    4. UniFi Adapter WLAN schalten funktioniert nicht mehr
    • Elektroniker86
      Elektroniker86 last edited by Elektroniker86
      Moin,
      seit ein paar Tagen oder Wochen, ich weiß es leider nicht genau kann ich mein Gast WLAN nicht mehr schalten. Vorher hat es immer einwandfrei funktioniert. Könnt Ihr das bei euch ebenfalls feststellen? In den Logs finde ich keine Auffälligkeiten:
      unifi.0
      2022-06-25 15:04:50.836	debug	Update done
      unifi.0
      2022-06-25 15:04:50.811	debug	fetchHealth: 5
      unifi.0
      2022-06-25 15:04:50.797	debug	fetchNetworks: 7
      unifi.0
      2022-06-25 15:04:50.733	debug	fetchWlans: 3
      unifi.0
      2022-06-25 15:04:50.398	debug	fetchDevices: 9
      unifi.0
      2022-06-25 15:04:50.313	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
      unifi.0
      2022-06-25 15:04:50.305	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
      unifi.0
      2022-06-25 15:04:50.204	info	State value to set for "unifi.0.default.clients.00:04:20:f6:1a:b2.noted" has to be type "boolean" but received type "string"
      unifi.0
      2022-06-25 15:04:50.051	info	State value to set for "unifi.0.default.clients.ac:0b:fb:d6:f8:71.noted" has to be type "boolean" but received type "string"
      unifi.0
      2022-06-25 15:04:49.947	info	State value to set for "unifi.0.default.clients.48:d2:24:3a:60:a8.noted" has to be type "boolean" but received type "string"
      unifi.0
      2022-06-25 15:04:49.746	info	State value to set for "unifi.0.default.clients.b8:27:eb:64:eb:29.noted" has to be type "boolean" but received type "string"
      unifi.0
      2022-06-25 15:04:49.640	debug	fetchClients: 50
      unifi.0
      2022-06-25 15:04:49.610	debug	fetchSiteSysinfo: 1
      unifi.0
      2022-06-25 15:04:49.566	debug	fetchSites: default
      unifi.0
      2022-06-25 15:04:49.544	debug	Login successful
      unifi.0
      2022-06-25 15:04:49.376	debug	Update started
      unifi.0
      2022-06-25 15:04:27.987	debug	Login successful
      unifi.0
      2022-06-25 15:04:20.535	debug	Update done
      unifi.0
      2022-06-25 15:04:20.522	debug	fetchHealth: 5
      unifi.0
      2022-06-25 15:04:20.508	debug	fetchNetworks: 7
      unifi.0
      2022-06-25 15:04:20.445	debug	fetchWlans: 3
      unifi.0
      2022-06-25 15:04:20.247	debug	fetchDevices: 9
      unifi.0
      2022-06-25 15:04:20.181	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
      unifi.0
      2022-06-25 15:04:20.174	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
      unifi.0
      2022-06-25 15:04:20.104	info	State value to set for "unifi.0.default.clients.00:04:20:f6:1a:b2.noted" has to be type "boolean" but received type "string"
      unifi.0
      2022-06-25 15:04:19.967	info	State value to set for "unifi.0.default.clients.ac:0b:fb:d6:f8:71.noted" has to be type "boolean" but received type "string"
      unifi.0
      2022-06-25 15:04:19.872	info	State value to set for "unifi.0.default.clients.48:d2:24:3a:60:a8.noted" has to be type "boolean" but received type "string"
      unifi.0
      2022-06-25 15:04:19.711	info	State value to set for "unifi.0.default.clients.b8:27:eb:64:eb:29.noted" has to be type "boolean" but received type "string"
      unifi.0
      2022-06-25 15:04:19.665	debug	fetchClients: 50
      unifi.0
      2022-06-25 15:04:19.625	debug	fetchSiteSysinfo: 1
      unifi.0
      2022-06-25 15:04:19.603	debug	fetchSites: default
      unifi.0
      2022-06-25 15:04:19.554	debug	Login successful
      unifi.0
      2022-06-25 15:04:19.374	debug	Update started
      unifi.0
      2022-06-25 15:04:08.196	debug	Login successful
      unifi.0
      2022-06-25 15:03:50.875	debug	Update done
      unifi.0
      2022-06-25 15:03:50.849	debug	fetchHealth: 5
      unifi.0
      2022-06-25 15:03:50.830	debug	fetchNetworks: 7
      unifi.0
      2022-06-25 15:03:50.796	debug	fetchWlans: 3
      unifi.0
      2022-06-25 15:03:50.430	debug	fetchDevices: 9
      unifi.0
      2022-06-25 15:03:50.341	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
      unifi.0
      2022-06-25 15:03:50.334	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
      unifi.0
      2022-06-25 15:03:50.225	info	State value to set for "unifi.0.default.clients.00:04:20:f6:1a:b2.noted" has to be type "boolean" but received type "string"
      unifi.0
      2022-06-25 15:03:50.044	info	State value to set for "unifi.0.default.clients.ac:0b:fb:d6:f8:71.noted" has to be type "boolean" but received type "string"
      unifi.0
      2022-06-25 15:03:49.927	info	State value to set for "unifi.0.default.clients.48:d2:24:3a:60:a8.noted" has to be type "boolean" but received type "string"
      unifi.0
      2022-06-25 15:03:49.694	info	State value to set for "unifi.0.default.clients.b8:27:eb:64:eb:29.noted" has to be type "boolean" but received type "string"
      unifi.0
      2022-06-25 15:03:49.610	debug	fetchClients: 50
      unifi.0
      2022-06-25 15:03:49.589	debug	fetchSiteSysinfo: 1
      unifi.0
      2022-06-25 15:03:49.567	debug	fetchSites: default
      unifi.0
      2022-06-25 15:03:49.544	debug	Login successful
      unifi.0
      2022-06-25 15:03:49.373	debug	Update started
      unifi.0
      2022-06-25 15:03:42.780	debug	Login successful
      Vielleicht hat jemand eine Idee?
      Das hatte ich vergessen, Hardware ist die UDM-Pro.
      • Elektroniker86
        Habe mich heute nochmals drangesetzt und die beta (0.6.3) installiert aber es funktioniert immer noch nicht. Beim schalten vom Gast WLAN habe ich nun folgende Error logs!
        unifi.0
        2022-11-09 19:01:26.612	error	[updateWlanStatus site default] error: Request failed with status code 400, stack: AxiosError: Request failed with status code 400 at settle (/opt/iobroker/node_modules/node-unifi/node_modules/axios/lib/core/settle.js:19:12) at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/node-unifi/node_modules/axios/lib/adapters/http.js:495:11) at IncomingMessage.emit (node:events:525:35) at IncomingMessage.emit (node:domain:489:12) at endReadableNT (node:internal/streams/readable:1358:12) at processTicksAndRejections (node:internal/process/task_queues:83:21)
        unifi.0
        2022-11-09 19:01:26.611	error	Error site default (data): {"meta":{"rc":"error","msg":"api.err.IdInvalid"},"data":[]}
        Vielleicht hat jetzt jemand ne Idee?
        System 9 1 Reply Last reply Reply Quote 0
        • System 9
          System 9 @Elektroniker86 last edited by
          Hallo, gleiche Problem habe ich leider auch.
            Danilo last edited by
            Hallo, ich habe auch das Problem, gibt es mittlerweile eine Lösung?
              @elektroniker86
              zieh das mal gerade
              Elektroniker86 1 Reply Last reply Reply Quote 0
              • Elektroniker86
                Elektroniker86 @arteck last edited by Elektroniker86
                @arteck
                Das habe ich bereits gemacht vor längerem sogar aber da ändert sich nichts.
                Wenn ich den Wert unter dem zu schaltenden WLAN bei enabled auf false setze dann geht er wieder nach 1-2 Sekunden auf true. Das WLAN schaltet nicht.
                Folgende Logs:
                unifi.0
                2023-01-19 10:14:29.562	error	[updateWlanStatus site default] error: Request failed with status code 400, stack: AxiosError: Request failed with status code 400 at settle (/opt/iobroker/node_modules/node-unifi/node_modules/axios/lib/core/settle.js:19:12) at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/node-unifi/node_modules/axios/lib/adapters/http.js:495:11) at IncomingMessage.emit (node:events:525:35) at IncomingMessage.emit (node:domain:489:12) at endReadableNT (node:internal/streams/readable:1358:12) at processTicksAndRejections (node:internal/process/task_queues:83:21)
                unifi.0
                2023-01-19 10:14:29.561	error	Error site default (data): {"meta":{"rc":"error","msg":"api.err.IdInvalid"},"data":[]}
                • Elektroniker86
                  Zur Info, das WLAN lässt sich seit dem letzten Adapter Update wieder schalten...
                  adapter problem unifi wlan
