    4. [Gelöst] Ubuntu updaten
    • Kusselin
      Kusselin last edited by Kusselin
      Hallo Zusammen, ich bekomme wenn ich mich über die Console anmlede udn ein apt-get udate && apt-get upgrade mache folgende Meldung:
      Welcome to Ubuntu 21.10 (GNU/Linux 5.15.35-1-pve x86_64)
       * Documentation:  https://help.ubuntu.com
       * Management:     https://landscape.canonical.com
       * Support:        https://ubuntu.com/advantage
      Your Ubuntu release is not supported anymore.
      For upgrade information, please visit:
      http://www.ubuntu.com/releaseendoflife
      New release '22.04.1 LTS' available.
      Run 'do-release-upgrade' to upgrade to it.
      Nach der Anmeldung das:
      Updaten das hier dann:
      apt-get update
      Hit:1 http://ppa.launchpad.net/ondrej/php/ubuntu impish InRelease
      Ign:2 http://archive.ubuntu.com/ubuntu impish InRelease
      Ign:3 http://archive.ubuntu.com/ubuntu impish-updates InRelease
      Ign:4 http://archive.ubuntu.com/ubuntu impish-security InRelease
      Err:5 http://archive.ubuntu.com/ubuntu impish Release
        404  Not Found [IP: 91.189.91.38 80]
      Err:6 http://archive.ubuntu.com/ubuntu impish-updates Release
      Err:7 http://archive.ubuntu.com/ubuntu impish-security Release
      Reading package lists... Done
      E: The repository 'http://archive.ubuntu.com/ubuntu impish Release' no longer has a Release file.
      N: Updating from such a repository can't be done securely, and is therefore disabled by default.
      N: See apt-secure(8) manpage for repository creation and user configuration details.
      E: The repository 'http://archive.ubuntu.com/ubuntu impish-updates Release' no longer has a Release file.
      E: The repository 'http://archive.ubuntu.com/ubuntu impish-security Release' no longer has a Release file.
      und das beim upgraden:
       apt-get upgrade
      Building dependency tree... Done
      Calculating upgrade... Done
      The following packages will be upgraded:
        apt apt-utils isc-dhcp-client isc-dhcp-common libapt-pkg6.0 libkeyutils1
        libnss-systemd libpam-systemd libsystemd0 libudev1 python3-distupgrade
        systemd systemd-sysv systemd-timesyncd ubuntu-advantage-tools
        ubuntu-release-upgrader-core udev
      17 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
      Need to get 10.4 MB of archives.
      After this operation, 32.8 kB of additional disk space will be used.
      Do you want to continue? [Y/n] y
      Err:1 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 libnss-systemd amd64 248.3-1ubuntu8.6
        404  Not Found [IP: 185.125.190.39 80]
      Err:2 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 libsystemd0 amd64 248.3-1ubuntu8.6
      Err:3 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 systemd-timesyncd amd64 248.3-1ubuntu8.6
      Err:4 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 systemd-sysv amd64 248.3-1ubuntu8.6
      Err:5 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 libpam-systemd amd64 248.3-1ubuntu8.6
      Err:6 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 systemd amd64 248.3-1ubuntu8.6
      Err:7 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 udev amd64 248.3-1ubuntu8.6
      Err:8 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 libudev1 amd64 248.3-1ubuntu8.6
      Err:9 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 libapt-pkg6.0 amd64 2.3.9ubuntu0.1
      Err:10 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 apt amd64 2.3.9ubuntu0.1
      Err:11 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 apt-utils amd64 2.3.9ubuntu0.1
      Err:12 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 libkeyutils1 amd64 1.6.1-2ubuntu2.1
      Err:13 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 isc-dhcp-client amd64 4.4.1-2.3ubuntu1.1
      Err:14 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 isc-dhcp-common amd64 4.4.1-2.3ubuntu1.1
      Err:15 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 ubuntu-advantage-tools amd64 27.9~21.10.1
      Err:16 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 ubuntu-release-upgrader-core all 1:21.10.10
      Err:17 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 python3-distupgrade all 1:21.10.10
      E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/s/systemd/libnss-systemd_248.3-1ubuntu8.6_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
      E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/s/systemd/libsystemd0_248.3-1ubuntu8.6_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
      E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/s/systemd/systemd-timesyncd_248.3-1ubuntu8.6_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
      E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/s/systemd/systemd-sysv_248.3-1ubuntu8.6_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
      E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/s/systemd/libpam-systemd_248.3-1ubuntu8.6_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
      E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/s/systemd/systemd_248.3-1ubuntu8.6_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
      E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/s/systemd/udev_248.3-1ubuntu8.6_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
      E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/s/systemd/libudev1_248.3-1ubuntu8.6_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
      E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/a/apt/libapt-pkg6.0_2.3.9ubuntu0.1_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
      E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/a/apt/apt_2.3.9ubuntu0.1_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
      E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/a/apt/apt-utils_2.3.9ubuntu0.1_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
      E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/k/keyutils/libkeyutils1_1.6.1-2ubuntu2.1_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
      E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/i/isc-dhcp/isc-dhcp-client_4.4.1-2.3ubuntu1.1_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
      E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/i/isc-dhcp/isc-dhcp-common_4.4.1-2.3ubuntu1.1_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
      E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/u/ubuntu-advantage-tools/ubuntu-advantage-tools_27.9%7e21.10.1_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
      E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/u/ubuntu-release-upgrader/ubuntu-release-upgrader-core_21.10.10_all.deb  404  Not Found [IP: 185.125.190.39 80]
      E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/u/ubuntu-release-upgrader/python3-distupgrade_21.10.10_all.deb  404  Not Found [IP: 185.125.190.39 80]
      E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
      Was macht man denn in solch einem Fall?
      Gibts da ein How to?
      Danke und Gruss
      ? crunchip 2 Replies Last reply Reply Quote 0
        A Former User @Kusselin last edited by
        @kusselin Liegt wohl daran, dass einige Repositories nicht mehr verfügbar bzw. veraltet sind.
        Hier ein StackOverflow Beitrag, der dir vielleicht weiter hilft.
        Kusselin 1 Reply Last reply Reply Quote 0
        • Kusselin
          Kusselin @Guest last edited by
          @tmartin O.K. aber was heisst das?
          gibts da nicht einfacheres ?
          J Thomas Braun 2 Replies Last reply Reply Quote 0
            Jan1 @Kusselin last edited by
            @kusselin
            Dein Ubuntu ist wohl zu alt und Du solltet ein aktuelles verwenden.
              Thomas Braun Most Active @Kusselin last edited by
              @kusselin
              sudo do-release-upgrade
              Und künftig keine Zwischenversionen einsetzen sondern nur LTS-Releases.
              Kusselin 1 Reply Last reply Reply Quote 1
              • crunchip
                crunchip Forum Testing Most Active @Kusselin last edited by
                @kusselin sagte in Ubuntu updaten:
                Steht ja auch da, wie Thomas schon schrieb
                • Kusselin
                  Kusselin @Jan1 last edited by
                  @jan1 ja genau...das sehe ich ja auch...das es alt ist....
                  und da muss es doch eine möglichkeit über console geben ubzugraden auf die nächst höhere version
                    @kusselin
                    Ja, mit
                    • Kusselin
                      Kusselin @Thomas Braun last edited by
                      @thomas-braun sagte in Ubuntu updaten:
                      @kusselin
                      O.K. danke Dir ..mit dem befehl solls gehen?
                        @kusselin
                        Ja.
                        • Kusselin
                          @thomas-braun schau...was muss ich hier denn machen??
                          Checking for a new Ubuntu release
                          Please install all available updates for your release before upgrading.
                            @kusselin
                            sudo apt update
                            sudo apt full-upgrade
                            sudo reboot
                            • Kusselin
                              nee thomas.....das klappt so nicht...das wäre zu einfach 🙂
                               sudo apt update
                                404  Not Found [IP: 91.189.91.39 80]
                              root@Nextcloud-live:~# sudo apt full-upgrade
                                @kusselin
                                Installier es neu und halte da dann das EndOfLife im Auge und spring vorher auf den Nachfolger.
                                  @kusselin
                                  Kannst aber auch hier mal schauen:
                                  https://help.ubuntu.com/community/EOLUpgrades
                                  • Kusselin
                                    @kusselin
                                    andree Möglichkeit wie neuinstallation gibts nicht?
                                    Thomas Braun crunchip 2 Replies Last reply Reply Quote 0
                                      Thomas Braun Most Active @Kusselin last edited by Thomas Braun
                                      @kusselin
                                      Steht im dem Link drin:
                                      Aber auch dort wird geschrieben:
                                      Reinstalling is usually easier and faster, especially if you would have to upgrade through several releases.
                                      • crunchip
                                        @kusselin hatte das kürzlich auch bei einer VM gemacht, sourceslist anpassen aufs aktuelle Ubuntu und danach das full update, geht ohne Probleme
                                        Homoran Kusselin 2 Replies Last reply Reply Quote 0
                                          @crunchip sagte in Ubuntu updaten:
                                          war da das alte Repo auch nicht mehr erreichbar?
                                          • Kusselin
                                            Kusselin @crunchip last edited by
                                            das hier:
                                            ## EOL upgrade sources.list
                                            # Required
                                            deb http://old-releases.ubuntu.com/ubuntu/ CODENAME main restricted universe multiverse
                                            deb http://old-releases.ubuntu.com/ubuntu/ CODENAME-updates main restricted universe multiverse
                                            deb http://old-releases.ubuntu.com/ubuntu/ CODENAME-security main restricted universe multiverse
                                            # Optional
                                            #deb http://old-releases.ubuntu.com/ubuntu/ CODENAME-backports main restricted universe multiverse
                                            muss in die source list.....
                                            Bitte an euch...wo bzw. welche pfad ist das /etc/......?
                                            und muss ich das alte dann komplett rausnehmen aus der source list udn das hier neu rein?
                                            4649
