    4. Alexa2 Adapter kann nicht mehr installiert werden
      ChrisBGL last edited by
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Pi4b
      js-controller: 4.0.23
      Nodejs-Version: 16.18.0
      NPM-Version: 8.19.2
      ich habe den Alexa2 Adapter deinstalliert und wollte ihn nun wieder reinstallieren.
      Dabei erhalte ich folgende Fehler:
      $ iobroker add alexa2 auto --host raspberrypi --debug
      NPM version: 8.19.2
      Installing iobroker.alexa2@3.19.10... (System call)
      npm WARN old lockfile npm WARN old lockfile The package-lock.json file was created with an old version of npm,npm WARN old lockfile so supplemental metadata must be fetched from the registry.npm WARN old lockfile npm WARN old lockfile This is a one-time fix-up, please be patient...npm WARN old lockfile
      npm ERR! code ETARGET
      npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2022-10-27T13_41_08_110Z-debug-0.log
      host.raspberrypi Cannot install iobroker.alexa2@3.19.10: 1
      ERROR: Process exited with code 25
      Die relevante Stelle im Log ist wohl die hier:
      2134 timing command:install Completed in 59527ms
      2135 verbose type version
      2136 verbose stack @sentry/utils: No matching version found for @sentry/utils@7.17.0.
      2136 verbose stack     at module.exports (/usr/lib/node_modules/npm/node_modules/npm-pick-manifest/lib/index.js:209:23)
      2136 verbose stack     at RegistryFetcher.manifest (/usr/lib/node_modules/npm/node_modules/pacote/lib/registry.js:125:22)
      2137 verbose cwd /opt/iobroker
      2138 verbose Linux 5.10.103-v7l+
      2139 verbose node v16.18.0
      2140 verbose npm  v8.19.2
      2141 error code ETARGET
      2142 error notarget No matching version found for @sentry/utils@7.17.0.
      2143 error notarget In most cases you or one of your dependencies are requesting
      2143 error notarget a package version that doesn't exist.
      2144 verbose exit 1
      2145 timing npm Completed in 59863ms
      2146 verbose unfinished npm timer reify 1666878068440
      2147 verbose unfinished npm timer reify:loadTrees 1666878068480
      2148 verbose code 1
      2149 error A complete log of this run can be found in:
      2149 error     /home/iobroker/.npm/_logs/2022-10-27T13_41_08_110Z-debug-0.log
      Kann mir bitte jemand helfen das Problem zu lösen?
      ? 2 Replies Last reply Reply Quote 0
        A Former User @ChrisBGL last edited by
        @chrisbgl da bist du nicht der einzigste, ist hier und bei anderen auch so. Warten, bis ein update fuers Update kommt, liegt wohl an einer fehlerhaften depency for Sentry, wenn ich das Fehlerlog richtig verstehe...
          Homoran Global Moderator Administrators @Guest last edited by
          https://forum.iobroker.net/post/880621
            @chrisbgl jetzt gehts, der Bug bei Sentry ist gefixt. Also nochmal probieren.. hier liefs jetzt durch
              ChrisBGL @Guest last edited by ChrisBGL
              @ilovegym Prima, bei mir auch. Danke für den Hinweis. War dann wohl schlechtes Timing von mir.
              Muss ich hierzu irgendwas machen?
              Hatte in meiner Verzweiflung auf Nodejs 16 geupdated.
              ? Thomas Braun 2 Replies Last reply Reply Quote 0
                @chrisbgl
                Dann schau mal, ob du Node richtig geupdated hast, hier wird dir geholfen:
                https://forum.iobroker.net/topic/44566/how-to-node-js-iobroker-richtig-updaten-2021-22-edition
                  Thomas Braun Most Active @ChrisBGL last edited by
                  @chrisbgl sagte in Alexa2 Adapter kann nicht mehr installiert werden:
                  Die Meldung dürfte mit dem Switch auf npm@8 (kommt mit nodejs@16 daher) zusammenhängen. Schau mal ob das Ganze 'senkrecht' installiert ist:
                  sudo ln -s /usr/bin/node /usr/bin/nodejs
                  uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                    @ilovegym Ja, nach dieser Anleitung hatte ich es gemacht.
                    MyzerAT 1 Reply Last reply Reply Quote 0
                    • MyzerAT
                      MyzerAT @ChrisBGL last edited by
                      woher kommt das update, katze, aber was npm oder github ?
                        Thomas Braun Most Active @MyzerAT last edited by
                        @myzerat
                        Die 3.19.10 kommt ganz regulär aus deinem Repo, nix 'Katze'.
                        • MyzerAT
                          MyzerAT @Thomas Braun last edited by
                          @thomas-braun sagte in Alexa2 Adapter kann nicht mehr installiert werden:
                          @myzerat
                          also als update angezeigt, wenn es sowiet ist und freigegeben , thx
                            @myzerat sagte in Alexa2 Adapter kann nicht mehr installiert werden:
                            iobroker update
                            iobroker upgrade
                            • MyzerAT
                              iobroker update
                              iobroker upgrade
                              ist das nicht wo man vorher "iobroker stop" machen muss ?
                                @myzerat
                                Nein.
                                • MyzerAT
                                  ok, ich warte aber bis es offiziell verkündet wird, von @apollon77 das alles wieder passt!
                                    @myzerat
                                    https://forum.iobroker.net/topic/59390/alexa-2-nutzer-der-3-19-x-bitte-auf-3-19-10-updaten
                                    • apollon77
                                      apollon77 last edited by
                                      Laut User-berichten geht es wieder ...
                                      MyzerAT 1 Reply Last reply Reply Quote 1
                                      • MyzerAT
                                        MyzerAT @apollon77 last edited by
                                        @apollon77
                                        für die dummen unter uns, gibt eine anleitung, bitte , danke
                                        • apollon77
                                          apollon77 @MyzerAT last edited by
                                          @myzerat Wie meinen? Einfach Update auf die 3.19.10 nochmal versuchen wenn es vorher heute nicht geklappt hat. Wer die 3.19.10 drauf hat sollte alles passen
                                          • MyzerAT
                                            @apollon77
                                            genau das ist ja mein problem, über die katze ? npm oder github
                                            Thomas Braun apollon77 2 Replies Last reply Reply Quote 0
                                            81.0k
                                            2043
