    4. [gelöst]Exception beim Start von Node-Red
      Stmiko last edited by
      ich bekomme beim Starten der Instanz von Node-Red eine Exception
      ` > node-red-0 2015-05-30 09:46:26 info node-red exited with 8
      node-red-0 2015-05-30 09:46:26 warn at Object. (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/express/index.js:2:18)
      node-red-0 2015-05-30 09:46:26 warn at require (module.js:380:17)
      node-red-0 2015-05-30 09:46:26 warn at Module.require (module.js:364:17)
      node-red-0 2015-05-30 09:46:26 warn at Function.Module._load (module.js:312:12)
      node-red-0 2015-05-30 09:46:26 warn at Module.load (module.js:356:32)
      node-red-0 2015-05-30 09:46:26 warn at Object.Module._extensions..js (module.js:474:10)
      node-red-0 2015-05-30 09:46:26 warn at Module._compile (module.js:456:26)
      node-red-0 2015-05-30 09:46:26 warn at Object. (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/express/lib/express.js:48:1)
      node-red-0 2015-05-30 09:46:26 warn at module.exports (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/express/node_modules/merge-descriptors/index.js:2:10)
      node-red-0 2015-05-30 09:46:26 warn at Function.getOwnPropertyNames (native)
      node-red-0 2015-05-30 09:46:26 warn TypeError: Object.getOwnPropertyNames called on non-object
      node-red-0 2015-05-30 09:46:26 warn ^
      node-red-0 2015-05-30 09:46:26 warn Object.getOwnPropertyNames(src).forEach(function (name) {
      node-red-0 2015-05-30 09:46:26 warn /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/express/node_modules/merge-descriptors/index.js:2
      node-red-0 2015-05-30 09:46:26 info Starting node-red: /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v –settings /opt/iobroker/node_modules/iobroker.node-red/userdata/settings.js `
      Mehrfaches Installieren/Deinstallieren und Neustart bringen keine Besserung (Raspi2).
      Konfiguration:
        Ok,
        hat sich erledigt.
        Habe nach der Deinstallation das node-red Verzeichnis unter node-modules von Hand gelöscht und dann neu installiert.
        Jetzt läufts 🙂
        1.0k
