    4. Zwave2 Adapter startet nicht mehr
      ross0865 last edited by
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Pi4
      Arbeitsspeicher: 4GB
      Festplattenart: SD-Karte
      Betriebssystem: raspbian buster
      Node-Version: 14.2.0
      Nodejs-Version: 14.2.0
      NPM-Version: 6.14.17
      Hallo aus dem Norden,
      seit einigen Tagen kann ich den Zwave2 Adapter nicht mehr starten. Im Protokoll von iobroker werden folgende Fehlermeldungen angezeigt:
      host.raspberrypi
      2022-09-02 16:28:45.367 info Restart adapter system.adapter.zwave2.0 because enabled
      host.raspberrypi
      2022-09-02 16:28:45.367 error instance system.adapter.zwave2.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.raspberrypi
      2022-09-02 16:28:45.367 error Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
      host.raspberrypi
      2022-09-02 16:28:45.367 error Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
      host.raspberrypi
      2022-09-02 16:28:45.366 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/@zwave-js/serial/src/MockSerialPort.ts:11:1)
      host.raspberrypi
      2022-09-02 16:28:45.366 error Caught by controller[0]: at require (internal/modules/cjs/helpers.js:101:18)
      host.raspberrypi
      2022-09-02 16:28:45.366 error Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
      host.raspberrypi
      2022-09-02 16:28:45.366 error Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
      host.raspberrypi
      2022-09-02 16:28:45.366 error Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
      host.raspberrypi
      2022-09-02 16:28:45.365 error Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
      host.raspberrypi
      2022-09-02 16:28:45.365 error Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
      host.raspberrypi
      2022-09-02 16:28:45.365 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/@zwave-js/serial/src/SerialPortMock.ts:16:37)
      host.raspberrypi
      2022-09-02 16:28:45.364 error Caught by controller[0]: TypeError: Class extends value undefined is not a constructor or null
      host.raspberrypi
      2022-09-02 16:28:43.854 info instance system.adapter.zwave2.0 started with pid 2860
      host.raspberrypi
      2022-09-02 16:28:13.662 info Restart adapter system.adapter.zwave2.0 because enabled
      Ich habe in der Zeit keine Veränderungen an dem System durchgeführt. Ein Update auf auf die Version 2.6 hat nicht geholfen. Der Adapter zeigt folgendes:
      Verbunden mit Host - nein
      Lebenszeichen - nein
      Verbunden mit Gerät oder Dienst - ja
      Hat jemand eine Idee?
        Thomas Braun Most Active @ross0865 last edited by
        @ross0865
        Bring das System zunächst auf nodejs 16, dann schauen wir weiter.
          ross0865 @Thomas Braun last edited by
          @thoma Mache ich morgen, vielen Dank!
            @ross0865
            nodejs 16 ist installiert.
            pi@raspberrypi:/opt/iobroker $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
            armv7l
            /usr/bin/nodejs
            /usr/bin/node
            /usr/bin/npm
            v16.17.0
            v16.17.0
            8.15.0
            pi
            /opt/iobroker
            Leider startet der Zwave2-Adapter immer noch nicht. Es erscheinen weiterhin folgende Fehlermeldungen:
            host.raspberrypi
            2022-09-03 10:24:45.509	info	Restart adapter system.adapter.zwave2.0 because enabled
            host.raspberrypi
            2022-09-03 10:24:45.509	error	instance system.adapter.zwave2.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            host.raspberrypi
            2022-09-03 10:24:45.509	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1180:10)
            host.raspberrypi
            2022-09-03 10:24:45.509	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1126:14)
            host.raspberrypi
            2022-09-03 10:24:45.509	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/@zwave-js/serial/src/MockSerialPort.ts:11:1)
            host.raspberrypi
            2022-09-03 10:24:45.508	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:102:18)
            host.raspberrypi
            2022-09-03 10:24:45.508	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1028:19)
            host.raspberrypi
            2022-09-03 10:24:45.508	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:839:12)
            host.raspberrypi
            2022-09-03 10:24:45.508	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1004:32)
            host.raspberrypi
            2022-09-03 10:24:45.508	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1180:10)
            host.raspberrypi
            2022-09-03 10:24:45.508	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1126:14)
            host.raspberrypi
            2022-09-03 10:24:45.507	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/@zwave-js/serial/src/SerialPortMock.ts:16:37)
            host.raspberrypi
            2022-09-03 10:24:45.507	error	Caught by controller[0]: TypeError: Class extends value undefined is not a constructor or null
            host.raspberrypi
            2022-09-03 10:24:43.889	info	instance system.adapter.zwave2.0 started with pid 23124
            host.raspberrypi
            2022-09-03 10:24:13.679	info	Restart adapter system.adapter.zwave2.0 because enabled
            Kann es sein, dass er keinen Zugriff mehr auf die serielle Schnittstelle zum Razberry hat? Kann ich das irgendwie prüfen?
              arteck Developer Most Active @ross0865 last edited by
              @ross0865 sagte in Zwave2 Adapter startet nicht mehr:
              SerialPortMock
              stop den adapter ma..zieh den stick mal ab und wieder rein und adapter neu starten
                ross0865 @arteck last edited by
                @arteck Ich habe das Aufsteckmodul für den Raspberry. Das Modul nutzt die GPIO Pins 1-10. Kann ich das Modul auch einfach wie ein USB-Stick im laufenden Betrieb abziehen?
                arteck R 2 Replies Last reply Reply Quote 0
                  arteck Developer Most Active @ross0865 last edited by arteck
                  @ross0865 ne..dann nimm kurz den pi vom strom.. also runnterfahren.. stromstecker raus..dann wieder hochfahren
                  da stimmt was mit dem serialport nicht
                    ross0865 @ross0865 last edited by
                    @ross0865 Hab ich gemacht. Unverändert, Adapter startet nicht....
                      @ross0865 Hier könnte mir evtl. jemand mit gleicher Hardware (raspberry pi 4 mit razberry2-Aufsteckmodul) weiterhelfen, der mir schreibt, was bei dem folgenden Befehl ausgegeben wird?
                      pi@raspberrypi:/opt/iobroker $ ls -la /dev/serial/by-id/
                      Ich bekomme keinen Hinweis auf eine serielle Schnittstelle.
                        Thomas Braun Most Active @ross0865 last edited by Thomas Braun
                        @ross0865
                        Ist die Serielle Schnittstelle auch in
                        sudu raspi-config
                        aktiviert worden?
                        Punkt 3 - I6 - NEIN - JA
                          @thomas-braun Ja, ich habe es nochmal geprüft. Ist korrekt.
                          Ich bin ratlos:
                          1. Bei einem alten funktionierenden Image hat es auch nicht geklappt. Gleiche Fehlermeldungen --> Hardware?
                          2. Neues Zwave-Modul getestet. Gleicher Fehler. ---> Fehler Hardware Raspberry Pi 4?
                            @ross0865 Ich habe das System neu aufgesetzt, jetzt startet der Adapter wieder. Also kein Hardware-Problem. Aber warum funktionierte das alte Image, was vorher fehlerfrei lief, auch nicht?
                            Jetzt beginnt die Arbeit mit InfluxDB. Grafana, MySQL usw. 😠 Vielen Dank für eure Bemühungen!
                              irgend ein alter schXXXX wirds da dazwischen gefunkt haben
                              Fred Freund 1 Reply Last reply Reply Quote 0
                              • Fred Freund
                                Fred Freund @arteck last edited by
                                Hallo , muss mich hier anhaengen:
                                nach dem update started der Adapter bei mir nicht mehr.
                                lsusb
                                Bus 002 Device 002: ID 174c:55aa ASMedia Technology Inc. Name: ASM1051E SATA 6Gb/s bridge, ASM1053E SATA 6Gb/s bridge, ASM1153 SATA 3Gb/s bridge, ASM1153E SATA 6Gb/s bridge
                                Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
                                Bus 001 Device 004: ID 0658:0200 Sigma Designs, Inc. Aeotec Z-Stick Gen5 (ZW090) - UZB
                                Bus 001 Device 003: ID 10c4:ea60 Cygnal Integrated Products, Inc. CP2102/CP2109 UART Bridge Controller [CP210x family]
                                Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
                                Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
                                usbreset gemacht
                                host.iobroker1
                                	2022-09-06 10:20:28.627	info	Restart adapter system.adapter.zwave2.0 because enabled
                                host.iobroker1
                                	2022-09-06 10:20:28.627	error	instance system.adapter.zwave2.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                host.iobroker1
                                	2022-09-06 10:20:28.627	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
                                host.iobroker1
                                	2022-09-06 10:20:28.626	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
                                host.iobroker1
                                	2022-09-06 10:20:28.626	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/@zwave-js/serial/src/MockSerialPort.ts:11:1)
                                host.iobroker1
                                	2022-09-06 10:20:28.626	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:101:18)
                                host.iobroker1
                                	2022-09-06 10:20:28.626	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
                                host.iobroker1
                                	2022-09-06 10:20:28.626	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
                                host.iobroker1
                                	2022-09-06 10:20:28.625	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
                                host.iobroker1
                                	2022-09-06 10:20:28.625	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
                                host.iobroker1
                                	2022-09-06 10:20:28.625	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
                                host.iobroker1
                                	2022-09-06 10:20:28.625	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/@zwave-js/serial/src/SerialPortMock.ts:16:37)
                                host.iobroker1
                                	2022-09-06 10:20:28.624	error	Caught by controller[0]: TypeError: Class extends value undefined is not a constructor or null
                                host.iobroker1
                                	2022-09-06 10:20:27.233	info	instance system.adapter.zwave2.0 started with pid 5584
                                host.iobroker1
                                	2022-09-06 10:19:57.038	info	Restart adapter system.adapter.zwave2.0 because enabled
                                und das wiederholt sich immer...
                                keine updates:
                                apt list --upgradable
                                Listing... Done
                                arteck AlCalzone 2 Replies Last reply Reply Quote 0
                                  arteck Developer Most Active @Fred Freund last edited by
                                  @fred-freund was hast du im USB sonst noch stecken ?
                                  • Fred Freund
                                    @arteck bootable usb sata, zigbee stick
                                      @fred-freund da hast du deine Probleme.. zeigmal die einstellung des adapter ?
                                      nochmal der kann den Port nicht öffnen ergo den zwave stick nicht finden
                                      • AlCalzone
                                        AlCalzone Developer @Fred Freund last edited by
                                        @fred-freund sagte in Zwave2 Adapter startet nicht mehr:
                                        Welche Version hast du denn installiert? Sieht mir nicht nach der stable-Version aus.
                                        • Fred Freund
                                          Fred Freund @AlCalzone last edited by Fred Freund
                                          @alcalzone
                                          • AlCalzone
                                            @fred-freund Seltsam. Du könntest mal auf 3.0.3 aus dem Latest/Beta-Repo upgraden. Da sollte das auf jeden Fall gehen.
                                            Es kann aber derzeit noch Probleme mit manchen Geräten geben. Fall das der Fall ist, bitte jeweils neu interviewen (nur interviewen, nicht neu anlernen).
                                            833
