    4. Z-Wave Adapter
    Z-Wave Adapter
      mimquadrat last edited by
      Hi Jungs,
      ich habe einen Fehler gemacht - nämlich Euch nicht zu fragen…
      Hab mir wegen diesem Artikel:
      http://siio.de/so-wird-dein-raspberry-p ... it-bridge/
      Diesen Z-Wave Adapter gekauft:
      http://www.amazon.de/Z-Wave-Me-RaZberry ... W1TZH00FE8
      und zum Testen diesen Stecker:
      http://www.amazon.de/Fibaro-Zwischenste ... y_60_img_y
      und erst dann hab ich mir gedacht...probier ich erstmal mit ioBroker....
      Bei der Installation des Z-Wave Adapters dann diese Fehler:
      ! make: *** [Release/obj.target/libopenzwave/deps/open-zwave/cpp/src/platform/unix/SerialControllerImpl.o] Error 1
      ! gyp
      ! ERR! build error
      ! gyp
      ! ERR!
      ! stack Error: make failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:267:23)
      ! gyp ERR! stack at ChildProcess.EventEmitter.emit (events.js:98:17)
      ! gyp ERR! stack at Process.ChildProcess._handle.onexit (child_process.js:789:12)
      ! gyp
      ! ERR! System Linux 3.18.11-v7+gyp ERR! command "node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      ! gyp ERR! cwd /opt/iobroker/node_modules/iobroker.zwave/node_modules/openzwave
      ! gyp ERR! node -v v0.10.22
      ! gyp ERR! node-gyp -v v0.11.0
      ! gyp
      ! ERR! not ok
      ! npm
      ! ERR! openzwave@0.0.33 install: node-gyp rebuildnpm ERR! Exit status 1
      ! npm ERR!
      ! npm ERR! Failed at the openzwave@0.0.33 install script.
      ! npm ERR! This is most likely a problem with the openzwave package,
      ! npm ERR! not with npm itself.
      ! npm ERR! Tell the author that this fails on your system:
      ! npm ERR! node-gyp rebuild
      ! npm ERR! You can get their info via:
      ! npm ERR! npm owner ls openzwave
      ! npm ERR! There is likely additional logging output above.
      ! npm ERR! System Linux 3.18.11-v7+
      ! npm ERR! command "/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.zwave" "–production" "--prefix" "/opt/iobroker"npm ERR! cwd /
      ! npm ERR! node -v v0.10.22
      ! npm ERR! npm -v 1.3.14npm ERR! code ELIFECYCLE
      ! npm ERR! npm ERR! Additional logging details can be found in:
      ! npm ERR! /npm-debug.log
      ! npm
      ! ERR! not ok code 0
      ! Cannot install iobroker.zwave: 1
      ! ERROR: process exited with code 25
      Mach ich was falsch? geht der Adapter überhaupt schon? Und kann ich diesen Zwischenstecker überhaupt einbinden?
      DANKE!
        Hab das jetzt mal mit Razberry
        http://razberry.z-wave.me
        durchgespielt.
        ioBroker ist deutlich mächtiger, aber das Interface ist sehr schön aufgebaut (auch die Installation war ultra einfach) - vielleicht können wir uns hier was abschauen.
          pix last edited by
          mein Rademacher Homepilot hat die Z- Wave Erweiterung 8430. Das ist ein USB Stick mit Z-Wave Technik. Vielleicht kann man darüber auch was machen. Werde mich mal einlesen.
          Pix
          Gesendet von meinem iPhone mit Tapatalk
          • ruhr70
            ruhr70 last edited by
            @mimquadrat:
            Hi Jungs,
            http://www.amazon.de/Fibaro-Zwischenste ... y_60_img_y `
            Hi mimquadrat,
            das klingt interessant. Gib mal bitte Info, wenn Du weitere Erkenntnisse hast.
            Der Artikel auf Siio ist ja recht aktuell. So schnell dürfte Amazon noch nicht geliefert haben? 😉
            Laut Beschreibung bietet das Z-Wave Modul eine JSON Schnittstelle.
            Da geht doch bestimmt was mit Node-red (oder auch direkt mit dem Javascript Adapter).
            Ich würde das auch gerne in Verbindung mit Node-red nutzen. Spannend.
            Michael
            • ruhr70
              @mimquadrat:
              durchgespielt.
              ioBroker ist deutlich mächtiger, aber das Interface ist sehr schön aufgebaut (auch die Installation war ultra einfach) - vielleicht können wir uns hier was abschauen. `
              Hast Du eigentlich den Zwischenstecker damit ansteuern können?
              Inkl. Leistungsmessung und Einstellung der Stufen für den LED-Ring?
                Hi Ruhr,
                du unterschätzt amazon Prime 😉 Samstag war alles da!
                Ich hab das ganze mal mit dem Zwischenstecker (inkl Leistungsmessung - mehr kann er aber nicht, keine Spannung, Frequenz oder Strom nur Leistung) ausprobiert. Das pairing, bei denen heißt das "inklusion", ging mit dem Fibaro Zwischenstecker, dem Razberry-Modul und der Software sehr einfach. Auch die einzelnen Kanäle sind schön dargestellt. Konnte den Stecker dann auch bedienen und die abgenommene Leistung ablesen. Steuern und Auswerten ging sehr schnell.
                Auf diese ganze Geschichte bin ich gekommen, weil das angeblich als HomeKit gateways genutzt werden kann. Soweit bin ich aber noch lang nicht.
                Was an Razberry gut ist (und was wir uns irgendwann mal abschauen können) das Design ist sehr schön und schlüssig.
                Was bei "denen" fehlt: es gibt kein VIS und kein Script.GUI (Steffen!).
                Der Fibaro-Stecker leuchtet je nach Leistungsaufnahme in unterschiedlichen Farben, allerdings flackert das bisschen viel wenn sich die Leistungen ändern.
                Er wirkt jedoch wertig, ist sehr kompakt und sieht auch gut aus - besser als die Homematic (die aber mehr können).
                Die installation war ULTRA einfach - das zWave Modul auf den Raspi, EIN Kommando auf einem laufenden Raspi mit Wheezy und das Ding läuft .
                OK - der Test hat mich jetzt 100 Euro gekostet 🙂 vielleicht kriegen wir das ganze hier ja auch noch zum laufen…darum ja mein ursprünglicher Post.
                • ruhr70
                  Guten Morgen mimquadrat,
                  vielen Dank für ausführliche Info!
                  Ich finde die Komponenten und das Thema Z-Wave an sich interessant. Werde mir das wohl auch mal zum spielen besorgen.
                  Interessant wird es, wenn man die Verbindung zu ioBroker hinbekommt und die Komponenten gescheit einbinden kann.
                  Ein zweites System neben dem bestehendem System (ioBroker) ist für mich uninteressant.
                  Von Homekit weiss ich noch gar nicht, was einen da erwarten wird. Im Juni zur WWDC gibt es wahrscheinlich ein paar Infos mehr.
                  Viele Grüße,
                  Michael
                  • ruhr70
                    Hi mimquadrat,
                    gibt es da schon etwas Neues?
                    Wenn ich mit dem Fritzadapter fertig bin, wollte ich mir das auch mal ansehen. Hast Du in Richtung ioBroker da etwas unternommen?
                    VG,
                    Michael
                    • V
                      versteckt last edited by
                      habe mir gerade 2 FGS-222 und einen ZME_UZB1 bestellt.
                      Klingen für mich sehr interessant, weil mein Haus auf Schalter und nicht auf Taster aufgebaut ist.
                      Sobald ich sie in Händen habe, werde ich mal den Z-Wave Adapter anwerfen und mal schauen wie weit ich komme.
                      LG Christian
                        hab da leider nichts mehr weiter unternommen…
                        • V
                          Habe den heutigen Abend damit verbracht, openzwave auf meinem Raspi zu installieren und mittels ozwcp ein Relais hinzuzufügen. Hat soweit funktioniert.
                          ioBroker kennt das auch schon, jetzt muss ich dann schauen, was alles seitens ioBroker nutzbar ist.
                          • ruhr70
                            hey, super! ich bin gespannt
                            • V
                              Hallo, so habe mich die letzten Tage ein wenig mit z-Wave auseinandergesetzt.
                              Folgendes habe ich mal probiert:
                              .) Raspberry Pi mit ZME_UZB1 USB Stick
                              .) FGBS001 Universal Binary Sensor
                              .) FGWPE Wall Plug
                              .) FGS222 Double Relay Switch 2x1.5kW
                              Dabei hat sich herausgestellt, das sowohl der FGBS001 und der FGS222 mehrere Objekte beinhalten, diese aber in ioBroker
                              nicht dargestellt werden. Habe ich mir angesehen, ist das Problem, das bei "zwave.on('value added'" nicht der richtige Name
                              kalkuliert wird. Habe ich soweit mal umgebaut, das die instance mit abgespeichert wird.
                              Nun kommt es aber zu dem Problem das lt. States die beiden Objekte unterschiedliche parents haben und in Objects auch nicht angezeigt werden.
                              Dafür bin ich bereits dabei, einen OpenZwave Configurator zu basteln, man will ja schliesslich nicht von anderen
                              Produkten abhängig sein…
                              Der langfristige Plan von mir ist, OpenZwave mittels eines Adapters (sowie hmm) konfigurieren zu können.
                              @Bluefox: Muss ich dir dann immer meine Änderungen mitteilen? Habe die HTML Seiten bei mir derzeit direkt im iobroker.zwave Adapter drinnen.
                                Es ist toll, dass du sich damit beschäftigst, weil die Adapter machen das Projekt.
                                Was meinst du mit Mitteilen?
                                Wenn du die Seiten in "admin"-Verzeichnis geändert hast, dann solltest du "iobroker upload zwave" schreiben, dann werden die sofort in "admin"-Oberfläche.
                                Wenn du mit Mitteilen Kode-Updates gemeint hast, dann solltest du direkt die "Pull-Request" auf github machen und ich werde dann mergen.
                                • V
                                  Nein, ganz falsch, damit kenne ich mich eh aus.
                                  Gemeint war der Upload in Github bzw. npm.js.
                                  Ok, dann baue ich mal fertig und gebe dir Bescheid.
                                  • ruhr70
                                    Daumen hoch!
                                    Was macht ein FGBS001?
                                      Du kannst nicht uploaden, weil adapter schon mit meinem Account initiert war. Aber ich verspreche, ich werde sehr operativ pull request mergen und "npm publish" machen. 😉
                                      • V
                                        Fibaro universalsensor mit Binäreingang. Zum testen recht praktisch, weil er viele Steuermöglichkeiten besitzt.
                                        • ruhr70
                                          OK, ich präzisiere… 😉
                                          Das es sich um einen Adapter mit Binäreingang handelt hatte ich nachgelesen. Aber was macht man damit?
                                          Was schaltet man denn z.B. am Binäreingang an?
                                            Hallo Versteckt!
                                            hast du deinen Adapter weiter bringen können?
                                            81.0k
                                            110
                                            28907
