    2. English
    3. ioBroker general
    4. S7-1200 cpu
    S7-1200 cpu
      tyson0941 last edited by
      Hi to all,
      I am using S7 adapter with a 1214c cpu and TIA 17 , I've created a DB disabled ''optimized block access" and enabled "PUT/GET" in device configuration ,everything is green but I can't write the DB from iobroker. If I change the DB value in cpu it will update the value in iobroker but if I change the DB value in iobroker the value in cpu will not update. Did someone had this issue ?
      • mickym
        mickym Most Active @tyson0941 last edited by mickym
        Gelöscht
