    2. English
    3. Visualization
    4. VIS - error (connect lost) when adding more than 300 widgets
      avhoboken last edited by
      For hours trying to figure what is going wrong here. Uninstalled and reinstalled VIS with all depencencies but the problem continues to exist:
      All works ok until I want to add a new widget that is nr w00300 or higher. Then connection gets lost and those widgets are not saved anymore. If I delete a few, than adding/modifying is no problem at all. What can be the cause of this?
      I'm using stable releases and all adapters are updated to the latest versions. And further:
      js controller: 4.0.23
      NPM: 8.15
      node.js: v16.17.0
      Raspberry pi 4, 8GB RAM , 32GB SD
      Hope someone can help me with this because I'm totally stuck at the moment 😞
      Thanks,
      Alex
