    4. Installation
    5. Keine Adapter Neuinsatllation oder Updgrades mehr möglich
    • E
      exe203 last edited by
      Hallo zusammen ,
      bei mir laufen seit geraumer Zeit keine Adapter-Upgrades mehr durch.
      Auch Neuinstallationen sind nicht mehr möglich.
      Beispiel vom Upgrade-Versuch:
      pi@raspberrypi:~ $ iobroker upgrade alexa2
      This upgrade of "alexa2" will at least introduce the following changes:
      -> 3.20.1:
      make sure caching works correctly with multiple instances of the adapter
      -> 3.20.0:
      Increase minimum interval for requesting smart home device data to 15 minutes (900s) because of Amazon rate limits. Please do not try to work around it!
      Cache Smart home device list and data to prevent too many requests when restarting adapter in short intervals and to prevent deleted smart home devices also on further rate limit issues
      -> 3.19.10:
      Fix issue in retry handling when rate limit exceeded is returned by Amazon
      Do not clean up Smart Home Device objects for now - delete manually if you remove a device
      -> 3.19.9:
      Receive the correct player status again when musik is stopped
      -> 3.19.8:
      Add safeguard for too high intervals
      -> 3.19.7:
      Fix doNotDisturb when using a time string
      -> 3.19.6:
      Would you like to upgrade alexa2 from @3.11.2 to @3.20.1 now? [(y)es, (n)o]: y
      Update alexa2 from @3.11.2 to @3.20.1
      NPM version: 8.19.3
      Installing iobroker.alexa2@3.20.1... (System call)
      host.raspberrypi Cannot install iobroker.alexa2@3.20.1: 217
      Danke für eure Unterstützung. Ich komme schlicht nicht mehr weiter.
        Thomas Braun Most Active @exe203 last edited by Thomas Braun
        @exe203
        Vermutlich der:
        https://forum.iobroker.net/topic/57337/fehler-25-bei-adapter-install-update-mit-npm8
        Bzw. riecht NPM version: 8.19.3 auch nach 'verfummelt'...
        Die regulären Versionen von nodejs kommen maximal mit 8.19.2 daher... (Stand heute).
          @exe203
          sudo ln -s /usr/bin/node /usr/bin/nodejs
          uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs
          sagt?
          • E
            Hallo Thomas,
            verfummelt kann sehr gut sein. Ich hoffe du kannst mir helfen, zu entknoten.
            pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
            ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
            pi@raspberrypi:~ $ pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
            -bash: pi@raspberrypi:~: Kommando nicht gefunden.
            pi@raspberrypi:~ $ ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
            -bash: ln:: Kommando nicht gefunden.
            pi@raspberrypi:~ $ uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs
            armv7l
            Kein Docker
            /usr/bin/nodejs
            /home/pi/.nvm/versions/node/v19.0.1/bin/node
            /home/pi/.nvm/versions/node/v19.0.1/bin/npm
            v10.24.1
            v19.0.1
            8.19.2
            4.0.23
            pi
            pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
            tty
            /home/pi
            OK:1 http://archive.raspberrypi.org/debian buster InRelease
            OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
            OK:3 https://deb.nodesource.com/node_10.x buster InRelease
            nodejs:
              Installiert:           10.24.1-1nodesource1
              Installationskandidat: 10.24.1-1nodesource1
              Versionstabelle:
             *** 10.24.1-1nodesource1 500
                    500 https://deb.nodesource.com/node_10.x buster/main armhf Packages
                    100 /var/lib/dpkg/status
                 10.24.0~dfsg-1~deb10u2 500
            pi@raspberrypi:~ $
              @exe203 sagte in Keine Adapter Neuinsatllation oder Updgrades mehr möglich:
              Warum???????
              Macht man so nicht, wenn man einen funktionierenden Paketmanager hat. Wie kommt man auf sowas?
              Schau in meiner Signatur wie man nodejs RICHTIG installiert.
              Und zwar im Moment die Version 16!
              E 1 Reply Last reply Reply Quote 1
              • E
                exe203 @Thomas Braun last edited by
                Das Warum kann ich dir nicht beantworten.
                Meine Installation basiert hauptsächlich auf zusammenkopierten Bestandteilen aus diversen Tutorials.
                Ich bin mir ziemlich sicher, dass du im System noch den ein oder anderen Augenverdreher oder Kopfschüttler finden würdest.
                Ich hangel mich mal durch den Post aus deiner Signatur und versuch das zu bereinigen.
                Thomas Braun bahnuhr 2 Replies Last reply Reply Quote 0
                  @exe203
                  Kann ja nicht lange her sein, die bei dir installierte reingepfuschte nodeJS 19.0.1 ist HEUTE veröffentlicht worden.
                  • bahnuhr
                    bahnuhr Forum Testing Most Active @exe203 last edited by
                    @exe203
                    oder du machst alles neu. Dürfte evtl. einfacher sein.
                    Dann kannst du auch gleich buster auf bullseye updaten.
                    Wie man installiert findest du in der Doku auf der iob Webseite.
                    youtube ist hier weniger sinnvoll.
                    Thomas Braun E 2 Replies Last reply Reply Quote 0
                    • E
                      ich hatte vermutet, dass es an einer veralteten nodejs Version liegen konnte und mich hieran gehalten:
                      https://phoenixnap.com/kb/update-node-js-version
                        Thomas Braun Most Active @bahnuhr last edited by
                        @bahnuhr sagte in Keine Adapter Neuinsatllation oder Updgrades mehr möglich:
                        Eigentlich muss nur der per nvm reingedübelte Mumpitz gelöscht werden und die nodesource.list auf 16 umgestellt werden. Und dann ordentlich mit dem Paketmanager arbeiten.
                        bahnuhr 1 Reply Last reply Reply Quote 1
                        • E
                          exe203 @bahnuhr last edited by
                          @bahnuhr
                          Ich habe ein bisschen Bammel, dabei meine Vis und die komplette Adapter-Config samt Skripten zu verlieren. Backup hab ich natürlich trommelwirbel keins...
                          bahnuhr Thomas Braun 2 Replies Last reply Reply Quote 0
                          • bahnuhr
                            bahnuhr Forum Testing Most Active @Thomas Braun last edited by
                            @thomas-braun sagte in Keine Adapter Neuinsatllation oder Updgrades mehr möglich:
                            Ja, das glaub ich dir. Wenn man weiß wie es geht.
                            Ich bin ja auch schon ne Weile dabei; und wüsste dies jetzt nicht.
                            • bahnuhr
                              Skripten
                              Das intensivste sind doch die Scripte.
                              Spiegel die im (Einstellung js. Adapter) und dann weg sichern.
                              Und die Adapter config kannst du in den meinsten Fälle auch speichern.
                                Alles nicht falsch (je nach Verwendungszweck und der sonstigen Installation), allerdings bricht dir das den Hals in Verbindung mit dem ioBroker, der setzt nämlich auf die übliche Installation via apt.
                                  Dann hast du noch nie mein node-HowTo gelesen.
                                  Da steht das nämlich alles drin und auch wie man das alles bereinigt.
                                    Und warum nicht? Wou ist der Backitup-Adapter nochmal da?
                                    • bahnuhr
                                      Hab ich schon einmal reingeschaut.
                                      Allerdings brauchte ich dies bisher nicht.
                                      • E
                                        ich bin ja einsichtig. Nützt jetzt halt auch nix mehr.
                                          Dann ran. Link zum HowTo hast du ja.
                                          • E
                                            @thomas-braun said in Keine Adapter Neuinsatllation oder Updgrades mehr möglich:
                                            Bevor ich es damit nur noch mehr verknote: Muss ich die jetzige Installation erstmal bereinigen oder installiert sich das nach dem How To sauber drüber?
                                            1011
