    3. Entwicklung
    4. [New Adapter] huawei fusionsolar api
    • KornSW
      KornSW last edited by KornSW
      Hi, ive written an adapter to connect to the Huawei 'Fusion Solar' cloud.
      The API itself is very new and still a little bit unstable, but my adapter now works fine for 2 weeks. So i decided to declare it als 1.0.0 MVP.
      It will be interresting for owners of SUN2000 PV inverters, which are also quite new on the german market. But im sure that this will change, i know already 5 persons who will also get installed one until end 2022...
      So everyone is invited to test the adapter and give feedback here!
      https://github.com/KornSW/ioBroker.fusionsolar
      KornSW Lars G. 2 Replies Last reply Reply Quote 3
      • KornSW
        KornSW @KornSW last edited by
        @kornsw and im directly starting with a little issue/question: the adapter is present in the List of GitHub Adapters, but it seems that the name cant be resolved:
        has anyone an idea, how to fix this?
          myssv @KornSW last edited by
          @kornsw enter the github address at "BENUTZERDEFINIERT"
            Skol last edited by
            Mit Eingabe des Links funktioniert es
            https://github.com/KornSW/ioBroker.fusionsolar/
            Vielleicht kanns du die Hilfe auch anpassen.
              timboros last edited by
              Hey kornsw,
              I installed your adapter. Sadly I cannot connect to the API. I tested and my credentials are correct. Can you tell from the log what is wrong? What is with the XSRF token?!
              Best regards
              Robert
                ple last edited by
                So, scheint zu klappen.
                Schön wäre es noch, wenn die Einheiten, Rollen, Typen der States noch defeniert werden könnten, dann wäre das für die Zukunft schon mal einfacher dann.
                Ansonsten habe ich hier eine Anleitung, wie man sich ein Api account erstellen kann, wenn man als installateur angemeldet ist.
                2022FSV8001 Create API account on FusionSolar Server (only Company Admin... (1).pdf
                Lars G. L 2 Replies Last reply Reply Quote 0
                  majawe last edited by majawe
                  Funktioniert der Adapter aktuell? Iwie bekomme ich nicht mehr als diese Daten!
                  Error:
                  API returned failCode #401
                  F J 2 Replies Last reply Reply Quote 0
                  • Lars G.
                    Lars G. @ple last edited by
                    @ple Problem ist nur, wenn man keinen API Account erstellt bekommt vom Installateur ...^^
                    Das muss doch auch irgendwie ohne gehen... Das man einfach die Werte aus der Cloud in iobroker einbinden kann.
                    • Lars G.
                      Lars G. @KornSW last edited by
                      @kornsw doesnt work for me. he try to install, but nothing happens.
                        stonytec last edited by
                        @KornSW Vielen Danke für die Entwicklung.
                        Leider bekomme ich keine Werte aus der API. An was könnte das liegen?
                        Login Funktioniert:
                          Funksoulbrotha @majawe last edited by
                          @majawe
                          Habe genau das selbe problem, live Daten kommen keine.
                            majawe @Funksoulbrotha last edited by
                            @funksoulbrotha habe es mitlerweile hinbekommen, du musst in der tat alles anklicken und einen haken setzten!!!
                              higginsd last edited by higginsd
                              Ich hab's noch nicht so ganz verstanden.... Habe mir in Fusionsolar einen Benutzer (API Account) für die Northbound-Schnittstelle angelegt. Dabei habe ich alle möglichen Zugriffe angeklickt/aktiviert.
                              Jetzt kann sich der Adapter verbinden mit diesem Benutzer/Password. Aber in den Objekten kommen ausser Info/Connection keine Daten an.
                              Was mache ich falsch?
                              EDIT: ich beantworte meine Frage mal selber. Man muss den API-Nutzer in Fusionsolar nach dem Anlegen über Edit-Funktion für die Anlage noch autorisieren.
                                Eine Frage: gibt es eine Dokumentation (= Übersetzung), welcher Wert aus den Realtime-Daten wo in den Objekten gespeichert wird? Ich kenne mich leider mit den PV-Bezeichnungen (z.B. MPTT usw.) nicht so aus.
                                Mich interessieren primär:
                                • kW aktuell "vom Dach"
                                • kW aktuell vom Inverter in/aus dem Speicher
                                • Ladezustand aktuell Speicher
                                • kW aktuell vom Inverter ins Hausnetz
                                • kW aktuell vom/zum Netz/EVU
                                • kWh Tagesproduktion bisher
                                • kWh Monatsproduktion bisher
                                • Netzbezug kWh Tag bisher
                                • Netzeinspeisung kWh bisher
                                Halt so die wichtigsten Daten, um auch für einen Laien verständlich anzuzeigen, was gerade wo passiert und wieviel die Anlage erzeugt hat.
                                Danke für jeden Tip! Umsetzen mit JS kann ich das dann selber, ich muss nur wissen, was wo steht.
                                  Martin65 last edited by
                                  Hi i can not install the adapter
                                  This is the message:
                                  $ iobroker-URL https://github.com/KornSW/ioBroker.fusionsolar/ --host raspberrypi --debug
                                  Installation von GitHub nicht möglich. Ungültige URL https://github.com/KornSW/ioBroker.fusionsolar/
                                  Prozess wurde mit Code 0 beendet
                                    mucki @higginsd last edited by
                                    @higginsd sagte in [New Adapter] huawei fusionsolar api:
                                    Danke für den Tipp - da bin ich auch gerade drüber gestolpert 🙂
                                    KornSW 1 Reply Last reply Reply Quote 0
                                    • KornSW
                                      KornSW @mucki last edited by
                                      erst einmal sorry für sämtliche ausgebliebenden Antworten meinerseits. Auch wenn mir mom. fast keine Zeit für meine Open-Source Projekte bleibt, bin ich eigentlich schon gern hintendran wenn was nicht geht. Hier lags einfach dran, dass ich 1. nicht gedacht hätte, dass sich wirklich so schnell weitere Verwender finden und 2. ich irgendwie aus diesem Forum hier keine Notification bekommen habe - lesson learned...
                                      der führende Ort waren bislang die "Issues" bei Github: https://github.com/KornSW/ioBroker.fusionsolar/issues?q=is%3Aissue+is%3Aclosed
                                      -> wenn ihr konkrete Bugs entdeckt, oder Feature-Requests habt, dann sind die dort am besten aufgehoben.
                                      (trotzdem werde versuchen dran zu denken hier öfter mal reinzuschauen)
                                      zum Thema "Installationsprobleme": ich habe keine Ahnung warum mein Adapter nicht unter der GitHub-Tab nicht richtig gelistet wird (mittlerweile ist ja auch noch ein Anderer als "UNDEFINED" dort drin). Habe die Hoffnung dass sich das legt, wenn man den Adapter via NPM bereitstellt (habe ich so eben getan).
                                      Wer noch Probleme hat, kann auch mal die Installation via URL von hier ausprobieren: https://kornsw.de/downloads/iobroker.fusionsolar-1.0.0.tgz
                                      zum Thema "Verbindungsprobleme": wie die Github Issues Zeigen, ist die API eine echte 'Diva'. Man darf darf da nix falsch machen und auch wenn man alles richtig macht, gibt's manchmal komische Effekte. Ich bin hier sehr Dankbar für eure Forschungsergebnisse! Nachvollziehen kann ich's leider nicht ganz, da das Ding bei mir seit der ersten Version sauber läuft... (habe aber noch einen der ersten API-Accounts, welcher direkt vom support für mich erstellt wurde)
                                      Und nochmal der Aufruf - wenn jemand Programmieren kann und mitmachen will - bitte melden!
                                      Gruß T.
                                        judge-one @majawe last edited by
                                        ich bekomm leider immer den Fehlercode #401.
                                        Über Fusion Solar hab ich aber einen entsprechenden Northbound-User angelegt:
                                        Christoph G 1 Reply Last reply Reply Quote 0
                                        • Christoph G
                                          Christoph G @judge-one last edited by
                                          @judge-one
                                          ich habe den selben Fehler 😞
                                          • Christoph G
                                            Christoph G @Christoph G last edited by
                                            @christoph-g said in [New Adapter] huawei fusionsolar api:
                                            @judge-one
                                            Hast du deine Anlage in dem API authorisiert?
                                            1.0k
                                            adapter
                                            45
                                            112
                                            26944
