    4. [Problem] Install ioBroker in Raspbian Jessie geht nicht weiter, Fehler
      hajo48 last edited by
      MOD-Edit by eric2905; 02-05.2017/20:07 - Betreff angepasst und Code-Tags gesetzt
      ich bin Anfänger und hab ein Problem mit der Einrichtung/Konfiguration von ioBroker.
      Ist-Zustand:
      Raspberry 1 Modell B
      Raspbian Jessie installiert ok
      Nach Installationsanleitung inclusive Node.js neu für Raspberry 1 ok.
      Anschliesende Installation von ioBroker geht nicht weiter, was läuft da schief.
      Hier der Ablauf:
      login as: pi
      pi@192.168.xxx password:
      The programs included with the Debian GNU/Linux system are free software;
      the exact distribution terms for each program are described in the
      individual files in /usr/share/doc/*/copyright.
      Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
      permitted by applicable law.
      Last login: Wed Apr 26 00:44:12 2017 from xxxx-pc.fritz.box
      pi@raspberrypi:~ $ node -v
      v0.12.6
      pi@raspberrypi:~ $ sudo mkdir /opt/iobroker
      pi@raspberrypi:~ $ sudo chmod 777 /opt/iobroker
      pi@raspberrypi:~ $ cd /opt/iobroker
      pi@raspberrypi:/opt/iobroker $ sudo npm install iobroker --unsafe-perm
      > iobroker@0.9.0 install /opt/iobroker/node_modules/iobroker
      > node lib/setup.js
      npm install iobroker.js-controller --production --prefix /opt/iobroker
      npm WARN engine request@2.81.0: wanted: {"node":">= 4"} (current: {"node":"0.12.6","npm":"2.11.2"})
      npm WARN engine har-validator@4.2.1: wanted: {"node":">=4"} (current: {"node":"0.12.6","npm":"2.11.2"})
      npm WARN engine har-schema@1.0.5: wanted: {"node":">=4"} (current: {"node":"0.12.6","npm":"2.11.2"})
      Ich bitte um Hilfe! 😞
        keynight last edited by
        ssh raspberrypi
        wget https://github.com/ioBroker/ioBroker/blob/master/install/linux/install-raspbian8.sh
        sudo bash install-raspbian8.sh
          Wo hast du die uralte Version von nodejs her, du benötigst mindestens 4.xx
          http://www.iobroker.net/?page_id=5106&lang=de
          • eric2905
            eric2905 last edited by
            Hallo und Willkommen an Bord,
            der Fehler steht doch im Log drin:
            Du verwendest eine zu alte Version von ppm und node.js.
            Schau Dir mal diese Anleitung an - da steht erklärt, wie Du node.js updates ==> http://www.iobroker.net/?page_id=5106&lang=de
            Bitte achte drauf, das Du den Abschnitt für Raspberry 1 verwendest!!!
            Gruß,
            Eric
            PS: Rainer war schneller 😄
              @Homoran:
              Rainer `
              Hallo Rainer,
              vielen Dank für die Antwort, hilft mir nur nicht wirklich weiter, habe die Installation genau nach dieser, von dir genannten
              Url/Seite vorgenommen.
              Habe auch Node.js wie angegeben, nur für Raspberry 1 genommen.
              Was muss ich denn nun laut Installationsanleitung Node.js Raspberry 1 anders machen?
              Gruss
              Joachim
                @eric2905:
                Gruß,
                Eric
                Hallo Eric,
                Das selbe habe ich auch Rainer geschrieben.
                PS: Rainer war schneller 😄 `
                  @hajo48:
                  Was muss ich denn nun laut Installationsanleitung Node.js Raspberry 1 anders machen? `
                  Mit dem Pi1 wirst du nicht lange glücklich werden.
                  Geh mal auf diese Seite
                  http://www.iobroker.net/?page_id=2563&lang=de
                  Dort habe ich ein Image für den Pi1 mit nodejs 6.xx gemacht.
                  Wie weiß ich im Moment selber nicht :oops:
                    Hallo Rainer,
                    entschuldige meine späte Antwort, das Image hatte ich schon mal installiert und ließ sich auch starten aber die vorgeschlagenen Update's lassen sich nicht installieren bzw. erst garnicht herrunterladen. Es kommen immer Errors.
                    Mein Vorhaben ist es eigendlich mit den Raspbi und einen nano CUL Bausatz CC1101 433Mhz CUL 433 USB-Stick für FHEM
                    meine Somfy Markiese zu steuern / bedienen.
                    Hast du da einen guten und nachvollziehbaren Vorschlag für einen Anfänger?
                    Vielen Dank im Voraus für deine Mühe.
                    Joachim 😐
                    • kmxak
                      Für den Pi1 brauchst du armv6 hatte auch probleme mit der installation auf einem zero.
                      Der Code siehe unten müsste theoretisch gehen. Habe ich aber noch nicht getestet.
                      Node v4.8.3 Installieren
                      wget https://nodejs.org/dist/v4.8.3/node-v4.8.3-linux-armv6l.tar.gz
                      tar -xvf node-v4.8.3-linux-armv6l.tar.gz
                      cd node-v4.8.3-linux-armv6l
                      sudo cp -R * /usr/local/
                      Version Prüfen
                      > node -v
                      ggf fall es noch nicht geht folgendes ausführen
                      sudo ln -s /usr/local/bin/nodejs /usr/bin/node
                      Wenn es immer noch nicht geht meld dich einfach nochmal
                      (@ Mod wir sollten die Installation für den pi1 oder zero und zero w mal anpassen. Die Anleitung für den Pi 1 geht bzw ging bei mir auch nicht.)
                        Hallo Alex,
                        vielen Dank für deinen Tip, die v4.8.3 habe ich installiert aber bei der Insallation von ioBroker
                        kommen Fehler über Fehler, die ich als Anfänger im Moment nicht einordnen kann.
                        Hier mal der Ablauf:
                        v4.8.3
                        mkdir: das Verzeichnis ▒/opt/iobroker▒ kann nicht angelegt werden: Die Datei existiert bereits
                        pi@raspberrypi:/opt/iobroker $ sudo npm install iobroker –unsafe-perm
                        node lib/setup.js
                        npm install iobroker.admin --production --prefix /opt/iobroker
                        npm install iobroker.discovery --production --prefix /opt/iobroker
                        In file included from ../src/dns_sd.cpp:1:0:
                        ../src/mdns.hpp:32:20: fatal error: dns_sd.h: Datei oder Verzeichnis nicht gefunden
                        #include <dns_sd.h>^
                        compilation terminated.
                        make: *** [Release/obj.target/dns_sd_bindings/src/dns_sd.o] Error 1
                        gyp ERR! build error
                        gyp ERR! stack Error: make failed with exit code: 2
                        gyp ERR! stack at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
                        gyp ERR! stack at emitTwo (events.js:87:13)
                        gyp ERR! stack at ChildProcess.emit (events.js:172:7)
                        gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:211:12)
                        gyp ERR! System Linux 4.9.24+
                        gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                        gyp ERR! cwd /opt/iobroker/node_modules/iobroker.discovery/node_modules/mdns
                        gyp ERR! node -v v4.8.3
                        gyp ERR! node-gyp -v v3.4.0
                        gyp ERR! not ok
                        npm WARN optional dep failed, continuing mdns@2.3.3
                        node-pre-gyp ERR! Tried to download(404): https://github.com/EmergingTechnologyAd … arm.tar.gz
                        node-pre-gyp ERR! Pre-built binaries not found for serialport@4.0.7 and node@4.8.3 (node-v46 ABI) (falling back to source compile with node-gyp)
                        Write "./iobroker start" to start the ioBroker
                        Auto-start was enabled. Write "update-rc.d -f iobroker.sh remove" to disable auto-start
                        iobroker is started. Go to "http://ip-addr:8081" to open the admin UI.
                        iobroker@0.9.0 node_modules/iobroker
                        └── yargs@7.1.0 (get-caller-file@1.0.2, decamelize@1.2.0, camelcase@3.0.0, y18n@3.2.1, which-module@1.0.0, set-blocking@2.0.0, yargs-parser@5.0.0, require-main-filename@1.0.1, require-directory@2.1.1, string-width@1.0.2, cliui@3.2.0, os-locale@1.4.0, read-pkg-up@1.0.1)
                        pi@raspberrypi:/opt/iobroker $ The programs included with the Debian GNU/Linux system are free software;
                        -bash: The: Kommando nicht gefunden.
                        pi@raspberrypi:/opt/iobroker $ the exact distribution terms for each program are described in the
                        -bash: the: Kommando nicht gefunden.
                        pi@raspberrypi:/opt/iobroker $ individual files in /usr/share/doc/*/copyright.
                        -bash: individual: Kommando nicht gefunden.
                        pi@raspberrypi:/opt/iobroker $ Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                        -bash: Debian: Kommando nicht gefunden.
                        pi@raspberrypi:/opt/iobroker $ permitted by applicable law.
                        -bash: permitted: Kommando nicht gefunden.
                        pi@raspberrypi:/opt/iobroker $ Last login: Fri May 5 20:21:37 2017 from winmac.fritz.box
                        -bash: Last: Kommando nicht gefunden.
                        pi@raspberrypi:/opt/iobroker $ pi@raspberrypi:~ $ node -v
                        -bash: pi@raspberrypi:~: Kommando nicht gefunden.
                        pi@raspberrypi:/opt/iobroker $ v4.8.3
                        -bash: v4.8.3: Kommando nicht gefunden.
                        pi@raspberrypi:/opt/iobroker $ pi@raspberrypi:~ $ sudo mkdir /opt/iobroker
                        icht angelegt werden: Die Datei existiert bereitshnis ▒/opt/iobroker▒ kann n
                        -bash: mkdir:: Kommando nicht gefunden.
                        pi@raspberrypi:/opt/iobroker $ pi@raspberrypi:~ $ sudo chmod 777 /opt/iobroker
                        pi@raspberrypi:/opt/iobroker $ pi@raspberrypi:~ $ cd /opt/iobroker
                        pi@raspberrypi:/opt/iobroker $ pi@raspberrypi:/opt/iobroker $ sudo npm install iobroker --unsafe-perm
                        -bash: pi@raspberrypi:/opt/iobroker: Datei oder Verzeichnis nicht gefunden
                        pi@raspberrypi:/opt/iobroker $ /
                        -bash: /: Ist ein Verzeichnis
                        pi@raspberrypi:/opt/iobroker $ > iobroker@0.9.0 install /opt/iobroker/node_modules/iobroker
                        install: Fehlender Zieldatei-Operand hinter ▒/opt/iobroker/node_modules/iobroker▒
                        ▒install --help▒ liefert weitere Informationen.
                        pi@raspberrypi:/opt/iobroker $ > node lib/setup.js
                        -bash: lib/setup.js: Datei oder Verzeichnis nicht gefunden
                        pi@raspberrypi:/opt/iobroker $ npm install iobroker.js-controller --production --prefix /opt/iobroker
                        npm ERR! Linux 4.9.24+
                        npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.js-controller" "--production" "--prefix" "/opt/iobroker"
                        npm ERR! node v4.8.3
                        npm ERR! npm v2.15.11
                        npm ERR! path /opt/iobroker/node_modules/.bin/iobroker
                        npm ERR! code EACCES
                        npm ERR! errno -13
                        npm ERR! syscall unlink
                        npm ERR! Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/.bin/iobroker'
                        npm ERR! at Error (native)
                        npm ERR! { [Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/.bin/iobroker']
                        npm ERR! errno: -13,
                        npm ERR! code: 'EACCES',
                        npm ERR! syscall: 'unlink',
                        npm ERR! path: '/opt/iobroker/node_modules/.bin/iobroker' }
                        npm ERR!
                        npm ERR! Please try running this command again as root/Administrator.
                        npm ERR! error rolling back Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/.bin/iobroker'
                        npm ERR! error rolling back at Error (native)
                        npm ERR! error rolling back { [Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/.bin/iobroker']
                        npm ERR! error rolling back errno: -13,
                        npm ERR! error rolling back code: 'EACCES',
                        npm ERR! error rolling back syscall: 'unlink',
                        npm ERR! error rolling back path: '/opt/iobroker/node_modules/.bin/iobroker' }
                        npm ERR! Please include the following file with any support request:
                        npm ERR! /opt/iobroker/npm-debug.log
                        pi@raspberrypi:/opt/iobroker $ npm install iobroker.admin –production --prefix /opt/iobroker
                        npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.admin" "--production" "--prefix" "/opt/iobroker"
                        npm ERR! path /opt/iobroker/node_modules/iobroker.admin/node_modules/request/node_modules/.bin/uuid
                        npm ERR! errno -13
                        npm ERR! Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.admin/node_modules/request/node_modules/.bin/uuid'
                        npm ERR! { [Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.admin/node_modules/request/node_modules/.bin/uuid']
                        npm ERR! path: '/opt/iobroker/node_modules/iobroker.admin/node_modules/request/node_modules/.bin/uuid' }
                        npm ERR!
                        npm ERR! error rolling back Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.admin/node_modules/request/node_modules/.bin/uuid'
                        npm ERR! error rolling back { [Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.admin/node_modules/request/node_modules/.bin/uuid']
                        npm ERR! error rolling back path: '/opt/iobroker/node_modules/iobroker.admin/node_modules/request/node_modules/.bin/uuid' }
                        Joachim</dns_sd.h>
                        • kmxak
                          hast du auch folgenden code ausgeführt?
                          sudo apt-get install build-essential python python-rpi.gpio
                            Hallo Alex,
                            der code unter "Node.js neu installieren nur für Raspberry 1" unter Punkt 3 habe ich übersehen .
                            Was muß denn nun unter "Node.js neu installieren nur für Raspberry 1" wirklich in der Reihenfolge
                            eigegeben werden und was muß weggelassen oder geändert werden?
                            Joachim
                            • kmxak
                              node ist ja nun schon drauf dann noch
                              nachinstallieren.
                              Ich persönlich würde nochmals den (/opt/)iobroker ordner löschen neu anlegen chmod 777 setzen und nochmal die iobroker installation probieren
                                @kmxak:
                                nachinstallieren.
                                Hallo Alex,
                                vielen Dank für deinen Tip aber trotzdem kein Erfolg erst dauert es eine Ewigkeit bis ioBroker Installation startet, hier mein Logg:
                                login as: pi
                                pi@192.168.xxxxxx password:
                                mkdir: das Verzeichnis „/opt/iobroker“ kann nicht angelegt werden: Die Datei exi stiert bereits
                                node lib/setup.js
                                ../src/mdns.hpp:32:20: fatal error: dns_sd.h: Datei oder Verzeichnis nicht gefun den
                                gyp ERR! stack at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_ modules/node-gyp/lib/build.js:276:23)
                                gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_proces s.js:211:12)
                                gyp ERR! System Linux 4.4.50+
                                gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_mod ules/node-gyp/bin/node-gyp.js" "rebuild"
                                gyp ERR! not ok
                                node-pre-gyp ERR! Tried to download(404): https://github.com/EmergingTechnologyA dvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v46-linux -arm.tar.gz
                                node-pre-gyp ERR! Pre-built binaries not found for serialport@4.0.7 and node@4.8 .3 (node-v46 ABI) (falling back to source compile with node-gyp)
                                └── yargs@7.1.0 (get-caller-file@1.0.2, decamelize@1.2.0, camelcase@3.0.0, y18n@3.2.1, wh ich-module@1.0.0, set-blocking@2.0.0, yargs-parser@5.0.0, require-main-filename@1.0.1, re quire-directory@2.1.1, cliui@3.2.0, os-locale@1.4.0, string-width@1.0.2, read-pkg-up@1.0. 1)
                                pi@raspberrypi:/opt/iobroker $</dns_sd.h>
                                  DeepCore last edited by
                                  Diesen Fehler hatte ich heute auch bei einer Testinstallation in Virtualbox und Debian 8 …
                                  ...</dns_sd.h> `
                                  Meine Lösung war folgende, ausgehend von einem frisch installierten Debian 8 64-bit System:
                                  # Using Debian, as root
                                  apt-get update
                                  apt-get upgrade
                                  apt-get install build-essential python libavahi-compat-libdnssd-dev
                                  apt-get install curl
                                  curl -sL https://deb.nodesource.com/setup_4.x | bash -
                                  apt-get install -y nodejs
                                  npm install node-gyp
                                  npm install mdns
                                  mkdir /opt/iobroker
                                  cd /opt/iobroker
                                  npm install --unsafe-perm iobroker
                                  ioBroker muss dann trotzdem noch manuell gestartet werden
                                  ./iobroker start
                                  • kmxak
                                    das wird nicht gehen mit
                                    er hat nen pi1 da brauchst wie oben schon erwähnt ein anderes node
                                      @kmxak
                                      Meine Antwort bezog sich auf den Fehler bei der Installation von iobroker.discovery, wo eine fehlende Datei bemängelt wird
                                      Geht den libavahi-compat-libdnssd-dev auf dem Pi 1?
                                      81.0k
                                      3667
