    4. erst Fehler 25, jetzt einfach so keine Updates mehr
      Raabensohn last edited by
      Hi!
      gefühlt nach dem update auf Admin 6.2 (kann aber auch an was anderem gelegen haben, auf jeden Fall nach dem Urlaub) kann ich keine Adapter mehr updaten.
      Erst hatte ich den Fehler 25, dann hab ich das im Post Fehler 25 bei Adapter-Install/Update mit npm8 getan, jetzt kommt das:
      $ iobroker upgrade influxdb@3.1.7 --debug
      Update influxdb from @2.6.3 to @3.1.7
      NPM version: 8.15.0
      Installing iobroker.influxdb@3.1.7... (System call)
      npm WARN skipping integrity check for git dependency ssh://git@github.com/t4qjXH8N/ioBroker.google-sharedlocations.git
      npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
      npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now a built-in Node module. If you've depended on crypto, you should switch to the one that's built-in.
      npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
      npm WARN deprecated har-validator@5.1.5: this library is no longer supported
      npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
      npm WARN deprecated cryptiles@2.0.5: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
      npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
      npm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
      npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
      npm WARN deprecated multer@1.4.4: Multer 1.x is affected by CVE-2022-24434. This is fixed in v1.4.4-lts.1 which drops support for versions of Node.js before 6. Please upgrade to at least Node.js 6 and version 1.4.4-lts.1 of Multer. If you need support for older versions of Node.js, we are open to accepting patches that would fix the CVE on the main 1.x release line, whilst maintaining compatibility with Node.js 0.10.
      npm WARN deprecated boom@2.10.1: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
      npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
      npm WARN deprecated sntp@1.0.9: This module moved to @hapi/sntp. Please make sure to switch over as this distribution is no longer supported and may contain bugs and critical security issues.
      npm WARN deprecated multer@1.4.2: Multer 1.x is affected by CVE-2022-24434. This is fixed in v1.4.4-lts.1 which drops support for versions of Node.js before 6. Please upgrade to at least Node.js 6 and version 1.4.4-lts.1 of Multer. If you need support for older versions of Node.js, we are open to accepting patches that would fix the CVE on the main 1.x release line, whilst maintaining compatibility with Node.js 0.10.
      npm WARN deprecated querystring@0.2.0: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
      npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
      npm WARN deprecated uuid@3.3.2: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
      npm WARN deprecated hoek@2.16.3: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
      npm WARN deprecated request@2.81.0: request has been deprecated, see https://github.com/request/request/issues/3142
      npm WARN deprecated har-validator@4.2.1: this library is no longer supported
      npm WARN deprecated request@2.88.0: request has been deprecated, see https://github.com/request/request/issues/3142
      npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
      npm WARN deprecated bcrypt@3.0.6: versions < v5.0.0 do not handle NUL in passwords properly
      npm WARN deprecated node-pre-gyp@0.12.0: Please upgrade to @mapbox/node-pre-gyp: the non-scoped node-pre-gyp package is deprecated and only the @mapbox scoped package will recieve updates in the future
      npm WARN deprecated node-pre-gyp@0.6.39: Please upgrade to @mapbox/node-pre-gyp: the non-scoped node-pre-gyp package is deprecated and only the @mapbox scoped package will recieve updates in the future
      npm WARN deprecated @google/maps@1.1.3: Please use @googlemaps/google-maps-services-js instead.
      npm WARN deprecated hawk@3.1.3: This module moved to @hapi/hawk. Please make sure to switch over as this distribution is no longer supported and may contain bugs and critical security issues.
      npm WARN deprecated axios@0.27.0: Formdata complete broken, incorrect build size
      npm WARN deprecated tar@2.2.2: This version of tar is no longer supported, and will not receive security updates. Please upgrade asap.
      npm WARN deprecated grpc@1.24.11: This library will not receive further updates other than security fixes. We recommend using @grpc/grpc-js instead.
      npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/snowboy
      npm ERR! node-pre-gyp http 404 https://snowboy-release-node.s3-us-west-2.amazonaws.com/snowboy/v1.2.0/Release/snowboy-v1.2.0-node-v93-linux-x64.tar.gznpm ERR! node-pre-gyp ERR! Tried to download(404): https://snowboy-release-node.s3-us-west-2.amazonaws.com/snowboy/v1.2.0/Release/snowboy-v1.2.0-node-v93-linux-x64.tar.gz npm ERR! node-pre-gyp ERR! Pre-built binaries not found for snowboy@1.2.0 and node@16.17.0 (node-v93 ABI, glibc) (falling back to source compile with node-gyp) npm ERR! node-pre-gyp http 404 status code downloading tarball https://snowboy-release-node.s3-us-west-2.amazonaws.com/snowboy/v1.2.0/Release/snowboy-v1.2.0-node-v93-linux-x64.tar.gz npm ERR! node-pre-gyp ERR! Tried to download(undefined): https://snowboy-release-node.s3-us-west-2.amazonaws.com/snowboy/v1.2.0/Release/snowboy-v1.2.0-node-v93-linux-x64.tar.gz npm ERR! node-pre-gyp ERR! Pre-built binaries not found for snowboy@1.2.0 and node@16.17.0 (node-v93 ABI, glibc) (falling back to source compile with node-gyp) npm ERR! node-pre-gyp http Connection closed while downloading tarball file npm ERR! gyp info it worked if it ends with oknpm ERR! gyp info using node-gyp@9.0.0npm ERR! gyp info using node@16.17.0 | linux | x64npm ERR! gyp info ok npm ERR! gyp info it worked if it ends with oknpm ERR! gyp info using node-gyp@9.0.0npm ERR! gyp info using node@16.17.0 | linux | x64npm ERR! gyp info ok npm ERR! gyp info it worked if it ends with oknpm ERR! gyp info using node-gyp@9.0.0npm ERR! gyp info using node@16.17.0 | linux | x64npm ERR! gyp info find Python using Python version 3.9.2 found at "/usr/bin/python3"npm ERR! gyp info it worked if it ends with oknpm ERR! gyp info using node-gyp@9.0.0npm ERR! gyp info using node@16.17.0 | linux | x64npm ERR! gyp info find Python using Python version 3.9.2 found at "/usr/bin/python3"npm ERR! gyp info spawn /usr/bin/python3npm ERR! gyp info spawn args [npm ERR! gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',npm ERR! gyp info spawn args 'binding.gyp',npm ERR! gyp info spawn args '-f',npm ERR! gyp info spawn args 'make',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/opt/iobroker/node_modules/snowboy/build/config.gypi',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/opt/iobroker/.cache/node-gyp/16.17.0/include/node/common.gypi',npm ERR! gyp info spawn args '-Dlibrary=shared_library',npm ERR! gyp info spawn args '-Dvisibility=default',npm ERR! gyp info spawn args '-Dnode_root_dir=/opt/iobroker/.cache/node-gyp/16.17.0',npm ERR! gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',npm ERR! gyp info spawn args '-Dnode_lib_file=/opt/iobroker/.cache/node-gyp/16.17.0/<(target_arch)/node.lib',npm ERR! gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/snowboy',npm ERR! gyp info spawn args '-Dnode_engine=v8',npm ERR! gyp info spawn args '--depth=.',npm ERR! gyp info spawn args '--no-parallel',npm ERR! gyp info spawn args '--generator-output',npm ERR! gyp info spawn args 'build',npm ERR! gyp info spawn args '-Goutput_dir=.'npm ERR! gyp info spawn args ]npm ERR! gyp info spawn /usr/bin/python3npm ERR! gyp info spawn args [npm ERR! gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',npm ERR! gyp info spawn args 'binding.gyp',npm ERR! gyp info spawn args '-f',npm ERR! gyp info spawn args 'make',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/opt/iobroker/node_modules/snowboy/build/config.gypi',
      npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/opt/iobroker/.cache/node-gyp/16.17.0/include/node/common.gypi',npm ERR! gyp info spawn args '-Dlibrary=shared_library',npm ERR! gyp info spawn args '-Dvisibility=default',npm ERR! gyp info spawn args '-Dnode_root_dir=/opt/iobroker/.cache/node-gyp/16.17.0',npm ERR! gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',npm ERR! gyp info spawn args '-Dnode_lib_file=/opt/iobroker/.cache/node-gyp/16.17.0/<(target_arch)/node.lib',npm ERR! gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/snowboy',npm ERR! gyp info spawn args '-Dnode_engine=v8',npm ERR! gyp info spawn args '--depth=.',npm ERR! gyp info spawn args '--no-parallel',npm ERR! gyp info spawn args '--generator-output',npm ERR! gyp info spawn args 'build',npm ERR! gyp info spawn args '-Goutput_dir=.'npm ERR! gyp info spawn args ]npm ERR! gyp info ok npm ERR! gyp info ok npm ERR! gyp info it worked if it ends with oknpm ERR! gyp info using node-gyp@9.0.0npm ERR! gyp info using node@16.17.0 | linux | x64npm ERR! gyp info spawn makenpm ERR! gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]npm ERR! <command-line>: warning: "_GLIBCXX_USE_CXX11_ABI" redefinednpm ERR! <command-line>: note: this is the location of the previous definitionnpm ERR! gyp info it worked if it ends with oknpm ERR! gyp info using node-gyp@9.0.0npm ERR! gyp info using node@16.17.0 | linux | x64npm ERR! gyp info spawn makenpm ERR! gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]npm ERR! <command-line>: warning: "_GLIBCXX_USE_CXX11_ABI" redefinednpm ERR! <command-line>: note: this is the location of the previous definitionnpm ERR! ../swig/Node/snowboy.cc: In constructor ‘SnowboyDetect::SnowboyDetect(const string&, const string&)’:npm ERR! ../swig/Node/snowboy.cc:37:31: warning: catching polymorphic type ‘class std::runtime_error’ by value [-Wcatch-value=]npm ERR! 37 | } catch (std::runtime_error e) {npm ERR! | ^npm ERR! In file included from ../node_modules/nan/nan.h:60,npm ERR! from ../swig/Node/snowboy.cc:1:npm ERR! ../swig/Node/snowboy.cc: At global scope:npm ERR! /opt/iobroker/.cache/node-gyp/16.17.0/include/node/node.h:859:7: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]npm ERR! 859 | (node::addon_register_func) (regfunc), \npm ERR! | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~npm ERR! /opt/iobroker/.cache/node-gyp/16.17.0/include/node/node.h:893:3: note: in expansion of macro ‘NODE_MODULE_X’npm ERR! 893 | NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage)npm ERR! | ^~~~~~~~~~~~~npm ERR! ../swig/Node/snowboy.cc:173:1: note: in expansion of macro ‘NODE_MODULE’npm ERR! 173 | NODE_MODULE(SnowboyDetect, SnowboyDetect::Init)npm ERR! | ^~~~~~~~~~~npm ERR! ../swig/Node/snowboy.cc: In constructor ‘SnowboyDetect::SnowboyDetect(const string&, const string&)’:npm ERR! ../swig/Node/snowboy.cc:37:31: warning: catching polymorphic type ‘class std::runtime_error’ by value [-Wcatch-value=]npm ERR! 37 | } catch (std::runtime_error e) {npm ERR! | ^npm ERR! In file included from ../node_modules/nan/nan.h:60,npm ERR! from ../swig/Node/snowboy.cc:1:npm ERR! ../swig/Node/snowboy.cc: At global scope:npm ERR! /opt/iobroker/.cache/node-gyp/16.17.0/include/node/node.h:859:7: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]npm ERR! 859 | (node::addon_register_func) (regfunc), \npm ERR! | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~npm ERR! /opt/iobroker/.cache/node-gyp/16.17.0/include/node/node.h:893:3: note: in expansion of macro ‘NODE_MODULE_X’npm ERR! 893 | NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage)npm ERR! | ^~~~~~~~~~~~~npm ERR! ../swig/Node/snowboy.cc:173:1: note: in expansion of macro ‘NODE_MODULE’npm ERR! 173 | NODE_MODULE(SnowboyDetect, SnowboyDetect::Init)npm ERR! | ^~~~~~~~~~~npm ERR! /usr/bin/ld: cannot find -lcblasnpm ERR! collect2: error: ld returned 1 exit statusnpm ERR! make: *** [snowboy.target.mk:153: Release/obj.target/snowboy.node] Error 1npm ERR! gyp ERR! build error npm ERR! gyp ERR! stack Error: `make` failed with exit code: 2npm ERR! gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:513:28)npm ERR! gyp ERR! stack at Process.ChildProcess._handle.onexit (node:internal/child_process:291:12)npm ERR! gyp ERR! System Linux 4.15.0-189-genericnpm ERR! gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/snowboy/lib/node/binding/Release/node-v93-linux-x64/snowboy.node" "--module_name=snowboy" "--module_path=/opt/iobroker/node_modules/snowboy/lib/node/binding/Release/node-v93-linux-x64"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/snowboynpm ERR! gyp ERR! node -v v16.17.0npm ERR! gyp ERR! node-gyp -v v9.0.0npm ERR! gyp ERR! not ok npm ERR! node-pre-gyp ERR! build error npm ERR! node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/snowboy/lib/node/binding/Release/node-v93-linux-x64/snowboy.node --module_name=snowboy --module_path=/opt/iobroker/node_modules/snowboy/lib/node/binding/Release/node-v93-linux-x64' (1)npm ERR! node-pre-gyp ERR! stack at ChildProcess.<anonymous> (/opt/iobroker/node_modules/snowboy/node_modules/node-pre-gyp/lib/util/compile.js:83:29)npm ERR! node-pre-gyp ERR! stack at ChildProcess.emit (node:events:513:28)npm ERR! node-pre-gyp ERR! stack at maybeClose (node:internal/child_process:1093:16)
      npm ERR! node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (node:internal/child_process:302:5)npm ERR! node-pre-gyp ERR! System Linux 4.15.0-189-genericnpm ERR! node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/snowboy/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"npm ERR! node-pre-gyp ERR! cwd /opt/iobroker/node_modules/snowboynpm ERR! node-pre-gyp ERR! node -v v16.17.0npm ERR! node-pre-gyp ERR! node-pre-gyp -v v0.6.39npm ERR! node-pre-gyp ERR! not ok npm ERR! /usr/bin/ld: cannot find -lcblasnpm ERR! collect2: error: ld returned 1 exit statusnpm ERR! make: *** [snowboy.target.mk:153: Release/obj.target/snowboy.node] Error 1npm ERR! gyp ERR! build error npm ERR! gyp ERR! stack Error: `make` failed with exit code: 2npm ERR! gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:513:28)npm ERR! gyp ERR! stack at Process.ChildProcess._handle.onexit (node:internal/child_process:291:12)npm ERR! gyp ERR! System Linux 4.15.0-189-genericnpm ERR! gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/snowboy/lib/node/binding/Release/node-v93-linux-x64/snowboy.node" "--module_name=snowboy" "--module_path=/opt/iobroker/node_modules/snowboy/lib/node/binding/Release/node-v93-linux-x64"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/snowboynpm ERR! gyp ERR! node -v v16.17.0npm ERR! gyp ERR! node-gyp -v v9.0.0npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in:npm ERR! /opt/iobroker/.npm/_logs/2022-08-31T20_02_51_987Z-debug-0.log
      upload [15] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/custom_m.html custom_m.html text/html
      upload [14] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/de/translations.json i18n/de/translations.json application/json
      upload [0] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/words.js words.js application/javascript
      Process exited with code 0
      Egal, ob influxdb oder ein anderer.
      Leuder versteh ich nicht genau, was mein system von mir will. 😞
      Vielleicht kann ja jemand helfen.
      Wenn noch weitere Infos benötigt werden, versuche ich die natürlich zu bringen.
      System läuft auf einem NUC Docker.
      mikeal created this issue in request/request
      open Request’s Past, Present and Future #3142
      Qix- created this issue in visionmedia/debug
      closed ReDos Vulnerability Regression Visibility Notice #797
        Thomas Braun Most Active @Raabensohn last edited by Thomas Braun
        @raabensohn
        Da klemmt es bei dem Modul snowboy beim kompilieren.
        Was auch immer das ist und wo auch immer das herkommt.
        Jedenfalls wird das seit vier Jahren wohl nicht mehr gepflegt. Möglich daß es auf aktuellen System nicht mehr gebaut werden kann.
