    4. Modbus-Adapter lässt sich nicht installieren
      leo013 last edited by
      Ich versuch gerade den Modbus-Adapter zu installieren.
      Leider gelingt mir dies nicht:
      $ ./iobroker add modbus
      npm install iobroker.modbus --production --prefix "/opt/iobroker" (System call)
      node-pre-gyp
      ERR! Tried to download(404): https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v46-linux-arm.tar.gz node-pre-gyp ERR! Pre-built binaries not found for serialport@4.0.7 and node@4.8.2 (node-v46 ABI) (falling back to source compile with node-gyp)
      ! gyp
      WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/4.8.2"gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/node_modules/serialport/.node-gyp"
      ! make: *** No rule to make target '../.node-gyp/4.8.2/include/node/common.gypi', needed by 'Makefile'. Schluss.
      gyp
      ERR!
      build error
      gyp
      ERR! stack Error: make failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
      ! gyp ERR! stack at emitTwo (events.js:87:13)gyp ERR! stack at ChildProcess.emit (events.js:172:7)
      gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:211:12)
      ! gyp ERR! System Linux 4.4.4-v7+gyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/node_modules/serialport/build/Release/serialport.node" "--module_name=serialport" "--module_path=/opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/node_modules/serialport/build/Release"
      gyp ERR! cwd /opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/node_modules/serialport
      gyp ERR! node -v v4.8.2
      ! gyp ERR! node-gyp -v v3.4.0gyp ERR! not ok
      node-pre-gyp ERR! build error
      ! node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/nodejs /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/node_modules/serialport/build/Release/serialport.node --module_name=serialport --module_path=/opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/node_modules/serialport/build/Release' (1)node-pre-gyp ERR! stack at ChildProcess. <anonymous>(/opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/node_modules/serialport/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
      node-pre-gyp ERR! stack at emitTwo (events.js:87:13)
      node-pre-gyp ERR! stack at ChildProcess.emit (events.js:172:7)
      node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:862:16)
      node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:222:5)
      node-pre-gyp ERR! System Linux 4.4.4-v7+
      node-pre-gyp ERR! command "/usr/bin/nodejs" "/opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/node_modules/serialport/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
      node-pre-gyp ERR! cwd /opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/node_modules/serialport
      node-pre-gyp ERR! node -v v4.8.2
      node-pre-gyp ERR! node-pre-gyp -v v0.6.32
      node-pre-gyp ERR! not ok
      ! node-pre-gyp
      ERR!
      Tried to download: https://github.com/voodootikigod/node-serialport/releases/download/3.1.2/serialport-v3.1.2-node-v46-linux-arm.tar.gz node-pre-gyp
      ERR! Pre-built binaries not found for serialport@3.1.2 and node@4.8.2 (node-v46 ABI) (falling back to source compile with node-gyp)
      gyp WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/4.8.2"gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/iobroker.modbus/node_modules/serialport/.node-gyp"
      gyp
      ERR!
      build error
      gyp ERR! stack Error: make failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
      ! gyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/iobroker.modbus/node_modules/serialport/build/Release/serialport.node" "--module_name=serialport" "--module_path=/opt/iobroker/node_modules/iobroker.modbus/node_modules/serialport/build/Release"gyp ERR! cwd /opt/iobroker/node_modules/iobroker.modbus/node_modules/serialport
      gyp ERR!
      node -v v4.8.2gyp ERR! node-gyp -v v3.4.0
      gyp ERR! not ok
      ! node-pre-gyp ERR! build error
      node-pre-gyp
      ERR!
      stack Error: Failed to execute '/usr/bin/nodejs /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/iobroker.modbus/node_modules/serialport/build/Release/serialport.node --module_name=serialport --module_path=/opt/iobroker/node_modules/iobroker.modbus/node_modules/serialport/build/Release' (1)node-pre-gyp ERR! stack at ChildProcess. <anonymous>(/opt/iobroker/node_modules/iobroker.modbus/node_modules/serialport/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
      node-pre-gyp
      ERR! command "/usr/bin/nodejs" "/opt/iobroker/node_modules/iobroker.modbus/node_modules/serialport/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
      node-pre-gyp ERR! cwd /opt/iobroker/node_modules/iobroker.modbus/node_modules/serialportnode-pre-gyp ERR! node -v v4.8.2
      node-pre-gyp ERR! node-pre-gyp -v v0.6.28
      ! npm WARN optional dep failed, continuing serialport@3.1.2npm ERR! Linux 4.4.4-v7+
      npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.modbus" "--production" "--prefix" "/opt/iobroker"
      npm ERR! node v4.8.2
      npm ERR! npm v2.15.11
      npm ERR! code ELIFECYCLE
      ! npm ERR! serialport@4.0.7 install: node-pre-gyp install --fallback-to-build
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the serialport@4.0.7 install script 'node-pre-gyp install --fallback-to-build'.
      npm ERR! This is most likely a problem with the serialport package,
      npm ERR! not with npm itself.
      npm ERR! Tell the author that this fails on your system:
      npm ERR! node-pre-gyp install --fallback-to-build
      npm ERR! You can get information on how to open an issue for this project with:
      npm ERR! npm bugs serialport
      npm ERR! Or if that isn't available, you can get their info via:
      npm ERR!
      npm ERR! npm owner ls serialport
      npm ERR! There is likely additional logging output above.
      ! npm
      ERR!
      Please include the following file with any support request:npm ERR! /opt/npm-debug.log
      ! ERROR: host.raspberrypi Cannot install iobroker.modbus: 1
      ERROR: process exited with code 25</anonymous></anonymous>
      Hat jemnad eine Idee?
      Wolfgang
        ChristianF last edited by
        Ja, das Problem ist bekannt. Der Adapter ist noch nicht fertig, was die serielle Implementierung angeht. Du kannst versuchen, serialport 4.0.7 manuell zu installieren.
        Mehr Infos sonst http://forum.iobroker.net/viewtopic.php … lit=modbus
          Ist build-essential Lib Installiert?
          Mich stört diese Aussage:
          Versuch mal hier zu lesen:
          http://www.iobroker.net/docu/?page_id=5510&lang=de
            Habe alles nach der Anleitung durch gestestet, ohne Erfolg.
            Sowohl die Installation aus IOBROKER heraus, wie auch die Installation
            über die Console werden mit Fehlermeldungen abgebrochen.
