    2. English
    3. Scripting / Logic
    5. using iobroker.socket-client in a NodeJs project
      Taragorm last edited by
      Hi, I'm in the process of writng a NodeJs project that will talk to IOBroker.
      According to npm:
      @iobroker/socket-client@1.1.14
      when I try to create a connection, I get:
      ReferenceError: window is not defined
          at P:\Projects\Vue\logik\logik-backend\node_modules\@iobroker\socket-client\dist\cjs\Connection.js:123:7
          at new Promise (<anonymous>)
          at Connection.waitForSocketLib (P:\Projects\Vue\logik\logik-backend\node_modules\@iobroker\socket-client\dist\cjs\Connection.js:122:34)
          at new Connection (P:\Projects\Vue\logik\logik-backend\node_modules\@iobroker\socket-client\dist\cjs\Connection.js:87:10)
      As I understand it, this happens because "window" is not defined in NodeJS projects [I am by no means an expert JS programmer, btw]
      So.
      Is this the right library for the job?
      Does it in fact support Node?
      Am I missing some bit of initialisation to create a suitable "window" object under node.
      Hints appreciated.
      • AlCalzone
        AlCalzone Developer @Taragorm last edited by
        @taragorm That library is meant for the browser.
          Taragorm @AlCalzone last edited by
          @alcalzone That was my assumption.
          Is there a NodeJs version?
          I can always use the basic REST interface, but it wouldn't be my first choice here...
          Bluefox 1 Reply Last reply Reply Quote 0
            Bluefox @Taragorm last edited by
            @taragorm if you will use normal "ws" library for node.js, it will be possible to communicate with ioBroker. But ioBroker.rest-api is very advanced and supports long polling and web hooks for events.
            T 2 Replies Last reply Reply Quote 0
              Taragorm @Bluefox last edited by
              @bluefox So you suggest the REST interface? - I'll go with that then. The app will likely be running on the same machine as ioBroker, anyhow.
                @bluefox The API seems straightforwards enough; a couple of questions though:
                • How do I unsubscribe? - I didn't see a command for that
                • Can I do a "Bulk" subscribe - i.e. ask for a list of states?
                1.1k
