    4. Adapter Systeminfo - Fehler im log
    • bahnuhr
      habe in proxmox eine neue VM erstellt mit bullseye.
      Danach iob installiert.
      Und per backitup ein restore eingespielt.
      Beim Start des Adapters Info kommt im log:
      host.iobroker
      2022-07-11 17:42:30.107	error	instance system.adapter.info.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.iobroker
      2022-07-11 17:42:30.107	error	Caught by controller[0]: at Process.ChildProcess._handle.onexit (node:internal/child_process:302:5)
      host.iobroker
      2022-07-11 17:42:30.107	error	Caught by controller[0]: at maybeClose (node:internal/child_process:1092:16)
      host.iobroker
      2022-07-11 17:42:30.107	error	Caught by controller[0]: at ChildProcess.emit (node:domain:475:12)
      host.iobroker
      2022-07-11 17:42:30.106	error	Caught by controller[0]: at ChildProcess.emit (node:events:527:28)
      host.iobroker
      2022-07-11 17:42:30.106	error	Caught by controller[0]: at ChildProcess.exithandler (node:child_process:390:7)
      host.iobroker
      2022-07-11 17:42:30.106	error	Caught by controller[0]: at /opt/iobroker/node_modules/systeminformation/lib/filesystem.js:127:23
      host.iobroker
      2022-07-11 17:42:30.106	error	Caught by controller[0]: at filterLines (/opt/iobroker/node_modules/systeminformation/lib/filesystem.js:66:9)
      host.iobroker
      2022-07-11 17:42:30.105	error	Caught by controller[0]: ReferenceError: line is not defined
      info.0
      2022-07-11 17:42:29.854	error	line is not defined
      info.0
      2022-07-11 17:42:29.853	error	ReferenceError: line is not defined at filterLines (/opt/iobroker/node_modules/systeminformation/lib/filesystem.js:66:9) at /opt/iobroker/node_modules/systeminformation/lib/filesystem.js:127:23 at ChildProcess.exithandler (node:child_process:390:7) at ChildProcess.emit (node:events:527:28) at ChildProcess.emit (node:domain:475:12) at maybeClose (node:internal/child_process:1092:16) at Process.ChildProcess._handle.onexit (node:internal/child_process:302:5)
      info.0
      2022-07-11 17:42:29.851	error	uncaught exception: line is not defined
      info.0
      2022-07-11 17:42:25.779	info	cpu Temp res = {"main":null,"cores":[],"max":null,"socket":[],"chipset":null}
      info.0
      2022-07-11 17:42:23.834	info	Reading/updating systemdata.
      info.0
      2022-07-11 17:42:23.473	info	starting. Version 1.9.19 in /opt/iobroker/node_modules/iobroker.info, node: v16.16.0, js-controller: 4.0.23
      Habe gedacht (wg. anderem thread) dass evtl. an fehlendem "web socket" liegen könnte.
      Habe socket.io Instanz aus geschaltet; web socket ein und im web als Grundlage web socket eingestellt.
      Fehler bleibt aber.
      Hat jemand eine Idee ?
      mfg
      • bahnuhr
        Offensichtlich gibts schon ein Issue.
        https://github.com/iobroker-community-adapters/ioBroker.info/issues/465
        Lösung hab ich bisher nicht gefunden.
        brkai created this issue in iobroker-community-adapters/ioBroker.info
        closed info-adapter seems not to be compatible with node 16.x #465
        • bahnuhr
          Guten Morgen,
          keiner eine Idee oder gar Lösung.
          Auf meinem derzeitigen System (mittlerweile auch auf 16.x) läuft dieser.
          Nur bei dem neu installierten System läuft er nicht.
            Thomas Braun Most Active @bahnuhr last edited by
            @bahnuhr sagte in Adapter Systeminfo - Fehler im log:
            Und worin unterscheiden sich die Systeme?
            • bahnuhr
              bahnuhr Forum Testing Most Active @Thomas Braun last edited by
              @thomas-braun sagte in Adapter Systeminfo - Fehler im log:
              Das derzeitige läuft schon mehrere jahre.
              Immer updates gemacht. also von 10 auf 12, dann 14 und jetzt 16
              Läuft als VM auf proxmox mit buster.
              Das neue hab ich nach Doku von iobroker Webseite ganz neu in einer VM auf proxmox eingerichtet.
              Wollte halt auf bullseye
              info line is not defined systeminfo
