    4. Error: Cannot find module 'moment'
      lesiflo Most Active last edited by lesiflo
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Pi4
      Arbeitsspeicher: 4GB
      Festplattenart: USB Stick
      Betriebssystem: Ubuntu
      Node-Version: 16.17.x
      Nodejs-Version: 16.17.x
      NPM-Version: 8.15.x
      Installationsart: Skript
      Image genutzt: Ja
      Ort/Name der Imagedatei: Link
      ich wollte mir heute morgen den BLE Adapter installieren und hab auch noch ein Update des Admin Adapters gemacht. Jetzt startet iobroker nicht mehr, im syslog kommt ständig dieser Fehler hier:
      Sep 18 08:58:36 ioBroker-Pi systemd[1]: Started ioBroker Server.
      Sep 18 08:58:38 ioBroker-Pi bash[11332]: Error initializing logger: Error: Cannot find module 'moment'
      Sep 18 08:58:38 ioBroker-Pi bash[11332]: Require stack:
      Sep 18 08:58:38 ioBroker-Pi bash[11332]: - /opt/iobroker/node_modules/file-stream-rotator/FileStreamRotator.js
      Sep 18 08:58:38 ioBroker-Pi bash[11332]: - /opt/iobroker/node_modules/winston-daily-rotate-file/daily-rotate-file.js
      Sep 18 08:58:38 ioBroker-Pi bash[11332]: - /opt/iobroker/node_modules/winston-daily-rotate-file/index.js
      Sep 18 08:58:38 ioBroker-Pi bash[11332]: - /opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/logger.js
      Sep 18 08:58:38 ioBroker-Pi bash[11332]: - /opt/iobroker/node_modules/@iobroker/js-controller-common/index.js
      Sep 18 08:58:38 ioBroker-Pi bash[11332]: - /opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/lib/common/tools.js
      Sep 18 08:58:38 ioBroker-Pi bash[11332]: - /opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/index.js
      Sep 18 08:58:38 ioBroker-Pi bash[11332]: - /opt/iobroker/node_modules/iobroker.js-controller/main.js
      Sep 18 08:58:38 ioBroker-Pi bash[11332]: - /opt/iobroker/node_modules/iobroker.js-controller/controller.js
      Sep 18 08:58:38 ioBroker-Pi bash[11332]:     at Function.Module._resolveFilename (node:internal/modules/cjs/loader:956:15)
      Sep 18 08:58:38 ioBroker-Pi bash[11332]:     at Function.Module._load (node:internal/modules/cjs/loader:804:27)
      Sep 18 08:58:38 ioBroker-Pi bash[11332]:     at Module.require (node:internal/modules/cjs/loader:1028:19)
      Sep 18 08:58:38 ioBroker-Pi bash[11332]:     at require (node:internal/modules/cjs/helpers:102:18)
      Sep 18 08:58:38 ioBroker-Pi bash[11332]:     at Object.<anonymous> (/opt/iobroker/node_modules/file-stream-rotator/FileStreamRotator.js:15:14)
      Sep 18 08:58:38 ioBroker-Pi bash[11332]:     at Module._compile (node:internal/modules/cjs/loader:1126:14)
      Sep 18 08:58:38 ioBroker-Pi bash[11332]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1180:10)
      Sep 18 08:58:38 ioBroker-Pi bash[11332]:     at Module.load (node:internal/modules/cjs/loader:1004:32)
      Sep 18 08:58:38 ioBroker-Pi bash[11332]:     at Function.Module._load (node:internal/modules/cjs/loader:839:12)
      Sep 18 08:58:38 ioBroker-Pi systemd[1]: iobroker.service: Main process exited, code=exited, status=15/n/a
      Sep 18 08:58:38 ioBroker-Pi systemd[1]: iobroker.service: Failed with result 'exit-code'.
      Hab das schon versucht hier: sudo npm install moment
      Leider ohne Erfolg.
      Den "iobroker fix" habe ich auch schon lauafen lassen.
      Bei "iobroker logs --watch | uniq" kommt der gleiche Fehler wie oben: Uncaught Rejection: Error: Cannot find module 'moment'
        Thomas Braun Most Active @lesiflo last edited by Thomas Braun
        @lesiflo sagte in Error: Cannot find module 'moment':
        Leider ohne Erfolg.
        Kein Wunder. Macht man ja auch nicht so.
        iobroker stop
        iobroker fix
        iobroker status
        cd /opt/iobroker
        npm ls moment
        • mickym
          Das würde ich auch nicht machen. Wenn Du die moment Library in Deinen Blocklies oder JS verwenden willst, dann trag es in die JS Adapterkonfiguration ein und die Bibliothek installiert sich automatisch an der richtigen Stelle.
            lesiflo Most Active @Thomas Braun last edited by lesiflo
            @thomas-braun:
            Hi, hab ich gemacht. Kommt dann das hier:
            pi@ioBroker-Pi:/opt/iobroker $ iobroker status
            Server Configured backup period 120 is larger than the supported maximum of 35791 minutes. Defaulting to 120 minutes.
            iobroker is not running on this host.
            pi@ioBroker-Pi:/opt/iobroker $ npm ls moment
            iobroker.inst@2.0.3 /opt/iobroker
            ├─┬ iobroker.heatingcontrol@2.8.6
            │ └─┬ cron@1.8.2
            │   └─┬ moment-timezone@0.5.37
            │     └── moment@ deduped invalid: "^2.29.3" from node_modules/iobroker.iot, "^2.29.3" from node_modules/iobroker.synology, ">= 2.9.0" from node_modules/moment-timezone
            ├─┬ iobroker.iot@1.11.8
            │ └── moment@ invalid: "^2.29.3" from node_modules/iobroker.iot, "^2.29.3" from node_modules/iobroker.synology
            ├─┬ iobroker.js-controller@4.0.23
            │ └─┬ @iobroker/js-controller-common@4.0.23
            │   └─┬ winston-daily-rotate-file@4.7.1
            │     └─┬ file-stream-rotator@0.6.1
            │       └── moment@ deduped invalid: "^2.29.3" from node_modules/iobroker.iot, "^2.29.3" from node_modules/iobroker.synology, ">= 2.9.0" from node_modules/moment-timezone, "^2.29.1" from node_modules/file-stream-rotator
            └─┬ iobroker.synology@2.1.9
            npm ERR! code ELSPROBLEMS
            npm ERR! invalid: moment@ /opt/iobroker/node_modules/moment
            npm ERR!     /home/iobroker/.npm/_logs/2022-09-18T08_37_16_044Z-debug-0.log
              @lesiflo
              Bitte in CodeTags setzen. Oben auch.
                @lesiflo
                cd /opt/iobroker
                sudo -H -u iobroker npm install iobroker.js-controller
                  pi@ioBroker-Pi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
                  npm ERR! code ENOTEMPTY
                  npm ERR! syscall rename
                  npm ERR! path /opt/iobroker/node_modules/dropbox-v2-api
                  npm ERR! dest /opt/iobroker/node_modules/.dropbox-v2-api-TOHC73BD
                  npm ERR! errno -39
                  npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/dropbox-v2-api' -> '/opt/iobroker/node_modules/.dropbox-v2-api-TOHC73BD'
                  npm ERR!     /home/iobroker/.npm/_logs/2022-09-18T08_58_21_538Z-debug-0.log
                    @lesiflo
                    https://forum.iobroker.net/topic/57337/fehler-25-bei-adapter-install-update-mit-npm8
                      Läuft jetzt alles wieder. Vielen Dank für die Hilfe. 👍
                        @lesiflo
                        iobroker status
                        systemctl status iobroker
                        671
