    4. Tuya Adapter: Gerät meldet sich nicht mehr.
    • Clay DE
      Clay DE last edited by
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Rasperry PI 3
      Arbeitsspeicher: 1GB
      Festplattenart: SD-Karte
      Betriebssystem: Ubuntu
      Node-Version:
      Nodejs-Version: 16.17.1
      NPM-Version: 8.15
      Installationsart: Skript
      2022-10-10 19:19:42.258  - info: tuya.0 (1593) bfac76cf0915b82aacnfti Init with IP=192.168.178.100, Key=44d4d062cc9101d2, Version=3.3
      2022-10-10 19:19:42.288  - info: tuya.0 (1593) bfac76cf0915b82aacnfti Init with IP=192.168.178.100, Key=44d4d062cc9101d2, Version=3.3
      2022-10-10 19:19:42.328  - info: tuya.0 (1593) bf03de245c6ea520a4wrgy Init with IP=192.168.178.68, Key=552d25ff14249d87, Version=3.3
      2022-10-10 19:19:42.378  - info: tuya.0 (1593) bf03de245c6ea520a4wrgy Init with IP=192.168.178.68, Key=552d25ff14249d87, Version=3.3
      2022-10-10 19:19:42.598  - warn: tuya.0 (1593) State "tuya.0.bf03de245c6ea520a4wrgy.38" has no existing object, this might lead to an error in future versions
      2022-10-10 19:19:42.601  - warn: tuya.0 (1593) State "tuya.0.bf03de245c6ea520a4wrgy.39" has no existing object, this might lead to an error in future versions
      2022-10-10 19:19:42.715  - warn: tuya.0 (1593) State "tuya.0.bf03de245c6ea520a4wrgy.38" has no existing object, this might lead to an error in future versions
      2022-10-10 19:19:42.717  - warn: tuya.0 (1593) State "tuya.0.bf03de245c6ea520a4wrgy.39" has no existing object, this might lead to an error in future versions
      2022-10-10 19:19:45.359  - error: tuya.0 (1593) bfac76cf0915b82aacnfti: connect EHOSTUNREACH 192.168.178.100:6668
      2022-10-10 19:19:45.364  - error: tuya.0 (1593) bfac76cf0915b82aacnfti: connect EHOSTUNREACH 192.168.178.100:6668
      2022-10-10 19:19:52.938  - warn: tuya.0 (1593) State "tuya.0.bf03de245c6ea520a4wrgy.38" has no existing object, this might lead to an error in future versions
      2022-10-10 19:19:52.940  - warn: tuya.0 (1593) State "tuya.0.bf03de245c6ea520a4wrgy.39" has no existing object, this might lead to an error in future versions
      2022-10-10 19:19:53.061  - info: admin.0 (1466) <== Disconnect system.user.admin from ::ffff:192.168.178.45
      2022-10-10 19:20:02.966  - warn: tuya.0 (1593) State "tuya.0.bf03de245c6ea520a4wrgy.38" has no existing object, this might lead to an error in future versions
      2022-10-10 19:20:02.968  - warn: tuya.0 (1593) State "tuya.0.bf03de245c6ea520a4wrgy.39" has no existing object, this might lead to an error in future versions
      2022-10-10 19:20:13.011  - warn: tuya.0 (1593) State "tuya.0.bf03de245c6ea520a4wrgy.38" has no existing object, this might lead to an error in future versions
      2022-10-10 19:20:13.017  - warn: tuya.0 (1593) State "tuya.0.bf03de245c6ea520a4wrgy.39" has no existing object, this might lead to an error in future versions
      2022-10-10 19:20:18.478  - warn: tuya.0 (1593) bfac76cf0915b82aacnfti: Error on Reconnectconnect EHOSTUNREACH 192.168.178.100:6668
      2022-10-10 19:20:23.173  - warn: tuya.0 (1593) State "tuya.0.bf03de245c6ea520a4wrgy.38" has no existing object, this might lead to an error in future versions
      2022-10-10 19:20:23.175  - warn: tuya.0 (1593) State "tuya.0.bf03de245c6ea520a4wrgy.39" has no existing object, this might lead to an error in future versions
      2022-10-10 19:20:33.295  - warn: tuya.0 (1593) State "tuya.0.bf03de245c6ea520a4wrgy.38" has no existing object, this might lead to an error in future versions
      2022-10-10 19:20:33.297  - warn: tuya.0 (1593) State "tuya.0.bf03de245c6ea520a4wrgy.39" has no existing object, this might lead to an error in future versions
      2022-10-10 19:20:43.627  - warn: tuya.0 (1593) State "tuya.0.bf03de245c6ea520a4wrgy.38" has no existing object, this might lead to an error in future versions
      2022-10-10 19:20:43.631  - warn: tuya.0 (1593) State "tuya.0.bf03de245c6ea520a4wrgy.39" has no existing object, this might lead to an error in future versions
      2022-10-10 19:20:51.600  - warn: tuya.0 (1593) bfac76cf0915b82aacnfti: Error on Reconnectconnect EHOSTUNREACH 192.168.178.100:6668
      2022-10-10 19:20:53.349  - warn: tuya.0 (1593) State "tuya.0.bf03de245c6ea520a4wrgy.38" has no existing object, this might lead to an error in future versions
      2022-10-10 19:20:53.353  - warn: tuya.0 (1593) State "tuya.0.bf03de245c6ea520a4wrgy.39" has no existing object, this might lead to an error in future versions
      2022-10-10 19:21:03.384  - warn: tuya.0 (1593) State "tuya.0.bf03de245c6ea520a4wrgy.38" has no existing object, this might lead to an error in future versions
      2022-10-10 19:21:03.386  - warn: tuya.0 (1593) State "tuya.0.bf03de245c6ea520a4wrgy.39" has no existing object, this might lead to an error in future version
      Hallo, zum einen habe ich das Problem dass ich die Log datei mit folgender "Warn" Meldung zugespamt bekomme:
      Wieso weshalbe weiß ich leider nicht.
      Jetzt kommt aber ein neues Problem hinzu,
      Bisher funktionierte alles so wie ich es wollte nur neuerdings ist ein Zwischenstecker stets als offline in Iobroker bzw
      als nicht erreichbar markiert.
      Ich habe bereits versucht die beiden Stecker erneut hinzuzufügen, danach klappt auch alles wieder aber halt nicht lange.
      Der eine Stecker ist aber stets erreichbar. Beide sind identische Stecker.
      Nachtrag: Ich habe einene Rasperry pi 3 auf dem IOBROKER läuft mit dem Tuya adapter, alle versionen sind aktuell und geupdated worden von mir.
      Zwei Stecker von Amazon sind in der Smartlife app angemeldet über die ich auch beide Stecker stets abrufen kann, dort sind beide Online und zeigen mir auch den Aktuellen stromverbrauch an. Nur in Iobroker ist einer der Stecker einfach nicht erreichbar wohl...
      Hoffe ihr könnt mir helfen.
      Clay DE 1 Reply Last reply Reply Quote 0
      • Clay DE
        Clay DE @Clay DE last edited by
        Keiner eine idee?
        81.0k
