    4. Problem: "Error: libnode.so.72" mit Folgen
      BeneMUC last edited by
      bin schon eine Weile hier im Forum als stiller Mitleser unterwegs aber jetzt benötige ich Hilfe.
      Ich habe gestern nach der Anleitung von @Thomas-Braun ("kleiner Werkzeugkasten") ein Upate vom Gesamtsystem gemacht. Anschließend hatte ich das Problem, dass mein Zigbee Adapter nicht mehr starten wollte. Im Log wure immer der Fehler "libnode.so.72: cannot open shared object file" geloggt:
      2022-11-01 18:04:26.333  - error: host.raspberrypi Caught by controller[0]: Error: libnode.so.72: cannot open shared object file: No such file or directory
      2022-11-01 18:04:26.333  - error: host.raspberrypi Caught by controller[0]:     at Object.Module._extensions..node (node:internal/modules/cjs/loader:1239:18)
      2022-11-01 18:04:26.333  - error: host.raspberrypi Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1033:32)
      2022-11-01 18:04:26.333  - error: host.raspberrypi Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:868:12)
      2022-11-01 18:04:26.334  - error: host.raspberrypi Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1057:19)
      2022-11-01 18:04:26.334  - error: host.raspberrypi Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:103:18)
      2022-11-01 18:04:26.334  - error: host.raspberrypi Caught by controller[0]:     at bindings (/opt/iobroker/node_modules/bindings/bindings.js:112:48)
      2022-11-01 18:04:26.334  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/linux.js:2:36)
      2022-11-01 18:04:26.334  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1155:14)
      2022-11-01 18:04:26.334  - error: host.raspberrypi Caught by controller[0]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1209:10)
      2022-11-01 18:04:26.335  - error: host.raspberrypi Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1033:32) {
      2022-11-01 18:04:26.335  - error: host.raspberrypi Caught by controller[0]:   code: 'ERR_DLOPEN_FAILED'
      Heute habe ich den ganzen Tag versucht das Problem zu beheben. Zu guter Letzt bin ich in einem anderen Forum über den Hinweis gestolpert, dass sich der Fehler mit "sudo apt install libnode72" beheben lassen soll. Gesagt, getan funktioniert jetzt leider mein IoBroker überhaupt nicht mehr. Aktuell lassen sich viele Befehle gar nicht mehr ausführen bzw. liefern kein Ergebnis zurück. Beispiele:
      pi@raspberrypi:~ $ iobroker logs --watch
      sudo: node: command not found
      pi@raspberrypi:/ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
      pi@raspberrypi:/ $
      pi@raspberrypi:/ $ npm -v
      -bash: eval: -v: invalid option
      Ich bin nun trotz einigem googeln wirklich ratlos. Evtl. kann jemand von Euch nachvollziehen, was ich mit der libnode72 Installation kaputt gemacht habe und wie sich das wieder fixen lässt. Das Protokoll von der Installation hab ich noch - wenn ich die knapp 400 Zeilen hier rein hänge, wird der Post allerding ultralang (kann man die Anzeige von Code irgendwie ausklapprbar machen?)
      Vielen Danke im Vorraus 🙂
        Thomas Braun Most Active @BeneMUC last edited by
        @benemuc sagte in Problem: "Error: libnode.so.72" mit Folgen:
        libnode.so.72
        Dann hattest du mit Sicherheit nicht die Version von nodesource sondern die dfsg-Version installiert. Denn:
        apt policy libnode72
        libnode72:
          Installed: (none)
          Candidate: 12.22.12~dfsg-1~deb11u1
          Version table:
             12.22.12~dfsg-1~deb11u1 500
                500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
             12.22.5~dfsg-2~11u1 500
                500 http://deb.debian.org/debian bullseye/main arm64 Packages
        Das hat nur gar nichts mit nodejs vom nodesource-Repo zu tun, die wir hier bevorzugen.
        Kurz: Wie schaut das jetzt da bei dir aus?
        sudo apt update
        apt policy libnodejs72 nodejs
          Wo war das?
            @thomas-braun said in Problem: "Error: libnode.so.72" mit Folgen:
            schaut jetzt so aus:
            pi@raspberrypi:/ $ sudo apt update
            Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
            Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
            Hit:3 https://deb.nodesource.com/node_10.x bullseye InRelease
            Hit:4 https://deb.nodesource.com/node_16.x bullseye InRelease
            Reading package lists... Done
            Building dependency tree... Done
            All packages are up to date.
            pi@raspberrypi:/ $ apt policy libnodejs72 nodejs
            nodejs:
              Installed: (none)
              Candidate: 16.18.0-deb-1nodesource1
              Version table:
                 16.18.0-deb-1nodesource1 500
                    500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                    500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Package         s
                 10.24.1-deb-1nodesource1 500
                    500 https://deb.nodesource.com/node_10.x bullseye/main armhf Packages
            N: Unable to locate package libnodejs72
            Wo war das?
            Darf ich hier Links auf ein anderes Forum posten?
            https://stackoverflow.com/questions/69378783/node-error-while-loading-shared-libraries-libnode-so-72
              @benemuc
              sudo apt install nodejs
                BeneMUC @Thomas Braun last edited by
                Bist mein Held 🙂 die NodeJS Installation ist erfolgreich durchgelaufen und der IoBroker startet wieder - herzlichen Dank!
                Wie kriege ich das jetzt noch glatt gezogen?
                  @benemuc
                  Dann lass mal sehen wie du da jetzt aufgestellt bist:
                  sudo ln -s /usr/bin/node /usr/bin/nodejs
                  uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                    Ergebnis:
                    pi@raspberrypi:/ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
                    uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installatio        n" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v &&        iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && s        udo apt update &> /dev/null && sudo apt update && apt policy nodejs
                    ln: failed to create symbolic link '/usr/bin/nodejs': File exists
                    armv7l
                    Kein Docker
                    /usr/bin/nodejs
                    /usr/bin/node
                    /usr/bin/npm
                    v16.18.0
                    v16.18.0
                    8.19.2
                    4.0.21
                    pi
                    pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c s        pi iobroker
                    tty
                    Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                    nodejs:
                      Installed: 16.18.0-deb-1nodesource1
                      Version table:
                     *** 16.18.0-deb-1nodesource1 500
                            100 /var/lib/dpkg/status
                      @benemuc
                      Deine /etc/apt/sources.list ist falsch. Hast du das System von einer Vorversion hochgezogen und auf 'bullseye' gebracht?
                      Meine schaut so aus:
                      deb http://deb.debian.org/debian bullseye main contrib non-free
                      deb http://security.debian.org/debian-security bullseye-security main contrib non-free
                      deb http://deb.debian.org/debian bullseye-updates main contrib non-free
                      deb http://deb.debian.org/debian bullseye-backports main contrib non-free
                      # Uncomment deb-src lines below then 'apt-get update' to enable 'apt-get source'
                      #deb-src http://deb.debian.org/debian bullseye main contrib non-free
                      #deb-src http://security.debian.org/debian-security bullseye-security main contrib non-free
                      #deb-src http://deb.debian.org/debian bullseye-updates main contrib non-free
                      #deb-src http://deb.debian.org/debian bullseye-backports main contrib non-free
                        ja du hast Recht, meine sources.list sah so aus:
                        deb http://raspbian.raspberrypi.org/raspbian/ bullseye main contrib non-free rpi
                        # Uncomment line below then 'apt-get update' to enable 'apt-get source'
                        #deb-src http://raspbian.raspberrypi.org/raspbian/ bullseye main contrib non-free rpi
                        Hatte aus deinem HowTo zum Nodejs-Upgrade nur nur die "/etc/apt/sources.list.d/nodesource.list" angepasst.
                          Thomas Braun Most Active @BeneMUC last edited by Thomas Braun
                          Das funktioniert (für die /etc/apt/sources.list) nicht bei Upgrades von z. B. buster auf bullseye, denn dort ist der Aufbau der Repos anders.
                            habe mit der angepassten sources.list jetzt ein full-upgrade durchgeführt.
                            Allerdings:
                            armv7l
                            Kein Docker
                            /usr/bin/nodejs
                            /usr/bin/node
                            /usr/bin/npm
                            v16.18.0
                            v16.18.0
                            8.19.2
                            4.0.21
                            pi
                            pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
                            tty
                            Irgendetwas ist immer noch nicht korrekt.
                              @benemuc
                              Was sagt
                              sudo apt update
                              sudo apt full-upgrade
                              Und warum stehst du überhaupt in / herum? Hat dein pi kein zuhause?
                              cd ~
                                BeneMUC @Thomas Braun last edited by BeneMUC
                                Was sagt
                                sudo apt update sudo apt full-upgrade
                                Get:1 http://security.debian.org/debian-security bullseye-security InRelease [48.4 kB]
                                Get:2 http://deb.debian.org/debian bullseye InRelease [116 kB]
                                Get:3 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
                                Get:4 http://deb.debian.org/debian bullseye-backports InRelease [49.0 kB]
                                Hit:5 http://archive.raspberrypi.org/debian bullseye InRelease
                                Err:1 http://security.debian.org/debian-security bullseye-security InRelease
                                  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 112695A0E562B32A NO_PUBKEY 54404762BBB6E853
                                Err:2 http://deb.debian.org/debian bullseye InRelease
                                  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 648ACFD622F3D138 NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 605C66F00D6C9793
                                Hit:6 https://deb.nodesource.com/node_10.x bullseye InRelease
                                Err:3 http://deb.debian.org/debian bullseye-updates InRelease
                                Hit:7 https://deb.nodesource.com/node_16.x bullseye InRelease
                                Err:4 http://deb.debian.org/debian bullseye-backports InRelease
                                W: GPG error: http://security.debian.org/debian-security bullseye-security InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 112695A0E562B32A NO_PUBKEY 54404762BBB6E853
                                E: The repository 'http://security.debian.org/debian-security bullseye-security InRelease' is not signed.
                                N: Updating from such a repository can't be done securely, and is therefore disabled by default.
                                N: See apt-secure(8) manpage for repository creation and user configuration details.
                                W: GPG error: http://deb.debian.org/debian bullseye InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 648ACFD622F3D138 NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 605C66F00D6C9793
                                E: The repository 'http://deb.debian.org/debian bullseye InRelease' is not signed.
                                W: GPG error: http://deb.debian.org/debian bullseye-updates InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 648ACFD622F3D138 NO_PUBKEY 0E98404D386FA1D9
                                E: The repository 'http://deb.debian.org/debian bullseye-updates InRelease' is not signed.
                                W: GPG error: http://deb.debian.org/debian bullseye-backports InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 648ACFD622F3D138 NO_PUBKEY 0E98404D386FA1D9
                                E: The repository 'http://deb.debian.org/debian bullseye-backports InRelease' is not signed.
                                Calculating upgrade... Done
                                The following packages were automatically installed and are no longer required:
                                  gyp libc-ares2 libfuse2 libjs-highlight.js libjs-inherits libjs-is-typedarray
                                  libjs-psl libjs-typedarray-to-buffer libssl-dev libuv1-dev node-chownr
                                  node-color-name node-err-code node-extsprintf node-fast-deep-equal node-indent-string
                                  node-ini node-is-typedarray node-json-parse-better-errors node-json-schema
                                  node-json-schema-traverse node-qs node-resolve-from node-through
                                  node-typedarray-to-buffer node-uuid
                                Use 'sudo apt autoremove' to remove them.
                                0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                                Werde die fehlenden Keys dann mal in den apt key manager einfügen.
                                da bin ich jetzt überfragt^^ was ist denn hier das Stichwort mit dem ich dazu googeln kann? #noop
                                  node-
                                  Neben den fehlenden keys...
                                  (Wie hast du die Kiste von wo aus upgegraded???)
                                  sudo apt remove node-*
                                  sudo apt update
                                  sudo apt autoremove
                                    Nach dem Fixen der Keys lasse ich jetzt sudo apt update und sudo apt full-upgrade durchlaufen. Schaut soweit gut aus aber dauert natürlich ein Weilchen.
                                    Kann ich dir leider nicht genau sagen. Hab die Kiste vor ca. 1,5 Jahren nach irgendeiner Anleitung aufgesetzt und mich seither nicht um System-Updates gekümmert. Gestern dann eben entsprechend deinem Werkzeugkasten versucht alles auf den neuesten Stand zu bringen.
                                      aktueller Stand sieht jetzt so aus:
                                      pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
                                      uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && o $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                      armv7l
                                      Kein Docker
                                      /usr/bin/nodejs
                                      /usr/bin/node
                                      /usr/bin/npm
                                      v16.18.0
                                      v16.18.0
                                      8.19.2
                                      4.0.21
                                      pi
                                      tty
                                      /home/pi
                                      Hit:1 http://deb.debian.org/debian bullseye InRelease
                                      Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                                      Hit:4 http://deb.debian.org/debian bullseye-backports InRelease
                                      Hit:5 http://security.debian.org/debian-security bullseye-security InRelease
                                      nodejs:
                                        Version table:
                                              500 http://security.debian.org/debian-security bullseye-security/main armhf Packages
                                              500 http://deb.debian.org/debian bullseye/main armhf Packages
                                      Um node- muss ich mich morgen kümmern - langsam fehlt die Konzentrtion 😉 Vielen Dank aber schonmal für Deine Hilfe bis hierher! 🙂
                                        @benemuc
                                        Ja, das schaut doch schon wesentlich anders aus. 🙂
                                          Eine Woche später...
                                          Da ich den libnode.so.72 Fehler trotz aller Maßnahmen nicht beseitigt bekommen habe, hab ich zwischenzeitlich den Raspberry komplett neu aufgesetzt (raspbian, nodejs, iobroker + Backup eingespielt).
                                          Ergebnis ist, dass der libnode.so.72 Fehler zwar weg ist aber der Zigbee Adapter immer noch nicht wieder startet.
                                          admin@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
                                          uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs
                                          aarch64
                                          Kein Docker
                                          /usr/bin/nodejs
                                          /usr/bin/node
                                          /usr/bin/npm
                                          v16.18.1
                                          v16.18.1
                                          8.19.2
                                          4.0.23
                                          admin
                                          admin adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                          tty
                                          /home/admin
                                          Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
                                          Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                                          Hit:5 http://deb.debian.org/debian bullseye-backports InRelease
                                          Hit:6 https://deb.nodesource.com/node_16.x bullseye InRelease
                                          nodejs:
                                            Installed: 16.18.1-deb-1nodesource1
                                            Candidate: 16.18.1-deb-1nodesource1
                                            Version table:
                                           *** 16.18.1-deb-1nodesource1 500
                                                  500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
                                          Fehlerlog:
                                          2022-11-08 18:19:44.554  - info: host.raspberrypi "system.adapter.zigbee.0" enabled
                                          2022-11-08 18:19:44.724  - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 12720
                                          2022-11-08 18:19:49.143  - info: zigbee.0 (12720) starting. Version 1.7.6 (non-npm: ioBroker/ioBroker.zigbee#90b31ec12c45cae433f13d23614d34a633baa2ca) in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.18.1, js-controller: 4.0.23
                                          2022-11-08 18:19:49.271  - info: zigbee.0 (12720) delete old Backup files. keep only last 10
                                          2022-11-08 18:19:49.274  - info: zigbee.0 (12720) Starting Zigbee  npm ...
                                          2022-11-08 18:19:49.960  - info: zigbee.0 (12720) Installed Version: ioBroker/ioBroker.zigbee#90b31ec12c45cae433f13d23614d34a633baa2ca
                                          2022-11-08 18:20:03.854  - error: javascript.0 (10979) Error in callback: TypeError: Cannot read properties of undefined (reading 'pmap_id')
                                          2022-11-08 18:20:03.854  - error: javascript.0 (10979)     at aktualisiere_datenpunkte (script.js.common.iRobot-Control:184:105)
                                          2022-11-08 18:20:03.855  - error: javascript.0 (10979)     at Object.<anonymous> (script.js.common.iRobot-Control:45:13)
                                          2022-11-08 18:20:03.855  - error: javascript.0 (10979)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1214:38)
                                          2022-11-08 18:20:03.856  - error: javascript.0 (10979)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:596:29)
                                          2022-11-08 18:20:03.856  - error: javascript.0 (10979)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5909:56)
                                          2022-11-08 18:20:03.857  - error: javascript.0 (10979)     at processImmediate (node:internal/timers:466:21)
                                          2022-11-08 18:20:10.091  - error: zigbee.0 (12720) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
                                          2022-11-08 18:20:10.129  - error: zigbee.0 (12720) Failed to start Zigbee
                                          2022-11-08 18:20:10.130  - error: zigbee.0 (12720) Error herdsman start
                                          2022-11-08 18:20:20.136  - info: zigbee.0 (12720) Try to reconnect. 1 attempts left
                                          2022-11-08 18:20:20.138  - info: zigbee.0 (12720) Starting Zigbee  npm ...
                                          2022-11-08 18:20:20.171  - info: zigbee.0 (12720) Installed Version: ioBroker/ioBroker.zigbee#90b31ec12c45cae433f13d23614d34a633baa2ca
                                          2022-11-08 18:20:20.469  - error: zigbee.0 (12720) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                                          2022-11-08 18:20:20.470  - error: zigbee.0 (12720) Failed to start Zigbee
                                          2022-11-08 18:20:20.471  - error: zigbee.0 (12720) Error herdsman start
                                          Leider fange ich mit den Fehler nicht viel an - sieht für mich sehr generisch aus.
                                            @benemuc
                                            Warum eine Version aus dem github?
                                            1072
