    4. Update js-controller from @4.0.21 to @4.0.23 => 217
      Markus 1 last edited by
      Als begeisterter iobroker-User aber linux-dummy habe ich evtl. meine Installation zerschossen.
      Der Iobroker-Oberfäche (:8081) lässt sich nicht mehr aufrufen. VIS und alles andere am iobroker laufen noch.
      Hoffe ihr könnt mir helfen. Mal als Start-Infos von mir alles was mir so als linux-dummy einfällt:
      Die Fehler auf der Kommando-Zeile:
      pi@raspberrypi:/opt/iobroker $ sudo iobroker upgrade self
      Stopped Objects DB
      Stopped States DB
      NPM version: 8.15.0
      Installing iobroker.js-controller@4.0.23... (System call)
      host.raspberrypi Cannot install iobroker.js-controller@4.0.23: 217
      oder
      This upgrade of "vis-icontwo" will introduce the following changes:
      -> 0.89.0:
      new icons added
      -> 0.88.0:
      new icons added
      Would you like to upgrade vis-icontwo from @0.87.0 to @0.89.0 now? [(y)es, (n)o]: y
      Update vis-icontwo from @0.87.0 to @0.89.0
      NPM version: 8.15.0
      Installing iobroker.vis-icontwo@0.89.0... (System call)
      host.raspberrypi Cannot install iobroker.vis-icontwo@0.89.0: 217
      sudo update / upgrade ist aktuell gelaufen
      Fixer ist gelaufen:
      pi@raspberrypi:/opt/iobroker $ curl -sL https://iobroker.net/fix.sh | bash -
      library: loaded
      Library version=2022-06-15
      Welcome to the ioBroker installation fixer!
      Script version: 2022-06-03
      You might need to enter your password a couple of times.
      Installing prerequisites (1/3)
      OK:1 http://archive.raspberrypi.org/debian buster InRelease
      OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
      OK:3 https://deb.nodesource.com/node_16.x buster InRelease
      OK:4 https://phoscon.de/apt/deconz buster InRelease
      Installed gcc-c++
      Checking ioBroker user and directory permissions (2/3)
      Created /etc/sudoers.d/iobroker
      Checking autostart (3/3)
      Enabling autostart...
      Autostart enabled!
      Your installation was fixed successfully
      Run iobroker start to start ioBroker again!
      pi@raspberrypi:/opt/iobroker $ node -v
      v16.17.0
      pi@raspberrypi:/opt/iobroker $ sudo npm --version
      8.15.0
      pi@raspberrypi:/opt/iobroker $ cat /etc/os-release
      PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
      NAME="Raspbian GNU/Linux"
      VERSION_ID="10"
      VERSION="10 (buster)"
      VERSION_CODENAME=buster
      ID=raspbian
      ID_LIKE=debian
      HOME_URL="http://www.raspbian.org/"
      SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
      BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
      pi@raspberrypi:/opt/iobroker $ iobroker info
      Platform : linux
      os : linux
      Architecture : arm
      CPUs : 4
      Speed : 1500 MHz
      Model : ARMv7 Processor rev 3 (v7l)
      RAM : 3.7 GB
      System uptime : 00:21:40
      Node.js : v16.17.0
      time : 1661873890459
      timeOffset : -120
      adapters count : 431
      NPM : v8.15.0
      Disk size : 29.0 GiB
      Disk free : 19.0 GiB
      Wäre super, wenn ihr mir helfen könntet....
      Glasfaser Thomas Braun 2 Replies Last reply Reply Quote 0
      • Glasfaser
        Glasfaser @Markus 1 last edited by
        @markus-1 sagte in Update js-controller from @4.0.21 to @4.0.23 => 217:
        Dazu hier :
        https://forum.iobroker.net/topic/57337/fehler-25-bei-adapter-install-update-mit-npm8
        iobroker upgrade vis-icontwo --debug
        dann siehst du den Fehler .
        Wo hast du das her , kein sudo vor iobroker Befehle
        deswegen ein
        iobroker fix
        drüber ...
          Thomas Braun Most Active @Markus 1 last edited by
          @markus-1
          iobroker NIE mit sudo anpacken.
          iobroker stop
          for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
          iobroker fix
          iobroker update
          iobroker upgrade
          iobroker start
            @Thomas-Braun Vielen DANK ! Läuft wieder 😉
