    4. uv-protect Adapter - Warn Meldungen
    • rtwl
      rtwl last edited by
      @simatec
      ich bekomme beim uv-protect Adapter folgende Fehlermeldung:
      was ist denn hier der Fehler? Hab den Adapter schon mehrfach neu gestartet. Aber es gibt keine Besserung.
      2022-06-26 10:00:01.733 - warn: uv-protect.0 (27873) Object uv-protect.0.uv is invalid: Default value has to be type "number" but received type "string"
      2022-06-26 10:00:01.736 - warn: uv-protect.0 (27873) This object will not be created in future versions. Please report this to the developer.
      2022-06-26 10:00:01.755 - warn: uv-protect.0 (27873) Object uv-protect.0.uv_max is invalid: Default value has to be type "number" but received type "string"
      2022-06-26 10:00:01.756 - warn: uv-protect.0 (27873) This object will not be created in future versions. Please report this to the developer.
      2022-06-26 10:00:01.771 - warn: uv-protect.0 (27873) Object uv-protect.0.ozone is invalid: Default value has to be type "number" but received type "string"
      2022-06-26 10:00:01.772 - warn: uv-protect.0 (27873) This object will not be created in future versions. Please report this to the developer.
      2022-06-26 10:00:01.786 - warn: uv-protect.0 (27873) Object uv-protect.0.safe_exposure_time.st1 is invalid: Default value has to be type "number" but received type "string"
      2022-06-26 10:00:01.786 - warn: uv-protect.0 (27873) This object will not be created in future versions. Please report this to the developer.
      2022-06-26 10:00:01.795 - warn: uv-protect.0 (27873) Object uv-protect.0.safe_exposure_time.st2 is invalid: Default value has to be type "number" but received type "string"
      2022-06-26 10:00:01.796 - warn: uv-protect.0 (27873) This object will not be created in future versions. Please report this to the developer.
      2022-06-26 10:00:01.805 - warn: uv-protect.0 (27873) Object uv-protect.0.safe_exposure_time.st3 is invalid: Default value has to be type "number" but received type "string"
      2022-06-26 10:00:01.806 - warn: uv-protect.0 (27873) This object will not be created in future versions. Please report this to the developer.
      2022-06-26 10:00:01.815 - warn: uv-protect.0 (27873) Object uv-protect.0.safe_exposure_time.st4 is invalid: Default value has to be type "number" but received type "string"
      2022-06-26 10:00:01.816 - warn: uv-protect.0 (27873) This object will not be created in future versions. Please report this to the developer.
      2022-06-26 10:00:01.825 - warn: uv-protect.0 (27873) Object uv-protect.0.safe_exposure_time.st5 is invalid: Default value has to be type "number" but received type "string"
      2022-06-26 10:00:01.825 - warn: uv-protect.0 (27873) This object will not be created in future versions. Please report this to the developer.
      2022-06-26 10:00:01.835 - warn: uv-protect.0 (27873) Object uv-protect.0.safe_exposure_time.st6 is invalid: Default value has to be type "number" but received type "string"
      2022-06-26 10:00:01.836 - warn: uv-protect.0 (27873) This object will not be created in future versions. Please report this to the developer.
      2022-06-26 10:00:01.928 - warn: uv-protect.0 (27873) Object uv-protect.0.sun_info.sun_position.azimuth is invalid: Default value has to be type "number" but received type "string"
      2022-06-26 10:00:01.928 - warn: uv-protect.0 (27873) This object will not be created in future versions. Please report this to the developer.
      2022-06-26 10:00:01.936 - warn: uv-protect.0 (27873) Object uv-protect.0.sun_info.sun_position.altitude is invalid: Default value has to be type "number" but received type "string"
      2022-06-26 10:00:01.936 - warn: uv-protect.0 (27873) This object will not be created in future versions. Please report this to the developer.
      2022-06-26 10:00:01.954 - warn: uv-protect.0 (27873) Object uv-protect.0.uv_alert is invalid: Default value has to be type "boolean" but received type "string"
      2022-06-26 10:00:01.955 - warn: uv-protect.0 (27873) This object will not be created in future versions. Please report this to the developer.
      2022-06-26 10:00:01.962 - warn: uv-protect.0 (27873) Object uv-protect.0.uv_warn is invalid: Default value has to be type "boolean" but received type "string"
      2022-06-26 10:00:01.963 - warn: uv-protect.0 (27873) This object will not be created in future versions. Please report this to the developer.
      2022-06-26 10:00:01.973 - info: uv-protect.0 (27873) starting. Version 0.3.4 in /opt/iobroker/node_modules/iobroker.uv-protect, node: v14.19.0, js-controller: 4.0.23
      2022-06-26 10:00:04.171 - info: host.smarthome instance system.adapter.netatmo-crawler.0 started with pid 27892
      2022-06-26 10:00:10.448 - info: host.smarthome instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2022-06-26 10:00:19.627 - warn: uv-protect.0 (27873) Request error: Error: Request failed with status code 500
      2022-06-26 10:00:25.634 - info: uv-protect.0 (27873) Terminated (NO_ERROR): Without reason
      2022
      Thomas Braun simatec 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @rtwl last edited by Thomas Braun
        @rtwl sagte in uv-protect Adapter - Warn Meldungen:
        Hast du das gemacht? Bzw. geschaut ob es nicht schon als Issue angelegt wurde?
        Siehe:
        https://github.com/simatec/ioBroker.uv-protect/issues/50
        BramTown created this issue in simatec/ioBroker.uv-protect
        closed wrong value types (?) #50
        • simatec
          simatec Developer Most Active @rtwl last edited by
          @rtwl Welche Version hast du installiert?
            Thomas Braun Most Active @simatec last edited by
            @simatec
            Also würde sich hier die Beta-Version empfehlen, oder man wartet ab bis die 0.3.5 stable wird.
            rtwl 1 Reply Last reply Reply Quote 0
            • rtwl
              rtwl @Thomas Braun last edited by
              @simatec ich hab die version 0.3.4 installiert (vor ca 7 Tagen)
              • simatec
                @rtwl Installiere mal die 0.3.5 aus dem latest.
                Ich pushe die die nächsten Tage ins Stable
                • rtwl
                  rtwl @simatec last edited by
                  @simatec
                  okay dsnke
                  ich warte vorerst mal auf die stabile Version.
                  bräuchte eh dann noch die Info (Anleitung) wie ich diesen UV Wert in shuttercontrol integrieren kann.
                  • simatec
                    @rtwl Ich pushe die Version nachher ins Stable.
