    4. Sonoff-Adapter: Frage zu einer Warnung
    • qqolli
      qqolli last edited by
      bekomme vom Sonoff-Adapter für eine Komponente die u. g. Meldung. Wie kann ich das Secret anpassen/ändern?
      sonoff.0
      2022-09-07 04:55:52.863	warn	Old client Carport with secret 1662525906131_4270 sends publish. Ignore! Actual secret is 1662526547077_8383
      sonoff.0
      2022-09-07 04:55:52.861	warn	Old client Carport with secret 1662525906131_4270 sends publish. Ignore! Actual secret is 1662526547077_8383
      sonoff.0
      sonoff.0
      2022-09-07 04:55:52.861	warn	Old client Carport with secret 1662525906131_4270 sends pingreq. Ignore! Actual secret is 1662526547077_8383
      sonoff.0
      sonoff.0
      sonoff.0
      2022-09-07 04:55:47.078	info	Client [Carport] reconnected. Old secret 1662525906131_4270. New secret 1662526547077_8383
      sonoff.0
      2022-09-07 04:54:48.261	info	Client [Sonoff_3] reconnected. Old secret 1662470969672_8268. New secret 1662526488259_3125
      sonoff.0
      2022-09-07 04:45:06.131	info	Client [Carport] reconnected. Old secret 1662525561962_6919. New secret 1662525906131_4270
      sonoff.0
      2022-09-07 04:39:22.891	warn	Old client Carport with secret 1662525278104_6244 sends publish. Ignore! Actual secret is 1662525561962_6919
      sonoff.0
      2022-09-07 04:39:22.858	warn	Old client Carport with secret 1662525278104_6244 sends publish. Ignore! Actual secret is 1662525561962_6919
      sonoff.0
      sonoff.0
      2022-09-07 04:39:22.858	warn	Old client Carport with secret 1662525278104_6244 sends pingreq. Ignore! Actual secret is 1662525561962_6919
      sonoff.0
      sonoff.0
      sonoff.0
      2022-09-07 04:39:21.963	info	Client [Carport] reconnected. Old secret 1662525278104_6244. New secret 1662525561962_6919
      sonoff.0
      2022-09-07 04:35:34.308	warn	Old client Carport with secret 1662525059329_7760 sends publish. Ignore! Actual secret is 1662525278104_6244
      sonoff.0
      2022-09-07 04:35:34.305	warn	Old client Carport with secret 1662525059329_7760 sends publish. Ignore! Actual secret is 1662525278104_6244
      sonoff.0
      2022-09-07 04:35:34.304	warn	Old client Carport with secret 1662525059329_7760 sends publish. Ignore! Actual secret is 1662525278104_6244
      sonoff.0
      2022-09-07 04:35:34.304	warn	Old client Carport with secret 1662525059329_7760 sends pingreq. Ignore! Actual secret is 1662525278104_6244
      sonoff.0
      sonoff.0
      sonoff.0
      2022-09-07 04:34:38.104	info	Client [Carport] reconnected. Old secret 1662525059329_7760. New secret 1662525278104_6244
      liv-in-sky Segway 2 Replies Last reply Reply Quote 0
      • liv-in-sky
        liv-in-sky @qqolli last edited by liv-in-sky
        @qqolli
        so genau weiß ich auch nicht, was die meldung bedeutet aber versuche mal:
        den sonoff vom strom zu nehmen - ein wenig warten und wieder einstecken
        evtl vorher die sonoff instanz pausieren - den sonoff ausstecken, den ordner dieses sonoffs löschen (im object tab), instanz starten und dann den sonoff erst einstecken (wieder an den strom)
        qqolli 2 Replies Last reply Reply Quote 0
        • qqolli
          qqolli @liv-in-sky last edited by
          @liv-in-sky
          Danke für die schnelle Antwort. Habe ich gemacht. Mal sehen, ob es das war 🙂
          • qqolli
            @liv-in-sky
            Hallo nochmal,
            leider hat es doch nichts gebracht 😞
            sonoff.0
            2022-09-07 06:13:51.121	warn	Old client Carport with secret 1662530490519_7131 sends publish. Ignore! Actual secret is 1662531224737_9385
            sonoff.0
            2022-09-07 06:13:51.119	warn	Old client Carport with secret 1662530490519_7131 sends publish. Ignore! Actual secret is 1662531224737_9385
            sonoff.0
            sonoff.0
            2022-09-07 06:13:51.119	warn	Old client Carport with secret 1662530490519_7131 sends pingreq. Ignore! Actual secret is 1662531224737_9385
            sonoff.0
            sonoff.0
            • Ralla66
              Ralla66 Most Active @qqolli last edited by
              @qqolli
              Im Sonoff Adapter mal Carport löschen. Nach neustart vom Sonoff Adapter wird der Datenpunkt neu angelegt.
              qqolli 1 Reply Last reply Reply Quote 0
              • qqolli
                qqolli @Ralla66 last edited by
                @ralla66
                Genau das hatte ich ja nach Anweisung von @liv-in-sky gemacht 🙂
                Ralla66 liv-in-sky 3 Replies Last reply Reply Quote 0
                • Ralla66
                  Ralla66 Most Active @qqolli last edited by Ralla66
                  @qqolli
                  Dann wurde der DP nicht richtig gelöscht.
                  Lösche mal Carport im Adapter und benenne den Teilnehmer um in z.B. Carport0
                  • liv-in-sky
                    @qqolli
                    was hat dieser sonoff für eine tasmota version - evtl updaten
                    • liv-in-sky
                      @qqolli
                      da gibt es noch den thread - vielleicht hilft da was https://forum.iobroker.net/post/594581
                        RalfDr @liv-in-sky last edited by
                        Bei mir hat geholfen in der Tasmotakonsole "MqttKeepAlive 15" einzugeben, bei der Sonoff Zigbeebridge, weil da konnte ich keine ältere Tasmotaversion installieren, bei allen anderen habe ich keine höhere Tasmotaversion wie 6.4.2 mit Core 2.3 installiert, da ich bei den höheren Versionen auch das Problem hatte.
                        Gruß Ralf
                        • Segway
                          Segway @qqolli last edited by
                          @qqolli sagte in Sonoff-Adapter: Frage zu einer Warnung & @arteck :
                          Gibt es hier schon eine sagen wir mal offizielle Lösung um diese Meldungen wegzubekommen ?
                          manchmal kommen schon einige dieser meldungen ins Log - die bei mir auch zahlreich vorhanden sind.
                          sonoff.0
                          sonoff.0
                          sonoff.0
                          sonoff.0
                          sonoff.0
                          sonoff.0
                          sonoff.0
                          sonoff.0
                          sonoff.0
                          sonoff.0
                          sonoff.0
                          sonoff.0
                          sonoff.0
                          sonoff.0
                          sonoff.0
                          sonoff.0
                          sonoff.0
                          sonoff.0
                          sonoff.0
                          sonoff.0
                          sonoff.0
                          sonoff.0
                          sonoff.0
                          Agrippinenser 1 Reply Last reply Reply Quote 0
                          • Agrippinenser
                            Agrippinenser @Segway last edited by
                            @segway sagte in Sonoff-Adapter: Frage zu einer Warnung:
                            ich hatte heute Morgen, mal wieder, jede Menge dieser Meldungen im Log und habe mal das Forum | Github nach Infos abgegrast. Einige Vorschläge kamen dabei zusammen aber eine "offizielle Lösung :-)" habe ich nicht gefunden.
                            (https://github.com/ioBroker/ioBroker.sonoff/issues/273#issuecomment-1146838710)
                            Nachricht ignorieren bzw. Device überprüfen.
                            (https://github.com/ioBroker/ioBroker.sonoff/issues/71#issuecomment-544563395)
                            zwei Clients mit identischer ID
                            (https://forum.iobroker.net/topic/17351/sonoff-adapter-old-client-with-secret-send-pingreq/30?_=1707195614667)
                            Tasmota-Console: WifiPower 15
                            (https://forum.iobroker.net/topic/17351/sonoff-adapter-old-client-with-secret-send-pingreq/24?_=1707195614667)
                            Fritzbox Funkkanal wechseln
                            (https://forum.iobroker.net/topic/17351/sonoff-adapter-old-client-with-secret-send-pingreq/13?_=1707195614667)
                            Adapter Loglevel reduzieren
                            (https://forum.iobroker.net/topic/57770/sonoff-adapter-frage-zu-einer-warnung/10)
                            Console: MqttKeepAlive 15
                            (https://forum.iobroker.net/topic/57770/sonoff-adapter-frage-zu-einer-warnung/6)
                            Datenpunkt löschen und durch restart Sonoff-Adapter neu aufbauen.
                            Trrw created this issue in ioBroker/ioBroker.sonoff
                            closed Client [Bluetooth] reconnected. Old secret XXX. New secret XXX #273
                            wowik2018 created this issue in ioBroker/ioBroker.sonoff
                            closed Fehler In Log #71
                            sonoff-adapter
                            1071
