    4. Alias subscription error. checkdefinitions
    • D3ltoroxp
      D3ltoroxp last edited by
      Hallo Com,
      Ich habe mal mit Alias angefangen und mir hierzu 2-3 Geräte erstellt und eben mit den originalen DP's verknüpft.
      Nun ist die Log mit solchen Meldungen voll.
      admin.0
      	2022-10-08 12:26:35.008	error	Alias subscription error. Please check your alias definitions: sourceId=fritzdect.0.DECT_116300066196.state, sourceObj={"type":"state","common":{"name":"Simple ON/OFF state and cmd","type":"boolean","read":true,"write":true,"role":"switch","desc":"Simple ON/OFF state and cmd"},"native":{},"from":"system.adapter.fritzdect.0","user":"system.user.admin","ts":1609841396458,"_id":"fritzdect.0.DECT_116300066196.state","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      admin.0
      	2022-10-08 12:26:35.008	error	Alias subscription error. Please check your alias definitions: sourceId=fritzdect.0.DECT_116300066196.power, sourceObj={"type":"state","common":{"name":"actual Power","type":"number","min":0,"max":4000,"unit":"W","read":true,"write":false,"role":"value","desc":"actual Power"},"native":{},"_id":"fritzdect.0.DECT_116300066196.power","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.admin.0","user":"system.user.admin","ts":1640945601137}
      admin.0
      	2022-10-08 12:26:35.007	error	Alias subscription error. Please check your alias definitions: sourceId=alexa2.0.Echo-Devices.G091ET06039404PA.Commands.speak, sourceObj={"common":{"role":"media.tts","type":"string","read":true,"write":true,"name":"speak","def":""},"type":"state","native":{},"from":"system.adapter.alexa2.0","user":"system.user.admin","ts":1664988919234,"_id":"alexa2.0.Echo-Devices.G091ET06039404PA.Commands.speak","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      admin.0
      	2022-10-08 12:26:35.007	error	Alias subscription error. Please check your alias definitions: sourceId=alexa2.0.Echo-Devices.G091ET06039404PA.Commands.announcement, sourceObj={"common":{"role":"media.tts","type":"string","read":true,"write":true,"name":"announcement","def":""},"type":"state","native":{},"from":"system.adapter.alexa2.0","user":"system.user.admin","ts":1664988919238,"_id":"alexa2.0.Echo-Devices.G091ET06039404PA.Commands.announcement","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      admin.0
      	2022-10-08 12:26:35.007	error	Alias subscription error. Please check your alias definitions: sourceId=zigbee.0.84b4dbfffe80a55f.state, sourceObj={"type":"state","common":{"name":"On/off state of the switch","type":"boolean","read":true,"write":true,"role":"switch"},"native":{},"from":"system.adapter.zigbee.0","user":"system.user.admin","ts":1664650502852,"_id":"zigbee.0.84b4dbfffe80a55f.state","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      admin.0
      	2022-10-08 12:26:35.007	error	Alias subscription error. Please check your alias definitions: sourceId=zigbee.0.00158d00045cb455.pressure, sourceObj={"type":"state","common":{"name":"Pressure","type":"number","unit":"hPa","read":true,"write":false,"role":"value.pressure","min":0,"max":10000},"native":{},"from":"system.adapter.zigbee.0","user":"system.user.admin","ts":1620740033276,"_id":"zigbee.0.00158d00045cb455.pressure","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      admin.0
      	2022-10-08 12:26:35.007	error	Alias subscription error. Please check your alias definitions: sourceId=zigbee.0.00158d00045cb455.humidity, sourceObj={"type":"state","common":{"name":"Humidity","type":"number","unit":"%","read":true,"write":false,"role":"value.humidity","min":0,"max":100},"native":{},"from":"system.adapter.zigbee.0","user":"system.user.admin","ts":1620137722728,"_id":"zigbee.0.00158d00045cb455.humidity","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      Als Beispiel
      Das meiste wurde ja automatisch erstellt beim anlegen der Alias Geräte, aber hier scheint was nicht zu stimmen.
      M liv-in-sky 2 Replies Last reply Reply Quote 0
        Marty56 @D3ltoroxp last edited by
        @d3ltoroxp Bist Du bei diesen Fehlermeldungen weitergekommen. Ich habe genau dasselbe. Massenweise Fehlermeldungen, die alle ein bis zwei Tage kommen.
        Ich kann bei mir keine Fehler finden und das Fehler Protokoll ist ohne Hinweise.
        • liv-in-sky
          liv-in-sky @D3ltoroxp last edited by
          @d3ltoroxp
          https://forum.iobroker.net/post/964461
