    4. Node-Red
    5. Node Red Fehler bei Aktualisierung auf 4.0.0
      frankyboy73 last edited by
      Hi, ich habe versucht auf die Node Red Version 4.0.0 zu aktualisieren. Die Aktualisierung wurde mit Fehler Code 25 beendet. Jetzt kann ich den Adapter nicht mehr neu starten bzw. versucht er dauerhaft neu zu starten und gibt folgende Meldungen raus.
      node-red.0
      2022-09-22 18:49:32.147	info	Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      host.raspberrypi
      2022-09-22 18:49:31.631	info	stopInstance timeout 5000 system.adapter.node-red.0 killing pid 3254
      node-red.0
      2022-09-22 18:49:30.526	info	node-red exited with 1
      node-red.0
      2022-09-22 18:49:30.513	warn	node:internal/modules/cjs/loader:959 throw err; ^Error: Cannot find module 'jsonfile/utils'Require stack:- /opt/iobroker/node_modules/node-red/node_modules/fs-extra/lib/json/output-json.js- /opt/iobroker/node_modules/node-red/node_modules/fs-extra/lib/json/index.js- /opt/iobroker/node_modules/node-red/node_modules/fs-extra/lib/index.js- /opt/iobroker/node_modules/node-red/red.js at Function.Module._resolveFilename (node:internal/modules/cjs/loader:956:15) at Function.Module._load (node:internal/modules/cjs/loader:804:27) at Module.require (node:internal/modules/cjs/loader:1028:19) at require (node:internal/modules/cjs/helpers:102:18) at Object.<anonymous> (/opt/iobroker/node_modules/node-red/node_modules/fs-extra/lib/json/output-json.js:3:23) at Module._compile (node:internal/modules/cjs/loader:1126:14) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1180:10) at Module.load (node:internal/modules/cjs/loader:1004:32) at Function.Module._load (node:internal/modules/cjs/loader:839:12) at Module.require (node:internal/modules/cjs/loader:1028:19) { code: 'MODULE_NOT_FOUND', requireStack: [ '/opt/iobroker/node_modules/node-red/node_modules/fs-extra/lib/json/output-json.js', '/opt/iobroker/node_modules/node-red/node_modules/fs-extra/lib/json/index.js', '/opt/iobroker/node_modules/node-red/node_modules/fs-extra/lib/index.js', '/opt/iobroker/node_modules/node-red/red.js' ]}
      node-red.0
      2022-09-22 18:49:29.466	info	Starting node-red: --max-old-space-size=1024 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
      host.raspberrypi
      2022-09-22 18:49:26.630	info	stopInstance system.adapter.node-red.0 (force=false, process=true)
      host.raspberrypi
      2022-09-22 18:49:26.628	info	"system.adapter.node-red.0" disabled
        Thomas Braun Most Active @frankyboy73 last edited by
        @frankyboy73
        https://forum.iobroker.net/topic/57337/fehler-25-bei-adapter-install-update-mit-npm8
        Dann
        iob update
          frankyboy73 @Thomas Braun last edited by
          Hi, habe ich gemacht, leider keine Änderung. Wenn ich zurück gehe auf NodeRed 3.3.1 funktioniert wieder alles, aber die 4.0.0 will nicht.
          $ iobroker upgrade node-red@4.0.0 --debug
          Update node-red from @3.3.1 to @4.0.0
          host.raspberrypi Adapter "system.adapter.node-red.0" is stopped.
          Installing iobroker.node-red@4.0.0... (System call)
          npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
          npm ERR! code ENOTEMPTY
          npm ERR! syscall rename
          host.raspberrypi Cannot install iobroker.node-red@4.0.0: 217
          ERROR: Process exited with code 25
          pi@raspberrypi:~ $ iob update
          Adapter    "admin"        : 6.2.22   , installed 6.2.22
          Adapter    "alexa2"       : 3.19.9   , installed 3.19.9
          Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
          Adapter    "deconz"       : 1.3.21   , installed 1.3.21
          Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
          Adapter    "flot"         : 1.11.0   , installed 1.11.0
          Adapter    "fritzdect"    : 2.2.3    , installed 2.2.5
          Adapter    "ical"         : 1.13.1   , installed 1.13.1
          Adapter    "info"         : 1.9.19   , installed 1.9.19
          Adapter    "iot"          : 1.11.9   , installed 1.11.9
          Controller "js-controller": 4.0.23   , installed 4.0.23
          Adapter    "mihome"       : 1.4.0    , installed 1.4.0
          Adapter    "node-red"     : 4.0.0    , installed 4.0.0
          Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
          Adapter    "socketio"     : 4.2.0    , installed 4.2.0
          Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
          Adapter    "sql"          : 2.1.8    , installed 2.1.8
          Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
          Adapter    "web"          : 4.3.0    , installed 4.3.0
          Adapter    "ws"           : 1.3.0    , installed 1.3.0
          mikeal created this issue in request/request
          open Request’s Past, Present and Future #3142
            @frankyboy73 sagte in Node Red Fehler bei Aktualisierung auf 4.0.0:
            Mach es über die richtige Konsole, nicht über die GUI.
              @thomas-braun Vielen Dank, jetzt scheint Alles wieder zu laufen. Beim ersten Versuch über das Konsole hatte ich noch ne Meldung das ich nen Ordner umbenennen sollte. Habe dann nochmals in /opt/iobroker/node_modules den Einzeiler drüber laufen lassen, danach ging das Update. Vielen Dank.
              Sollte ich in Zukunft immer Updates über die Konsole machen und nicht über die GUI?
                Ich mach das bei meinen Systemen ausschließlich über das Terminal. Das lügt dich nicht an, das schluckt keine Meldungen, das ist schneller, das ist genauer, das tut was es tun soll. Ich mag die Konsole.
                  @thomas-braun Stimmt, ohne hätte ich die Meldung auch nicht gesehen, dann werde ich das in Zukunft auch so machen, danke nochmal.
