    4. Node-red Adapter Installation funktioniert nicht
      Fonzo last edited by
      ich habe versucht unter Windows Server 2012 R2 den node-red Adapter von der Admin Console von ioBroker heraus zu installieren. Python 2.7 sowie Microsoft NET Framework 3.5 sowie NET Framework 4.5 sind als Features unter Windows Server 2012 installiert.
      Bei dem Versuch node-red Adapter zu installieren erscheint folgende Fehlermeldung:
      $ ./iobroker add node-red
      npm install iobroker.node-red --production --prefix "D:/ioBroker" (System call)
      gyp
      ERR! configure error
      gyp
       ERR! stack Error: Can't find Python executable "python", you can set the PYTHON env variable.gyp ERR! stack     at failNoPython (D:\Programme\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:103:14)
      gyp ERR!
      stack     at D:\Programme\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:64:11gyp ERR! stack     at FSReqWrap.oncomplete (evalmachine.<anonymous>:99:15)
      gyp ERR! System Windows_NT 6.3.9600
      gyp ERR! command "node" "D:\\Programme\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"gyp ERR! cwd D:\ioBroker\node_modules\iobroker.node-red\node_modules\node-red\node_modules\irc\node_modules\node-icu-charset-detector
      gyp ERR! node -v v0.11.16gyp ERR! node-gyp -v v1.0.2
      gyp ERR! not ok
      gyp
      gyp ERR! stack Error: Can't find Python executable "python", you can set the PYTHON env variable.gyp ERR! stack     at failNoPython (D:\Programme\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:103:14)
      gyp ERR! stack     at D:\Programme\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:64:11gyp ERR! stack     at FSReqWrap.oncomplete (evalmachine.<anonymous>:99:15)
      gyp ERR! command "node" "D:\\Programme\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"gyp ERR! cwd D:\ioBroker\node_modules\iobroker.node-red\node_modules\node-red\node_modules\bcrypt
      gyp ERR! not ok
      npm
       WARN optional dep failed, continuing node-icu-charset-detector@0.0.7
      gyp
       stack     at failNoPython (D:\Programme\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:103:14)gyp ERR! stack     at D:\Programme\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:64:11
      gyp ERR! System Windows_NT 6.3.9600gyp ERR! command "node" "D:\\Programme\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"
      gyp ERR! cwd D:\ioBroker\node_modules\iobroker.node-red\node_modules\node-red\node_modules\ws\node_modules\bufferutil
      gyp ERR! not ok
      npm
       WARN optional dep failed, continuing bcrypt@0.8.1
      gyp
      gyp ERR! stack     at failNoPython (D:\Programme\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:103:14)gyp ERR! stack     at D:\Programme\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:64:11
      gyp ERR! stack     at FSReqWrap.oncomplete (evalmachine.<anonymous>:99:15)gyp ERR! System Windows_NT 6.3.9600
      gyp ERR! command "node" "D:\\Programme\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"gyp ERR! cwd D:\ioBroker\node_modules\iobroker.node-red\node_modules\node-red\node_modules\ws\node_modules\utf-8-validate
      gyp
       ERR! not ok
      npm
       WARN optional dep failed, continuing bufferutil@1.0.1
      npm
       WARN optional dep failed, continuing utf-8-validate@1.0.1
      gyp
      ERR!
      configure error gyp ERR!
       stack
      gyp
      ERR! command "node" "D:\\Programme\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "configure" "--fallback-to-build" "--module=D:\\ioBroker\\node_modules\\iobroker.node-red\\node_modules\\mongodb\\node_modules\\mongodb-core\\node_modules\\bson\\node_modules\\bson-ext\\build\\Release\\bson.node" "--module_name=bson" "--module_path=D:\\ioBroker\\node_modules\\iobroker.node-red\\node_modules\\mongodb\\node_modules\\mongodb-core\\node_modules\\bson\\node_modules\\bson-ext\\build\\Release"gyp ERR! cwd D:\ioBroker\node_modules\iobroker.node-red\node_modules\mongodb\node_modules\mongodb-core\node_modules\bson\node_modules\bson-ext
      gyp ERR! not ok
      node-pre-gyp
      ERR! build error
      node-pre-gyp ERR! stack
       Error: Failed to execute 'node-gyp.cmd configure --fallback-to-build --module=D:\ioBroker\node_modules\iobroker.node-red\node_modules\mongodb\node_modules\mongodb-core\node_modules\bson\node_modules\bson-ext\build\Release\bson.node --module_name=bson --module_path=D:\ioBroker\node_modules\iobroker.node-red\node_modules\mongodb\node_modules\mongodb-core\node_modules\bson\node_modules\bson-ext\build\Release' (1)node-pre-gyp ERR!
      stack     at ChildProcess. <anonymous>(D:\ioBroker\node_modules\iobroker.node-red\node_modules\mongodb\node_modules\mongodb-core\node_modules\bson\node_modules\bson-ext\node_modules\node-pre-gyp\lib\util\compile.js:83:29)node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:110:17)
      node-pre-gyp ERR! stack     at maybeClose (child_process.js:1008:16)
      node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (child_process.js:1080:5)
      node-pre-gyp ERR! System Windows_NT 6.3.9600
      node-pre-gyp ERR! command "node" "D:\\ioBroker\\node_modules\\iobroker.node-red\\node_modules\\mongodb\\node_modules\\mongodb-core\\node_modules\\bson\\node_modules\\bson-ext\\node_modules\\node-pre-gyp\\bin\\node-pre-gyp.js" "install" "--fallback-to-build"
      node-pre-gyp ERR! cwd D:\ioBroker\node_modules\iobroker.node-red\node_modules\mongodb\node_modules\mongodb-core\node_modules\bson\node_modules\bson-ext
      node-pre-gyp ERR! node -v v0.11.16
      node-pre-gyp ERR! node-pre-gyp -v v0.6.4
      node-pre-gyp ERR! not ok
      gyp
      gyp
      gyp
      ERR! cwd D:\ioBroker\node_modules\iobroker.node-red\node_modules\node-red\node_modules\irc\node_modules\iconvgyp ERR! node -v v0.11.16
      gyp ERR! not ok
      child_process: customFds option is deprecated, use stdio instead.
      gyp
      gyp ERR!
       ERR! command "node" "D:\\Programme\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild" "--name=serialport" "--configuration=Release" "--module_name=serialport" "--version=1.4.10" "--major=1" "--minor=4" "--patch=10" "--runtime=node" "--node_abi=node-v14" "--platform=win32" "--target_platform=win32" "--arch=x64" "--target_arch=x64" "--module_main=./serialport" "--host=https://node-serialport.s3.amazonaws.com/" "--module_path=D:\\ioBroker\\node_modules\\iobroker.node-red\\node_modules\\node-red\\node_modules\\serialport\\build\\serialport\\v1.4.10\\Release\\node-v14-win32-x64" "--remote_path=./serialport/v1.4.10/Release/" "--package_name=node-v14-win32-x64.tar.gz" "--staged_tarball=build\\stage\\serialport\\v1.4.10\\Release\\node-v14-win32-x64.tar.gz" "--hosted_path=https://node-serialport.s3.amazonaws.com/serialport/v1.4.10/Release/" "--hosted_tarball=https://node-serialport.s3.amazonaws.com/serialport/v1.4.10/Release/node-v14-win32-x64.tar.gz"gyp ERR! cwd D:\ioBroker\node_modules\iobroker.node-red\node_modules\node-red\node_modules\serialport
      gyp ERR! not ok
      node-pre-gyp
       ERR! build error
      node-pre-gyp
       ERR! stack Error: Failed to execute 'node-gyp.cmd rebuild --name=serialport --configuration=Release --module_name=serialport --version=1.4.10 --major=1 --minor=4 --patch=10 --runtime=node --node_abi=node-v14 --platform=win32 --target_platform=win32 --arch=x64 --target_arch=x64 --module_main=./serialport --host=https://node-serialport.s3.amazonaws.com/ --module_path=D:\ioBroker\node_modules\iobroker.node-red\node_modules\node-red\node_modules\serialport\build\serialport\v1.4.10\Release\node-v14-win32-x64 --remote_path=./serialport/v1.4.10/Release/ --package_name=node-v14-win32-x64.tar.gz --staged_tarball=build\stage\serialport\v1.4.10\Release\node-v14-win32-x64.tar.gz --hosted_path=https://node-serialport.s3.amazonaws.com/serialport/v1.4.10/Release/ --hosted_tarball=https://node-serialport.s3.amazonaws.com/serialport/v1.4.10/Release/node-v14-win32-x64.tar.gz' (1)node-pre-gyp
       ERR! stack     at ChildProcess. <anonymous>(D:\ioBroker\node_modules\iobroker.node-red\node_modules\node-red\node_modules\serialport\node_modules\node-pre-gyp\lib\util\compile.js:76:29)node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:110:17)
      node-pre-gyp ERR! System Windows_NT 6.3.9600node-pre-gyp
       ERR! command "node" "D:\\ioBroker\\node_modules\\iobroker.node-red\\node_modules\\node-red\\node_modules\\serialport\\node_modules\\node-pre-gyp\\bin\\node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd D:\ioBroker\node_modules\iobroker.node-red\node_modules\node-red\node_modules\serialport
      node-pre-gyp ERR! node-pre-gyp -v v0.5.19
      npm
       WARN optional dep failed, continuing iconv@2.1.7
      npm
       ERR! Windows_NT 6.3.9600npm ERR! argv "D:\\Programme\\nodejs\\\\node.exe" "D:\\Programme\\nodejs\\node_modules\\npm\\bin\\npm-cli.js" "install" "iobroker.node-red" "--production" "--prefix" "D:/ioBroker"
      npm ERR! node v0.11.16
      npm ERR! npm  v2.3.0
      npm ERR! code ELIFECYCLE
      npm ERR! serialport@1.4.10 install: `node-pre-gyp install --fallback-to-build`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the serialport@1.4.10 install script 'node-pre-gyp install --fallback-to-build'.
      npm ERR! This is most likely a problem with the serialport package,
      npm ERR! not with npm itself.
      npm ERR!
       Tell the author that this fails on your system:npm ERR!     node-pre-gyp install --fallback-to-build
      npm ERR! You can get their info via:
      npm ERR!     npm owner ls serialport
      npm ERR! There is likely additional logging output above.
      npm ERR! Please include the following file with any support request:npm ERR!
           C:\Windows\system32\npm-debug.log
      Cannot install iobroker.node-red: 1
      ERROR: process exited with code 25</anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous>
        @Fonzo:
        gyp
        gyp
        gyp ERR!
        gyp ERR! not ok
        gyp
        gyp ERR! not ok
        npm
        gyp
        gyp ERR! not ok
        npm
        gyp
        gyp
         ERR! not ok
        npm
        npm
        gyp
        ERR!
         stack
        gyp
        gyp ERR! not ok
        node-pre-gyp
        ERR! build error
        gyp
        gyp
        gyp
        gyp ERR! not ok
        gyp
        gyp ERR!
        gyp ERR! not ok
        node-pre-gyp
         ERR! build error
        node-pre-gyp
        npm
        npm
        npm ERR! npm  v2.3.0
        npm ERR!
        npm ERR!
        Viel zu viel… Was für eine node.js Version hast du? Es geht nur kleine 0.12.0.
        Probiere mal aus "als Administrator" Konsole in ioBroker Verzeichnis:
          @akamia in anderm Thread:
          Es ist unsportlich - gebe ich ja zu - aber ich habe einfach nur
          http://download.iobroker.org/ioBrokerIn … .0.5.0.exe
          ausgeführt. Vorher Deine Node-Version sauber deinstallieren. `
          Hast du das gemacht?
            @Bluefox:
            Version 0.11.6
            Wenn ich das npm in der Admin Konsole ausführe findet er wohl Pyton aber es kommt dann eine Meldung
            Die Projekte in dieser Projektmappe werden nacheinander erstellt. Um eine parall
            ele Erstellung zu ermöglichen, müssen Sie den Schalter "/m" hinzufügen.
            MSBUILD : error MSB3428: Die Visual C++-Komponente "VCBuild.exe" konnte nicht g
            eladen werden. Um dieses Problem zu beheben, installieren Sie entweder 1) .NET
            Framework 2.0 SDK oder 2) Microsoft Visual Studio 2005 oder 3) fügen Sie den Sp
            eicherort der Komponente zum Systempfad hinzu, falls er vom Standardspeicherort
             abweicht.
            Net Framework 3.5 und 4.0 läuft allerdings auf dem Server. Die höheren Versionen sollten an sich ja die kleineren inkludiert haben.
              @Fonzo:
              @Bluefox:
              Version 0.11.6
               abweicht.
              Net Framework 3.5 und 4.0 läuft allerdings auf dem Server. Die höheren Versionen sollten an sich ja die kleineren inkludiert haben. `
              Visual Studio ist optional.
              So lange, dass " WARN optional dep failed," erscheinen, ist es ok.
