiviere, schmiert er sofort wieder ab. Auszug aus dem Logfile:
      host-raspberrypi	2015-05-28 06:00:28	info	Restart adapter system.adapter.legacy.0 because enabled
      host-raspberrypi	2015-05-28 06:00:28	error	instance system.adapter.legacy.0 terminated with code 6 (uncaught exception)
      legacy-0	2015-05-28 06:00:28	info	terminating http server
      inMem	2015-05-28 06:00:28	debug	message * system.adapter.web.0.uptime val=245376, ack=true, ts=1432785628, from=system.adapter.web.0, lc=1432785628
      inMem	2015-05-28 06:00:28	debug	message * system.adapter.web.0.memHeapUsed val=14.77, ack=true, ts=1432785628, from=system.adapter.web.0, lc=1432785628
      inMem	2015-05-28 06:00:28	debug	message * system.adapter.web.0.memHeapTotal val=29.58, ack=true, ts=1432785628, from=system.adapter.web.0, lc=1432779852
      inMem	2015-05-28 06:00:28	debug	message * system.adapter.web.0.memRss val=42.86, ack=true, ts=1432785628, from=system.adapter.web.0, lc=1432785493
      inMem	2015-05-28 06:00:28	debug	message * system.adapter.web.0.connected val=true, ack=true, ts=1432785628, from=system.adapter.web.0, lc=1432540256
      inMem	2015-05-28 06:00:28	debug	message * system.adapter.web.0.alive val=true, ack=true, ts=1432785628, from=system.adapter.web.0, lc=1432540256
      inMem	2015-05-28 06:00:28	debug	message * system.adapter.admin.0.uptime val=40521, ack=true, ts=1432785628, from=system.adapter.admin.0, lc=1432785628
      inMem	2015-05-28 06:00:28	debug	message * system.adapter.admin.0.memHeapUsed val=19.1, ack=true, ts=1432785628, from=system.adapter.admin.0, lc=1432785628
      inMem	2015-05-28 06:00:28	debug	message * system.adapter.admin.0.memHeapTotal val=35.39, ack=true, ts=1432785628, from=system.adapter.admin.0, lc=1432785583
      inMem	2015-05-28 06:00:28	debug	message * system.adapter.admin.0.memRss val=49.98, ack=true, ts=1432785628, from=system.adapter.admin.0, lc=1432785583
      inMem	2015-05-28 06:00:28	debug	message * system.adapter.admin.0.connected val=true, ack=true, ts=1432785628, from=system.adapter.admin.0, lc=1432745114
      inMem	2015-05-28 06:00:28	debug	message * system.adapter.admin.0.alive val=true, ack=true, ts=1432785628, from=system.adapter.admin.0, lc=1432745114
      inMem	2015-05-28 06:00:28	debug	message * hm-rpc.0.KEQ0194610.1.BRIGHTNESS val=147, ack=true, ts=1432785628, from=system.adapter.hm-rpc.0, lc=1432785628
      inMem	2015-05-28 06:00:28	debug	message * hm-rpc.0.HEQ0513285.1.ERROR val=0, ack=true, ts=1432785626, from=system.adapter.hm-rpc.0, lc=1430495196
      inMem	2015-05-28 06:00:28	debug	message * hm-rpc.0.HEQ0513285.1.VALVE_STATE val=0, ack=true, ts=1432785626, from=system.adapter.hm-rpc.0, lc=1432756988
      inMem	2015-05-28 06:00:28	debug	message * hm-rpc.0.HEQ0510473.2.ADJUSTING_DATA val=0, ack=true, ts=1432785626, from=system.adapter.hm-rpc.0, lc=1432756806
      inMem	2015-05-28 06:00:28	debug	message * hm-rpc.0.HEQ0510473.2.ADJUSTING_COMMAND val=0, ack=true, ts=1432785626, from=system.adapter.hm-rpc.0, lc=1432756988
      inMem	2015-05-28 06:00:28	debug	message * system.adapter.hm-rpc.0.connected val=true, ack=false, ts=1432785626, lc=1432753176
      inMem	2015-05-28 06:00:28	debug	message * system.adapter.hm-rpc.0.uptime val=32451, ack=true, ts=1432785623, from=system.adapter.hm-rpc.0, lc=1432785623
      inMem	2015-05-28 06:00:28	debug	message * system.adapter.hm-rpc.0.memHeapUsed val=16.46, ack=true, ts=1432785622, from=system.adapter.hm-rpc.0, lc=1432785622
      inMem	2015-05-28 06:00:28	debug	message * system.adapter.hm-rpc.0.memHeapTotal val=31.51, ack=true, ts=1432785622, from=system.adapter.hm-rpc.0, lc=1432784167
      inMem	2015-05-28 06:00:28	debug	message * system.adapter.hm-rpc.0.memRss val=43.98, ack=true, ts=1432785622, from=system.adapter.hm-rpc.0, lc=1432784166
      inMem	2015-05-28 06:00:28	debug	message * system.adapter.hm-rpc.0.connected val=true, ack=true, ts=1432785622, from=system.adapter.hm-rpc.0, lc=1432753176
      inMem	2015-05-28 06:00:28	debug	message * system.adapter.hm-rpc.0.alive val=true, ack=true, ts=1432785622, from=system.adapter.hm-rpc.0, lc=1432753176
      inMem	2015-05-28 06:00:28	debug	message * system.host.raspberrypi.uptime val=245385, ack=true, ts=1432785620, from=system.host.raspberrypi, lc=1432785620
      inMem	2015-05-28 06:00:28	debug	message * system.host.raspberrypi.memHeapUsed val=39.5, ack=true, ts=1432785620, from=system.host.raspberrypi, lc=1432785620
      inMem	2015-05-28 06:00:28	debug	message * system.host.raspberrypi.memHeapTotal val=54.59, ack=true, ts=1432785620, from=system.host.raspberrypi, lc=1432785620
      inMem	2015-05-28 06:00:28	debug	message * system.host.raspberrypi.memRss val=94.91, ack=true, ts=1432785620, from=system.host.raspberrypi, lc=1432785620
      inMem	2015-05-28 06:00:28	debug	message * system.host.raspberrypi.mem val=19, ack=true, ts=1432785620, from=system.host.raspberrypi, lc=1432785620
      inMem	2015-05-28 06:00:28	debug	message * system.host.raspberrypi.load val=0.58, ack=true, ts=1432785620, from=system.host.raspberrypi, lc=1432785620
      inMem	2015-05-28 06:00:28	debug	message * system.host.raspberrypi.alive val=true, ack=true, ts=1432785620, from=system.host.raspberrypi, lc=1432745307
      TypeError:	2015-05-28 06:00:28	error	at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
      TypeError:	2015-05-28 06:00:28	error	at Decoder. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
      TypeError:	2015-05-28 06:00:28	error	at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:301:8)
      TypeError:	2015-05-28 06:00:28	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
      TypeError:	2015-05-28 06:00:28	error	at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
      TypeError:	2015-05-28 06:00:28	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:220:12)
      TypeError:	2015-05-28 06:00:28	error	at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:295:6)
      TypeError:	2015-05-28 06:00:28	error	at Socket. (/opt/iobroker/node_modules/iobroker.legacy/legacy.js:416:17)
      TypeError:	2015-05-28 06:00:28	error	at obj2rega (/opt/iobroker/node_modules/iobroker.legacy/legacy.js:344:102)
      TypeError:	2015-05-28 06:00:28	error	at translate (/opt/iobroker/node_modules/iobroker.legacy/legacy.js:107:14)
      TypeError:	2015-05-28 06:00:28	error	Cannot read property 'words' of undefined
      uncaught	2015-05-28 06:00:28	error	exception: Cannot read property 'words' of undefined
      legacy-0	2015-05-28 06:00:27	info	creating ccu.io objects
      legacy-0	2015-05-28 06:00:19	info	received all objects
      legacy-0	2015-05-28 06:00:17	info	webserver listening on port 8088
      legacy-0	2015-05-28 06:00:16	info	starting. Version 0.1.12 in /opt/iobroker/node_modules/iobroker.legacy
      legacy-0	2015-05-28 06:00:16	debug	statesDB connected
      legacy-0	2015-05-28 06:00:16	debug	objectDB connected
      host-raspberrypi	2015-05-28 06:00:13	info	instance system.adapter.legacy.0 started with pid 18115
      host-raspberrypi	2015-05-28 06:00:13	info	object change system.adapter.legacy.0
      host-raspberrypi	2015-05-28 05:59:59	info	instance system.adapter.legacy.0 terminated with code 0 (OK)
      legacy-0	2015-05-28 05:59:59	info	terminating
      inMem	2015-05-28 05:59:59	debug	message * system.adapter.legacy.0.alive val=false, ack=true, ts=1432785599, from=system.adapter.legacy.0, lc=1432785599
      inMem	2015-05-28 05:59:59	debug	message * system.adapter.hm-rega.0.uptime val=245350, ack=true, ts=1432785599, from=system.adapter.hm-rega.0, lc=1432785599
      inMem	2015-05-28 05:59:59	debug	message * system.adapter.hm-rega.0.memHeapUsed val=13.76, ack=true, ts=1432785599, from=system.adapter.hm-rega.0, lc=1432785599
      inMem	2015-05-28 05:59:59	debug	message * system.adapter.hm-rega.0.memHeapTotal val=30.55, ack=true, ts=1432785599, from=system.adapter.hm-rega.0, lc=1432785164
      inMem	2015-05-28 05:59:59	debug	message * system.adapter.hm-rega.0.memRss val=42.95, ack=true, ts=1432785599, from=system.adapter.hm-rega.0, lc=1432785584
      inMem	2015-05-28 05:59:59	debug	message * system.adapter.hm-rega.0.connected val=true, ack=true, ts=1432785599, from=system.adapter.hm-rega.0, lc=1432540255
      inMem	2015-05-28 05:59:59	debug	message * system.adapter.hm-rega.0.alive val=true, ack=true, ts=1432785599, from=system.adapter.hm-rega.0, lc=1432540255
      legacy-0	2015-05-28 05:59:59	info	terminating http server
      inMem	2015-05-28 05:59:59	debug	message * system.adapter.web.0.uptime val=245346, ack=true, ts=1432785598, from=system.adapter.web.0, lc=1432785598
      inMem	2015-05-28 05:59:59	debug	message * system.adapter.web.0.memHeapUsed val=17.08, ack=true, ts=1432785598, from=system.adapter.web.0, lc=1432785598
      inMem	2015-05-28 05:59:59	debug	message * system.adapter.web.0.memHeapTotal val=29.58, ack=true, ts=1432785598, from=system.adapter.web.0, lc=1432779852
      inMem	2015-05-28 05:59:59	debug	message * system.adapter.web.0.memRss val=42.86, ack=true, ts=1432785598, from=system.adapter.web.0, lc=1432785493
      inMem	2015-05-28 05:59:59	debug	message * system.adapter.web.0.connected val=true, ack=true, ts=1432785598, from=system.adapter.web.0, lc=1432540256
      inMem	2015-05-28 05:59:59	debug	message * system.adapter.web.0.alive val=true, ack=true, ts=1432785598, from=system.adapter.web.0, lc=1432540256
      inMem	2015-05-28 05:59:59	debug	message * system.adapter.admin.0.uptime val=40491, ack=true, ts=1432785598, from=system.adapter.admin.0, lc=1432785598
      inMem	2015-05-28 05:59:59	debug	message * system.adapter.admin.0.memHeapUsed val=16.34, ack=true, ts=1432785598, from=system.adapter.admin.0, lc=1432785598
      inMem	2015-05-28 05:59:59	debug	message * system.adapter.admin.0.memHeapTotal val=35.39, ack=true, ts=1432785598, from=system.adapter.admin.0, lc=1432785583
      inMem	2015-05-28 05:59:59	debug	message * system.adapter.admin.0.memRss val=49.98, ack=true, ts=1432785598, from=system.adapter.admin.0, lc=1432785583
      inMem	2015-05-28 05:59:59	debug	message * system.adapter.admin.0.connected val=true, ack=true, ts=1432785598, from=system.adapter.admin.0, lc=1432745114
      inMem	2015-05-28 05:59:58	debug	message * system.adapter.admin.0.alive val=true, ack=true, ts=1432785598, from=system.adapter.admin.0, lc=1432745114
      inMem	2015-05-28 05:59:58	debug	message * system.adapter.hm-rpc.0.uptime val=32421, ack=true, ts=1432785592, from=system.adapter.hm-rpc.0, lc=1432785592
      inMem	2015-05-28 05:59:58	debug	message * system.adapter.hm-rpc.0.memHeapUsed val=16.33, ack=true, ts=1432785592, from=system.adapter.hm-rpc.0, lc=1432785592
      inMem	2015-05-28 05:59:58	debug	message * system.adapter.hm-rpc.0.memHeapTotal val=31.51, ack=true, ts=1432785592, from=system.adapter.hm-rpc.0, lc=1432784167
      inMem	2015-05-28 05:59:58	debug	message * system.adapter.hm-rpc.0.memRss val=43.98, ack=true, ts=1432785592, from=system.adapter.hm-rpc.0, lc=1432784166
      inMem	2015-05-28 05:59:58	debug	message * system.adapter.hm-rpc.0.connected val=true, ack=true, ts=1432785592, from=system.adapter.hm-rpc.0, lc=1432753176
      inMem	2015-05-28 05:59:58	debug	message * system.adapter.hm-rpc.0.alive val=true, ack=true, ts=1432785592, from=system.adapter.hm-rpc.0, lc=1432753176
      inMem	2015-05-28 05:59:58	debug	message * system.host.raspberrypi.uptime val=245355, ack=true, ts=1432785590, from=system.host.raspberrypi, lc=1432785590
      inMem	2015-05-28 05:59:58	debug	message * system.host.raspberrypi.memHeapUsed val=31.51, ack=true, ts=1432785590, from=system.host.raspberrypi, lc=1432785590
      inMem	2015-05-28 05:59:58	debug	message * system.host.raspberrypi.memHeapTotal val=50.41, ack=true, ts=1432785590, from=system.host.raspberrypi, lc=1432785590
      inMem	2015-05-28 05:59:58	debug	message * system.host.raspberrypi.memRss val=89.54, ack=true, ts=1432785590, from=system.host.raspberrypi, lc=1432785590
      inMem	2015-05-28 05:59:58	debug	message * system.host.raspberrypi.mem val=20, ack=true, ts=1432785590, from=system.host.raspberrypi, lc=1432785590
      inMem	2015-05-28 05:59:58	debug	message * system.host.raspberrypi.load val=0.53, ack=true, ts=1432785590, from=system.host.raspberrypi, lc=1432785590
      inMem	2015-05-28 05:59:58	debug	message * system.host.raspberrypi.alive val=true, ack=true, ts=1432785590, from=system.host.raspberrypi, lc=1432745307
      TypeError:	2015-05-28 05:59:58	error	at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
      TypeError:	2015-05-28 05:59:58	error	at Decoder. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
      TypeError:	2015-05-28 05:59:58	error	at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:301:8)
      TypeError:	2015-05-28 05:59:58	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
      TypeError:	2015-05-28 05:59:58	error	at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
      TypeError:	2015-05-28 05:59:58	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:220:12)
      TypeError:	2015-05-28 05:59:58	error	at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:295:6)
      TypeError:	2015-05-28 05:59:58	error	at Socket. (/opt/iobroker/node_modules/iobroker.legacy/legacy.js:416:17)
      TypeError:	2015-05-28 05:59:58	error	at obj2rega (/opt/iobroker/node_modules/iobroker.legacy/legacy.js:344:102)
      TypeError:	2015-05-28 05:59:58	error	at translate (/opt/iobroker/node_modules/iobroker.legacy/legacy.js:107:14)
      TypeError:	2015-05-28 05:59:58	error	Cannot read property 'words' of undefined
      uncaught	2015-05-28 05:59:58	error	exception: Cannot read property 'words' of undefined
      legacy-0	2015-05-28 05:59:58	info	creating ccu.io objects
      host-raspberrypi	2015-05-28 05:59:58	info	stopInstance system.adapter.legacy.0 killing pid 18109
      host-raspberrypi	2015-05-28 05:59:58	info	object change system.adapter.legacy.0
      legacy-0	2015-05-28 05:59:50	info	received all objects
      legacy-0	2015-05-28 05:59:47	info	webserver listening on port 8088
      legacy-0	2015-05-28 05:59:47	info	starting. Version 0.1.12 in /opt/iobroker/node_modules/iobroker.legacy
      legacy-0	2015-05-28 05:59:47	debug	statesDB connected
      legacy-0	2015-05-28 05:59:47	debug	objectDB connected
      host-raspberrypi	2015-05-28 05:59:43	info	instance system.adapter.legacy.0 started with pid 18109
      host-raspberrypi	2015-05-28 05:59:13	info	Restart adapter system.adapter.legacy.0 because enabled
      host-raspberrypi	2015-05-28 05:59:13	error	instance system.adapter.legacy.0 terminated with code 6 (uncaught exception)
      legacy-0	2015-05-28 05:59:12	info	creating ccu.io objects
      legacy-0	2015-05-28 05:59:04	info	received all objects
      legacy-0	2015-05-28 05:59:01	info	webserver listening on port 8088
      legacy-0	2015-05-28 05:59:01	info	starting. Version 0.1.12 in /opt/iobroker/node_modules/iobroker.legacy
      legacy-0	2015-05-28 05:59:00	debug	statesDB connected
      legacy-0	2015-05-28 05:59:00	debug	objectDB connected
      host-raspberrypi	2015-05-28 05:58:57	info	instance system.adapter.legacy.0 started with pid 18103
      host-raspberrypi	2015-05-28 05:58:27	info	Restart adapter system.adapter.legacy.0 because enabled
      host-raspberrypi	2015-05-28 05:58:27	error	instance system.adapter.legacy.0 terminated with code 6 (uncaught exception)
      Habe alles automatisch installiert und gestern nochmals nach updates gesucht und upgedatet. Was kann ich noch machen?
        ak1 last edited by
        Hallo!
        Ich habe gerade begonnen mich mit ioBroker zu beschäftigen und stoße auch auf auf das von "klassisch" beschriebene Problem.
        Hat jemand einen Rat?
        ak1
          Ja!
          Legacy meiden[GRINNING FACE WITH SMILING EYES]
          Erst einmal Willkommen im Forum!
          Ganz im ernst. Der legacy Adapter wird nicht mehr gepflegt und wahrscheinlich bald aus dem Repository genommen.
          Wenn du ihn für dashui nutzen wolltest, ist jetzt vis die bessere Alternative.
          Für yahui wird es den mobile Adapter geben.
          Gesendet von meinem LIFETAB_S785X mit Tapatalk
            ak1 last edited by
            Rainer, danke für die schnelle und schonungslose Antwort 😉
            Bei mir geht es tatsächlich um Yahui. Dann wart ich halt mal, was da so mit dem Mobile Adapter geben wird. Gibt es dazu schon irgendwelche Informationen?
            ak1
              Ich habe jetzt legacy endgültig aus dem Repository gelöscht… Um die Leute nicht zu verwirren.
                ak1 last edited by
                Ich habe die Tage nun erstmalig etwas genauer auf ioBroker geschaut und damit etwas herumprobiert. Es ist ziemlich beeindruckend, was das ioBroker Team hier bislang geschaffen hat! Klasse!
                Der mobile Adapter hat aber wohl zur Zeit keinen Fokus, so interpretiere ich als Laie zumindest den Status des Adapters auf Github. Ich denke aber, dass meine Yahui-Installation noch eine Zeit lang durchhält …
                ak1
