    4. Probleme mit Updates
      Steinmetz_4 last edited by
      Servus,
      ich kann seit ein paar Wochen keine Updates mehr machen.
      Ich glaube mich zu erinnern, dass ich Node und oder Node-js upgedatet habe.
      Alle Updates brechen mit Error 25 ab.
      pi@iobroker-pi:/opt/iobroker/node_modules $ for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
      pi@iobroker-pi:/opt/iobroker/node_modules $ cd
      pi@iobroker-pi:~ $ iob stop
      pi@iobroker-pi:~ $ iobroker update
      Server Configured backup period 120 is larger than the supported maximum of 35791 minutes. Defaulting to 120 minutes.
      Used repository: stable
      Adapter    "admin"        : 6.2.23   , installed 6.2.22 [Updatable]
      Adapter    "alexa2"       : 3.19.9   , installed 3.19.9
      Adapter    "backitup"     : 2.4.12   , installed 2.4.12
      Adapter    "chromecast"   : 2.3.1    , installed 2.3.1
      Adapter    "cloud"        : 4.2.2    , installed 4.2.2
      Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
      Adapter    "daswetter"    : 3.1.3    , installed 3.1.3
      Adapter    "discovery"    : 3.0.5    , installed 3.0.5
      Adapter    "ds18b20"      : 1.6.0    , installed 1.6.0
      Adapter    "dwd"          : 2.8.3    , installed 2.8.3
      Adapter    "epson_ecotank_et_2750": 0.0.12, installed 0.0.12
      Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
      Adapter    "flot"         : 1.11.0   , installed 1.11.0
      Adapter    "fritzdect"    : 2.2.3    , installed 2.2.3
      Adapter    "history"      : 2.2.0    , installed 2.2.0
      Adapter    "homeconnect"  : 1.1.0    , installed 1.1.0
      Adapter    "hs100"        : 2.1.2    , installed 2.1.2
      Adapter    "ical"         : 1.13.1   , installed 1.13.1
      Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
      Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
      Adapter    "influxdb"     : 3.1.8    , installed 3.1.8
      Adapter    "info"         : 1.9.19   , installed 1.9.19
      Adapter    "iot"          : 1.11.9   , installed 1.11.9
      Adapter    "jarvis"       : 3.0.15   , installed 3.0.14 [Updatable]
      Adapter    "javascript"   : 6.0.3    , installed 6.0.3
      Controller "js-controller": 4.0.23   , installed 4.0.23
      Adapter    "knx"          : 2.0.13   , installed 2.0.13
      Adapter    "lgtv"         : 1.1.10   , installed 1.1.10
      Adapter    "meross"       : 1.14.0   , installed 1.14.0
      Adapter    "mihome-vacuum": 3.4.2    , installed 3.4.2
      Adapter    "node-red"     : 4.0.0    , installed 4.0.0
      Adapter    "ping"         : 1.5.3    , installed 1.5.3
      Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
      Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
      Adapter    "shelly"       : 6.0.0    , installed 6.0.0
      Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
      Adapter    "socketio"     : 4.2.0    , installed 4.2.0
      Adapter    "sonnen"       : 1.11.0   , installed 1.11.0
      Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
      Adapter    "sql"          : 2.1.8    , installed 2.1.8
      Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
      Adapter    "telegram"     : 1.14.1   , installed 1.14.1
      Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
      Adapter    "trashschedule": 2.0.3    , installed 2.0.3
      Adapter    "vis"          : 1.4.15   , installed 1.4.15
      Adapter    "vis-google-fonts": 1.0.3 , installed 1.0.3
      Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
      Adapter    "vis-icontwo"  : 0.89.0   , installed 0.89.0
      Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.3
      Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
      Adapter    "weatherunderground": 3.4.2, installed 3.4.2
      Adapter    "web"          : 4.3.0    , installed 4.3.0
      Adapter    "whatsapp-cmb" : 0.2.2    , installed 0.2.2
      Adapter    "worx"         : 2.0.3    , installed 1.7.0  [Updatable]
      Adapter    "ws"           : 1.3.0    , installed 1.3.0
      Adapter    "zwave2"       : 3.0.3    , installed 3.0.3
      pi@iobroker-pi:~ $ iobroker upgrade self
      Host    "IoBroker-Pi4-Master" is up to date.
      Hier vermute ich den Fehler, Installed und Candidate sind nicht gleich.
      pi@iobroker-pi:/opt/iobroker $ which nodejs node npm && nodejs -v && node -v && npm -v && apt policy nodejs
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      v16.17.1
      v16.17.1
      8.19.2
      nodejs:
        Installed: 16.17.1-deb-1nodesource1
        Candidate: 16.18.0-deb-1nodesource1
        Version table:
           16.18.0-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
       *** 16.17.1-deb-1nodesource1 100
              100 /var/lib/dpkg/status
           12.22.12~dfsg-1~deb11u1 500
              500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
           12.22.5~dfsg-2~11u1 500
              500 http://deb.debian.org/debian bullseye/main arm64 Packages
      pi@iobroker-pi:/opt/iobroker $ cd
      Kann mir jemand weiterhelfen, bevor ich alles zu Grunde experimentiere?
      Mfg
      Tom
      Meister Mopper mickym Homoran 3 Replies Last reply Reply Quote 0
      • Meister Mopper
        Meister Mopper @Steinmetz_4 last edited by
        @steinmetz_4
        Hast Du hier im Forum schon mal nach error 25 gesucht? Da wirste mit Lösungen erschlagen.
        • mickym
          mickym Most Active @Steinmetz_4 last edited by mickym
          @steinmetz_4 Schau mal welche Themen in dem Forum zur Verfügung stehen:
          Fällt Dir was auf?
          Ansonsten hier MEIN vorgehen:
          https://forum.iobroker.net/post/845093
            Homoran Global Moderator Administrators @Steinmetz_4 last edited by
            @steinmetz_4 sagte in Probleme mit Updates:
              Steinmetz_4 @Homoran last edited by
              @homoran sagte in Probleme mit Updates:
              Das da oben habe ich gemacht, hilft aber leider nicht.
              Irgendwie scheint mein Problem noch wo anders zu liegen.
              Dass ich bei "Error25" duzende Einträge finde, habe ich gemerkt. Ich weiß nur nicht, was für mich der richtige Ansatz ist...
              Thomas Braun Homoran mickym 3 Replies Last reply Reply Quote 0
                Thomas Braun Most Active @Steinmetz_4 last edited by Thomas Braun
                @steinmetz_4
                Dann installier einen der Adapter mit --debug-Option.
                Ausgaben dann hier posten.
                An deinem npm hast du aber manuell herumgefummelt, das ist nicht die vorgesehene Version für nodejs 16.17.1
                  dann zeig mal
                  • mickym
                    @steinmetz_4 Ich hab Dir mein Vorgehen noch verlinkt. Mach halt ein Backup deines systems vorher.
                      dann zeig mal
                        Steinmetz_4 @Thomas Braun last edited by
                        @thomas-braun sagte in Probleme mit Updates:
                        @steinmetz_4
                        Kann sein, dass ich auch npm aktualisiert habe.
                          @steinmetz_4
                          iobroker upgrade admin --debug
                            Steinmetz_4 @mickym last edited by
                            @mickym sagte in Probleme mit Updates:
                            pi@iobroker-pi:~ $ cd /opt/iobroker
                            pi@iobroker-pi:/opt/iobroker $ sudo rm -rf node_modules
                            pi@iobroker-pi:/opt/iobroker $ sudo rm package-lock.json
                            pi@iobroker-pi:/opt/iobroker $ npm cache clean --force
                            npm WARN using --force Recommended protections disabled.
                            pi@iobroker-pi:/opt/iobroker $ npm install
                            npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
                            npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated
                            npm WARN deprecated source-map-url@0.4.1: See https://github.com/lydell/source-map-url#deprecated
                            npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated
                            npm WARN deprecated source-map-resolve@0.5.3: See https://github.com/lydell/source-map-resolve#deprecated
                            npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                            npm WARN deprecated multer@1.4.4: Multer 1.x is affected by CVE-2022-24434. This is fixed in v1.4.4-lts.1 which drops support for versions of Node.js before 6. Please upgrade to at least Node.js 6 and version 1.4.4-lts.1 of Multer. If you need support for older versions of Node.js, we are open to accepting patches that would fix the CVE on the main 1.x release line, whilst maintaining compatibility with Node.js 0.10.
                            npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
                            npm WARN deprecated w3c-hr-time@1.0.2: Use your platform's native performance.now() and performance.timeOrigin.
                            npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                            npm WARN deprecated circular-json@0.5.9: CircularJSON is in maintenance only, flatted is its successor.
                            npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now a built-in Node module. If you've depended on crypto, you should switch to the one that's built-in.
                            npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                            npm WARN deprecated xmldom@0.1.31: Deprecated due to CVE-2021-21366 resolved in 0.5.0
                            npm WARN deprecated @types/keyv@4.2.0: This is a stub types definition. keyv provides its own type definitions, so you do not need this installed.
                            npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
                            npm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
                            npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                            npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
                            npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                            npm WARN deprecated axios@0.27.0: Formdata complete broken, incorrect build size
                            npm WARN deprecated xmldom@0.1.16: Deprecated due to CVE-2021-21366 resolved in 0.5.0
                            added 2246 packages in 6m
                            194 packages are looking for funding
                              run `npm fund` for details
                            pi@iobroker-pi:/opt/iobroker $ npm list
                            iobroker.inst@3.0.0 /opt/iobroker
                            ├── @types/caseless@0.12.2 extraneous
                            ├── @types/request@2.48.8 extraneous
                            ├── @types/tough-cookie@4.0.2 extraneous
                            ├── coffeescript@1.12.7 extraneous
                            ├── iobroker.admin@6.2.23
                            ├── iobroker.alexa2@3.19.9
                            ├── iobroker.backitup@2.4.12
                            ├── iobroker.chromecast@2.3.1
                            ├── iobroker.cloud@4.2.2
                            ├── iobroker.coronavirus-statistics@0.8.7
                            ├── iobroker.daswetter@3.1.3
                            ├── iobroker.discovery@3.1.0
                            ├── iobroker.ds18b20@1.6.0
                            ├── iobroker.dwd@2.8.3
                            ├── iobroker.epson_ecotank_et_2750@0.0.12
                            ├── iobroker.feiertage@1.1.0
                            ├── iobroker.flot@1.11.0
                            ├── iobroker.fritzdect@2.2.3
                            ├── iobroker.history@2.2.0
                            ├── iobroker.homeconnect@1.1.0
                            ├── iobroker.hs100@2.1.2
                            ├── iobroker.ical@1.13.1
                            ├── iobroker.icons-addictive-flavour-png@0.1.0
                            ├── iobroker.icons-material-png@0.1.0
                            ├── iobroker.icons-material-svg@0.1.0
                            ├── iobroker.icons-mfd-png@1.1.0
                            ├── iobroker.icons-mfd-svg@1.1.0
                            ├── iobroker.icons-open-icon-library-png@0.1.2
                            ├── iobroker.icons-ultimate-png@1.0.1
                            ├── iobroker.influxdb@3.1.8
                            ├── iobroker.info@1.9.19
                            ├── iobroker.iot@1.11.9
                            ├── iobroker.jarvis@3.0.15
                            ├── iobroker.javascript@6.0.3
                            ├── iobroker.js-controller@4.0.23
                            ├── iobroker.knx@2.0.13
                            ├── iobroker.lgtv@1.1.10
                            ├── iobroker.meross@1.14.0
                            ├── iobroker.mihome-vacuum@3.4.2
                            ├── iobroker.net-tools@0.2.0
                            ├── iobroker.node-red@3.3.1
                            ├── iobroker.ping@1.5.3
                            ├── iobroker.pollenflug@1.0.6
                            ├── iobroker.rpi2@1.3.2
                            ├── iobroker.scenes@2.3.9
                            ├── iobroker.shelly@6.0.0
                            ├── iobroker.simple-api@2.7.0
                            ├── iobroker.sonnen@1.11.0
                            ├── iobroker.sonoff@2.5.1
                            ├── iobroker.sourceanalytix@0.4.12-1
                            ├── iobroker.sql@2.1.8
                            ├── iobroker.tankerkoenig@2.1.1
                            ├── iobroker.telegram@1.14.1
                            ├── iobroker.tr-064@4.2.16
                            ├── iobroker.trashschedule@2.0.3
                            ├── iobroker.vis-google-fonts@1.0.3
                            ├── iobroker.vis-hqwidgets@1.3.0
                            ├── iobroker.vis-icontwo@0.89.0
                            ├── iobroker.vis-inventwo@3.3.3
                            ├── iobroker.vis-jqui-mfd@1.0.12
                            ├── iobroker.vis-justgage@1.0.2
                            ├── iobroker.vis-materialdesign@0.5.9
                            ├── iobroker.vis-plumb@1.0.2
                            ├── iobroker.vis-timeandweather@1.2.2
                            ├── iobroker.vis@1.4.15
                            ├── iobroker.weatherunderground@3.4.2
                            ├── iobroker.web@4.3.0
                            ├── iobroker.whatsapp-cmb@0.2.2
                            ├── iobroker.worx@1.7.0
                            ├── iobroker.zwave2@3.0.3
                            ├── node-inspect@2.0.0 extraneous
                            ├── suncalc2@1.8.1 extraneous
                            ├── typescript@4.7.4 extraneous
                            ├── virtual-tsc@0.6.2 extraneous
                            └── wake_on_lan@1.0.0 extraneous
                            Hab ich gemacht. 'Soll ich npm prune auch machen?
                            mikeal created this issue in request/request
                            open Request’s Past, Present and Future #3142
                            Qix- created this issue in visionmedia/debug
                            closed ReDos Vulnerability Regression Visibility Notice #797
                            mickym Homoran 2 Replies Last reply Reply Quote 0
                            • mickym
                              Ja
                                @steinmetz_4 mixst du gerade beide Anleitungen?
                                die verfolgen unterschiedliche Ansätze!
                                entweder - oder! nicht beides!
                                  pi@iobroker-pi:~ $ iobroker upgrade jarvis --debug
                                  Would you like to upgrade jarvis from @3.0.14 to @3.0.15 now? [(y)es, (n)o]: y
                                  Update jarvis from @3.0.14 to @3.0.15
                                  NPM version: 8.19.2
                                  Installing iobroker.jarvis@3.0.15... (System call)
                                  added 56 packages, removed 16 packages, and changed 74 packages in 22s
                                  188 packages are looking for funding
                                  upload [153] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/apple-touch-icon-120x120.png apple-touch-icon-120x120.png image/png
                                  upload [150] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/apple-touch-icon-iphone-retina.png.png apple-touch-icon-iphone-retina.png.png image/png
                                  upload [100] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/icons/favicon.ico icons/favicon.ico image/vnd.microsoft.icon
                                  upload [90] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/icons/ios/AppIcon-20~ipad.png icons/ios/AppIcon-20~ipad.png image/png
                                  upload [80] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/icons/ios/AppIcon-60@2x~car.png icons/ios/AppIcon-60@2x~car.png image/png
                                  upload [70] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/icons/web/favicon.ico icons/web/favicon.ico image/vnd.microsoft.icon
                                  upload [60] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/img/moon_12.436b3798.png img/moon_12.436b3798.png image/png
                                  upload [50] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/img/moon_21.f3b5ba0a.png img/moon_21.f3b5ba0a.png image/png
                                  upload [40] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/img/moon_4.61c6ba58.png img/moon_4.61c6ba58.png image/png
                                  upload [30] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/img/weather_set5_13.a630a54d.png img/weather_set5_13.a630a54d.png image/png
                                  upload [20] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/img/weather_set5_5.5334b7ac.png img/weather_set5_5.5334b7ac.png image/png
                                  upload [19] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/img/weather_set5_6.1435f645.png img/weather_set5_6.1435f645.png image/png
                                  upload [18] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/img/weather_set5_7.439d10db.png img/weather_set5_7.439d10db.png image/png
                                  upload [17] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/img/weather_set5_8.9011b110.png img/weather_set5_8.9011b110.png image/png
                                  upload [16] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/img/weather_set5_9.9dc0f52e.png img/weather_set5_9.9dc0f52e.png image/png
                                  upload [15] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/index.html index.html text/html
                                  upload [14] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/js/1.e516e81e.js js/1.e516e81e.js application/javascript
                                  upload [13] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/js/10.de09a5cd.js js/10.de09a5cd.js application/javascript
                                  upload [12] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/js/11.b003d093.js js/11.b003d093.js application/javascript
                                  upload [11] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/js/3.4a8ae51d.js js/3.4a8ae51d.js application/javascript
                                  upload [10] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/js/4.9a563abe.js js/4.9a563abe.js application/javascript
                                  upload [9] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/js/5.9ba66b59.js js/5.9ba66b59.js application/javascript
                                  upload [8] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/js/6.020de47f.js js/6.020de47f.js application/javascript
                                  upload [7] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/js/7.89eaea6c.js js/7.89eaea6c.js application/javascript
                                  upload [6] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/js/8.cb657ea9.js js/8.cb657ea9.js application/javascript
                                  upload [5] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/js/9.e9a6eb5e.js js/9.e9a6eb5e.js application/javascript
                                  upload [4] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/js/app.5d534061.js js/app.5d534061.js application/javascript
                                  upload [3] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/js/app.hash.json js/app.hash.json application/json
                                  upload [2] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/js/app.licences.json js/app.licences.json application/json
                                  upload [1] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/js/vendor.3ed67ef3.js js/vendor.3ed67ef3.js application/javascript
                                  upload [0] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/socket.io-2.3.1.slim.js socket.io-2.3.1.slim.js application/javascript
                                  upload [15] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/admin.css admin.css text/css
                                  upload [14] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/admin.js admin.js application/javascript
                                  upload [13] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                  upload [12] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                  upload [11] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                  upload [10] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                  upload [9] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                  upload [8] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                  upload [7] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                  upload [6] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                  upload [5] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                  upload [4] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                  upload [3] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/index_m.html index_m.html text/html
                                  upload [2] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/jarvis.png jarvis.png image/png
                                  upload [1] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/words.js words.js application/javascript
                                  upload [0] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/zefau.jpg zefau.jpg image/jpeg
                                    @steinmetz_4 da ist kein error25
                                    und ACHTUNG!!
                                      Nein! Ich mische nichts durcheinander.
                                        @steinmetz_4
                                        Von
                                        war aber nicht die Rede. Jedenfalls nicht von mir.
                                          das war der alternative Vorschlag von @mickym, den @Steinmetz_4 leider hier untergemischt hat
                                            Ja, ich kann mich düster erinnern, dass das ganze begann mit einem Update von Nodered. Darum habe ich den Vorschlag von Mickym ausprobiert.
                                            Ich habe nun den Worx Adapter über die Adminoberfläche upgedatet und es hat funktioniert.
                                            Ich Danke euch für eure Hilfe!!! Ohne eure Tips, wäre das nie wieder was geworden.
                                            Tolles Forum, tolle Leute...
                                            Mfg
                                            Tom
                                            81.0k
                                            2083
