    4. [Gelöst] iobroker mag nicht mehr - cloud adapter, hm rega, js script alle rot
      tempestas last edited by
      Moin,
      gestern ging auf einmal der cloud adapter nicht mehr, alles auf rot.
      Heute habe ich dann mal den pi neugestartet und nun gehen auch der hm rega, er js adapter und eben weiterhin die cloud nimmer mehr. Folgendes log ergibt sich
      ! Drücke Strg+A und danach Strg+C, um den Inhalt in die Zwischenablage zu kopieren. Klicke irgendwo, um das Fenster zu schliessen.
      openHABianPi	2017-04-03 18:17:48.284	info	host.openHABianPi Restart adapter system.adapter.cloud.0 because enabled
      openHABianPi	2017-04-03 18:17:48.283	error	host.openHABianPi instance system.adapter.cloud.0 terminated with code 1 ()
      openHABianPi	2017-04-03 18:17:47.732	info	host.openHABianPi instance system.adapter.cloud.0 started with pid 1734
      openHABianPi	2017-04-03 18:17:46.625	info	host.openHABianPi Restart adapter system.adapter.cloud.0 because enabled
      openHABianPi	2017-04-03 18:17:46.621	error	host.openHABianPi instance system.adapter.cloud.0 terminated with code 1 ()
      openHABianPi	2017-04-03 18:17:46.084	info	host.openHABianPi instance system.adapter.cloud.0 started with pid 1728
      openHABianPi	2017-04-03 18:17:45.068	info	host.openHABianPi Restart adapter system.adapter.cloud.0 because enabled
      openHABianPi	2017-04-03 18:17:45.067	error	host.openHABianPi instance system.adapter.cloud.0 terminated with code 1 ()
      openHABianPi	2017-04-03 18:17:44.472	info	host.openHABianPi instance system.adapter.cloud.0 started with pid 1722
      openHABianPi	2017-04-03 18:17:43.450	info	host.openHABianPi Restart adapter system.adapter.cloud.0 because enabled
      openHABianPi	2017-04-03 18:17:43.449	error	host.openHABianPi instance system.adapter.cloud.0 terminated with code 1 ()
      host.openHABianPi	2017-04-03 18:17:42.907	info	instance system.adapter.cloud.0 started with pid 1716
      host.openHABianPi	2017-04-03 18:17:41.894	info	Restart adapter system.adapter.cloud.0 because enabled
      host.openHABianPi	2017-04-03 18:17:41.893	error	instance system.adapter.cloud.0 terminated with code 1 ()
      host.openHABianPi	2017-04-03 18:17:40.362	info	Restart adapter system.adapter.javascript.0 because enabled
      host.openHABianPi	2017-04-03 18:17:40.361	error	instance system.adapter.javascript.0 terminated with code 1 ()
      host.openHABianPi	2017-04-03 18:17:39.916	info	instance system.adapter.javascript.0 started with pid 1710
      host.openHABianPi	2017-04-03 18:17:35.606	info	Restart adapter system.adapter.hm-rega.0 because enabled
      host.openHABianPi	2017-04-03 18:17:35.606	error	instance system.adapter.hm-rega.0 terminated with code 0 (OK)
      host.openHABianPi	2017-04-03 18:17:32.860	info	instance system.adapter.hm-rega.0 started with pid 1699
      host.openHABianPi	2017-04-03 18:17:16.234	info	instance system.adapter.cloud.0 started with pid 1690
      host.openHABianPi	2017-04-03 18:17:16.211	info	'system.adapter.cloud.0' enabled
      host.openHABianPi	2017-04-03 18:17:16.210	info	object change system.adapter.cloud.0
      host.openHABianPi	2017-04-03 18:17:09.889	info	Restart adapter system.adapter.javascript.0 because enabled
      host.openHABianPi	2017-04-03 18:17:09.888	error	instance system.adapter.javascript.0 terminated with code 1 ()
      host.openHABianPi	2017-04-03 18:17:09.405	info	instance system.adapter.javascript.0 started with pid 1680
      host.openHABianPi	2017-04-03 18:17:02.845	info	Restart adapter system.adapter.hm-rega.0 because enabled
      host.openHABianPi	2017-04-03 18:17:02.845	error	instance system.adapter.hm-rega.0 terminated with code 0 (OK)
      host.openHABianPi	2017-04-03 18:17:00.076	info	instance system.adapter.hm-rega.0 started with pid 1654
      host.openHABianPi	2017-04-03 18:16:39.384	info	Restart adapter system.adapter.javascript.0 because enabled
      host.openHABianPi	2017-04-03 18:16:39.383	error	instance system.adapter.javascript.0 terminated with code 1 ()
      host.openHABianPi	2017-04-03 18:16:38.894	info	instance system.adapter.javascript.0 started with pid 1635
      host.openHABianPi	2017-04-03 18:16:31.405	info	instance system.adapter.vis.0 terminated while should be started once
      vis.0	2017-04-03 18:16:30.869	info	Uploaded.
      host.openHABianPi	2017-04-03 18:16:30.061	info	Restart adapter system.adapter.hm-rega.0 because enabled
      host.openHABianPi	2017-04-03 18:16:30.060	error	instance system.adapter.hm-rega.0 terminated with code 0 (OK)
      hm-rega.0	2017-04-03 18:16:29.911	info	terminating
      hm-rega.0	2017-04-03 18:16:29.828	error	at Object.Module._extensions..js (module.js:416:10)
      hm-rega.0	2017-04-03 18:16:29.828	error	at Module._compile (module.js:409:26)
      hm-rega.0	2017-04-03 18:16:29.828	error	at Object. (/opt/iobroker/node_modules/iobroker.hm-rega/node_modules/request/request.js:30:14)
      hm-rega.0	2017-04-03 18:16:29.828	error	at require (internal/module.js:12:17)
      hm-rega.0	2017-04-03 18:16:29.828	error	at Module.require (module.js:353:17)
      hm-rega.0	2017-04-03 18:16:29.828	error	at Function.Module._load (module.js:300:12)
      hm-rega.0	2017-04-03 18:16:29.828	error	at Module.load (module.js:343:32)
      hm-rega.0	2017-04-03 18:16:29.828	error	at Module._compile (module.js:373:25)
      hm-rega.0	2017-04-03 18:16:29.828	error	at exports.runInThisContext (vm.js:53:16)
      hm-rega.0	2017-04-03 18:16:29.828	error	SyntaxError: Unexpected token return
      hm-rega.0	2017-04-03 18:16:29.815	error	uncaught exception: Unexpected token return
      hm-rega.0	2017-04-03 18:16:28.442	info	subscribe hm-rpc.0.BidCoS-RF.50.PRESS_SHORT
      hm-rega.0	2017-04-03 18:16:28.424	info	starting. Version 1.4.3 in /opt/iobroker/node_modules/iobroker.hm-rega, node: v4.7.3
      host.openHABianPi	2017-04-03 18:16:26.786	info	instance system.adapter.hm-rega.0 started with pid 1494
      host.openHABianPi	2017-04-03 18:16:26.770	info	object change system.adapter.hm-rega.0
      hm-rpc.1	2017-04-03 18:16:26.390	info	new HmIP devices/channels after filter: 0
      hm-rpc.1	2017-04-03 18:16:26.359	info	xmlrpc <- newDevices 67
      host.openHABianPi	2017-04-03 18:16:26.302	error	instance system.adapter.ical.0 terminated with code 6 (uncaught exception)
      vis.0	2017-04-03 18:16:26.231	info	300 files uploaded...
      ical.0	2017-04-03 18:16:25.247	error	at Object.Module._extensions..js (module.js:416:10)
      ical.0	2017-04-03 18:16:25.247	error	at Module._compile (module.js:409:26)
      ical.0	2017-04-03 18:16:25.247	error	at Object. (/opt/iobroker/node_modules/iobroker.ical/node_modules/request/request.js:25:11)
      ical.0	2017-04-03 18:16:25.247	error	at require (internal/module.js:12:17)
      ical.0	2017-04-03 18:16:25.247	error	at Module.require (module.js:353:17)
      ical.0	2017-04-03 18:16:25.247	error	at Function.Module._load (module.js:300:12)
      ical.0	2017-04-03 18:16:25.247	error	at Module.load (module.js:343:32)
      ical.0	2017-04-03 18:16:25.247	error	at Module._compile (module.js:373:25)
      ical.0	2017-04-03 18:16:25.247	error	at exports.runInThisContext (vm.js:53:16)
      ical.0	2017-04-03 18:16:25.247	error	SyntaxError: Unexpected identifier
      ical.0	2017-04-03 18:16:25.237	error	uncaught exception: Unexpected identifier
      hm-rpc.1	2017-04-03 18:16:25.174	info	xmlrpc -> 0 devices
      hm-rpc.1	2017-04-03 18:16:25.143	info	xmlrpc <- listDevices ['hm-rpc.1']
      hm-rpc.1	2017-04-03 18:16:25.068	info	Connected
      hm-rpc.1	2017-04-03 18:16:24.954	info	xmlrpc client is trying to connect to 192.168.2.201:2010 with ['http://192.168.2.220:2010','hm-rpc.1']
      hm-rpc.1	2017-04-03 18:16:24.950	info	xmlrpc server is trying to listen on 192.168.2.220:2010
      hm-rpc.1	2017-04-03 18:16:23.896	info	starting. Version 1.4.2 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v4.7.3
      hm-rpc.0	2017-04-03 18:16:23.704	info	Connected
      hm-rpc.0	2017-04-03 18:16:23.488	info	binrpc -> 69 devices
      hm-rpc.0	2017-04-03 18:16:23.455	info	binrpc <- listDevices ['hm-rpc.0']
      hm-rpc.0	2017-04-03 18:16:23.423	info	binrpc <- system.listMethods ['hm-rpc.0']
      hm-rpc.0	2017-04-03 18:16:23.167	info	binrpc client is trying to connect to 192.168.2.201:2001 with ['xmlrpc_bin://192.168.2.220:2001','hm-rpc.0']
      hm-rpc.0	2017-04-03 18:16:23.163	info	binrpc server is trying to listen on 192.168.2.220:2001
      hm-rpc.0	2017-04-03 18:16:22.636	info	starting. Version 1.4.2 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v4.7.3
      host.openHABianPi	2017-04-03 18:16:22.167	info	instance system.adapter.hm-rpc.1 started with pid 1480
      host.openHABianPi	2017-04-03 18:16:22.144	info	object change system.adapter.hm-rpc.1
      host.openHABianPi	2017-04-03 18:16:16.893	info	instance system.adapter.hm-rpc.0 started with pid 1474
      host.openHABianPi	2017-04-03 18:16:16.878	info	object change system.adapter.hm-rpc.0
      host.openHABianPi	2017-04-03 18:16:08.934	info	instance system.adapter.hmm.0 terminated with code 0 (OK)
      hmm.0	2017-04-03 18:16:08.888	info	terminating
      host.openHABianPi	2017-04-03 18:16:08.876	info	Restart adapter system.adapter.javascript.0 because enabled
      host.openHABianPi	2017-04-03 18:16:08.875	error	instance system.adapter.javascript.0 terminated with code 1 ()
      host.openHABianPi	2017-04-03 18:16:08.853	info	stopInstance system.adapter.hmm.0 killing pid 1085
      host.openHABianPi	2017-04-03 18:16:08.113	info	instance system.adapter.hm-rega.0 terminated with code 6 (uncaught exception)
      host.openHABianPi	2017-04-03 18:16:08.102	info	instance system.adapter.hm-rpc.1 terminated with code 0 (OK)
      host.openHABianPi	2017-04-03 18:16:08.090	info	instance system.adapter.hm-rpc.0 terminated with code 0 (OK)
      hm-rpc.1	2017-04-03 18:16:07.852	info	terminating
      hm-rpc.0	2017-04-03 18:16:07.816	info	terminating
      host.openHABianPi	2017-04-03 18:16:07.761	info	stopInstance system.adapter.hmm.0
      host.openHABianPi	2017-04-03 18:16:07.750	info	'system.adapter.hmm.0' disabled
      host.openHABianPi	2017-04-03 18:16:07.750	info	object change system.adapter.hmm.0
      host.openHABianPi	2017-04-03 18:16:07.749	info	instance system.adapter.javascript.0 started with pid 1467
      host.openHABianPi	2017-04-03 18:16:07.717	info	stopInstance system.adapter.hm-rpc.1 killing pid 1117
      host.openHABianPi	2017-04-03 18:16:07.716	info	stopInstance system.adapter.hm-rpc.1
      host.openHABianPi	2017-04-03 18:16:07.716	info	'system.adapter.hm-rpc.1' disabled
      host.openHABianPi	2017-04-03 18:16:07.715	info	object change system.adapter.hm-rpc.1
      host.openHABianPi	2017-04-03 18:16:07.704	info	stopInstance system.adapter.hm-rpc.0 killing pid 1049
      host.openHABianPi	2017-04-03 18:16:07.703	info	stopInstance system.adapter.hm-rpc.0
      host.openHABianPi	2017-04-03 18:16:07.703	info	'system.adapter.hm-rpc.0' disabled
      host.openHABianPi	2017-04-03 18:16:07.702	info	object change system.adapter.hm-rpc.0
      host.openHABianPi	2017-04-03 18:16:07.696	info	stopInstance system.adapter.hm-rega.0 killing pid 1427
      host.openHABianPi	2017-04-03 18:16:07.695	info	stopInstance system.adapter.hm-rega.0
      host.openHABianPi	2017-04-03 18:16:07.695	info	'system.adapter.hm-rega.0' disabled
      hm-rpc.1	2017-04-03 18:16:07.758	info	Disconnected
      hm-rpc.1	2017-04-03 18:16:07.724	info	xmlrpc -> 192.168.2.201:2010 init ['http://192.168.2.220:2010','']
      hm-rpc.0	2017-04-03 18:16:07.717	info	Disconnected
      hm-rpc.0	2017-04-03 18:16:07.709	info	binrpc -> 192.168.2.201:2001 init ['xmlrpc_bin://192.168.2.220:2001','']
      host.openHABianPi	2017-04-03 18:16:07.694	info	object change system.adapter.hm-rega.0
      hmm.0	2017-04-03 18:16:06.851	info	hmm exited with 1
      hmm.0	2017-04-03 18:16:06.848	error	at Module._compile (module.js:409:26)
      hmm.0	2017-04-03 18:16:06.848	error	at Object. (/opt/iobroker/node_modules/iobroker.hmm/node_modules/homematic-manager/main.js:17:17)
      hmm.0	2017-04-03 18:16:06.848	error	at require (internal/module.js:12:17)
      hmm.0	2017-04-03 18:16:06.848	error	at Module.require (module.js:353:17)
      hmm.0	2017-04-03 18:16:06.848	error	at Function.Module._load (module.js:276:25)
      hmm.0	2017-04-03 18:16:06.848	error	at Function.Module._resolveFilename (module.js:323:25)
      hmm.0	2017-04-03 18:16:06.848	error	at Function.Module._findPath (module.js:153:20)
      hmm.0	2017-04-03 18:16:06.848	error	at tryPackage (module.js:91:13)
      hmm.0	2017-04-03 18:16:06.848	error	at readPackage (module.js:81:52)
      hmm.0	2017-04-03 18:16:06.848	error	at Object.parse (native)
      hmm.0	2017-04-03 18:16:06.848	error	SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.hmm/node_modules/homematic-manager/node_modules/express/package.json: Unexpected token ]
      hmm.0	2017-04-03 18:16:06.848	error	^
      hmm.0	2017-04-03 18:16:06.848	error	throw e;
      hmm.0	2017-04-03 18:16:06.848	error	module.js:85
      hmm.0	2017-04-03 18:16:06.474	info	Starting homematic-manager: /opt/iobroker/node_modules/iobroker.hmm/node_modules/homematic-manager/main.js
      hmm.0	2017-04-03 18:16:01.468	info	hmm exited with 1
      hm-rega.0	2017-04-03 18:16:01.146	info	starting. Version 1.4.3 in /opt/iobroker/node_modules/iobroker.hm-rega, node: v4.7.3
      hmm.0	2017-04-03 18:16:01.464	error	at Module._compile (module.js:409:26)
      hmm.0	2017-04-03 18:16:01.464	error	at Object. (/opt/iobroker/node_modules/iobroker.hmm/node_modules/homematic-manager/main.js:17:17)
      hmm.0	2017-04-03 18:16:01.464	error	at require (internal/module.js:12:17)
      hmm.0	2017-04-03 18:16:01.464	error	at Module.require (module.js:353:17)
      hmm.0	2017-04-03 18:16:01.464	error	at Function.Module._load (module.js:276:25)
      hmm.0	2017-04-03 18:16:01.464	error	at Function.Module._resolveFilename (module.js:323:25)
      hmm.0	2017-04-03 18:16:01.464	error	at Function.Module._findPath (module.js:153:20)
      hmm.0	2017-04-03 18:16:01.464	error	at tryPackage (module.js:91:13)
      hmm.0	2017-04-03 18:16:01.464	error	at readPackage (module.js:81:52)
      hmm.0	2017-04-03 18:16:01.464	error	at Object.parse (native)
      hmm.0	2017-04-03 18:16:01.464	error	SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.hmm/node_modules/homematic-manager/node_modules/express/package.json: Unexpected token ]
      hmm.0	2017-04-03 18:16:01.464	error	^
      hmm.0	2017-04-03 18:16:01.464	error	throw e;
      hmm.0	2017-04-03 18:16:01.464	error	module.js:85
      hmm.0	2017-04-03 18:16:01.041	info	Starting homematic-manager: /opt/iobroker/node_modules/iobroker.hmm/node_modules/homematic-manager/main.js
      hmm.0	2017-04-03 18:15:56.039	info	hmm exited with 1
      hmm.0	2017-04-03 18:15:56.036	error	at Module._compile (module.js:409:26)
      hmm.0	2017-04-03 18:15:56.036	error	at Object. (/opt/iobroker/node_modules/iobroker.hmm/node_modules/homematic-manager/main.js:17:17)
      hmm.0	2017-04-03 18:15:56.036	error	at require (internal/module.js:12:17)
      hmm.0	2017-04-03 18:15:56.036	error	at Module.require (module.js:353:17)
      hmm.0	2017-04-03 18:15:56.036	error	at Function.Module._load (module.js:276:25)
      hmm.0	2017-04-03 18:15:56.036	error	at Function.Module._resolveFilename (module.js:323:25)
      hmm.0	2017-04-03 18:15:56.036	error	at Function.Module._findPath (module.js:153:20)
      hmm.0	2017-04-03 18:15:56.036	error	at tryPackage (module.js:91:13)
      hmm.0	2017-04-03 18:15:56.036	error	at readPackage (module.js:81:52)
      hmm.0	2017-04-03 18:15:56.036	error	at Object.parse (native)
      hmm.0	2017-04-03 18:15:56.036	error	SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.hmm/node_modules/homematic-manager/node_modules/express/package.json: Unexpected token ]
      hmm.0	2017-04-03 18:15:56.036	error	^
      hmm.0	2017-04-03 18:15:56.036	error	throw e;
      hmm.0	2017-04-03 18:15:56.036	error	module.js:85
      hmm.0	2017-04-03 18:15:55.643	info	Starting homematic-manager: /opt/iobroker/node_modules/iobroker.hmm/node_modules/homematic-manager/main.js
      hmm.0	2017-04-03 18:15:50.639	info	hmm exited with 1
      hmm.0	2017-04-03 18:15:50.633	error	at Module._compile (module.js:409:26)
      hmm.0	2017-04-03 18:15:50.633	error	at Object. (/opt/iobroker/node_modules/iobroker.hmm/node_modules/homematic-manager/main.js:17:17)
      hmm.0	2017-04-03 18:15:50.633	error	at require (internal/module.js:12:17)
      hmm.0	2017-04-03 18:15:50.633	error	at Module.require (module.js:353:17)
      hmm.0	2017-04-03 18:15:50.633	error	at Function.Module._load (module.js:276:25)
      hmm.0	2017-04-03 18:15:50.633	error	at Function.Module._resolveFilename (module.js:323:25)
      hmm.0	2017-04-03 18:15:50.633	error	at Function.Module._findPath (module.js:153:20)
      hmm.0	2017-04-03 18:15:50.633	error	at tryPackage (module.js:91:13)
      hmm.0	2017-04-03 18:15:50.633	error	at readPackage (module.js:81:52)
      hmm.0	2017-04-03 18:15:50.633	error	at Object.parse (native)
      hmm.0	2017-04-03 18:15:50.633	error	SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.hmm/node_modules/homematic-manager/node_modules/express/package.json: Unexpected token ]
      hmm.0	2017-04-03 18:15:50.633	error	^
      hmm.0	2017-04-03 18:15:50.633	error	throw e;
      hmm.0	2017-04-03 18:15:50.633	error	module.js:85
      hmm.0	2017-04-03 18:15:50.306	info	Starting homematic-manager: /opt/iobroker/node_modules/iobroker.hmm/node_modules/homematic-manager/main.js
      vis.0	2017-04-03 18:15:49.857	info	200 files uploaded...
      ical.0	2017-04-03 18:15:49.311	info	starting. Version 1.3.2 in /opt/iobroker/node_modules/iobroker.ical, node: v4.7.3
      host.openHABianPi	2017-04-03 18:15:48.218	info	instance system.adapter.hm-rega.0 started with pid 1427
      hmm.0	2017-04-03 18:15:45.303	info	hmm exited with 1
      hmm.0	2017-04-03 18:15:45.299	error	at Module._compile (module.js:409:26)
      hmm.0	2017-04-03 18:15:45.299	error	at Object. (/opt/iobroker/node_modules/iobroker.hmm/node_modules/homematic-manager/main.js:17:17)
      hmm.0	2017-04-03 18:15:45.299	error	at require (internal/module.js:12:17)
      hmm.0	2017-04-03 18:15:45.299	error	at Module.require (module.js:353:17)
      hmm.0	2017-04-03 18:15:45.299	error	at Function.Module._load (module.js:276:25)
      hmm.0	2017-04-03 18:15:45.299	error	at Function.Module._resolveFilename (module.js:323:25)
      hmm.0	2017-04-03 18:15:45.299	error	at Function.Module._findPath (module.js:153:20)
      hmm.0	2017-04-03 18:15:45.299	error	at tryPackage (module.js:91:13)
      hmm.0	2017-04-03 18:15:45.299	error	at readPackage (module.js:81:52)
      hmm.0	2017-04-03 18:15:45.299	error	at Object.parse (native)
      hmm.0	2017-04-03 18:15:45.299	error	SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.hmm/node_modules/homematic-manager/node_modules/express/package.json: Unexpected token ]
      hmm.0	2017-04-03 18:15:45.299	error	^
      hmm.0	2017-04-03 18:15:45.299	error	throw e;
      hmm.0	2017-04-03 18:15:45.299	error	module.js:85
      hmm.0	2017-04-03 18:15:44.971	info	Starting homematic-manager: /opt/iobroker/node_modules/iobroker.hmm/node_modules/homematic-manager/main.js
      hmm.0	2017-04-03 18:15:39.969	info	hmm exited with 1
      hmm.0	2017-04-03 18:15:39.965	error	at Module._compile (module.js:409:26)
      hmm.0	2017-04-03 18:15:39.965	error	at Object. (/opt/iobroker/node_modules/iobroker.hmm/node_modules/homematic-manager/main.js:17:17)
      hmm.0	2017-04-03 18:15:39.965	error	at require (internal/module.js:12:17)
      hmm.0	2017-04-03 18:15:39.965	error	at Module.require (module.js:353:17)
      hmm.0	2017-04-03 18:15:39.965	error	at Function.Module._load (module.js:276:25)
      hmm.0	2017-04-03 18:15:39.965	error	at Function.Module._resolveFilename (module.js:323:25)
      hmm.0	2017-04-03 18:15:39.965	error	at Function.Module._findPath (module.js:153:20)
      hmm.0	2017-04-03 18:15:39.965	error	at tryPackage (module.js:91:13)
      hmm.0	2017-04-03 18:15:39.965	error	at readPackage (module.js:81:52)
      hmm.0	2017-04-03 18:15:39.965	error	at Object.parse (native)
      hmm.0	2017-04-03 18:15:39.965	error	SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.hmm/node_modules/homematic-manager/node_modules/express/package.json: Unexpected token ]
      hmm.0	2017-04-03 18:15:39.965	error	^
      hmm.0	2017-04-03 18:15:39.965	error	throw e;
      hmm.0	2017-04-03 18:15:39.965	error	module.js:85
      hmm.0	2017-04-03 18:15:39.591	info	Starting homematic-manager: /opt/iobroker/node_modules/iobroker.hmm/node_modules/homematic-manager/main.js
      hmm.0	2017-04-03 18:15:34.585	info	hmm exited with 1
      hmm.0	2017-04-03 18:15:34.576	error	at Module._compile (module.js:409:26)
      hmm.0	2017-04-03 18:15:34.576	error	at Object. (/opt/iobroker/node_modules/iobroker.hmm/node_modules/homematic-manager/main.js:17:17)
      hmm.0	2017-04-03 18:15:34.576	error	at require (internal/module.js:12:17)
      hmm.0	2017-04-03 18:15:34.576	error	at Module.require (module.js:353:17)
      hmm.0	2017-04-03 18:15:34.576	error	at Function.Module._load (module.js:276:25)
      hmm.0	2017-04-03 18:15:34.576	error	at Function.Module._resolveFilename (module.js:323:25)
      hmm.0	2017-04-03 18:15:34.576	error	at Function.Module._findPath (module.js:153:20)
      hmm.0	2017-04-03 18:15:34.576	error	at tryPackage (module.js:91:13)
      hmm.0	2017-04-03 18:15:34.576	error	at readPackage (module.js:81:52)
      hmm.0	2017-04-03 18:15:34.576	error	at Object.parse (native)
      hmm.0	2017-04-03 18:15:34.576	error	SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.hmm/node_modules/homematic-manager/node_modules/express/package.json: Unexpected token ]
      hmm.0	2017-04-03 18:15:34.576	error	^
      hmm.0	2017-04-03 18:15:34.576	error	throw e;
      hmm.0	2017-04-03 18:15:34.576	error	module.js:85
      host.openHABianPi	2017-04-03 18:15:34.570	info	Restart adapter system.adapter.javascript.0 because enabled
      host.openHABianPi	2017-04-03 18:15:34.568	error	instance system.adapter.javascript.0 terminated with code 1 ()
      hmm.0	2017-04-03 18:15:34.189	info	Starting homematic-manager: /opt/iobroker/node_modules/iobroker.hmm/node_modules/homematic-manager/main.js
      host.openHABianPi	2017-04-03 18:15:31.326	info	instance system.adapter.javascript.0 started with pid 1397
      sayit.2	2017-04-03 18:15:30.335	info	All files uploaded
      sayit.1	2017-04-03 18:15:30.320	info	All files uploaded
      hmm.0	2017-04-03 18:15:29.182	info	hmm exited with 1
      hmm.0	2017-04-03 18:15:29.178	error	at Module._compile (module.js:409:26)
      hmm.0	2017-04-03 18:15:29.178	error	at Object. (/opt/iobroker/node_modules/iobroker.hmm/node_modules/homematic-manager/main.js:17:17)
      hmm.0	2017-04-03 18:15:29.178	error	at require (internal/module.js:12:17)
      hmm.0	2017-04-03 18:15:29.178	error	at Module.require (module.js:353:17)
      hmm.0	2017-04-03 18:15:29.178	error	at Function.Module._load (module.js:276:25)
      hmm.0	2017-04-03 18:15:29.178	error	at Function.Module._resolveFilename (module.js:323:25)
      hmm.0	2017-04-03 18:15:29.178	error	at Function.Module._findPath (module.js:153:20)
      hmm.0	2017-04-03 18:15:29.178	error	at tryPackage (module.js:91:13)
      hmm.0	2017-04-03 18:15:29.178	error	at readPackage (module.js:81:52)
      hmm.0	2017-04-03 18:15:29.178	error	at Object.parse (native)
      hmm.0	2017-04-03 18:15:29.178	error	SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.hmm/node_modules/homematic-manager/node_modules/express/package.json: Unexpected token ]
      hmm.0	2017-04-03 18:15:29.178	error	^
      hmm.0	2017-04-03 18:15:29.178	error	throw e;
      hmm.0	2017-04-03 18:15:29.178	error	module.js:85
      hmm.0	2017-04-03 18:15:28.814	info	Starting homematic-manager: /opt/iobroker/node_modules/iobroker.hmm/node_modules/homematic-manager/main.js
      sayit.2	2017-04-03 18:15:25.893	info	Upload announce mp3 files
      sayit.2	2017-04-03 18:15:25.870	info	starting. Version 1.5.1 in /opt/iobroker/node_modules/iobroker.sayit, node: v4.7.3
      sayit.1	2017-04-03 18:15:25.727	info	Upload announce mp3 files
      sayit.1	2017-04-03 18:15:25.678	info	starting. Version 1.5.1 in /opt/iobroker/node_modules/iobroker.sayit, node: v4.7.3
      hmm.0	2017-04-03 18:15:23.813	info	hmm exited with 1
      hmm.0	2017-04-03 18:15:23.804	error	at Module._compile (module.js:409:26)
      hmm.0	2017-04-03 18:15:23.804	error	at Object. (/opt/iobroker/node_modules/iobroker.hmm/node_modules/homematic-manager/main.js:17:17)
      hmm.0	2017-04-03 18:15:23.804	error	at require (internal/module.js:12:17)
      hmm.0	2017-04-03 18:15:23.804	error	at Module.require (module.js:353:17)
      hmm.0	2017-04-03 18:15:23.804	error	at Function.Module._load (module.js:276:25)
      hmm.0	2017-04-03 18:15:23.804	error	at Function.Module._resolveFilename (module.js:323:25)
      hmm.0	2017-04-03 18:15:23.804	error	at Function.Module._findPath (module.js:153:20)
      hmm.0	2017-04-03 18:15:23.804	error	at tryPackage (module.js:91:13)
      hmm.0	2017-04-03 18:15:23.804	error	at readPackage (module.js:81:52)
      hmm.0	2017-04-03 18:15:23.804	error	at Object.parse (native)
      hmm.0	2017-04-03 18:15:23.804	error	SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.hmm/node_modules/homematic-manager/node_modules/express/package.json: Unexpected token ]
      hmm.0	2017-04-03 18:15:23.804	error	^
      hmm.0	2017-04-03 18:15:23.804	error	throw e;
      hmm.0	2017-04-03 18:15:23.804	error	module.js:85
      hmm.0	2017-04-03 18:15:23.467	info	Starting homematic-manager: /opt/iobroker/node_modules/iobroker.hmm/node_modules/homematic-manager/main.js
      hmm.0	2017-04-03 18:15:18.463	info	hmm exited with 1
      hmm.0	2017-04-03 18:15:18.457	error	at Module._compile (module.js:409:26)
      hmm.0	2017-04-03 18:15:18.457	error	at Object. (/opt/iobroker/node_modules/iobroker.hmm/node_modules/homematic-manager/main.js:17:17)
      hmm.0	2017-04-03 18:15:18.457	error	at require (internal/module.js:12:17)
      hmm.0	2017-04-03 18:15:18.457	error	at Module.require (module.js:353:17)
      hmm.0	2017-04-03 18:15:18.457	error	at Function.Module._load (module.js:276:25)
      hmm.0	2017-04-03 18:15:18.457	error	at Function.Module._resolveFilename (module.js:323:25)
      hmm.0	2017-04-03 18:15:18.457	error	at Function.Module._findPath (module.js:153:20)
      hmm.0	2017-04-03 18:15:18.457	error	at tryPackage (module.js:91:13)
      hmm.0	2017-04-03 18:15:18.457	error	at readPackage (module.js:81:52)
      hmm.0	2017-04-03 18:15:18.457	error	at Object.parse (native)
      hmm.0	2017-04-03 18:15:18.457	error	SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.hmm/node_modules/homematic-manager/node_modules/express/package.json: Unexpected token ]
      hmm.0	2017-04-03 18:15:18.457	error	^
      hmm.0	2017-04-03 18:15:18.457	error	throw e;
      hmm.0	2017-04-03 18:15:18.457	error	module.js:85
      hmm.0	2017-04-03 18:15:18.116	info	Starting homematic-manager: /opt/iobroker/node_modules/iobroker.hmm/node_modules/homematic-manager/main.js
      vis.0	2017-04-03 18:15:17.524	info	100 files uploaded...
      host.openHABianPi	2017-04-03 18:15:17.145	info	Restart adapter system.adapter.hm-rega.0 because enabled
      host.openHABianPi	2017-04-03 18:15:17.144	error	instance system.adapter.hm-rega.0 terminated with code 6 (uncaught exception)
      host.openHABianPi	2017-04-03 18:15:16.972	info	instance system.adapter.sayit.2 started with pid 1362
      hm-rega.0	2017-04-03 18:15:15.331	error	at Object.Module._extensions..js (module.js:416:10)
      hm-rega.0	2017-04-03 18:15:15.331	error	at Module._compile (module.js:409:26)
      hm-rega.0	2017-04-03 18:15:15.331	error	at Object. (/opt/iobroker/node_modules/iobroker.hm-rega/node_modules/request/request.js:30:14)
      hm-rega.0	2017-04-03 18:15:15.331	error	at require (internal/module.js:12:17)
      hm-rega.0	2017-04-03 18:15:15.331	error	at Module.require (module.js:353:17)
      hm-rega.0	2017-04-03 18:15:15.331	error	at Function.Module._load (module.js:300:12)
      hm-rega.0	2017-04-03 18:15:15.331	error	at Module.load (module.js:343:32)
      hm-rega.0	2017-04-03 18:15:15.331	error	at Module._compile (module.js:373:25)
      hm-rega.0	2017-04-03 18:15:15.331	error	at exports.runInThisContext (vm.js:53:16)
      hm-rega.0	2017-04-03 18:15:15.331	error	SyntaxError: Unexpected token return
      hm-rega.0	2017-04-03 18:15:15.324	error	uncaught exception: Unexpected token return
      hm-rega.0	2017-04-03 18:15:13.997	info	subscribe hm-rpc.0.BidCoS-RF.50.PRESS_SHORT
      hm-rega.0	2017-04-03 18:15:13.985	info	starting. Version 1.4.3 in /opt/iobroker/node_modules/iobroker.hm-rega, node: v4.7.3
      host.openHABianPi	2017-04-03 18:15:13.221	info	instance system.adapter.ical.0 started with pid 1355
      host.openHABianPi	2017-04-03 18:15:13.205	info	instance scheduled system.adapter.ical.0 0,30 * * * *
      host.openHABianPi	2017-04-03 18:15:13.175	info	instance system.adapter.sayit.1 started with pid 1349
      hmm.0	2017-04-03 18:15:13.112	info	hmm exited with 1
      hmm.0	2017-04-03 18:15:13.107	error	at Module._compile (module.js:409:26)
      hmm.0	2017-04-03 18:15:13.107	error	at Object. (/opt/iobroker/node_modules/iobroker.hmm/node_modules/homematic-manager/main.js:17:17)
      hmm.0	2017-04-03 18:15:13.107	error	at require (internal/module.js:12:17)
      hmm.0	2017-04-03 18:15:13.107	error	at Module.require (module.js:353:17)
      hmm.0	2017-04-03 18:15:13.107	error	at Function.Module._load (module.js:276:25)
      hmm.0	2017-04-03 18:15:13.107	error	at Function.Module._resolveFilename (module.js:323:25)
      hmm.0	2017-04-03 18:15:13.107	error	at Function.Module._findPath (module.js:153:20)
      hmm.0	2017-04-03 18:15:13.107	error	at tryPackage (module.js:91:13)
      hmm.0	2017-04-03 18:15:13.107	error	at readPackage (module.js:81:52)
      hmm.0	2017-04-03 18:15:13.107	error	at Object.parse (native)
      hmm.0	2017-04-03 18:15:13.107	error	SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.hmm/node_modules/homematic-manager/node_modules/express/package.json: Unexpected token ]
      hmm.0	2017-04-03 18:15:13.107	error	^
      hmm.0	2017-04-03 18:15:13.107	error	throw e;
      hmm.0	2017-04-03 18:15:13.107	error	module.js:85
      hmm.0	2017-04-03 18:15:12.765	info	Starting homematic-manager: /opt/iobroker/node_modules/iobroker.hmm/node_modules/homematic-manager/main.js
      hmm.0	2017-04-03 18:15:07.759	info	hmm exited with 1
      hmm.0	2017-04-03 18:15:07.755	error	at Module._compile (module.js:409:26)
      hmm.0	2017-04-03 18:15:07.755	error	at Object. (/opt/iobroker/node_modules/iobroker.hmm/node_modules/homematic-manager/main.js:17:17)
      hmm.0	2017-04-03 18:15:07.755	error	at require (internal/module.js:12:17)
      hmm.0	2017-04-03 18:15:07.755	error	at Module.require (module.js:353:17)
      hmm.0	2017-04-03 18:15:07.755	error	at Function.Module._load (module.js:276:25)
      hmm.0	2017-04-03 18:15:07.755	error	at Function.Module._resolveFilename (module.js:323:25)
      hmm.0	2017-04-03 18:15:07.755	error	at Function.Module._findPath (module.js:153:20)
      hmm.0	2017-04-03 18:15:07.755	error	at tryPackage (module.js:91:13)
      hmm.0	2017-04-03 18:15:07.755	error	at readPackage (module.js:81:52)
      hmm.0	2017-04-03 18:15:07.755	error	at Object.parse (native)
      hmm.0	2017-04-03 18:15:07.755	error	SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.hmm/node_modules/homematic-manager/node_modules/express/package.json: Unexpected token ]
      hmm.0	2017-04-03 18:15:07.755	error	^
      hmm.0	2017-04-03 18:15:07.755	error	throw e;
      hmm.0	2017-04-03 18:15:07.755	error	module.js:85
      hm-rega.0	2017-04-03 18:15:11.543	error	no connection to objects DB
      hmm.0	2017-04-03 18:15:07.405	info	Starting homematic-manager: /opt/iobroker/node_modules/iobroker.hmm/node_modules/homematic-manager/main.js
      host.openHABianPi	2017-04-03 18:15:05.377	info	instance system.adapter.hm-rega.0 started with pid 1325
      hmm.0	2017-04-03 18:15:02.403	info	hmm exited with 1
      hmm.0	2017-04-03 18:15:02.391	error	at Module._compile (module.js:409:26)
      hmm.0	2017-04-03 18:15:02.391	error	at Object. (/opt/iobroker/node_modules/iobroker.hmm/node_modules/homematic-manager/main.js:17:17)
      hmm.0	2017-04-03 18:15:02.391	error	at require (internal/module.js:12:17)
      hmm.0	2017-04-03 18:15:02.391	error	at Module.require (module.js:353:17)
      hmm.0	2017-04-03 18:15:02.391	error	at Function.Module._load (module.js:276:25)
      hmm.0	2017-04-03 18:15:02.391	error	at Function.Module._resolveFilename (module.js:323:25)
      hmm.0	2017-04-03 18:15:02.391	error	at Function.Module._findPath (module.js:153:20)
      hmm.0	2017-04-03 18:15:02.391	error	at tryPackage (module.js:91:13)
      hmm.0	2017-04-03 18:15:02.391	error	at readPackage (module.js:81:52)
      hmm.0	2017-04-03 18:15:02.391	error	at Object.parse (native)
      hmm.0	2017-04-03 18:15:02.391	error	SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.hmm/node_modules/homematic-manager/node_modules/express/package.json: Unexpected token ]
      hmm.0	2017-04-03 18:15:02.391	error	^
      hmm.0	2017-04-03 18:15:02.391	error	throw e;
      hmm.0	2017-04-03 18:15:02.391	error	module.js:85
      hmm.0	2017-04-03 18:15:01.921	info	Starting homematic-manager: /opt/iobroker/node_modules/iobroker.hmm/node_modules/homematic-manager/main.js
      host.openHABianPi	2017-04-03 18:15:01.421	info	stopInstance system.adapter.vis.0
      host.openHABianPi	2017-04-03 18:15:01.420	info	'system.adapter.vis.0' enabled
      host.openHABianPi	2017-04-03 18:15:01.419	info	object change system.adapter.vis.0
      host.openHABianPi	2017-04-03 18:15:01.380	info	stopInstance system.adapter.vis.0
      host.openHABianPi	2017-04-03 18:15:01.377	info	'system.adapter.vis.0' disabled
      host.openHABianPi	2017-04-03 18:15:01.376	info	object change system.adapter.vis.0
      host.openHABianPi	2017-04-03 18:15:01.312	info	Restart adapter system.adapter.javascript.0 because enabled
      host.openHABianPi	2017-04-03 18:15:01.311	error	instance system.adapter.javascript.0 terminated with code 1 ()
      host.openHABianPi	2017-04-03 18:15:00.391	info	instance system.adapter.javascript.0 started with pid 1288
      scenes.0	2017-04-03 18:14:59.321	info	starting. Version 0.2.6 in /opt/iobroker/node_modules/iobroker.scenes, node: v4.7.3
      vis.0	2017-04-03 18:14:58.715	info	Upload vis anew, while changes detected...
      vis.0	2017-04-03 18:14:57.817	info	Changes in index.html detected => update cache.manifest
      sonos.0	2017-04-03 18:14:57.797	info	http sonos server listening on port 8083
      sonos.0	2017-04-03 18:14:57.265	info	starting. Version 1.4.2 in /opt/iobroker/node_modules/iobroker.sonos, node: v4.7.3
      hmm.0	2017-04-03 18:14:56.919	info	hmm exited with 1
      hmm.0	2017-04-03 18:14:56.908	error	at Module._compile (module.js:409:26)
      hmm.0	2017-04-03 18:14:56.908	error	at Object. (/opt/iobroker/node_modules/iobroker.hmm/node_modules/homematic-manager/main.js:17:17)
      hmm.0	2017-04-03 18:14:56.908	error	at require (internal/module.js:12:17)
      hmm.0	2017-04-03 18:14:56.908	error	at Module.require (module.js:353:17)
      hmm.0	2017-04-03 18:14:56.908	error	at Function.Module._load (module.js:276:25)
      hmm.0	2017-04-03 18:14:56.908	error	at Function.Module._resolveFilename (module.js:323:25)
      hmm.0	2017-04-03 18:14:56.908	error	at Function.Module._findPath (module.js:153:20)
      hmm.0	2017-04-03 18:14:56.908	error	at tryPackage (module.js:91:13)
      hmm.0	2017-04-03 18:14:56.908	error	at readPackage (module.js:81:52)
      hmm.0	2017-04-03 18:14:56.908	error	at Object.parse (native)
      hmm.0	2017-04-03 18:14:56.908	error	SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.hmm/node_modules/homematic-manager/node_modules/express/package.json: Unexpected token ]
      hmm.0	2017-04-03 18:14:56.908	error	^
      hmm.0	2017-04-03 18:14:56.908	error	throw e;
      hmm.0	2017-04-03 18:14:56.908	error	module.js:85
      host.openHABianPi	2017-04-03 18:14:56.560	info	instance system.adapter.scenes.0 started with pid 1262
      sonos.0	2017-04-03 18:14:56.156	error	no connection to objects DB
      hmm.0	2017-04-03 18:14:56.079	info	Starting homematic-manager: /opt/iobroker/node_modules/iobroker.hmm/node_modules/homematic-manager/main.js
      vis.0	2017-04-03 18:14:43.206	info	starting. Version 0.10.15 in /opt/iobroker/node_modules/iobroker.vis, node: v4.7.3
      hmm.0	2017-04-03 18:14:51.077	info	hmm exited with 1
      hmm.0	2017-04-03 18:14:51.074	error	at Module._compile (module.js:409:26)
      hmm.0	2017-04-03 18:14:51.074	error	at Object. (/opt/iobroker/node_modules/iobroker.hmm/node_modules/homematic-manager/main.js:17:17)
      hmm.0	2017-04-03 18:14:51.074	error	at require (internal/module.js:12:17)
      hmm.0	2017-04-03 18:14:51.074	error	at Module.require (module.js:353:17)
      hmm.0	2017-04-03 18:14:51.074	error	at Function.Module._load (module.js:276:25)
      hmm.0	2017-04-03 18:14:51.074	error	at Function.Module._resolveFilename (module.js:323:25)
      hmm.0	2017-04-03 18:14:51.074	error	at Function.Module._findPath (module.js:153:20)
      hmm.0	2017-04-03 18:14:51.074	error	at tryPackage (module.js:91:13)
      hmm.0	2017-04-03 18:14:51.074	error	at readPackage (module.js:81:52)
      hmm.0	2017-04-03 18:14:51.074	error	at Object.parse (native)
      hmm.0	2017-04-03 18:14:51.074	error	SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.hmm/node_modules/homematic-manager/node_modules/express/package.json: Unexpected token ]
      hmm.0	2017-04-03 18:14:51.074	error	^
      hmm.0	2017-04-03 18:14:51.074	error	throw e;
      hmm.0	2017-04-03 18:14:51.074	error	module.js:85
      hmm.0	2017-04-03 18:14:50.751	info	Starting homematic-manager: /opt/iobroker/node_modules/iobroker.hmm/node_modules/homematic-manager/main.js
      hmm.0	2017-04-03 18:14:45.749	info	hmm exited with 1
      debug	at Module._compile (module.js:409:26)
      debug	at Object. (/opt/iobroker/node_modules/iobroker.hmm/node_modules/homematic-manager/main.js:17:17)
      debug	at require (internal/module.js:12:17)
      debug	at Module.require (module.js:353:17)
      debug	at Function.Module._load (module.js:276:25)
      debug	at Function.Module._resolveFilename (module.js:323:25)
      help 😞
        Wie sieht z.B.
        Aus?
        SD Karte kaputt?
          Hallo fox,
          hatte alles deinstalliert und neu gemacht, das hat nichts geholfen. Mit diese Anleitung
          http://www.iobroker.net/docu/?page_id=3 … stallieren
          ging es dann. Wobei der cloud Adapter sich nicht installieren lassen wollte, aber nachdem ich alles andere gem Anleitung neu gemacht hatte, mochte der dann bei der normalen installation aus dem broker heraus auch wieder mitspielen.
          Also alles wortwörtlich im "grünen Bereich".
          Aber Interesse, was da vor sich gegangen ist hätte ich schon.
          LG
            VORSICHT!
            @tempestas:
            ging es dann `
            oder doch nicht so richtig?
            @tempestas:
            Wobei der cloud Adapter sich nicht installieren lassen wollte `
            Ich tippe auch auf:
            @Bluefox:
            SD Karte kaputt? `
            Denn es waren einfach zu viele Fehler.
            Vielleicht hast du jetzt "Glück" gehabt und die Karte benutzt im Moment andere Speicherzellen.
            Aber wie lange halten die noch?
            Ich würde asap eine neue Karte nehmen
              ok danke, mache ich
