    2. English
    3. ioBroker general
    4. Update System iobroker failed
      Tiger last edited by
      Dear All,
      this morning I would like to upgrade my IOBROKER.ADMIN as I was in version 4
      So I've upgrade node.js to V14.20.0,
      I've tried to upgrade js-controller with command
      iobroker upgrade self
      after that... nothing was working... i tried lots of things from Forum and now I've already the same error message...
      when put command : iobroker update
      pi@raspberrypi:/ $ iobroker upadte
      internal/modules/cjs/loader.js:905
      throw err;
      at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
      at Function.Module._load (internal/modules/cjs/loader.js:746:27)
      at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12)
      at internal/main/run_main_module.js:17:47 {
      code: 'MODULE_NOT_FOUND',
      requireStack: []
      I tried
      npm install iobroker.js-controller
      pi@raspberrypi:/ $ npm install iobroker.js-controller
      npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
      npm WARN deprecated har-validator@5.1.5: this library is no longer supported
      npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
      npm WARN checkPermissions Missing write access to /
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      npm WARN enoent ENOENT: no such file or directory, open '/package.json'
      npm WARN !invalid#1 No description
      npm WARN !invalid#1 No repository field.
      npm WARN !invalid#1 No README data
      npm WARN !invalid#1 No license field.
      npm ERR! code EACCES
      npm ERR! syscall access
      npm ERR! path /
      npm ERR! errno -13
      npm ERR! Error: EACCES: permission denied, access '/'
      npm ERR! [Error: EACCES: permission denied, access '/'] {
      npm ERR! errno: -13,
      npm ERR! code: 'EACCES',
      npm ERR! syscall: 'access',
      npm ERR! path: '/'
      npm ERR! }
      npm ERR!
      npm ERR! The operation was rejected by your operating system.
      npm ERR! It is likely you do not have the permissions to access this file as the current user
      npm ERR!
      npm ERR! If you believe this might be a permissions issue, please double-check the
      npm ERR! permissions of the file and its containing directories, or try running
      npm ERR! the command again as root/Administrator.
      npm ERR! /home/pi/.npm/_logs/2022-08-15T11_51_26_878Z-debug.log
      version are
      NPM -v : 6.14.17
      node -v : 14.20.0
      Thanks for your help for a beginner...
      Regards
      mikeal created this issue in request/request
      open Request’s Past, Present and Future #3142
        Thomas Braun Most Active @Tiger last edited by Thomas Braun
        @tiger
        What is the current situation?
        Check:
        sudo ln -s /usr/bin/node /usr/bin/nodejs
        uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
        You are standig in the wrong directroy with the wrong command:
          Tiger @Thomas Braun last edited by Homoran
          This is what I've when checking :
          pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
          ln: failed to create symbolic link '/usr/bin/nodejs': File exists
          pi@raspberrypi:~ $
          pi@raspberrypi:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
          armv7l
          /usr/bin/nodejs
          /usr/local/bin/node
          /usr/local/bin/npm
          v10.24.1
          v14.20.0
          6.14.17
          pi
          /home/pi
          i'd retied in the correct folder (hoping it is the good one 😉
          with the lfollowing messages :
          pi@raspberrypi:~ $ npm install iobroker.js-controller
          > iobroker.js-controller@4.0.23 preinstall /home/pi/node_modules/iobroker.js-controller
          > node lib/preinstallCheck.js
          NPM version: 6.14.17
          > unix-dgram@2.0.4 install /home/pi/node_modules/unix-dgram
          > node-gyp rebuild
          make: Entering directory '/home/pi/node_modules/unix-dgram/build'
            CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
          In file included from ../../nan/nan.h:60,
                           from ../src/unix_dgram.cc:5:
          /home/pi/.cache/node-gyp/14.20.0/include/node/node.h:793:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                 (node::addon_register_func) (regfunc),                          \
          /home/pi/.cache/node-gyp/14.20.0/include/node/node.h:827:3: note: in expansion of macro ‘NODE_MODULE_X’
             NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
          ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
           NODE_MODULE(unix_dgram, Initialize)
            SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
            COPY Release/unix_dgram.node
          make: Leaving directory '/home/pi/node_modules/unix-dgram/build'
          > ursa-optional@0.9.10 install /home/pi/node_modules/ursa-optional
          > node rebuild.js
          ursaNative bindings compilation fail. This is not an issue. Modules that depend on it will use fallbacks.
          > diskusage@1.1.3 install /home/pi/node_modules/diskusage
          > node-gyp rebuild
          make: Entering directory '/home/pi/node_modules/diskusage/build'
            CXX(target) Release/obj.target/diskusage/src/main.o
                           from ../src/main.cpp:3:
          ../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’
           NODE_MODULE(diskusage, Init)
            CXX(target) Release/obj.target/diskusage/src/diskusage_posix.o
            SOLINK_MODULE(target) Release/obj.target/diskusage.node
            COPY Release/diskusage.node
          make: Leaving directory '/home/pi/node_modules/diskusage/build'
          > iobroker.js-controller@4.0.23 install /home/pi/node_modules/iobroker.js-controller
          > node iobroker.js setup first
          Successfully migrated 2282 objects to Redis Sets
          object _design/system updated
            "defaultPrivate": "-----BEGIN RSA PRIVATE KEY-----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\r\nLQrsTuqtxiZzoneLoSuOcEsYGIB8TMHG1XNU6aGAJ0cI78mvbm8L\r\n-----END RSA PRIVATE KEY-----\r\n",
            "defaultPublic": "-----BEGIN CERTIFICATE-----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\r\nSYj6sP0IU2F3Gr3yMbYJAAHWsSagmHaLCViVXwwFDvQjLsZynHgBsZf0\r\n-----END CERTIFICATE-----\r\n"
          Update certificate defaultPrivate
          The object "system.certificates" was updated successfully.
          Update certificate defaultPublic
          > @root/acme@3.1.0 postinstall /home/pi/node_modules/@root/acme
          > node scripts/postinstall
          > esbuild@0.11.23 postinstall /home/pi/node_modules/esbuild
          > node install.js
          npm WARN pi@1.0.0 No description
          npm WARN pi@1.0.0 No repository field.
          + iobroker.js-controller@4.0.23
          added 312 packages from 288 contributors, removed 1 package and audited 313 packages in 85.481s
          18 packages are looking for funding
            run `npm fund` for details
          found 8 vulnerabilities (3 low, 2 moderate, 3 high)
            run `npm audit fix` to fix them, or `npm audit` for details
          thanks
          Homoran Thomas Braun 3 Replies Last reply Reply Quote 0
            Homoran Global Moderator Administrators @Tiger last edited by
            @tiger please use code-tags for the log
              @tiger sagte in Update System iobroker failed:
              /usr/bin/nodejs
              /usr/local/bin/node
              /usr/local/bin/npm
              v10.24.1
              v14.20.0
              nodejs is not installed correctly.
              Can you understand German?
              Here is an extended guide on how to fix it:
              https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
              BTW: Still a wrong directory:
              You need to stand in /opt/iobroker for any operations with npm.
              Using npm is not recommended anyway. For this exakt reason.
              But first fix your nodejs-Installation.
              T 2 Replies Last reply Reply Quote 0
                I do not understand german, but will try with google traductor... 🙂
                I come back after 🙂
                  this command is executed in the pi's home instead of /opt/iobroker
                    in other languages f.i. french it will be worse for us
                      I'm trying to fix with your guide, but to complicate for me.
                      AS I'm a newbee and so I don't understand what I'm doing, so it's difficult.
                      I've a backup of my Sd Card.
                      If I use this backup and retry to upgrade my system,
                      do you have a guide with all steps to do?
                      When try to update Iobroker.Admin, tells me that Node.JS 10 is not goof and I've to upgrade to V16, when made, I try to upgrade system, and another adapter has to be upgraded but the version of Node.JS V16 was not good for it and should be not more than V14...
                      So if you've a guide, it should be more easy for a stupid guy like me
                        Tiger @Homoran last edited by
                        @homoran I completely agree, that's why I'm trying to explain in English 🙂
                          @tiger dou you have a backup of your iobroker installation?
                          done by backitup or iobroker backup?
                          then i would recommend to install all brandnew, best on a new SD card, so you'll still have the old one, and restore your backup to the new installation.
                          All will be built anew
                          T crunchip 2 Replies Last reply Reply Quote 0
                            Yes I've two backup in fact
                            • 1 made thanks to win32 image disc, so I've my image of yestarday
                              -1 made thanks to iobroker backup
                            My idea was to copy the imagedisc of yestarday and retry to upgrade thanks to a guide, and with the correct order of different upgrade
                            • crunchip
                              @homoran and install vis before backup if vis is used
                                Homoran Global Moderator Administrators @Tiger last edited by Homoran
                                win32 image disc,
                                this contains all the broken stuff.
                                not recommended!
                                what adapters did you install?
                                iobroker update -i
                                  Thomas Braun Most Active @Tiger last edited by Homoran
                                  @tiger
                                  First action:
                                  iobroker stop
                                  sudo apt update
                                  sudo apt full-upgrade
                                  sudo reboot
                                  Please post the output of
                                  sudo apt update
                                    @crunchip sagte in Update System iobroker failed:
                                    Restore
                                      to be honest yestarday I tried to upgrade and was in same situation as now, so I took the imagedisc and works as before.
                                      Adapters installed and needed was :
                                      • Siemens S7 adapter
                                      • Zigbee
                                      • Rfxcom
                                      • History
                                      iobroker update -i gives error too
                                      throw err;
                                      requireStack: []
                                        @tiger
                                        Will you try to setup nodejs the proper way or trying around with your backups (which are most propably based on a wrong installation)
                                          History
                                          in the regular iobroker backup the history won't be included.
                                          You have to save the directory /opt/iobroker/iobroker-data/history by yourself
                                            actually I'm trying your command, it's in progress.
                                            It should be better to re install everything... to have a proper installation up to date...
                                            But as you have notice, installation part is not my favorite things, I'm afroid to lost all my domotics and all i've already done with Alexa, Node red etc...
                                            Moreover, as I used the commande : iobroker backup, and I don't see the backup in /opt/iobroker... not sure I've the backup...
                                            regards
                                            1.0k
                                            update iobroker
                                            20427
