    4. Ständiger Restart der Adapater und ioBroker
      Fonzo last edited by
      Hallo, bei den ersten versuchen läuft ioBroker nicht stabil, die Adapter starten ständig neu.
      omeserver	2015-06-01 12:04:39	info	iobroker _restart
      Homeserver	2015-06-01 12:04:39	error	TypeError: Cannot read property 'fragmentedOperation' of null at Receiver.endPacket (D:\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io\node_modules\engine.io\node_modules\ws\l
      Homeserver	2015-06-01 12:04:39	error	uncaught exception: Cannot read property 'fragmentedOperation' of null
      Homeserver	2015-06-01 12:04:39	info	host.Homeserver instance system.adapter.hue.0 terminated with code 1 ()
      Homeserver	2015-06-01 12:04:39	info	iobroker _restart
      restart
      TypeError:	2015-06-01 12:11:19	error	at TCP.onread (net.js:529:20)
      TypeError:	2015-06-01 12:11:19	error	at Socket.Readable.push (_stream_readable.js:126:10)
      TypeError:	2015-06-01 12:11:19	error	at readableAddChunk (_stream_readable.js:163:16)
      TypeError:	2015-06-01 12:11:19	error	at Socket.emit (events.js:107:17)
      TypeError:	2015-06-01 12:11:19	error	at Socket.firstHandler (D:\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io\node_modules\engine.io\node_modules\ws\lib\WebSocket.js:718:22)
      TypeError:	2015-06-01 12:11:19	error	at Receiver.add (D:\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io\node_modules\engine.io\node_modules\ws\lib\Receiver.js:87:24)
      TypeError:	2015-06-01 12:11:19	error	at Receiver. (D:\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io\node_modules\engine.io\node_modules\ws\lib\Receiver.js:372:33)
      TypeError:	2015-06-01 12:11:19	error	at Receiver.opcodes.1.finish (D:\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io\node_modules\engine.io\node_modules\ws\lib\Receiver.js:394:12)
      TypeError:	2015-06-01 12:11:19	error	at Receiver.endPacket (D:\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io\node_modules\engine.io\node_modules\ws\lib\Receiver.js:222:18)
      TypeError:	2015-06-01 12:11:19	error	Cannot read property 'fragmentedOperation' of null
      uncaught	2015-06-01 12:11:19	error	exception: Cannot read property 'fragmentedOperation' of null
        kann das mit deinem Versuch zusammenhängen Hue zu konfigurieren?
        ich würde testweise diese Instanz deaktivieren.
          Ich habe mal die Adapter socketio, simple-api und hue deaktiviert, jetzt scheint es erst mal so weit nicht mehr ständig neu zu laden.
          1.0k
