    4. Zigbee Adapter lässt sich nicht einrichten
      hausautomation.digital last edited by
      Seit Stunden lese ich hier und suche im Netz, aber ich bekomm den Adapter nicht zum laufen.
      zigbee.0
      	2022-10-11 20:12:36.643	error	Error herdsman start
      zigbee.0
      	2022-10-11 20:12:36.642	error	Failed to start Zigbee
      zigbee.0
      	2022-10-11 20:12:36.641	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
      zigbee.0
      	2022-10-11 20:12:36.407	info	Installed Version: iobroker.zigbee@1.7.5
      zigbee.0
      	2022-10-11 20:12:36.364	info	Starting Zigbee npm ...
      Was mach ich falsch? 😧
        Thomas Braun Most Active @hausautomation.digital last edited by
        @hausautomation-digital
        Zeig mal einen vollständigen Start des Adapters.
          hausautomation.digital @Thomas Braun last edited by
          zigbee.0
          	2022-10-11 20:44:08.130	error	Error herdsman start
          zigbee.0
          	2022-10-11 20:44:08.129	error	Failed to start Zigbee
          zigbee.0
          	2022-10-11 20:44:08.128	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
          zigbee.0
          	2022-10-11 20:44:07.844	info	Installed Version: iobroker.zigbee@1.7.5
          zigbee.0
          	2022-10-11 20:44:07.820	info	Starting Zigbee npm ...
          zigbee.0
          	2022-10-11 20:44:07.819	info	Try to reconnect. 1 attempts left
          zigbee.0
          	2022-10-11 20:43:57.813	error	Error herdsman start
          zigbee.0
          	2022-10-11 20:43:57.812	error	Failed to start Zigbee
          zigbee.0
          	2022-10-11 20:43:57.811	error	Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
          zigbee.0
          	2022-10-11 20:43:57.676	error	Re-commissioning your network will require re-pairing of all devices!
          zigbee.0
          	2022-10-11 20:43:57.675	error	If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
          zigbee.0
          	2022-10-11 20:43:57.675	error	Please update configuration to prevent further issues.
          zigbee.0
          	2022-10-11 20:43:57.674	error	- Channel List: configured=26, adapter=20
          zigbee.0
          	2022-10-11 20:43:57.673	error	- Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
          zigbee.0
          	2022-10-11 20:43:57.673	error	- Extended PAN ID: configured=00124b0024c11445, adapter=00124b0024c11445
          zigbee.0
          	2022-10-11 20:43:57.671	error	- PAN ID: configured=6754, adapter=6754
          zigbee.0
          	2022-10-11 20:43:57.671	error	Configuration is not consistent with adapter state/backup!
          zigbee.0
          	2022-10-11 20:43:57.443	info	Installed Version: iobroker.zigbee@1.7.5
          zigbee.0
          	2022-10-11 20:43:56.911	info	Starting Zigbee npm ...
          zigbee.0
          	2022-10-11 20:43:56.908	info	delete old Backup files. keep only last 10
          zigbee.0
          	2022-10-11 20:43:56.804	info	starting. Version 1.7.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.17.1, js-controller: 4.0.23
          host.homebutler
          	2022-10-11 20:43:53.357	info	instance system.adapter.zigbee.0 started with pid 27988
          host.homebutler
          	2022-10-11 20:43:53.289	info	"system.adapter.zigbee.0" enabled
            Thomas Braun Most Active @hausautomation.digital last edited by Thomas Braun
            @hausautomation-digital sagte in Zigbee Adapter lässt sich nicht einrichten:
            Stell es übereinstimmend ein.
              @thomas-braun 🍻 DANKE! Hatte ich doch glatt übersehen.... Läuft!
