    4. ioBroker startet nicht mehr
      Magnus 0 last edited by
      Nach einem Neustart meines Raspberry Pi startet ioBroker nicht mehr.
      Vor dem Neustart lief ioBroker ohne Probleme.
      Folgende meine Versionen:
      node -v
      v16.17.1
      nodejs -v
      v16.17.1
      npm -v
      8.15.0
      iobroker -v
      4.0.23
      Wenn ich den Befehl "iobroker logs" ausführe, erscheint immer wieder folgender Fehler:
      2022-09-30 20:33:48.748  - info: host.DELO0150 iobroker _restart
      2022-09-30 20:33:49.603  - info: host.DELO0150 connected to Objects and States
      2022-09-30 20:33:49.633  - info: host.DELO0150 added notifications configuration of host
      2022-09-30 20:33:49.642  - info: host.DELO0150 Node.js version has changed from 16.16.0 to 16.17.1
      2022-09-30 20:33:49.731  - info: host.DELO0150 Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
      2022-09-30 20:33:54.238  - info: host.DELO0150 iobroker.js-controller version 4.0.23 js-controller starting
      2022-09-30 20:33:54.245  - info: host.DELO0150 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
      2022-09-30 20:33:54.246  - info: host.DELO0150 hostname: DELO0150, node: v16.17.1
      2022-09-30 20:33:54.247  - info: host.DELO0150 ip addresses: 192.168.178.150 fe80::5068:6694:ad08:cc79
      2022-09-30 20:34:24.266  - error: host.DELO0150 No connection to databases possible, restart
      2022-09-30 20:34:24.276  - info: host.DELO0150 iobroker _restart
      2022-09-30 20:34:24.863  - info: host.DELO0150 connected to Objects and States
      2022-09-30 20:34:24.892  - info: host.DELO0150 added notifications configuration of host
      2022-09-30 20:34:24.901  - info: host.DELO0150 Node.js version has changed from 16.16.0 to 16.17.1
      2022-09-30 20:34:24.972  - info: host.DELO0150 Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
      2022-09-30 20:34:25.048  - info: host.DELO0150 Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      2022-09-30 20:34:25.160  - info: host.DELO0150 7 instances found
      2022-09-30 20:34:25.191  - info: host.DELO0150 starting 7 instances
      2022-09-30 20:34:25.295  - info: host.DELO0150 instance system.adapter.admin.0 started with pid 3390
      2022-09-30 20:34:29.967  - info: host.DELO0150 iobroker.js-controller version 4.0.23 js-controller starting
      2022-09-30 20:34:29.974  - info: host.DELO0150 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
      2022-09-30 20:34:29.975  - info: host.DELO0150 hostname: DELO0150, node: v16.17.1
      2022-09-30 20:34:29.976  - info: host.DELO0150 ip addresses: 192.168.178.150 fe80::5068:6694:ad08:cc79
      Ich habe nun schon einige Beiträge im Forum durchgelesen, aber kam bisher noch zu keiner Lösung.
      Weiß jemand, was ich hier machen kann?
        Thomas Braun Most Active @Magnus 0 last edited by
        @magnus-0
        systemctl status iobroker.service
          Magnus 0 @Thomas Braun last edited by
          @thomas-braun sagte in ioBroker startet nicht mehr:
          pi@DELO0150:~ $ systemctl status iobroker.service
          ● iobroker.service - ioBroker Server
             Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; vendor preset: enabled)
             Active: active (running) since Fri 2022-09-30 20:38:37 CEST; 9s ago
               Docs: http://iobroker.net
           Main PID: 3646 (iobroker.js-con)
              Tasks: 11 (limit: 4915)
             CGroup: /system.slice/iobroker.service
                     └─3646 iobroker.js-controller
          Sep 30 20:38:37 DELO0150 systemd[1]: Started ioBroker Server.
            Thomas Braun Most Active last edited by Thomas Braun
            @magnus-0 sagte in ioBroker startet nicht mehr:
            sudo systemctl stop iobroker.service
            iobroker status
              iobroker status
              pi@DELO0150:~ $ sudo systemctl stop iobroker.service
              pi@DELO0150:~ $ iobroker status
              No connection to databases possible ...
                @magnus-0
                ps aux | grep ^io
                  pi@DELO0150:~ $ ps aux | grep ^io
                  pi@DELO0150:~ $
                    @magnus-0
                    sudo ln -s /usr/bin/node /usr/bin/nodejs
                    uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                      pi@DELO0150:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
                      ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
                      pi@DELO0150:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                      armv7l
                      /usr/bin/nodejs
                      /usr/bin/node
                      /usr/bin/npm
                      v16.17.1
                      v16.17.1
                      8.15.0
                      4.0.23
                      pi
                      pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
                      /home/pi
                      OK:1 http://archive.raspberrypi.org/debian buster InRelease
                      OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                      OK:3 https://deb.nodesource.com/node_16.x buster InRelease
                      Abhängigkeitsbaum wird aufgebaut.
                      Statusinformationen werden eingelesen.... Fertig
                      Alle Pakete sind aktuell.
                      nodejs:
                        Installiert:           16.17.1-deb-1nodesource1
                        Installationskandidat: 16.17.1-deb-1nodesource1
                        Versionstabelle:
                       *** 16.17.1-deb-1nodesource1 500
                              500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                              100 /var/lib/dpkg/status
                           10.24.0~dfsg-1~deb10u1 500
                        @magnus-0
                        Starte die Kiste mal sauber durch.
                          also "sudo reboot"?
                            @magnus-0
                            Ja.
                              Gleiches Problem immer noch.
                                @magnus-0
                                iobroker status
                                iobroker update -i
                                  Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
                                    pi@DELO0150:~ $ iobroker update -i
                                      @magnus-0
                                      iobroker status
                                      iobroker start
                                        iobroker start
                                           Active: active (running) since Fri 2022-09-30 20:56:19 CEST; 28s ago
                                         Main PID: 882 (iobroker.js-con)
                                                   └─882 iobroker.js-controller
                                        Sep 30 20:56:19 DELO0150 systemd[1]: Started ioBroker Server.
                                        pi@DELO0150:~ $ iobroker start
                                          sudo apt install lsof
                                          sudo lsof /opt/iobroker/iobroker-data/objects.jsonl
                                            Magnus 0 @Thomas Braun last edited by Magnus 0
                                            pi@DELO0150:~ $ sudo apt install lsof
                                            Die folgenden NEUEN Pakete werden installiert:
                                              lsof
                                            0 aktualisiert, 1 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                                            Es müssen 307 kB an Archiven heruntergeladen werden.
                                            Nach dieser Operation werden 447 kB Plattenplatz zusätzlich benutzt.
                                            Holen:1 http://mirror1.hs-esslingen.de/pub/Mirrors/archive.raspbian.org/raspbian buster/main armhf lsof armhf 4.91+dfsg-1 [307 kB]
                                            Es wurden 307 kB in 2 s geholt (196 kB/s).
                                            Vormals nicht ausgewähltes Paket lsof wird gewählt.
                                            (Lese Datenbank ... 53671 Dateien und Verzeichnisse sind derzeit installiert.)
                                            Vorbereitung zum Entpacken von .../lsof_4.91+dfsg-1_armhf.deb ...
                                            Entpacken von lsof (4.91+dfsg-1) ...
                                            lsof (4.91+dfsg-1) wird eingerichtet ...
                                            Trigger für man-db (2.8.5-2) werden verarbeitet ...
                                            pi@DELO0150:~ $ sudo lsof /opt/iobroker/iobroker-data/objects.jsonl
                                            COMMAND    PID     USER   FD   TYPE DEVICE  SIZE/OFF   NODE NAME
                                            iobroker. 1226 iobroker   19u   REG  179,2 972533859 261398 /opt/iobroker/iobroker-data/objects.jsonl
                                            1701
