    4. InfluxDB läuft nicht richtig
      Has3nb3inMH last edited by
      bei mir ist der Wurm drin und ich komme nicht weiter.
      Nach dem Start des influx dienst ist folgendes passiert:
      root@Datenbanken:~# sudo systemctl start influxdb
      Job for influxdb.service failed because a timeout was exceeded.
      See "systemctl status influxdb.service" and "journalctl -xe" for details.
      root@Datenbanken:~# systemctl status influxdb.service
      * influxdb.service - InfluxDB is an open-source, distributed, time series datab>
           Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor pres>
           Active: activating (start) since Sat 2022-09-24 07:50:32 UTC; 17s ago
             Docs: https://docs.influxdata.com/influxdb/
      Cntrl PID: 659 (influxd-systemd)
            Tasks: 9 (limit: 8984)
           Memory: 323.3M
           CGroup: /system.slice/influxdb.service
                   |-659 /bin/bash -e /usr/lib/influxdb/scripts/influxd-systemd-start>
                   |-660 /usr/bin/influxd -config /etc/influxdb/influxdb.conf
                   `-738 /bin/bash -e /usr/lib/influxdb/scripts/influxd-systemd-start>
      Sep 24 07:50:49 Datenbanken influxd-systemd-start.sh[660]: ts=2022-09-24T07:50:>
      lines 1-23...skipping...
      * influxdb.service - InfluxDB is an open-source, distributed, time series database
           Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset: enabled)
           Memory: 323.3M
                   |-659 /bin/bash -e /usr/lib/influxdb/scripts/influxd-systemd-start.sh
                   `-738 /bin/bash -e /usr/lib/influxdb/scripts/influxd-systemd-start.sh
      Sep 24 07:50:49 Datenbanken influxd-systemd-start.sh[660]: ts=2022-09-24T07:50:49.803931Z lvl=info msg="Opened shard" log_id=0d7cTYgG000 service=store trace_id=0d7cTZBl000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/dat>
      Sep 24 07:50:49 Datenbanken influxd-systemd-start.sh[660]: ts=2022-09-24T07:50:49.806410Z lvl=info msg="Opened file" log_id=0d7cTYgG000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/Energie/global/1979/000000001-000000001.ts>
      Sep 24 07:50:49 Datenbanken influxd-systemd-start.sh[660]: ts=2022-09-24T07:50:49.817509Z lvl=info msg="Opened shard" log_id=0d7cTYgG000 service=store trace_id=0d7cTZBl000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/dat>
      Sep 24 07:50:49 Datenbanken influxd-systemd-start.sh[660]: ts=2022-09-24T07:50:49.820308Z lvl=info msg="Opened file" log_id=0d7cTYgG000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/Energie/global/1980/000000001-000000001.ts>
      Sep 24 07:50:49 Datenbanken influxd-systemd-start.sh[660]: ts=2022-09-24T07:50:49.842413Z lvl=info msg="Opened shard" log_id=0d7cTYgG000 service=store trace_id=0d7cTZBl000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/dat>
      Sep 24 07:50:49 Datenbanken influxd-systemd-start.sh[660]: ts=2022-09-24T07:50:49.845186Z lvl=info msg="Opened file" log_id=0d7cTYgG000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/Energie/global/1981/000000001-000000001.ts>
      Sep 24 07:50:49 Datenbanken influxd-systemd-start.sh[660]: ts=2022-09-24T07:50:49.863748Z lvl=info msg="Opened shard" log_id=0d7cTYgG000 service=store trace_id=0d7cTZBl000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/dat>
      Sep 24 07:50:49 Datenbanken influxd-systemd-start.sh[660]: ts=2022-09-24T07:50:49.866826Z lvl=info msg="Opened file" log_id=0d7cTYgG000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/Energie/global/1982/000000001-000000001.ts>
      Sep 24 07:50:49 Datenbanken influxd-systemd-start.sh[660]: ts=2022-09-24T07:50:49.884734Z lvl=info msg="Opened shard" log_id=0d7cTYgG000 service=store trace_id=0d7cTZBl000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/dat>
      Sep 24 07:50:49 Datenbanken influxd-systemd-start.sh[660]: ts=2022-09-24T07:50:49.888390Z lvl=info msg="Opened file" log_id=0d7cTYgG000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/Energie/global/1983/000000001-000000001.ts>
      Sep 24 07:50:49 Datenbanken influxd-systemd-start.sh[660]: ts=2022-09-24T07:50:49.902821Z lvl=info msg="Opened shard" log_id=0d7cTYgG000 service=store trace_id=0d7cTZBl000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/dat>
      Sep 24 07:50:49 Datenbanken influxd-systemd-start.sh[660]: ts=2022-09-24T07:50:49.906182Z lvl=info msg="Opened file" log_id=0d7cTYgG000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/Energie/global/1984/000000001-000000001.ts>
      Sep 24 07:50:49 Datenbanken influxd-systemd-start.sh[659]: InfluxDB API unavailable after 18 attempts...
      Sep 24 07:50:49 Datenbanken influxd-systemd-start.sh[660]: ts=2022-09-24T07:50:49.921470Z lvl=info msg="Opened shard" log_id=0d7cTYgG000 service=store trace_id=0d7cTZBl000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/dat>
      Sep 24 07:50:49 Datenbanken influxd-systemd-start.sh[660]: ts=2022-09-24T07:50:49.925737Z lvl=info msg="Opened file" log_id=0d7cTYgG000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/Energie/global/1985/000000001-000000001.ts>
      Seit dem Start ist die Systemlast sehr hoch. Da läuft nur Influx und Grafana.
      Ich bin schon drauf und dran die Maschine einfach neu einzurichten.
        Thomas Braun Most Active @Has3nb3inMH last edited by
        @has3nb3inmh
        Stimmt, da ist schon im login prompt der Wurm drin:
        Macht gar keinen Sinn.
          Has3nb3inMH @Thomas Braun last edited by
          @thomas-braun ja, das stimmt. Aber das sollte beim Ausführen des Befehls keine Auswirkung haben
            @has3nb3inmh
            Da nicht. Aber grundsätzlich bei anderen Konstellationen.
            Meld dich gar nicht erst als root an!
              @thomas-braun 👍 ich hoffe ich denk nächstes Mal dran
                @has3nb3inmh
                Was gibt es eigentlich da zu 'dran denken'?
                root Login ist verboten! Und in richtigen Installationen auch nur über Umwege möglich. Als Standarduser einloggen. Immer.
