    4. Installation
    5. Iobrocker installation Raspberry
      Trivianni last edited by
      Hello,
      I wanted to install iobroker on my Raspberry debian 11.
      In the installation guidelines there is always mentioned a syntax starting with curl.
      Unfortunately nothing happens while executing this. It means after 2 sec the input line is appearing again.
      Does anyone has a hint for me what the problem could be?
      Is there a different why to install iobroker?
      Thanks in advance.
      Regards
      Christian
        Homoran Global Moderator Administrators @Trivianni last edited by
        @trivianni sagte in Iobrocker installation Raspberry:
        no!
        just the one line
        curl -sLf https://iobroker.net/install.sh | bash -
        this will install nodejs and iobroker completely.
        really debian? or raspberrypi OS?
          Thomas Braun Most Active @Trivianni last edited by
          @trivianni
          Try
            Trivianni @Thomas Braun last edited by
            Hi this is the syntax I have tried but nothing is happening during execution.
            No error, no warning nothing.
            Regards
            Christian
              Trivianni @Homoran last edited by
              Hi yesterday I did the upgrade von buster to bullseye.
                on what base?
                @homoran sagte in Iobrocker installation Raspberry:
                  I don't know from my mind but is this important for this issue?
                  I thought it is a more general problem instead of related to any specific base.
                    maybe! in basic debian installation there is no curl.
                    on the other hand Raspberry pi OS is an optimized debian for Raspberrys
                      it seems as if curl is installed:
                      pi@raspberrypi:~ $ curl -V
                      curl 7.74.0 (arm-unknown-linux-gnueabihf) libcurl/7.74.0 OpenSSL/1.1.1n zlib/1.2.11 brotli/1.0.9 libidn2/2.3.0 libpsl/0.21.0 (+libidn2/2.3.0) libssh2/1.9.0 nghttp2/1.43.0 librtmp/2.3
                      Release-Date: 2020-12-09
                      Protocols: dict file ftp ftps gopher http https imap imaps ldap ldaps mqtt pop3 pop3s rtmp rtsp scp sftp smb smbs smtp smtps telnet tftp
                      Features: alt-svc AsynchDNS brotli GSS-API HTTP2 HTTPS-proxy IDN IPv6 Kerberos Largefile libz NTLM NTLM_WB PSL SPNEGO SSL TLS-SRP UnixSockets
                      Are there any other tests I can do?
                        Thomas Braun Most Active last edited by Thomas Braun
                        @trivianni
                        curl -vL https://iobroker.net/install.sh | bash -
                        installationsprobleme
                        368
