    4. [gelöst] VIS lässt sich nicht installieren
    • bahnuhr
      bahnuhr Forum Testing Most Active last edited by bahnuhr
      habe in proxmox eine neue VM erstellt mit bullseye.
      Danach iob installiert.
      Und per backitup ein restore eingespielt.
      Hat alles geklappt, bis auf die Installation von VIS.
      Im log kommt:
      vis.0
      2022-07-10 11:19:53.933	error	Not exists
      vis.0
      2022-07-10 11:19:53.931	error	Error: Not exists at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:2973:17) at ObjectsInRedisClient._readFile (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1043:26) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1092:29) at processImmediate (node:internal/timers:468:21)
      vis.0
      2022-07-10 11:19:53.928	error	unhandled promise rejection: Not exists
      vis.0
      2022-07-10 11:19:53.927	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      vis.0
      2022-07-10 11:19:53.361	info	vis license is OK.
      vis.0
      2022-07-10 11:19:53.244	info	starting. Version 1.4.15 in /opt/iobroker/node_modules/iobroker.vis, node: v16.16.0, js-controller: 4.0.23
      Danach manuell per putty probiert mit:
      iob upgrade vis@1.4.15 --debug
      This upgrade of "vis" will at least introduce the following changes:
      -> 1.4.15:
      Better check of the offline license
      -> 1.4.14:
      Corrected GUI bug
      -> 1.4.13:
      The group attributes will be replaced recursively
      -> 1.4.12:
      Fixed bug with the export of specific widgets
      -> 1.4.11:
      Removed ES6 commands to be supported by older browsers
      Fixed problem with update of grouped widgets
      Added web manifest to be able to handle vis as the web app
      -> 1.4.8:
      Added support for js-controller 4.x
      -> 1.4.7:
      Fixed subscribeOidAtRuntime if called with invalid IDs
      Added support of license manager
      BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
      Would you like to upgrade vis from @0.0.0 to @1.4.15 now? [(y)es, (n)o]: Y
      Update vis from @0.0.0 to @1.4.15
      NPM version: 8.11.0
      Installing iobroker.vis@1.4.15... (System call)
      npm ERR! code 6
      npm ERR! path /opt/iobroker/node_modules/iobroker.vis
      npm ERR! command failed
      npm ERR! command sh -c node main.js --install
      npm ERR!     /home/iobroker/.npm/_logs/2022-07-10T09_25_08_664Z-debug-0.log
      host.iobroker Cannot install iobroker.vis@1.4.15: 6
      Und in dem da gezeigten log steht dann folgendes:
      Frage:
      Warum lässt sich VIS als einzige Instanz nicht installieren. (alle anderen Instanzen wurden nach installiert)
      Bitte mal kurz drüber schauen wo dort der Fehler liegt.
      Danke.
      mfg
      Dieter
      Homoran crunchip M 3 Replies Last reply Reply Quote 0
        @bahnuhr was sagt iobroker list adapters ?
        • crunchip
          crunchip Forum Testing Most Active @bahnuhr last edited by
          Problem ist ja schon mehrfach hier im Forum aufgetreten
          @bahnuhr sagte in VIS lässt sich nicht installieren:
          geht doch eigentlich gar nicht, da vis Adapter nicht vorhanden
          daher auch
          • bahnuhr
            bahnuhr Forum Testing Most Active @crunchip last edited by
            @crunchip
            bei iob install vis@1.4.15 --debug
            kommt:
            dieter@iobroker:~$ iob install  vis@1.4.15 --debug
            NPM version: 8.11.0
            npm ERR! code 6
            npm ERR!     /home/iobroker/.npm/_logs/2022-07-10T11_54_23_970Z-debug-0.log
            und das dazugehörige log:
            • bahnuhr
              bahnuhr Forum Testing Most Active @Homoran last edited by
              @homoran sagte in VIS lässt sich nicht installieren:
              dieter@iobroker:~$ iob list adapters
              system.adapter.admin                   : admin          - v5.3.8
              system.adapter.alias-manager           : alias-manager  - v1.2.4
              system.adapter.asterisk                : asterisk       - v1.0.6
              system.adapter.backitup                : backitup       - v2.4.9
              system.adapter.bmw                     : bmw            - v2.5.4
              system.adapter.bosch-ebike             : bosch-ebike    - v0.0.1
              system.adapter.cloud                   : cloud          - v4.1.1
              system.adapter.contact                 : contact        - v1.1.3
              system.adapter.daswetter               : daswetter      - v3.1.2
              system.adapter.doorio                  : doorio         - v2.1.4
              system.adapter.dwd                     : dwd            - v2.8.3
              system.adapter.email                   : email          - v1.1.3
              system.adapter.fb-checkpresence        : fb-checkpresence - v1.1.14
              system.adapter.feiertage               : feiertage      - v1.1.0
              system.adapter.flot                    : flot           - v1.11.0
              system.adapter.fritzbox                : fritzbox       - v0.2.1
              system.adapter.fritzdect               : fritzdect      - v2.2.3
              system.adapter.hm-rega                 : hm-rega        - v3.0.40
              system.adapter.hm-rpc                  : hm-rpc         - v1.15.12
              system.adapter.ical                    : ical           - v1.12.1
              system.adapter.icons-material-png      : icons-material-png - v0.1.0
              system.adapter.icons-mfd-png           : icons-mfd-png  - v1.1.0
              system.adapter.icons-open-icon-library-png: icons-open-icon-library-png - v0.1.2
              system.adapter.info                    : info           - v1.9.19
              system.adapter.javascript              : javascript     - v5.7.0
              system.adapter.linux-control           : linux-control  - v1.1.3
              system.adapter.logparser               : logparser      - v1.1.0
              system.adapter.mbus                    : mbus           - v2.3.4
              system.adapter.mihome                  : mihome         - v1.4.0
              system.adapter.mihome-vacuum           : mihome-vacuum  - v3.4.2
              system.adapter.mqtt                    : mqtt           - v3.0.6
              system.adapter.musiccast               : musiccast      - v1.0.5
              system.adapter.octoprint               : octoprint      - v4.0.0
              system.adapter.onvif                   : onvif          - v0.4.5
              system.adapter.parser                  : parser         - v1.1.7
              system.adapter.ping                    : ping           - v1.5.3
              system.adapter.pollenflug              : pollenflug     - v1.0.6
              system.adapter.proxmox                 : proxmox        - v1.3.4
              system.adapter.rest-api                : rest-api       - v1.0.0
              system.adapter.rssfeed                 : rssfeed        - v1.0.0
              system.adapter.sayit                   : sayit          - v1.12.3
              system.adapter.shelly                  : shelly         - v5.3.2
              system.adapter.simple-api              : simple-api     - v2.7.0
              system.adapter.smartmeter              : smartmeter     - v3.3.4
              system.adapter.socketio                : socketio       - v4.2.0
              system.adapter.sql                     : sql            - v2.1.7
              system.adapter.tankerkoenig            : tankerkoenig   - v2.1.1
              system.adapter.telegram                : telegram       - v1.13.0
              system.adapter.tr-064                  : tr-064         - v4.2.16
              system.adapter.tuya                    : tuya           - v3.6.15
              system.adapter.viessmann               : viessmann      - v1.3.7
              system.adapter.vis                     : vis            - v1.4.15
              system.adapter.vis-bars                : vis-bars       - v0.1.4
              system.adapter.vis-canvas-gauges       : vis-canvas-gauges - v0.1.5
              system.adapter.vis-colorpicker         : vis-colorpicker - v1.2.0
              system.adapter.vis-fancyswitch         : vis-fancyswitch - v1.1.0
              system.adapter.vis-google-fonts        : vis-google-fonts - v1.0.3
              system.adapter.vis-history             : vis-history    - v1.0.0
              system.adapter.vis-hqwidgets           : vis-hqwidgets  - v1.2.0
              system.adapter.vis-icontwo             : vis-icontwo    - v0.87.0
              system.adapter.vis-inventwo            : vis-inventwo   - v3.3.1
              system.adapter.vis-jqui-mfd            : vis-jqui-mfd   - v1.0.12
              system.adapter.vis-justgage            : vis-justgage   - v1.0.2
              system.adapter.vis-keyboard            : vis-keyboard   - v0.0.2
              system.adapter.vis-lcars               : vis-lcars      - v1.0.4
              system.adapter.vis-map                 : vis-map        - v1.0.4
              system.adapter.vis-materialdesign      : vis-materialdesign - v0.5.86
              system.adapter.vis-metro               : vis-metro      - v1.2.0
              system.adapter.vis-players             : vis-players    - v0.1.6
              system.adapter.vis-plumb               : vis-plumb      - v1.0.2
              system.adapter.vis-rgraph              : vis-rgraph     - v0.0.2
              system.adapter.vis-timeandweather      : vis-timeandweather - v1.1.7
              system.adapter.web                     : web            - v4.3.0
              system.adapter.wiobrowser              : wiobrowser     - v1.1.4
              system.adapter.yamaha                  : yamaha         - v0.5.2
              system.adapter.zigbee                  : zigbee         - v1.7.5
              dieter@iobroker:~$
              Da steht vis drin. Ist ja auch logisch. Wurde ja durch restore bei backitup eingespielt.
              Er lässt sich nur nicht installieren.
              crunchip Homoran 2 Replies Last reply Reply Quote 0
              • crunchip
                crunchip Forum Testing Most Active @bahnuhr last edited by crunchip
                @bahnuhr https://forum.iobroker.net/post/813432 war z.b. vis/backitup ein Thema
                allerdings war es üblicherweise so, das der vis Adapter nicht vorhanden war, aber die Instanz
                aus dem log sehe ich z.b.
                39 silly fetch manifest iobroker.vis@1.4.15
                40 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules
                64 info run iobroker.vis@1.4.15 install node_modules/iobroker.vis node main.js --install
                65 info run iobroker.vis@1.4.15 install { code: 6, signal: null }
                66 timing reify:rollback:createSparse Completed in 433ms
                67 timing reify:rollback:retireShallow Completed in 0ms
                68 timing command:install Completed in 16463ms
                69 verbose stack Error: command failed
                69 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:63:27)
                69 verbose stack     at ChildProcess.emit (node:events:527:28)
                69 verbose stack     at maybeClose (node:internal/child_process:1092:16)
                69 verbose stack     at Process.ChildProcess._handle.onexit (node:internal/child_process:302:5)
                70 verbose pkgid iobroker.vis@1.4.15
                71 verbose cwd /opt/iobroker
                jedoch kann ich damit auch nix anfangen
                probier es mal im Nachgang mit
                cd /opt/iobroker
                npm install vis@1.4.12
                  Michi68 @bahnuhr last edited by
                  @bahnuhr
                  hatte letztens das selbe Problem als ich meinen Raspberry auf Bullseye geupdatet habe.
                  Installiere VIS bevor du das Backup zurückspielst dann sollte es gehen.
                  • bahnuhr
                    @crunchip
                    @Michi68
                    Danke an alle.
                    Die Lösung stand auf git:
                    https://github.com/ioBroker/ioBroker.vis/issues/459
                    zuerst:
                    iobroker install vis@1.4.5
                    Und dann bei den Adapter upgrade gedrückt.
                    Läuft wieder.
                    P.S.
                    Dieser Fehler sollte trotzdem bereinigt werden.
                      @bahnuhr sagte in [gelöst] VIS lässt sich nicht installieren:
                      eben icht!
                      gerade wenn durch den vis bug bei Backitup ein Backup wiederhergestellt wurde.
                      Dann wurde zwar die Instanz, aber eben nicht der Adapter installiert.
                      Dieser ist bei dir ja aus irgendeinem Grund vorhanden.
                      was willst du denn dan installieren?
                      • bahnuhr
                        Ein Anwender setzt alles neu auf (gemäß proxmox Doku auf iobroker)
                        Backitup eingespielt.
                        Alle Adapter/Intanzen werden nachinstalliert.
                        Nur nicht vis.
                        Alles muss da irgendwo der Fehler sein.
                        Entweder in vis, oder in iob, oder wo auch immer.
                        Und diesen Fehler/bug sollte man bereinigen.
                          Richtig!
                          gibt es gefühlt 100 Threads zu
                          • bahnuhr
                            @homoran sagte in [gelöst] VIS lässt sich nicht installieren:
                            Das freut mich für dich wenn du diese alle gelesen hast.
                            Für mich war dies nicht present (obwohl ich mehrere Stunden täglich hier im Forum bin).
                            • crunchip
                              alleine, wenn man genau deinen Threadtitel in die Suche eingibt, findet man etliche Thread's zumal Tage dabei waren, an denen es fast Top Thema war.
                              error vis
                              512
