    4. Zigbee Neustart bei Firmwareupdatesüberprüfung
    • tugsi
      tugsi last edited by
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Pi3 (Slave und Zigbee-Adapter) und Docker (Master)
      Arbeitsspeicher: 1GB
      Festplattenart: SD-Karte/HDD
      Betriebssystem: Ubuntu/Docker
      Node-Version: 14.20.0
      Nodejs-Version: 14.20.0
      NPM-Version: 6.14.17
      Es gibt ja die Möglichkeit im Zigbee-Adapter oben rechts auf den Button zu klicken "Auf Firmwareupdates überprüfen".
      Immer wenn ich dies mache, stürzt der Adapter ab und startet neu.
      Hier das Log dazu:
      2022-08-30 11:26:07.549 - info: zigbee.0 (26364) Failed to check if update available for '0x540f57fffe3f5cde' (No image available for imageType '5634')
      2022-08-30 11:26:07.582 - info: zigbee.0 (26364) Failed to check if update available for '0x94deb8fffe4c0e07' (No image available for imageType '5634')
      2022-08-30 11:26:35.624 - info: zigbee.0 (26364) Failed to check if update available for '0x14b457fffeca020d' (Device didn't respond to OTA request)
      2022-08-30 11:26:35.631 - error: zigbee.0 (26364) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2022-08-30 11:26:35.633 - error: zigbee.0 (26364) unhandled promise rejection: Timeout - 63764 - 1 - null - 25 - 1 after 30000ms
      2022-08-30 11:26:35.696 - error: zigbee.0 (26364) Error: Timeout - 63764 - 1 - null - 25 - 1 after 30000ms
      at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:64:35)
      at listOnTimeout (internal/timers.js:557:17)
      at processTimers (internal/timers.js:500:7)
      2022-08-30 11:26:35.697 - error: zigbee.0 (26364) Timeout - 63764 - 1 - null - 25 - 1 after 30000ms
      2022-08-30 11:26:35.742 - info: zigbee.0 (26364) cleaned everything up...
      2022-08-30 11:26:36.115 - info: zigbee.0 (26364) Zigbee: disabling joining new devices.
      2022-08-30 11:26:36.143 - info: zigbee.0 (26364) Failed to check if update available for '0x14b457fffe91707c' (Device didn't respond to OTA request)
      2022-08-30 11:26:36.265 - info: zigbee.0 (26364) terminating
      2022-08-30 11:26:36.269 - warn: zigbee.0 (26364) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2022-08-30 11:26:37.433 - error: host.raspberrypi Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      2022-08-30 11:26:37.446 - error: host.raspberrypi Caught by controller[1]: Error: Timeout - 63764 - 1 - null - 25 - 1 after 30000ms
      2022-08-30 11:26:37.448 - error: host.raspberrypi Caught by controller[1]: at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:64:35)
      2022-08-30 11:26:37.449 - error: host.raspberrypi Caught by controller[1]: at listOnTimeout (internal/timers.js:557:17)
      2022-08-30 11:26:37.450 - error: host.raspberrypi Caught by controller[1]: at processTimers (internal/timers.js:500:7)
      2022-08-30 11:26:37.451 - error: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2022-08-30 11:26:37.453 - info: host.raspberrypi Restart adapter system.adapter.zigbee.0 because enabled
      2022-08-30 11:27:08.116 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 27006
      2022-08-30 11:27:19.448 - info: zigbee.0 (27006) starting. Version 1.7.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.20.0, js-controller: 4.0.23
      2022-08-30 11:27:19.730 - info: zigbee.0 (27006) Starting Zigbee npm ...
      Und hier der Log im Debug-Modus (hab es mal auf vermeintlich wesentliche gekürzt):
      2022-08-30 11:31:25.011 - debug: zigbee.0 (27006) No converter available for 'ICPSHC24-30EU-IL-1' with cluster 'genOta' and type 'commandQueryNextImageRequest'
      2022-08-30 11:31:25.040 - debug: zigbee.0 (27006) Is new image available for '0xb4e3f9fffea54848', current '{"fieldControl":1,"manufacturerCode":4476,"imageType":16641,"fileVersion":304371058}', latest meta '{"fileVersion":587753009,"url":"http://fw.ota.homesmart.ikea.net/global/GW1.0/01.19.032/bin/159495-TRADFRI-transformer-2.3.086.ota.ota.signed"}'
      2022-08-30 11:31:25.041 - debug: zigbee.0 (27006) Update available for '0xb4e3f9fffea54848': YES
      2022-08-30 11:31:25.042 - debug: zigbee.0 (27006) Firmware update for 0xb4e3f9fffea54848 is available
      2022-08-30 11:31:25.694 - debug: zigbee.0 (27006) ZigbeeOTA: downloaded main index
      2022-08-30 11:31:25.697 - info: zigbee.0 (27006) Failed to check if update available for '0x540f57fffe3f5cde' (No image available for imageType '5634')
      2022-08-30 11:31:25.698 - silly: zigbee.0 (27006) sendTo "checkOtaAvail" to system.adapter.admin.0 from system.adapter.zigbee.0
      2022-08-30 11:31:25.706 - debug: zigbee.0 (27006) Is new image available for '0x0c4314fffe1f2ffa', current '{"fieldControl":1,"manufacturerCode":4476,"imageType":16641,"fileVersion":304371058}', latest meta '{"fileVersion":587753009,"url":"http://fw.ota.homesmart.ikea.net/global/GW1.0/01.19.032/bin/159495-TRADFRI-transformer-2.3.086.ota.ota.signed"}'
      2022-08-30 11:31:25.707 - debug: zigbee.0 (27006) Update available for '0x0c4314fffe1f2ffa': YES
      2022-08-30 11:31:25.708 - debug: zigbee.0 (27006) Firmware update for 0x0c4314fffe1f2ffa is available
      2022-08-30 11:31:25.709 - silly: zigbee.0 (27006) sendTo "checkOtaAvail" to system.adapter.admin.0 from system.adapter.zigbee.0
      2022-08-30 11:31:25.734 - debug: zigbee.0 (27006) No converter available for 'ICPSHC24-10EU-IL-1' with cluster 'genOta' and type 'commandQueryNextImageRequest'
      2022-08-30 11:31:25.750 - debug: zigbee.0 (27006) No converter available for 'ICPSHC24-30EU-IL-1' with cluster 'genOta' and type 'commandQueryNextImageRequest'
      2022-08-30 11:31:25.798 - debug: zigbee.0 (27006) Is new image available for '0xb4e3f9fffe66dff7', current '{"fieldControl":1,"manufacturerCode":4476,"imageType":16641,"fileVersion":304371058}', latest meta '{"fileVersion":587753009,"url":"http://fw.ota.homesmart.ikea.net/global/GW1.0/01.19.032/bin/159495-TRADFRI-transformer-2.3.086.ota.ota.signed"}'
      2022-08-30 11:31:25.799 - debug: zigbee.0 (27006) Update available for '0xb4e3f9fffe66dff7': YES
      2022-08-30 11:31:25.800 - debug: zigbee.0 (27006) Firmware update for 0xb4e3f9fffe66dff7 is available
      2022-08-30 11:31:53.133 - info: zigbee.0 (27006) Failed to check if update available for '0x14b457fffeca020d' (Device didn't respond to OTA request)
      2022-08-30 11:31:53.135 - silly: zigbee.0 (27006) sendTo "checkOtaAvail" to system.adapter.admin.0 from system.adapter.zigbee.0
      2022-08-30 11:31:53.143 - error: zigbee.0 (27006) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2022-08-30 11:31:53.144 - error: zigbee.0 (27006) unhandled promise rejection: Timeout - 63764 - 1 - null - 25 - 1 after 30000ms
      2022-08-30 11:31:53.205 - error: zigbee.0 (27006) Error: Timeout - 63764 - 1 - null - 25 - 1 after 30000ms
      2022-08-30 11:31:53.206 - error: zigbee.0 (27006) Timeout - 63764 - 1 - null - 25 - 1 after 30000ms
      2022-08-30 11:31:53.250 - info: zigbee.0 (27006) cleaned everything up...
      2022-08-30 11:31:53.256 - debug: zigbee.0 (27006) DeviceAvailability:Publish available for 0x588e81fffe016ba4 = false
      2022-08-30 11:31:53.261 - debug: zigbee.0 (27006) DeviceAvailability:Publish LQ for 0x588e81fffe016ba4 = 0
      2022-08-30 11:31:53.656 - debug: zigbee.0 (27006) DeviceAvailability:Publish available for 0x14b457fffe91707c = false
      2022-08-30 11:31:53.662 - debug: zigbee.0 (27006) DeviceAvailability:Publish LQ for 0x14b457fffe91707c = 0
      2022-08-30 11:31:53.676 - info: zigbee.0 (27006) Zigbee: disabling joining new devices.
      2022-08-30 11:31:53.721 - info: zigbee.0 (27006) Failed to check if update available for '0x14b457fffe91707c' (Device didn't respond to OTA request)
      2022-08-30 11:31:53.722 - silly: zigbee.0 (27006) sendTo "checkOtaAvail" to system.adapter.admin.0 from system.adapter.zigbee.0
      2022-08-30 11:31:53.754 - info: zigbee.0 (27006) terminating
      2022-08-30 11:31:53.757 - debug: zigbee.0 (27006) Plugin sentry destroyed
      2022-08-30 11:31:53.758 - warn: zigbee.0 (27006) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2022-08-30 11:31:54.950 - error: host.raspberrypi Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      2022-08-30 11:31:54.952 - error: host.raspberrypi Caught by controller[1]: Error: Timeout - 63764 - 1 - null - 25 - 1 after 30000ms
      2022-08-30 11:31:54.953 - error: host.raspberrypi Caught by controller[1]: at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:64:35)
      2022-08-30 11:31:54.954 - error: host.raspberrypi Caught by controller[1]: at listOnTimeout (internal/timers.js:557:17)
      2022-08-30 11:31:54.956 - error: host.raspberrypi Caught by controller[1]: at processTimers (internal/timers.js:500:7)
      2022-08-30 11:31:54.957 - error: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2022-08-30 11:31:54.958 - info: host.raspberrypi Restart adapter system.adapter.zigbee.0 because enabled
      2022-08-30 11:32:25.621 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 27279
      Ich sehe noch, dass bei einigen Geräten auf der Kachel ein Update angeboten wird, aber durch den Reset, kann ich das nicht durchführen.
      Ich hatte vor kurzem erst den Stick gewechselt und Zigbee neu installiert und auch die Shepard-DB gelöscht, also sollte alles clean sein. Systemdata Bitte Ausfüllen
      Hardwaresystem: NUC/Pi3/etc.
      Festplattenart: SD-Karte/SSD/HDD
      Betriebssystem: Ubuntu/Windows/Mac
      Node-Version: 10.x.x
      Nodejs-Version: 10.x.x
      NPM-Version: 6.x.x
      Image genutzt: Ja/Nein
      Ort/Name der Imagedatei: Link Systemdata Bitte Ausfüllen
      Hier das Log dazu:
        arteck Developer Most Active @tugsi last edited by
        @tugsi ja da ist ein bug in der Version.. installier mal bitte von GIT ..
        tugsi 1 Reply Last reply Reply Quote 0
        • tugsi
          tugsi @arteck last edited by
          @arteck Ok, aber da bekomme ich ja auch nur die v1.7.6, wie ich bisher hatte und klappt nicht.
          Oder muss ich von GIT eine andere Adresse Benutzerdefiniert eingeben und nicht auf die "Katze" klicken und den Zigbee auswählen?
            Thomas Braun Most Active @tugsi last edited by
            @tugsi
            Schau ob der Adapter aus git stammt:
            cd /opt/iobroker/ && npm ls | grep zigbee
            • tugsi
              tugsi @Thomas Braun last edited by
              @thomas-braun Das ist meine Antwort, sind die Errors alle so ok? Ich weiss das mit dem coffee ist alt, aber irgendwie wirkt das so viele...
              pi@raspberrypi:~ $ cd /opt/iobroker/ && npm ls | grep zigbee
              ├─┬ iobroker.zigbee@1.7.6 (github:ioBroker/ioBroker.zigbee#eea83037ea5f0cd3020a9e16154c6980c70f492f)
              │ ├─┬ zigbee-herdsman@0.14.49
              │ └─┬ zigbee-herdsman-converters@14.0.608
              │   └── zigbee-herdsman@0.14.49 deduped
              npm ERR! extraneous: @abandonware/noble@1.9.2-5 /opt/iobroker/node_modules/@abandonware/noble
              npm ERR! extraneous: @apollon/frankjoke-myadapter@1.2.5 /opt/iobroker/node_modules/@apollon/frankjoke-myadapter
              npm ERR! extraneous: @types/request@2.48.3 /opt/iobroker/node_modules/@types/request
              npm ERR! extraneous: iobroker.admin /opt/iobroker/node_modules/iobroker.admin
              npm ERR! error in /opt/iobroker/node_modules/iobroker.admin: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/package.json'
              npm ERR! extraneous: areq@0.2.0 /opt/iobroker/node_modules/areq
              npm ERR! extraneous: better-queue@3.8.10 /opt/iobroker/node_modules/better-queue
              npm ERR! extraneous: cc-znp@0.5.0 /opt/iobroker/node_modules/cc-znp
              npm ERR! extraneous: chai@4.2.0 /opt/iobroker/node_modules/chai
              npm ERR! extraneous: coffee-compiler@0.3.2 /opt/iobroker/node_modules/coffee-compiler
              npm ERR! extraneous: coffee-script@1.12.7 /opt/iobroker/node_modules/coffee-script
              npm ERR! extraneous: fsevents@2.1.2 /opt/iobroker/node_modules/fsevents
              npm ERR! extraneous: mdns-discovery@0.2.6 /opt/iobroker/node_modules/mdns-discovery
              npm ERR! extraneous: netmask@1.0.6 /opt/iobroker/node_modules/netmask
              npm ERR! extraneous: node-pre-gyp@0.12.0 /opt/iobroker/node_modules/node-pre-gyp
              npm ERR! extraneous: node-ssdp@3.3.0 /opt/iobroker/node_modules/node-ssdp
              npm ERR! extraneous: objectbox@0.3.0 /opt/iobroker/node_modules/objectbox
              npm ERR! extraneous: osx-temperature-sensor@1.0.4 /opt/iobroker/node_modules/osx-temperature-sensor
              npm ERR! extraneous: ping@0.2.2 /opt/iobroker/node_modules/ping
              npm ERR! extraneous: proving@0.1.0 /opt/iobroker/node_modules/proving
              npm ERR! extraneous: queue@6.0.1 /opt/iobroker/node_modules/queue
              npm ERR! extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
              npm ERR! extraneous: typescript@3.7.2 /opt/iobroker/node_modules/typescript
              npm ERR! extraneous: virtual-tsc@0.4.6 /opt/iobroker/node_modules/virtual-tsc
              npm ERR! extraneous: vm2@3.8.4 /opt/iobroker/node_modules/vm2
              npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
              npm ERR! extraneous: xpc-connection@0.1.4 /opt/iobroker/node_modules/xpc-connection
              npm ERR! extraneous: zcl-packet@0.2.4 /opt/iobroker/node_modules/zcl-packet
              npm ERR! extraneous: zstack-constants@0.2.0 /opt/iobroker/node_modules/zstack-constants
              npm ERR! extraneous: zwave-js@7.2.3 /opt/iobroker/node_modules/zwave-js
              npm ERR! peer dep missing: @zwave-js/core@>=10.0.0, required by @zwave-js/log-transport-json@3.0.0
              npm ERR! peer dep missing: @zwave-js/shared@>=10.0.0, required by @zwave-js/log-transport-json@3.0.0
                Thomas Braun Most Active @tugsi last edited by Thomas Braun
                @tugsi sagte in Zigbee Neustart bei Firmwareupdatesüberprüfung:
                Errors sind grundsätzlich nie okay, sonst wäre es Warnings und keine Errors.
                Insbesondere der sieht komisch aus:
                Installier den admin nochmal drüber. Und bring deine nodejs-Installation auf Stand 16, du bist da offenbar noch mit was altem unterwegs.
                tugsi 2 Replies Last reply Reply Quote 0
                • tugsi
                  @thomas-braun sagte in Zigbee Neustart bei Firmwareupdatesüberprüfung:
                  Es gibt aber auch Errors, die man getrost ignorieren kann, deswegen meine Frage 😉
                    Erzähl mir mehr...
                    Nein, Errors schaut man sich an und fixt sie, damit die Fehler ausgemerzt werden.
                    • tugsi
                      Ich denke der fehlende admin kommt weil dies im Multihost ein Slave ist?
                      Nodejs auf 16, heißt aber auch, dass ich dann beim Master auf 16 gehen sollte oder? Gibt es denn dann auch so eine Reihenfolge wie beim JS-Controller, erst Master dann Slave?
                      Zum Thema beseitigen der Errors, habe gerade mal geschaut, das liegt daran, dass unter node_modules Pakete liegen, die nicht in der package.json gelistet sind.
                      Der Befehl
                      rm -rf node_modules
                      würde alle löschen und mit
                      npm install
                      die benötigten erneut installieren.
                      Kannst das bestätigen oder eher anders vorgehen (abgesehen von V16 updaten)?
                      Auf 16 mache ich nicht mehr heute, da brauche ich Ruhe und Zeit, wenn mal was nicht so rundläuft, also was für das Wochenende 🙂
                        Da du die beiden Systeme eh währenddessen runterfährst: Kein Problem der Reihenfolge.
                          Das sollte eigentlich nicht der Fall sein. Zusätzliches Zeug ist i.d. R. unter dem javascript-Adapter zu finden.
                          • David G.
                            Ich habe auch die 1.7.6 drauf.
                            Habe die Tage noch ein paar Firmwareupdates eingespielt.
                            ├── iobroker.zigbee@1.7.6 (git+ssh://git@github.com/ioBroker/ioBroker.zigbee.git#6e5ff46b6464c71c20f8fe099c0600b3cca68c07)
                            • tugsi
                              Ich hab mir das gerade mal angeschaut und ich habe einen Verdacht, dass ich damals wohl schlampig gearbeitet hatte. Kann mich nicht mehr so recht dran erinnern, aber ich hatte zuerst ioBroker auf den Pi, dann wurde das alles zu knapp da und bin umgezogen auf Docker als Master und den Pi als Slave, eventuell habe ich keine reine Neuinstallation da gemacht oder zum testen noch was anderes zusätzlich, dann als Slave eingebunden und alles lief und never change a running System ... so gelassen.
                              Ist ja auch an meinem Touchscreen dran und das damals einzurichten war auch alles nicht simpel...
                              Hab da Leichen im Keller 😆
                              Vieleicht wirklich mal ein guter Anlass alles mal auf den aktuellsten Stand zu ziehen und den Raspberry neu aufzusetzen. Muss nur gerade den Pi alles zusammensuchen wegen dem Monitor, manchmal ist einiges Try&Error, weil man nicht das passende im Netz findet und am Ende des Tages freust Dich und bist froh, aber machst keine Doku für später.... (Kenn ich von der Arbeit, bin SPS-Programmierer... und Doku ist das langweiligste was es gibt, aber man ärgert sich später immer wieder, dass man es nicht sofort getan hat)
                                Was für ein Monitor?
                                ssh und go...
                                • tugsi
                                  ssh und go...
                                  ssh ist kein Problem, das war irgendwas mit der Auflösung und der Config für X... wie gesagt, kein Hexenwerk, muss aber nochmal die Dinge zusammensuchen und wenn ich damit anfange, sollte es auch in einem Rutsch gemacht werden, ansonsten habe ich hier eine Frau die sich a) fragt, warum ich wieder so lange am Laptop sitze und b) warum ihr doch mittlerweile geliebter Screen nix anzeigt
                                  Aber vielleicht kannst Du mir das beantworten, auch wenn der Thread hier gerade abdriftet.
                                  Muss ich den Slave erstmal beim Master abmelden, bevor ich den dann neu aufsetze oder?
                                    Was für ein X? Man lässt da kein X laufen.
                                    • tugsi
                                      Das mag Deine Sichtweise sein.
                                      Ich habe auf den Pi ein X laufen, weil das meinen Monitor als Visualisierung befeuert und da der zentral liegt, läuft darauf ein ioBroker im Slavemodus mit Zigbee und ZWave.
                                      Mir wäre neu, dass man auf einem Pi mit ioBroker nichts anderes laufen lassen darf, zumal wie gesagt es ein Slavesystem ist. Mir erstellt sich nicht der Sinn, warum ich extra für meine Visualisierung einen extra Rechner und somit Stromfresser hinsetzen muss.
                                        @tugsi @david-g
                                        leute .. nur weil ihr die Version 1.7.6 drauf habt heisst es nicht das diese aktuell ist..
                                        ich mach täglich ein update auf GIT der Version 1.7.6 ..
                                        also GIT Version installieren JETZT und nochmal schauen..bitte
                                        • tugsi
                                          @arteck Keep calm, ich habe das schon verstanden, ich komm doch selber aus der Programmierecke, auch wenn es Automatisierung ist, aber man macht nicht immer für kleine Zwischenschritte sofort eine Versionsänderung.
                                          Ich hatte Deine Bitte für eine Neuinstallation über GIT befolgt und hatte ja das gleiche Problem, deswegen kam meine Nachfrage, ob es so richtig war mit der Installation...
                                          Aber jetzt weiß ich ja, wo ich nachschauen muss, ob er es genommen hat, ich sehe ja Deine Versionsänderungen von herdsman und schaue bei Github welche Du in der package.json gepackt hast.
                                          Gerade upgedatet und nachgeschaut, das aktuelle von Dir drauf:
                                          ├─┬ iobroker.zigbee@1.7.6 (github:ioBroker/ioBroker.zigbee#4e4143cee5b8affa73b2b1e1ed6f9fb91201f078)
                                          │ ├─┬ zigbee-herdsman@0.14.51
                                          │ └─┬ zigbee-herdsman-converters@14.0.610
                                          │   └── zigbee-herdsman@0.14.51 deduped
                                          Aber Problem besteht immer noch:
                                          2022-09-01 08:06:06.531 - info: zigbee.0 (8913) Failed to check if update available for '0x540f57fffe3f5cde' (No image available for imageType '5634')
                                          2022-09-01 08:06:06.607 - info: zigbee.0 (8913) Failed to check if update available for '0x94deb8fffe4c0e07' (No image available for imageType '5634')
                                          2022-09-01 08:06:34.439 - info: zigbee.0 (8913) Failed to check if update available for '0x14b457fffeca020d' (Device didn't respond to OTA request)
                                          2022-09-01 08:06:34.446 - error: zigbee.0 (8913) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                          2022-09-01 08:06:34.447 - error: zigbee.0 (8913) unhandled promise rejection: Timeout - 63764 - 1 - null - 25 - 1 after 30000ms
                                          2022-09-01 08:06:34.449 - error: zigbee.0 (8913) Error: Timeout - 63764 - 1 - null - 25 - 1 after 30000ms
                                          2022-09-01 08:06:34.450 - error: zigbee.0 (8913) Timeout - 63764 - 1 - null - 25 - 1 after 30000ms
                                          2022-09-01 08:06:34.470 - info: zigbee.0 (8913) cleaned everything up...
                                          2022-09-01 08:06:34.819 - info: zigbee.0 (8913) Zigbee: disabling joining new devices.
                                          2022-09-01 08:06:34.846 - info: zigbee.0 (8913) Failed to check if update available for '0x14b457fffe91707c' (Device didn't respond to OTA request)
                                          2022-09-01 08:06:34.972 - info: zigbee.0 (8913) terminating
                                          2022-09-01 08:06:34.975 - warn: zigbee.0 (8913) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                          2022-09-01 08:06:36.082 - error: host.raspberrypi Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                          2022-09-01 08:06:36.084 - error: host.raspberrypi Caught by controller[1]: Error: Timeout - 63764 - 1 - null - 25 - 1 after 30000ms
                                          2022-09-01 08:06:36.091 - error: host.raspberrypi Caught by controller[1]: at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:64:35)
                                          2022-09-01 08:06:36.093 - error: host.raspberrypi Caught by controller[1]: at listOnTimeout (internal/timers.js:557:17)
                                          2022-09-01 08:06:36.093 - error: host.raspberrypi Caught by controller[1]: at processTimers (internal/timers.js:500:7)
                                          2022-09-01 08:06:36.095 - error: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                          2022-09-01 08:06:36.096 - info: host.raspberrypi Restart adapter system.adapter.zigbee.0 because enabled
                                          • Asgothian
                                            Asgothian Developer @tugsi last edited by
                                            @tugsi Um dem weiter nachzugehen musst du heraus finden welches Gerät betroffen ist.
                                            Dazu bitte die Geräte durch nutzen des Ein/Ausschalt Icons auf der Kachel deaktivieren bevor du den Firmware check machst. Deaktivierte Geräte werden im Firmwarecheck ignoriert.
                                            Zur Nutzung musst du die Geräte im Nachgang natürlich wieder aktivieren.
                                            A.
                                            absturz firmwareupdate zigbee
                                            1708
