    4. JS-controller upgrade funktioniert nicht
      Darek668181 last edited by Homoran
      Hallo ich versuch seit paar Tagen verzweifelt den js-controller upzudaten bekomme aber immer nur Fehlermeldungen.
      Habe es mittels
      iobroker stop
      iobroker update
      iobroker upgrade self
      versucht klappt aber nicht. Kann wer von euch Profis mal draufscheuen, dass wäre mega nett.
      VG
      Darek
      C:\Program Files\iobroker\SmartHome>iobroker upgrade self
      Update js-controller from @2.1.0 to @4.0.23
      NPM version: 8.15.0
      npm install iobroker.js-controller@4.0.23 --unsafe-perm --loglevel error --prefix "C:/Program Files/iobroker/SmartHome" (System call)
      npm ERR! code 1
      npm ERR! path C:\Program Files\iobroker\SmartHome\node_modules\iobroker.js-controller
      npm ERR! command failed
      npm ERR! command C:\WINDOWS\system32\cmd.exe /d /s /c C:\Users\Server\AppData\Local\Temp\install-dca759ff.cmd
      npm ERR! C:\Program Files\iobroker\SmartHome\node_modules\standard-as-callback\built\index.js:6
      npm ERR!         throw e;
      npm ERR!         ^
      npm ERR!
      npm ERR! ReplyError: Error scan NOT SUPPORTED
      npm ERR!     at parseError (C:\Program Files\iobroker\SmartHome\node_modules\redis-parser\lib\parser.js:179:12)
      npm ERR!     at parseType (C:\Program Files\iobroker\SmartHome\node_modules\redis-parser\lib\parser.js:302:14)
      npm ERR! Emitted 'error' event on ScanStream instance at:
      npm ERR!     at C:\Program Files\iobroker\SmartHome\node_modules\ioredis\built\ScanStream.js:38:22
      npm ERR!     at tryCatcher (C:\Program Files\iobroker\SmartHome\node_modules\standard-as-callback\built\utils.js:12:23)
      npm ERR!     at C:\Program Files\iobroker\SmartHome\node_modules\standard-as-callback\built\index.js:33:51
      npm ERR!     at processTicksAndRejections (node:internal/process/task_queues:96:5) {
      npm ERR!   command: {
      npm ERR!     name: 'scan',
      npm ERR!     args: [ '0', 'MATCH', 'cfg.o.system.host.*', 'COUNT', '250' ]
      npm ERR!   }
      npm ERR! }
      npm ERR!     C:\Users\Server\AppData\Local\npm-cache\_logs\2022-09-08T15_10_25_487Z-debug-0.log
      Starting node restart.js
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Intel i3-5005U
      Arbeitsspeicher: 8GB
      Festplattenart: SD-Karte/SSD/HDD
      Betriebssystem: Windows 10 Pro x64
      Node-Version: 10.x.x
      Nodejs-Version: 10.x.x
      NPM-Version: 6.x.x
      Image genutzt: Ja/Nein
      Ort/Name der Imagedatei: Link
        Thomas Braun Most Active @Darek668181 last edited by
        @darek668181
        Da bist du ja fast Anwärter für den 'Schliemann des Jahres'-Preis.
          @thomas-braun sagte in JS-controller upgrade funktioniert nicht:
          @darek668181
          gut dass es kein Trojaner ist 😂
            @darek668181
            Hier mal reingeschaut?
            https://forum.iobroker.net/topic/52886/js-controller-4-0-x-jetzt-für-alle-user-im-stable
            Diese Urzeit-Installation muss anders angepackt werden und wird mit simplen upgrade self nicht funktionieren.
              Darek668181 @Thomas Braun last edited by
              Solang das System lief habe ich es nicht angefasst und wollte jetzt mal neu aufsetzten, da wurde mir halt die Version installiert.
              Den Link von dir schaue ich mir gleich mal an.
              Danke schon mal.
                @darek668181 sagte in JS-controller upgrade funktioniert nicht:
                Fehler. Pfleg Updates zeitnah ein. Dann läufst du weniger wahrscheinlich in solche Probleme.
                Vermutlich ist genau das der gescheitere Ansatz. Komplett neuaufsetzen.
