    4. Time-Switch Adapter: Exceptions bei Astrotrigger
      diwoma last edited by diwoma
      Ich habe den Time-Switch-Adapter mit 3 Trigger über Astro:
      1 x bei Sonnenuntergang
      1 x bei Sonnenaufgang
      1 x bei Sonnenaufgang - 30min
      Um 02:00, anscheinend wenn die neuen Astro-Zeiten eingelesen/übernommen werden bekomme ich diese Error-Meldungen:
      2022-10-12 02:00:00.029 - error: time-switch.0 (1175) uncaught exception: Trigger TimeTrigger {id=TimeTriggerForAstroTrigger:1, hour=6, minute=39, weekdays=[1]} is not registered.
      2022-10-12 02:00:00.031 - error: time-switch.0 (1175) Error: Trigger TimeTrigger {id=TimeTriggerForAstroTrigger:1, hour=6, minute=39, weekdays=[1]} is not registered.
      at TimeTriggerScheduler.unregister (/opt/iobroker/node_modules/iobroker.time-switch/build/scheduler/TimeTriggerScheduler.js:34:19)
      at /opt/iobroker/node_modules/iobroker.time-switch/build/scheduler/AstroTriggerScheduler.js:25:73
      at Array.forEach ()
      at Object.execute (/opt/iobroker/node_modules/iobroker.time-switch/build/scheduler/AstroTriggerScheduler.js:25:32)
      at Job.job (/opt/iobroker/node_modules/iobroker.time-switch/build/scheduler/TimeTriggerScheduler.js:22:33)
      at Job.invoke (/opt/iobroker/node_modules/iobroker.time-switch/node_modules/node-schedule/lib/schedule.js:175:17)
      at /opt/iobroker/node_modules/iobroker.time-switch/node_modules/node-schedule/lib/schedule.js:555:26
      at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.time-switch/node_modules/node-schedule/lib/schedule.js:512:7)
      at listOnTimeout (node:internal/timers:559:17)
      at processTimers (node:internal/timers:502:7)
      2022-10-12 02:00:00.031 - error: time-switch.0 (1175) Trigger TimeTrigger {id=TimeTriggerForAstroTrigger:1, hour=6, minute=39, weekdays=[1]} is not registered.
      2022-10-12 02:00:00.034 - info: time-switch.0 (1175) cleaning everything up...
      2022-10-12 02:00:00.035 - info: time-switch.0 (1175) terminating
      2022-10-12 02:00:00.035 - warn: time-switch.0 (1175) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2022-10-12 02:00:00.041 - error: time-switch.0 (1175) uncaught exception: Trigger TimeTrigger {id=TimeTriggerForAstroTrigger:1, hour=7, minute=9, weekdays=[1]} is not registered.
      2022-10-12 02:00:00.042 - error: time-switch.0 (1175) Error: Trigger TimeTrigger {id=TimeTriggerForAstroTrigger:1, hour=7, minute=9, weekdays=[1]} is not registered.
      at Array.forEach ()
      2022-10-12 02:00:00.042 - error: time-switch.0 (1175) Trigger TimeTrigger {id=TimeTriggerForAstroTrigger:1, hour=7, minute=9, weekdays=[1]} is not registered.
      2022-10-12 02:00:00.047 - info: javascript.0 (456) script.js.Temperatur.Temperatur_Verwaltung: CRON Startet: 12.10.2022 02:00:00
      2022-10-12 02:00:00.051 - error: time-switch.0 (1175) uncaught exception: Trigger TimeTrigger {id=TimeTriggerForAstroTrigger:2, hour=18, minute=23, weekdays=[1]} is not registered.
      2022-10-12 02:00:00.051 - error: time-switch.0 (1175) Error: Trigger TimeTrigger {id=TimeTriggerForAstroTrigger:2, hour=18, minute=23, weekdays=[1]} is not registered.
      at Array.forEach ()
      2022-10-12 02:00:00.052 - error: time-switch.0 (1175) Trigger TimeTrigger {id=TimeTriggerForAstroTrigger:2, hour=18, minute=23, weekdays=[1]} is not registered.
      2022-10-12 02:00:00.076 - info: mqtt.0 (576) send2Server mqtt.0.haus.Panels.NSPanel_1.cmnd.CustomSend[haus/Panels/NSPanel_1/cmnd/CustomSend]
      2022-10-12 02:00:00.095 - info: mqtt.0 (576) send2Server mqtt.0.haus.Panels.NSPanel_1.cmnd.CustomSend[haus/Panels/NSPanel_1/cmnd/CustomSend]
      2022-10-12 02:00:00.254 - error: javascript.0 (456) Error in request callback: TypeError: Cannot read properties of undefined (reading 'channels')
      2022-10-12 02:00:00.573 - error: host.ioBroker instance system.adapter.time-switch.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2022-10-12 02:00:00.574 - info: host.ioBroker Restart adapter system.adapter.time-switch.0 because enabled
      Die Schaltung löst aber korrekt aus.
      Funktional stört es zwar nicht, aber vielleicht lässt sich herausfinden woran es liegt
      Edit:
      ein paar der Zeilen gehören mit ziemlicher Sicherheit nicht zu den Meldungen des Adapters
      • BananaJoe
        BananaJoe Most Active @diwoma last edited by
        @diwoma da nehmen wir doch mal @walli545 mit rein und eventuell solltest du das als Issue auf Github melden: https://github.com/walli545/ioBroker.time-switch
          diwoma @BananaJoe last edited by
          @bananajoe said in Time-Switch Adapter: Exceptions bei Astrotrigger:
          Vielleicht sieht er das schon hier in den nächsten Tagen, sonst werde ich das Issue auf Github melden
          • BananaJoe
            BananaJoe Most Active last edited by BananaJoe
            @diwoma er war seit dem 3. Januar nicht mehr Online, ich hoffe es geht ihm gut ... auf Github hat er im April zuletzt was beantwortet ...
              Das habe ich auf Github gesehen, deswegen hoffte ich, er wäre hier aktiver.
              Ich hoffe auch, das es ihm gut geht.
                andibr @diwoma last edited by
                @diwoma
                Hallo zusammen, hoffen wir mal das es ihm gut geht und er den Adapter weiterbetreut?
                Ich habe gestern ein komplett neues System aufgesetzt und folgende Probleme festgestellt:
                • bei mir zwar die Schaltbefehle ausgeführt werden, aber auch mit den Astrotrigger da Error-Meldungen entstehen. Immer um ca. 02.00.
                • das Widget über das Cloud Login nicht angezeigt wird. Da gehe ich aber davon aus, dass ich irgend was noch nicht oder falsch eingestellt habe?
                Vieleicht hat ja jemand bereits eine Lösung gefunden? Es wäre nämlich sehr schade wenn dieser Adapter der so simpel und einfach ist, verloren gehen würde. Leider beherrsche ich keine Programiersprache sonst könnte man das ja anschauen.
