    2. English
    3. ioBroker general
    4. Run iobroker behind a proxy
    • Peter Bauer
      Peter Bauer last edited by
      Hi *!
      Since I had to run iobroker behind a web proxy, I had to solve the issue that node does not support proxy requests out of the box.
      The solution was to install node-global-proxy like this
      # make npm proxy ready
      > npm config set proxy http://192.168.0.1:8080
      # next, install node-global-proxy in iobroker directory
      > cd /opt/iobroker
      > npm install node-global-proxy --save
      # edit controller.js
      > vi /opt/iobroker/node_modules/iobroker.js-controller/controller.js
      and make sure it looks like this:
       *      Redirect for older installations
       *      Copyright 2018-2022 bluefox <dogafox@gmail.com>,
       *      MIT License
      const proxy = require("node-global-proxy").default;
      proxy.setConfig("proxy.corp.itserv.de:8080");
      proxy.start();
      require('./main').init();
      just in case this helps somebody in the future.
      If the integration can be done better than editing controller.js, please tell me. Thank you.
