Cloud Adapter verliert manchmal die Verbindung
ich weiss nicht warum , aber mein Cloud Adapter (4.2.2) verliert ab und zu die Verbindung und verbindet sich dann sofort wieder mit einem anderen Port. Ist das normal ?2022-11-05 15:30:07.787 - info: cloud.0 (21866) Connection changed: disconnect 2022-11-05 15:30:07.789 - info: cloud.0 (21866) Connection lost 2022-11-05 15:30:07.790 - info: cloud.0 (21866) Restart adapter by disconnect 2022-11-05 15:30:08.582 - info: ical.0 (3972) Terminated (NO_ERROR): Without reason 2022-11-05 15:30:09.149 - info: host.raspberrypi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR) 2022-11-05 15:30:17.792 - warn: cloud.0 (21866) Terminated (-100): Without reason 2022-11-05 15:30:18.443 - info: host.raspberrypi instance system.adapter.cloud.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP) 2022-11-05 15:30:18.444 - info: host.raspberrypi Restart adapter system.adapter.cloud.0 because enabled 2022-11-05 15:30:19.536 - info: host.raspberrypi instance system.adapter.cloud.0 started with pid 4170 2022-11-05 15:30:21.879 - info: cloud.0 (4170) starting. Version 4.2.2 in /opt/iobroker/node_modules/iobroker.cloud, node: v16.18.0, js-controller: 4.0.23 2022-11-05 15:30:21.964 - info: cloud.0 (4170) Connecting with https://iobroker.pro:10555 with "@pro_xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx" 2022-11-05 15:30:22.161 - info: cloud.0 (4170) Trying to connect as system.user.admin to cloud 2022-11-05 15:30:22.314 - info: cloud.0 (4170) Adapter redirected temporally to "https://iobroker.pro:10556" in 30 seconds. Reason: command from server 2022-11-05 15:30:22.318 - info: cloud.0 (4170) Connection changed: disconnect 2022-11-05 15:30:48.424 - info: javascript.0 (807) script.js.common.Wichtig.System_Adapter_wahr_falsch_TEST: telegram['Michael']: cloud.0 is connected false Adapter NICHT erreichbar 2022-11-05 15:30:52.354 - info: cloud.0 (4170) Trying to connect as system.user.admin to cloud 2022-11-05 15:30:55.130 - info: cloud.0 (4170) Connection changed: connect
