    4. Harmony Adapter gibt error und startet immer neu
      badplay last edited by
      Hallo
      ich hab nen denke ich Problem mit dem harmony adapter. Wenn ich eine Aktion bzw Activität nutze und diese ausführe bleibt der adapter immer hängen folgenden fehler bekomme ich
      harmony.0 2017-04-06 19:13:32.330 info synced hub config
      harmony.0 2017-04-06 19:13:31.635 info connected to Harmony Hub
      harmony.0 2017-04-06 19:13:29.334 info connecting to Harmony Hub
      harmony.0 2017-04-06 19:13:29.296 info discovered Harmony Hub
      harmony.0 2017-04-06 19:13:28.119 info searching for Harmony Hubs…
      harmony.0 2017-04-06 19:13:28.089 info starting. Version 0.7.0 in /opt/iobroker/node_modules/iobroker.harmony, node: v4.8.1
      host.ubuntu-hd 2017-04-06 19:13:26.695 info instance system.adapter.harmony.0 started with pid 20565
      host.ubuntu-hd 2017-04-06 19:12:56.687 info Restart adapter system.adapter.harmony.0 because enabled
      host.ubuntu-hd 2017-04-06 19:12:56.686 error instance system.adapter.harmony.0 terminated with code 0 (OK)
      harmony.0 2017-04-06 19:12:56.670 info terminating
      harmony.0 2017-04-06 19:12:56.657 info terminating
      harmony.0 2017-04-06 19:12:56.656 error at null._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3030:38)
      harmony.0 2017-04-06 19:12:56.656 error at Adapter.emit (events.js:172:7)
      harmony.0 2017-04-06 19:12:56.656 error at emitTwo (events.js:87:13)
      harmony.0 2017-04-06 19:12:56.656 error at Adapter. (/opt/iobroker/node_modules/iobroker.harmony/harmony.js:34:15)
      harmony.0 2017-04-06 19:12:56.656 error at Object.semaphore.take (/opt/iobroker/node_modules/iobroker.harmony/node_modules/semaphore/lib/semaphore.js:45:9)
      harmony.0 2017-04-06 19:12:56.656 error at Object.item.task (/opt/iobroker/node_modules/iobroker.harmony/node_modules/semaphore/lib/semaphore.js:34:29)
      harmony.0 2017-04-06 19:12:56.656 error at /opt/iobroker/node_modules/iobroker.harmony/harmony.js:36:9
      harmony.0 2017-04-06 19:12:56.656 error at processStateChange (/opt/iobroker/node_modules/iobroker.harmony/harmony.js:67:21)
      harmony.0 2017-04-06 19:12:56.656 error at switchActivity (/opt/iobroker/node_modules/iobroker.harmony/harmony.js:137:92)
      harmony.0 2017-04-06 19:12:56.656 error at Promise.fin.Promise.finally (/opt/iobroker/node_modules/iobroker.harmony/node_modules/harmonyhubjs-client/node_modules/q/q.js:1775:15)
      harmony.0 2017-04-06 19:12:56.656 error Error: Q can't apply finally callback
      harmony.0 2017-04-06 19:12:56.652 error uncaught exception: Q can't apply finally callback
      harmony.0 2017-04-06 19:11:19.739 info synced hub config
      harmony.0 2017-04-06 19:11:18.893 info connected to Harmony Hub
      harmony.0 2017-04-06 19:11:16.594 info connecting to Harmony Hub
      harmony.0 2017-04-06 19:11:16.555 info discovered Harmony Hub
      harmony.0 2017-04-06 19:11:15.354 info searching for Harmony Hubs...
      harmony.0 2017-04-06 19:11:15.325 info starting. Version 0.7.0 in /opt/iobroker/node_modules/iobroker.harmony, node: v4.8.1
      host.ubuntu-hd 2017-04-06 19:11:13.784 info instance system.adapter.harmony.0 started with pid 20419
      host.ubuntu-hd 2017-04-06 19:10:43.775 info Restart adapter system.adapter.harmony.0 because enabled
      weiß einer warum das kommt? wenn ich ein gerät mit dem Scenen Adapter also ohne einer fertigen Aktivität aus Harmony nutze passiert das nicht
