    4. [gelöst] Zigbee: DeviceConfigure failed?!
      kukoratsch last edited by kukoratsch
      Mein ioBroker ist installiert auf NUC VM , mit Zigbee version 1.5.7
      Seit gestern bekommt folgende FM und ich musste die PAN ID ändern, aber wenn ich das ändere muss ich doch alle Geräte neu anlernen oder?
      Wenn ich Backup vor 3 Tage wider zurückspiele bekomme ich trotzdem gleiche Meldung.
      USB Stick ist eine TI Z-Stack/CCxxxx QinHeng Electronics CH340 serial converter
      Kann mir biete jemand helfen
      zigbee.0
      	2022-11-08 08:23:31.765	error	Error herdsman start
      zigbee.0
      	2022-11-08 08:23:31.765	error	Failed to start Zigbee
      zigbee.0
      	2022-11-08 08:23:31.765	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
      zigbee.0
      	2022-11-08 08:23:31.654	info	Installed Version: iobroker.zigbee@1.7.5
      zigbee.0
      	2022-11-08 08:23:31.642	info	Starting Zigbee npm ...
      zigbee.0
      	2022-11-08 08:23:31.642	info	Try to reconnect. 1 attempts left
      zigbee.0
      	2022-11-08 08:23:21.640	error	Error herdsman start
      zigbee.0
      	2022-11-08 08:23:21.640	error	Failed to start Zigbee
      zigbee.0
      	2022-11-08 08:23:21.640	error	Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
      zigbee.0
      	2022-11-08 08:23:21.587	error	Re-commissioning your network will require re-pairing of all devices!
      zigbee.0
      	2022-11-08 08:23:21.587	error	If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
      zigbee.0
      	2022-11-08 08:23:21.587	error	Please update configuration to prevent further issues.
      zigbee.0
      	2022-11-08 08:23:21.586	error	- Channel List: configured=11, adapter=11
      zigbee.0
      	2022-11-08 08:23:21.586	error	- Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
      zigbee.0
      	2022-11-08 08:23:21.586	error	- Extended PAN ID: configured=00124b00228116da, adapter=dddddddddddddddd
      zigbee.0
      	2022-11-08 08:23:21.585	error	- PAN ID: configured=6754, adapter=6754
      zigbee.0
      	2022-11-08 08:23:21.585	error	Configuration is not consistent with adapter state/backup!
      zigbee.0
      	2022-11-08 08:23:21.398	info	Installed Version: iobroker.zigbee@1.7.5
      zigbee.0
      	2022-11-08 08:23:21.221	info	Starting Zigbee npm ...
      zigbee.0
      	2022-11-08 08:23:21.220	info	delete old Backup files. keep only last 10
      zigbee.0
      	2022-11-08 08:23:21.183	info	starting. Version 1.7.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.18.0, js-controller: 4.0.23
        Thomas Braun Most Active @kukoratsch last edited by
        @kukoratsch sagte in Zigbee: DeviceConfigure failed?!:
        Trag n3w2m40U0aCe85d statt dddddddddddddddd im Adapter ein.
          kukoratsch @Thomas Braun last edited by
          Danke schön Thomas Braun Ungerer nach 6 mall Backup Zurückspielen ist Adapter wieder grün mit PAN ID dddddddddddddddd.
            dddddddddddddddd
            Sollte man nicht verwenden. Wenn dein Nachbar auf die selbe (Nicht)-Idee kommt haste ein Problem.
              @thomas-braun Wenn ich PAN ID abändere, muss ich dann alle Geräte neu anlernen?
                Thomas Braun Most Active @kukoratsch last edited by Thomas Braun
                @kukoratsch
                Ja, damit die dann auch in 'dein' Netz kommen und nicht weiterhin mehr oder weniger offen durch die Gegend funken.
                  @thomas-braun dankeschön hat super funktioniert
                    DerrickOlley last edited by DerrickOlley
                    Der gleiche Fehler war die Lösung scheint hier zu finden zu sein!!
