    4. Fehler bei Boschintegration
    • Jörg Knechten
      Jörg Knechten last edited by
      Hi. Habe ein Problem mit der Integration Bosch Smart Home / IOBroker.
      Alles lt. Video von "verdrahtet soweit durchgeführt. BOSCH Controller Taste gedrückt....
      Und denn kommt das als Protokoll. Komme leider nicht weiter.
      Homoran S 2 Replies Last reply Reply Quote 0
        Homoran Global Moderator Administrators @Jörg Knechten last edited by
        @jörg-knechten Text bitte als Text in code-tags posten
        Keine Screenshots.
          Smartuser_1 @Jörg Knechten last edited by
          @jörg-knechten
          ich habe leider das gleiche Problem. Hast Du eine Lösung gefunden?
          host.raspberrypi
          2022-07-22 00:46:04.779	warn	Do not restart adapter system.adapter.bshb.0 because restart loop detected
          host.raspberrypi
          2022-07-22 00:46:04.778	info	Restart adapter system.adapter.bshb.0 because enabled
          host.raspberrypi
          2022-07-22 00:46:04.777	error	instance system.adapter.bshb.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
          bshb.0
          2914	2022-07-22 00:46:04.177	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
          bshb.0
          2914	2022-07-22 00:46:04.176	info	terminating
          bshb.0
          2914	2022-07-22 00:46:04.175	info	cleaned everything up...
          bshb.0
          2914	2022-07-22 00:46:04.172	error	error during call to BSHC:
          bshb.0
          2914	2022-07-22 00:46:04.172	error	BshbError: error during call to BSHC: at BshcClient.AbstractBshcClient.handleError (/opt/iobroker/node_modules/bosch-smart-home-bridge/dist/api/abstract-bshc-client.js:171:32) at ClientRequest.<anonymous> (/opt/iobroker/node_modules/bosch-smart-home-bridge/dist/api/abstract-bshc-client.js:155:23) at ClientRequest.emit (events.js:400:28) at TLSSocket.socketErrorListener (_http_client.js:475:9) at TLSSocket.emit (events.js:400:28) at emitErrorNT (internal/streams/destroy.js:106:8) at emitErrorCloseNT (internal/streams/destroy.js:74:3) at processTicksAndRejections (internal/process/task_queues.js:82:21)
          bshb.0
          2914	2022-07-22 00:46:04.170	error	uncaught exception: error during call to BSHC:
          bshb.0
          2914	2022-07-22 00:46:03.688	info	Start detecting open doors/windows...
          bshb.0
          2914	2022-07-22 00:46:03.674	info	Start detecting devices...
          bshb.0
          2914	2022-07-22 00:46:03.668	info	Start detecting intrusion detection system...
          bshb.0
          2914	2022-07-22 00:46:03.666	info	Start detecting messages...
          Jörg Knechten 1 Reply Last reply Reply Quote 0
          • Jörg Knechten
            Jörg Knechten @Smartuser_1 last edited by
            @smartuser_1
            kleines Update. JA. Das Passwort wurde nicht richtig erkannt. Nach dem ca. 20ten mal funktioniert es jetzt.
            bosch iobroker
