    4. ModBus Error FC5 write request outside coils boundaries
      hennerich last edited by
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Pi4
      Arbeitsspeicher: 4GB
      Festplattenart: SD-Karte
      Betriebssystem: Raspbian
      Node-Version: v14.20.0
      Nodejs-Version: v14.20.0
      NPM-Version: 6.14.17
      Installationsart: Manuell
      Image genutzt: Nein
      in unregelmäßigen Abständen tauchen im Log beim ModBus folgende Fehler auf:
      FC5 write request outside coils boundaries: from 25, value false. Expected max address: 24
      Das Debug Log schreibt:
      022-09-29 19:53:39.151 - info: host.raspberrypi "system.adapter.modbus.0" enabled
      2022-09-29 19:53:39.444 - info: host.raspberrypi instance system.adapter.modbus.0 started with pid 27858
      2022-09-29 19:53:41.115 - debug: modbus.0 (27858) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2022-09-29 19:53:41.193 - debug: modbus.0 (27858) Objects client ready ... initialize now
      2022-09-29 19:53:41.196 - debug: modbus.0 (27858) Objects create System PubSub Client
      2022-09-29 19:53:41.197 - debug: modbus.0 (27858) Objects create User PubSub Client
      2022-09-29 19:53:41.272 - debug: modbus.0 (27858) Objects client initialize lua scripts
      2022-09-29 19:53:41.279 - debug: modbus.0 (27858) Objects connected to redis: 127.0.0.1:9001
      2022-09-29 19:53:41.333 - debug: modbus.0 (27858) Redis States: Use Redis connection: 127.0.0.1:9000
      2022-09-29 19:53:41.364 - debug: modbus.0 (27858) States create System PubSub Client
      2022-09-29 19:53:41.366 - debug: modbus.0 (27858) States create User PubSub Client
      2022-09-29 19:53:41.416 - debug: modbus.0 (27858) States connected to redis: 127.0.0.1:9000
      2022-09-29 19:53:41.602 - debug: modbus.0 (27858) Plugin sentry Initialize Plugin (enabled=true)
      2022-09-29 19:53:41.984 - info: modbus.0 (27858) starting. Version 5.0.8 in /opt/iobroker/node_modules/iobroker.modbus, node: v14.20.0, js-controller: 4.0.23
      2022-09-29 19:53:42.260 - debug: modbus.0 (27858) Iterate coils coils: 2 = coils.18_PumpeSol
      2022-09-29 19:53:42.260 - debug: modbus.0 (27858) Iterate coils coils: 3 = coils.19_VentilSol1
      2022-09-29 19:53:42.261 - debug: modbus.0 (27858) Iterate coils coils: 4 = coils.20_VentilSol2
      2022-09-29 19:53:42.261 - debug: modbus.0 (27858) Iterate coils coils: 5 = coils.21_LadepumpeSP
      2022-09-29 19:53:42.262 - debug: modbus.0 (27858) Iterate coils coils: 6 = coils.22_AnfBrenner
      2022-09-29 19:53:42.263 - debug: modbus.0 (27858) Iterate holdingRegs holdingRegisters: 0 = holdingRegisters.1_Temp_Koll1
      2022-09-29 19:53:42.263 - debug: modbus.0 (27858) Iterate holdingRegs holdingRegisters: 1 = holdingRegisters.2_Temp_Koll2
      2022-09-29 19:53:42.264 - debug: modbus.0 (27858) Iterate holdingRegs holdingRegisters: 2 = holdingRegisters.3_SolarVL
      2022-09-29 19:53:42.264 - debug: modbus.0 (27858) Iterate holdingRegs holdingRegisters: 3 = holdingRegisters.4_SolarRL
      2022-09-29 19:53:42.265 - debug: modbus.0 (27858) Iterate holdingRegs holdingRegisters: 4 = holdingRegisters.5_TempAussen
      2022-09-29 19:53:42.265 - debug: modbus.0 (27858) Iterate holdingRegs holdingRegisters: 5 = holdingRegisters.6_TempPufferO
      2022-09-29 19:53:42.265 - debug: modbus.0 (27858) Iterate holdingRegs holdingRegisters: 6 = holdingRegisters.7_TempHeizVL
      2022-09-29 19:53:42.266 - debug: modbus.0 (27858) Iterate holdingRegs holdingRegisters: 7 = holdingRegisters.8_BetriebsHBrenner
      2022-09-29 19:53:42.266 - debug: modbus.0 (27858) Iterate holdingRegs holdingRegisters: 8 = holdingRegisters.9_StartsBrenner
      2022-09-29 19:53:42.267 - debug: modbus.0 (27858) Iterate holdingRegs holdingRegisters: 9 = holdingRegisters.10_PufferVL
      2022-09-29 19:53:42.267 - debug: modbus.0 (27858) Iterate holdingRegs holdingRegisters: 10 = holdingRegisters.11_PufferRL
      2022-09-29 19:53:42.267 - debug: modbus.0 (27858) Iterate holdingRegs holdingRegisters: 11 = holdingRegisters.12_TempBoilerO
      2022-09-29 19:53:42.268 - debug: modbus.0 (27858) Iterate holdingRegs holdingRegisters: 12 = holdingRegisters.13_RaumTemp
      2022-09-29 19:53:42.268 - debug: modbus.0 (27858) Iterate holdingRegs holdingRegisters: 13 = holdingRegisters.14_FeuchteInnen
      2022-09-29 19:53:42.268 - debug: modbus.0 (27858) Iterate holdingRegs holdingRegisters: 14 = holdingRegisters.15_FeuchteAussen
      2022-09-29 19:53:42.269 - debug: modbus.0 (27858) Iterate holdingRegs holdingRegisters: 15 = holdingRegisters.16_PVEin
      2022-09-29 19:53:42.270 - debug: modbus.0 (27858) Initialize Objects for disInputs: []
      2022-09-29 19:53:42.270 - debug: modbus.0 (27858) Initialize Objects for coils: [{"_address":18,"name":"PumpeSol","description":"Pumpe Solar","role":"state","room":"","poll":true,"wp":false,"cw":false,"address":18,"factor":1,"offset":0,"type":"uint16be","len":1,"deviceId":10,"id":"coils.18_PumpeSol"},{"_address":19,"name":"VentilSol1","description":"Solarventil Osten","role":"state","room":"","poll":true,"wp":false,"cw":false,"type":"uint16be","len":1,"factor":1,"offset":0,"address":19,"deviceId":10,"id":"coils.19_VentilSol1"},{"_address":20,"name":"VentilSol2","description":"Solarventil Westen","role":"state","room":"","poll":true,"wp":false,"cw":false,"type":"uint16be","len":1,"factor":1,"offset":0,"address":20,"deviceId":10,"id":"coils.20_VentilSol2"},{"_address":21,"name":"LadepumpeSP","description":"Ladepumpe Speicher","role":"state","room":"","poll":true,"wp":false,"cw":false,"type":"uint16be","len":1,"factor":1,"offset":0,"address":21,"deviceId":10,"id":"coils.21_LadepumpeSP"},{"_address":22,"name":"AnfBrenner","description":"Brenner aktiv","role":"state","room":"","poll":true,"wp":false,"cw":false,"type":"uint16be","len":1,"factor":1,"offset":0,"address":22,"deviceId":10,"id":"coils.22_AnfBrenner"}]
      2022-09-29 19:53:42.271 - debug: modbus.0 (27858) Add coils.18_PumpeSol: {"_id":"coils.18_PumpeSol","type":"state","common":{"name":"Pumpe Solar","role":"state","type":"boolean","read":true,"write":true,"def":false},"native":{"regType":"coils","address":18,"deviceId":10,"poll":true,"wp":false}}
      2022-09-29 19:53:42.272 - debug: modbus.0 (27858) Add coils.19_VentilSol1: {"_id":"coils.19_VentilSol1","type":"state","common":{"name":"Solarventil Osten","role":"state","type":"boolean","read":true,"write":true,"def":false},"native":{"regType":"coils","address":19,"deviceId":10,"poll":true,"wp":false}}
      2022-09-29 19:53:42.272 - debug: modbus.0 (27858) Add coils.20_VentilSol2: {"_id":"coils.20_VentilSol2","type":"state","common":{"name":"Solarventil Westen","role":"state","type":"boolean","read":true,"write":true,"def":false},"native":{"regType":"coils","address":20,"deviceId":10,"poll":true,"wp":false}}
      2022-09-29 19:53:42.273 - debug: modbus.0 (27858) Add coils.21_LadepumpeSP: {"_id":"coils.21_LadepumpeSP","type":"state","common":{"name":"Ladepumpe Speicher","role":"state","type":"boolean","read":true,"write":true,"def":false},"native":{"regType":"coils","address":21,"deviceId":10,"poll":true,"wp":false}}
      2022-09-29 19:53:42.274 - debug: modbus.0 (27858) Add coils.22_AnfBrenner: {"_id":"coils.22_AnfBrenner","type":"state","common":{"name":"Brenner aktiv","role":"state","type":"boolean","read":true,"write":true,"def":false},"native":{"regType":"coils","address":22,"deviceId":10,"poll":true,"wp":false}}
      2022-09-29 19:53:42.274 - debug: modbus.0 (27858) Initialize Objects for inputRegs: []
      2022-09-29 19:53:42.275 - debug: modbus.0 (27858) Initialize Objects for holdingRegs: [{"_address":1,"name":"Temp_Koll1","description":"Temperatur Kollektor Osten","unit":"°C","type":"int16be","len":1,"factor":10,"offset":0,"role":"value.temperature","room":"","poll":true,"wp":false,"address":1,"deviceId":10,"id":"holdingRegisters.1_Temp_Koll1"},{"_address":2,"name":"Temp_Koll2","description":"Temperatur Kollektor Westen","unit":"°C","type":"int16be","len":1,"factor":10,"offset":0,"role":"value.temperature","room":"","poll":true,"wp":false,"address":2,"deviceId":10,"id":"holdingRegisters.2_Temp_Koll2"},{"_address":3,"name":"SolarVL","description":"Temperatur Solar Vorlauf","unit":"°C","type":"int16be","len":1,"factor":10,"offset":0,"role":"value.temperature","room":"","poll":true,"wp":false,"address":3,"deviceId":10,"id":"holdingRegisters.3_SolarVL"},{"_address":4,"name":"SolarRL","description":"Temperatur Solar Rücklauf","unit":"°C","type":"int16be","len":1,"factor":10,"offset":0,"role":"value.temperature","room":"","poll":true,"wp":false,"address":4,"deviceId":10,"id":"holdingRegisters.4_SolarRL"},{"_address":5,"name":"TempAussen","description":"Außentemperatur","unit":"°C","type":"int16be","len":1,"factor":10,"offset":0,"role":"value.temperature","room":"","poll":true,"wp":false,"address":5,"deviceId":10,"id":"holdingRegisters.5_TempAussen"},{"_address":6,"name":"TempPufferO","description":"Temperatur Pufferspeicher Oben","unit":"°C","type":"int16be","len":1,"factor":10,"offset":0,"role":"value.temperature","room":"","poll":true,"wp":false,"address":6,"deviceId":10,"id":"holdingRegisters.6_TempPufferO"},{"_address":7,"name":"TempHeizVL","description":"Temperatur Heizung Vorlauf","unit":"°C","type":"int16be","len":1,"factor":10,"offset":0,"role":"value.temperature","room":"","poll":true,"wp":false,"address":7,"deviceId":10,"id":"holdingRegisters.7_TempHeizVL"},{"_address":8,"name":"BetriebsHBrenner","description":"Betriebsstunden Brenner","unit":"h","type":"int16be","len":1,"factor":1,"offset":0,"role":"value","room":"","poll":true,"wp":false,"address":8,"deviceId":10,"id":"holdingRegisters.8_BetriebsHBrenner"},{"_address":9,"name":"StartsBrenner","description":"Starts Brenner","unit":"","type":"int16be","len":1,"factor":1,"offset":0,"role":"value","room":"","poll":true,"wp":false,"address":9,"deviceId":10,"id":"holdingRegisters.9_StartsBrenner"},{"_address":10,"name":"PufferVL","description":"Temperatur Puffer Vorlauf","unit":"°C","type":"int16be","len":1,"factor":10,"offset":0,"role":"value","room":"","poll":true,"wp":false,"address":10,"deviceId":10,"id":"holdingRegisters.10_PufferVL"},{"_address":11,"name":"PufferRL","description":"Temperatur Puffer Rücklauf","unit":"°C","type":"int16be","len":1,"factor":10,"offset":0,"role":"value","room":"","poll":true,"wp":false,"address":11,"deviceId":10,"id":"holdingRegisters.11_PufferRL"},{"_address":12,"name":"TempBoilerO","description":"Temperatur Warmwasserspeicher Oben","unit":"°C","type":"int16be","len":1,"factor":10,"offset":0,"role":"value","room":"","poll":true,"wp":false,"address":12,"deviceId":10,"id":"holdingRegisters.12_TempBoilerO"},{"_address":13,"name":"RaumTemp","description":"Raumtemperatur Werkstatt","unit":"°C","type":"int16be","len":1,"factor":10,"offset":0,"role":"value.temperature","room":"","poll":true,"wp":false,"address":13,"deviceId":10,"id":"holdingRegisters.13_RaumTemp"},{"_address":14,"name":"FeuchteInnen","description":"relative Feuchte Werkstatt","unit":"%","type":"int16be","len":1,"factor":10,"offset":0,"role":"value.humidity","room":"","poll":true,"wp":false,"deviceId":10,"address":14,"id":"holdingRegisters.14_FeuchteInnen"},{"_address":15,"name":"FeuchteAussen","description":"relative Feuchte aussen","unit":"%","type":"int16be","len":1,"factor":10,"offset":0,"role":"value.humidity","room":"","poll":true,"wp":false,"deviceId":10,"address":15,"id":"holdingRegisters.15_FeuchteAussen"},{"_address":16,"name":"PVEin","description":"PV Ueberschuss","unit":"W","type":"int16be","len":1,"factor":1,"offset":0,"role":"value","room":"","poll":true,"wp":false,"deviceId":10,"address":16,"cw":false,"id":"holdingRegisters.16_PVEin"}]
      2022-09-29 19:53:42.276 - debug: modbus.0 (27858) Add holdingRegisters.1_Temp_Koll1: {"_id":"holdingRegisters.1_Temp_Koll1","type":"state","common":{"name":"Temperatur Kollektor Osten","role":"value.temperature","type":"number","read":true,"write":true,"def":0,"unit":"°C"},"native":{"regType":"holdingRegs","address":1,"deviceId":10,"type":"int16be","len":1,"offset":0,"factor":10,"poll":true}}
      2022-09-29 19:53:42.276 - debug: modbus.0 (27858) Add holdingRegisters.2_Temp_Koll2: {"_id":"holdingRegisters.2_Temp_Koll2","type":"state","common":{"name":"Temperatur Kollektor Westen","role":"value.temperature","type":"number","read":true,"write":true,"def":0,"unit":"°C"},"native":{"regType":"holdingRegs","address":2,"deviceId":10,"type":"int16be","len":1,"offset":0,"factor":10,"poll":true}}
      2022-09-29 19:53:42.277 - debug: modbus.0 (27858) Add holdingRegisters.3_SolarVL: {"_id":"holdingRegisters.3_SolarVL","type":"state","common":{"name":"Temperatur Solar Vorlauf","role":"value.temperature","type":"number","read":true,"write":true,"def":0,"unit":"°C"},"native":{"regType":"holdingRegs","address":3,"deviceId":10,"type":"int16be","len":1,"offset":0,"factor":10,"poll":true}}
      2022-09-29 19:53:42.277 - debug: modbus.0 (27858) Add holdingRegisters.4_SolarRL: {"_id":"holdingRegisters.4_SolarRL","type":"state","common":{"name":"Temperatur Solar Rücklauf","role":"value.temperature","type":"number","read":true,"write":true,"def":0,"unit":"°C"},"native":{"regType":"holdingRegs","address":4,"deviceId":10,"type":"int16be","len":1,"offset":0,"factor":10,"poll":true}}
      2022-09-29 19:53:42.278 - debug: modbus.0 (27858) Add holdingRegisters.5_TempAussen: {"_id":"holdingRegisters.5_TempAussen","type":"state","common":{"name":"Außentemperatur","role":"value.temperature","type":"number","read":true,"write":true,"def":0,"unit":"°C"},"native":{"regType":"holdingRegs","address":5,"deviceId":10,"type":"int16be","len":1,"offset":0,"factor":10,"poll":true}}
      2022-09-29 19:53:42.278 - debug: modbus.0 (27858) Add holdingRegisters.6_TempPufferO: {"_id":"holdingRegisters.6_TempPufferO","type":"state","common":{"name":"Temperatur Pufferspeicher Oben","role":"value.temperature","type":"number","read":true,"write":true,"def":0,"unit":"°C"},"native":{"regType":"holdingRegs","address":6,"deviceId":10,"type":"int16be","len":1,"offset":0,"factor":10,"poll":true}}
      2022-09-29 19:53:42.279 - debug: modbus.0 (27858) Add holdingRegisters.7_TempHeizVL: {"_id":"holdingRegisters.7_TempHeizVL","type":"state","common":{"name":"Temperatur Heizung Vorlauf","role":"value.temperature","type":"number","read":true,"write":true,"def":0,"unit":"°C"},"native":{"regType":"holdingRegs","address":7,"deviceId":10,"type":"int16be","len":1,"offset":0,"factor":10,"poll":true}}
      2022-09-29 19:53:42.279 - debug: modbus.0 (27858) Add holdingRegisters.8_BetriebsHBrenner: {"_id":"holdingRegisters.8_BetriebsHBrenner","type":"state","common":{"name":"Betriebsstunden Brenner","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"h"},"native":{"regType":"holdingRegs","address":8,"deviceId":10,"type":"int16be","len":1,"offset":0,"factor":1,"poll":true}}
      2022-09-29 19:53:42.280 - debug: modbus.0 (27858) Add holdingRegisters.9_StartsBrenner: {"_id":"holdingRegisters.9_StartsBrenner","type":"state","common":{"name":"Starts Brenner","role":"value","type":"number","read":true,"write":true,"def":0,"unit":""},"native":{"regType":"holdingRegs","address":9,"deviceId":10,"type":"int16be","len":1,"offset":0,"factor":1,"poll":true}}
      2022-09-29 19:53:42.280 - debug: modbus.0 (27858) Add holdingRegisters.10_PufferVL: {"_id":"holdingRegisters.10_PufferVL","type":"state","common":{"name":"Temperatur Puffer Vorlauf","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"°C"},"native":{"regType":"holdingRegs","address":10,"deviceId":10,"type":"int16be","len":1,"offset":0,"factor":10,"poll":true}}
      2022-09-29 19:53:42.281 - debug: modbus.0 (27858) Add holdingRegisters.11_PufferRL: {"_id":"holdingRegisters.11_PufferRL","type":"state","common":{"name":"Temperatur Puffer Rücklauf","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"°C"},"native":{"regType":"holdingRegs","address":11,"deviceId":10,"type":"int16be","len":1,"offset":0,"factor":10,"poll":true}}
      2022-09-29 19:53:42.281 - debug: modbus.0 (27858) Add holdingRegisters.12_TempBoilerO: {"_id":"holdingRegisters.12_TempBoilerO","type":"state","common":{"name":"Temperatur Warmwasserspeicher Oben","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"°C"},"native":{"regType":"holdingRegs","address":12,"deviceId":10,"type":"int16be","len":1,"offset":0,"factor":10,"poll":true}}
      2022-09-29 19:53:42.281 - debug: modbus.0 (27858) Add holdingRegisters.13_RaumTemp: {"_id":"holdingRegisters.13_RaumTemp","type":"state","common":{"name":"Raumtemperatur Werkstatt","role":"value.temperature","type":"number","read":true,"write":true,"def":0,"unit":"°C"},"native":{"regType":"holdingRegs","address":13,"deviceId":10,"type":"int16be","len":1,"offset":0,"factor":10,"poll":true}}
      2022-09-29 19:53:42.282 - debug: modbus.0 (27858) Add holdingRegisters.14_FeuchteInnen: {"_id":"holdingRegisters.14_FeuchteInnen","type":"state","common":{"name":"relative Feuchte Werkstatt","role":"value.humidity","type":"number","read":true,"write":true,"def":0,"unit":"%"},"native":{"regType":"holdingRegs","address":14,"deviceId":10,"type":"int16be","len":1,"offset":0,"factor":10,"poll":true}}
      2022-09-29 19:53:42.282 - debug: modbus.0 (27858) Add holdingRegisters.15_FeuchteAussen: {"_id":"holdingRegisters.15_FeuchteAussen","type":"state","common":{"name":"relative Feuchte aussen","role":"value.humidity","type":"number","read":true,"write":true,"def":0,"unit":"%"},"native":{"regType":"holdingRegs","address":15,"deviceId":10,"type":"int16be","len":1,"offset":0,"factor":10,"poll":true}}
      2022-09-29 19:53:42.283 - debug: modbus.0 (27858) Add holdingRegisters.16_PVEin: {"_id":"holdingRegisters.16_PVEin","type":"state","common":{"name":"PV Ueberschuss","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"W"},"native":{"regType":"holdingRegs","address":16,"deviceId":10,"type":"int16be","len":1,"offset":0,"factor":1,"poll":true}}
      2022-09-29 19:53:42.376 - debug: modbus.0 (27858) Remove old object modbus.0.coils.20_PumpeSol
      2022-09-29 19:53:42.377 - debug: modbus.0 (27858) Remove old object modbus.0.coils.21_VentilSol1
      2022-09-29 19:53:42.377 - debug: modbus.0 (27858) Remove old object modbus.0.coils.22_VentilSol2
      2022-09-29 19:53:42.378 - debug: modbus.0 (27858) Remove old object modbus.0.coils.23_LadepumpeSP
      2022-09-29 19:53:42.378 - debug: modbus.0 (27858) Remove old object modbus.0.coils.24_AnfBrenner
      2022-09-29 19:53:42.788 - debug: modbus.0 (27858) Slave ready to start
      2022-09-29 19:53:42.982 - debug: modbus.0 (27858) server is listening on port
      2022-09-29 19:53:42.983 - debug: modbus.0 (27858) initiating read coils request handler.
      2022-09-29 19:53:42.984 - debug: modbus.0 (27858) setting request handler
      2022-09-29 19:53:42.985 - debug: modbus.0 (27858) initiating read discrete inputs request handler.
      2022-09-29 19:53:42.985 - debug: modbus.0 (27858) setting request handler
      2022-09-29 19:53:42.986 - debug: modbus.0 (27858) initiating read holding registers request handler.
      2022-09-29 19:53:42.986 - debug: modbus.0 (27858) setting request handler
      2022-09-29 19:53:42.987 - debug: modbus.0 (27858) initiating read input registers request handler.
      2022-09-29 19:53:42.987 - debug: modbus.0 (27858) setting request handler
      2022-09-29 19:53:42.988 - debug: modbus.0 (27858) initiating write multiple coils request handler.
      2022-09-29 19:53:42.989 - debug: modbus.0 (27858) setting request handler
      2022-09-29 19:53:42.989 - debug: modbus.0 (27858) initiating write multiple registers request handler.
      2022-09-29 19:53:42.990 - debug: modbus.0 (27858) setting request handler
      2022-09-29 19:53:42.991 - debug: modbus.0 (27858) initiating write single coil request handler.
      2022-09-29 19:53:42.991 - debug: modbus.0 (27858) setting request handler
      2022-09-29 19:53:42.992 - debug: modbus.0 (27858) initiating write single register request handler.
      2022-09-29 19:53:42.992 - debug: modbus.0 (27858) setting request handler
      2022-09-29 19:54:23.130 - debug: modbus.0 (27858) new connection
      2022-09-29 19:54:23.134 - debug: modbus.0 (27858) + Clients connected: 192.168.178.93
      2022-09-29 19:54:23.245 - debug: modbus.0 (27858) handling write single register request.
      2022-09-29 19:54:23.260 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 19:54:26.228 - debug: modbus.0 (27858) handling write single register request.
      2022-09-29 19:54:26.229 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 19:54:26.334 - warn: modbus.0 (27858) FC5 write request outside coils boundaries: from 25, value false. Expected max address: 24
      2022-09-29 19:54:26.335 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 19:54:27.227 - debug: modbus.0 (27858) handling write single register request.
      2022-09-29 19:54:27.228 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 19:54:28.230 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 19:54:36.226 - debug: modbus.0 (27858) handling write single register request.
      2022-09-29 19:54:36.228 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 19:54:38.227 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 19:54:48.227 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 19:54:58.227 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 19:55:00.094 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 27954
      2022-09-29 19:55:02.627 - info: dwd.0 (27954) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v14.20.0, js-controller: 4.0.23
      2022-09-29 19:55:03.846 - info: dwd.0 (27954) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2022-09-29 19:55:04.421 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2022-09-29 19:55:08.227 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 19:55:13.226 - debug: modbus.0 (27858) handling write single register request.
      2022-09-29 19:55:13.228 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 19:55:18.227 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 19:55:26.227 - warn: modbus.0 (27858) FC5 write request outside coils boundaries: from 25, value false. Expected max address: 24
      2022-09-29 19:55:26.228 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 19:55:28.227 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 19:55:29.227 - debug: modbus.0 (27858) handling write single register request.
      2022-09-29 19:55:29.229 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 19:55:30.227 - debug: modbus.0 (27858) handling write single register request.
      2022-09-29 19:55:30.229 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 19:55:31.227 - debug: modbus.0 (27858) handling write single register request.
      2022-09-29 19:55:31.229 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 19:55:38.227 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 19:55:39.227 - debug: modbus.0 (27858) handling write single register request.
      2022-09-29 19:55:39.228 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 19:55:41.226 - debug: modbus.0 (27858) handling write single register request.
      2022-09-29 19:55:41.228 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 19:55:48.227 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 19:55:58.227 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 19:56:08.228 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 19:56:18.227 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 19:56:21.227 - debug: modbus.0 (27858) FC5 finished writing single coil: at 18, value false
      2022-09-29 19:56:21.228 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 19:56:25.227 - debug: modbus.0 (27858) handling write single register request.
      2022-09-29 19:56:25.228 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 19:56:25.331 - debug: modbus.0 (27858) handling write single register request.
      2022-09-29 19:56:25.333 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 19:56:26.226 - warn: modbus.0 (27858) FC5 write request outside coils boundaries: from 25, value false. Expected max address: 24
      2022-09-29 19:56:26.228 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 19:56:28.227 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 19:56:30.227 - debug: modbus.0 (27858) FC5 finished writing single coil: at 20, value false
      2022-09-29 19:56:30.228 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 19:56:31.227 - debug: modbus.0 (27858) FC5 finished writing single coil: at 21, value false
      2022-09-29 19:56:31.228 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 19:56:34.227 - debug: modbus.0 (27858) handling write single register request.
      2022-09-29 19:56:34.228 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 19:56:38.227 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 19:56:48.227 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 19:56:58.228 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 19:57:08.227 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 19:57:12.302 - info: admin.0 (22624) ==> Connected system.user.admin from ::ffff:192.168.178.61
      2022-09-29 19:57:15.216 - info: host.raspberrypi Updating repository "beta" under "http://download.iobroker.net/sources-dist-latest.json"
      2022-09-29 19:57:18.227 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 19:57:24.227 - debug: modbus.0 (27858) handling write single register request.
      2022-09-29 19:57:24.228 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 19:57:26.227 - warn: modbus.0 (27858) FC5 write request outside coils boundaries: from 25, value false. Expected max address: 24
      2022-09-29 19:57:26.227 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 19:57:28.228 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 19:57:38.227 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 19:57:48.228 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 19:57:58.227 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 19:58:08.227 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 19:58:18.227 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 19:58:26.227 - warn: modbus.0 (27858) FC5 write request outside coils boundaries: from 25, value false. Expected max address: 24
      2022-09-29 19:58:26.228 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 19:58:28.227 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 19:58:38.227 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 19:58:42.227 - debug: modbus.0 (27858) handling write single register request.
      2022-09-29 19:58:42.228 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 19:58:44.227 - debug: modbus.0 (27858) handling write single register request.
      2022-09-29 19:58:44.228 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 19:58:44.331 - debug: modbus.0 (27858) handling write single register request.
      2022-09-29 19:58:44.333 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 19:58:48.227 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 19:58:49.227 - debug: modbus.0 (27858) FC5 finished writing single coil: at 19, value false
      2022-09-29 19:58:49.228 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 19:58:58.227 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 19:59:04.227 - debug: modbus.0 (27858) FC5 finished writing single coil: at 22, value false
      2022-09-29 19:59:04.228 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 19:59:08.227 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 19:59:18.227 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 19:59:26.227 - warn: modbus.0 (27858) FC5 write request outside coils boundaries: from 25, value false. Expected max address: 24
      2022-09-29 19:59:26.228 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 19:59:27.225 - debug: modbus.0 (27858) handling write single register request.
      2022-09-29 19:59:27.226 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 19:59:28.225 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 19:59:36.227 - debug: modbus.0 (27858) handling write single register request.
      2022-09-29 19:59:36.228 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 19:59:38.227 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 19:59:48.227 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 19:59:58.227 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 20:00:00.056 - info: javascript.0 (22662) script.js.PV.Sonnenstand: Script Sonnenstand; Erfolgreich gelaufen, Werte akzeptiert
      2022-09-29 20:00:00.176 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 28120
      2022-09-29 20:00:02.780 - info: dwd.0 (28120) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v14.20.0, js-controller: 4.0.23
      2022-09-29 20:00:04.244 - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 28135
      2022-09-29 20:00:04.604 - info: dwd.0 (28120) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2022-09-29 20:00:05.153 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2022-09-29 20:00:06.827 - info: daswetter.0 (28135) starting. Version 3.1.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v14.20.0, js-controller: 4.0.23
      2022-09-29 20:00:08.227 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 20:00:08.301 - info: host.raspberrypi instance system.adapter.ical.0 started with pid 28150
      2022-09-29 20:00:11.584 - info: ical.0 (28150) starting. Version 1.13.2 in /opt/iobroker/node_modules/iobroker.ical, node: v14.20.0, js-controller: 4.0.23
      2022-09-29 20:00:12.161 - info: ical.0 (28150) processing URL: Abfall https://calendar.google.com/calendar/ical/e8dcmr7nuak48aee17iqj43uqc%40group.calendar.google.com/private-01424a46d58bc950fa7c7666a61d1515/basic.ics
      2022-09-29 20:00:13.227 - debug: modbus.0 (27858) handling write single register request.
      2022-09-29 20:00:13.228 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 20:00:17.513 - info: ical.0 (28150) Terminated (NO_ERROR): Without reason
      2022-09-29 20:00:18.045 - info: host.raspberrypi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
      2022-09-29 20:00:18.226 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 20:00:24.578 - info: daswetter.0 (28135) still wrong data structure from server received! repaired...
      2022-09-29 20:00:26.225 - warn: modbus.0 (27858) FC5 write request outside coils boundaries: from 25, value false. Expected max address: 24
      2022-09-29 20:00:26.226 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 20:00:28.227 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 20:00:29.010 - info: daswetter.0 (28135) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
      2022-09-29 20:00:29.226 - debug: modbus.0 (27858) handling write single register request.
      2022-09-29 20:00:29.227 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 20:00:29.534 - info: daswetter.0 (28135) cleaned everything up...
      2022-09-29 20:00:29.564 - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2022-09-29 20:00:30.227 - debug: modbus.0 (27858) handling write single register request.
      2022-09-29 20:00:30.228 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 20:00:31.227 - debug: modbus.0 (27858) handling write single register request.
      2022-09-29 20:00:31.228 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 20:00:37.939 - info: admin.0 (22624) <== Disconnect system.user.admin from ::ffff:192.168.178.61
      2022-09-29 20:00:38.226 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 20:00:39.225 - debug: modbus.0 (27858) handling write single register request.
      2022-09-29 20:00:39.227 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 20:00:41.227 - debug: modbus.0 (27858) handling write single register request.
      2022-09-29 20:00:41.229 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 20:00:48.227 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 20:00:58.227 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 20:01:08.227 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 20:01:18.226 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 20:01:21.226 - debug: modbus.0 (27858) FC5 finished writing single coil: at 18, value false
      2022-09-29 20:01:21.227 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 20:01:25.226 - debug: modbus.0 (27858) handling write single register request.
      2022-09-29 20:01:25.228 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 20:01:25.329 - debug: modbus.0 (27858) handling write single register request.
      2022-09-29 20:01:25.331 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 20:01:26.225 - warn: modbus.0 (27858) FC5 write request outside coils boundaries: from 25, value false. Expected max address: 24
      2022-09-29 20:01:26.227 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 20:01:28.226 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 20:01:30.226 - debug: modbus.0 (27858) FC5 finished writing single coil: at 20, value false
      2022-09-29 20:01:30.227 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 20:01:31.226 - debug: modbus.0 (27858) FC5 finished writing single coil: at 21, value false
      2022-09-29 20:01:31.227 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 20:01:34.226 - debug: modbus.0 (27858) handling write single register request.
      2022-09-29 20:01:34.227 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 20:01:38.226 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 20:01:48.227 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 20:01:58.227 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 20:02:08.227 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 20:02:18.227 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 20:02:24.226 - debug: modbus.0 (27858) handling write single register request.
      2022-09-29 20:02:24.228 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 20:02:26.226 - warn: modbus.0 (27858) FC5 write request outside coils boundaries: from 25, value false. Expected max address: 24
      2022-09-29 20:02:26.228 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 20:02:28.227 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 20:02:38.227 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 20:02:48.227 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 20:02:58.227 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 20:03:08.227 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 20:03:18.226 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 20:03:26.226 - warn: modbus.0 (27858) FC5 write request outside coils boundaries: from 25, value false. Expected max address: 24
      2022-09-29 20:03:26.227 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 20:03:28.226 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 20:03:38.227 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 20:03:42.226 - debug: modbus.0 (27858) handling write single register request.
      2022-09-29 20:03:42.227 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 20:03:44.226 - debug: modbus.0 (27858) handling write single register request.
      2022-09-29 20:03:44.228 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 20:03:44.329 - debug: modbus.0 (27858) handling write single register request.
      2022-09-29 20:03:44.331 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 20:03:48.226 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 20:03:49.227 - debug: modbus.0 (27858) FC5 finished writing single coil: at 19, value false
      2022-09-29 20:03:49.228 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 20:03:58.226 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 20:04:04.226 - debug: modbus.0 (27858) FC5 finished writing single coil: at 22, value false
      2022-09-29 20:04:04.228 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 20:04:08.226 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 20:04:18.226 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 20:04:26.226 - warn: modbus.0 (27858) FC5 write request outside coils boundaries: from 25, value false. Expected max address: 24
      2022-09-29 20:04:26.226 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 20:04:27.226 - debug: modbus.0 (27858) handling write single register request.
      2022-09-29 20:04:27.227 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 20:04:28.226 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 20:04:36.226 - debug: modbus.0 (27858) handling write single register request.
      2022-09-29 20:04:36.227 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 20:04:38.226 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 20:04:48.226 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 20:04:58.226 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 20:05:00.110 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 28339
      2022-09-29 20:05:02.875 - info: dwd.0 (28339) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v14.20.0, js-controller: 4.0.23
      2022-09-29 20:05:03.981 - info: dwd.0 (28339) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2022-09-29 20:05:04.518 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2022-09-29 20:05:08.226 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 20:05:13.225 - debug: modbus.0 (27858) handling write single register request.
      2022-09-29 20:05:13.226 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 20:05:18.226 - debug: modbus.0 (27858) sending tcp data
      2022-09-29 20:05:21.436 - info: admin.0 (22624) <== Disconnect system.user.admin from ::ffff:192.168.178.31 admin
      2022-09-29 20:05:21.448 - info: admin.0 (22624) <== Disconnect system.user.admin from ::ffff:192.168.178.61 admin
      2022-09-29 20:05:21.450 - info: admin.0 (22624) <== Disconnect system.user.admin from ::ffff:192.168.178.31 javascript
      2022-09-29 20:05:21.671 - info: admin.0 (22624) ==> Connected system.user.admin from ::ffff:192.168.178.61
      2022-09-29 20:05:22.002 - info: admin.0 (22624) ==> Connected system.user.admin from ::ffff:192.168.178.31
      2022-09-29 20:05:22.810 - info: admin.0 (22624) ==> Connected system.user.admin from ::ffff:192.168.178.31
      2022-09-29 20:05:26.225 - warn: modbus.0 (27858) FC5 write request outside coils boundaries: from 25, value false. Expected max address: 24
      Bisher dachte ich, dass ich keine Objekte mit Adressen größer als 24 anlegen darf/kann (was mir unlogisch erscheint, weil mit 5 Stellen wie beim Modbus für die PV Anlage geht es). Aber nach Korrektur habe ich keine Objekte mehr deren ID größer als 24 ist.
      Und wenn die Werte damit gemeint sein sollen, dann verstehe ich das auch nicht:
      Hat jemand für mich einen Tipp, was den Fehler auslöst und wie ich ihn abstellen kann?
      Henri
        DirkM @hennerich last edited by
        @hennerich
        Gibt es hierzu mittlerweile eine Lösung?
        Dirk
          hennerich @DirkM last edited by
          @dirkm
          Puhh, du fragst mich Sachen 😇
          Ich meine mich daran zu erinnnern, dass ich das Problem zwar nicht final gelöst bekommen hatte, aber es wurde weniger. Ich weiß nur nicht mehr wie ich das angestellt habe.
          Warum schreibe ich das in der Vergangenheit: ich bin zu Home Assistant migriert und mache nichts mehr mit ioBroker. Sorry dafür.
            @hennerich
            Danke für deine Info. Bei mir war das Problem, dass ich dachte ich könnte sowohl bei analogen als auch digitalen Datenpunkte mit der Adresse 0 Anfangen. Das scheint so nicht zu funktionieren. Nachdem ich bei den digitalen Datenpunkten mit einer noch nicht verwendeten Adresse begonnen habe, war mein Problem erledigt.
            Dirk
