    4. *gelöst* Zigbee Adapter läuft nicht mehr nach
    • G
      gluecksmann last edited by gluecksmann
      pi@raspberrypi:~ $ iobroker status
      Objects type: jsonl
      States  type: jsonl
      pi@raspberrypi:~ $
      pi@raspberrypi:~ $ iobroker list instances
      + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
        system.adapter.alias-manager.0          : alias-manager         : raspberrypi                              - disabled
      + system.adapter.ble.0                    : ble                   : raspberrypi                              -  enabled
      + system.adapter.chromecast.0             : chromecast            : raspberrypi                              -  enabled
        system.adapter.daswetter.0              : daswetter             : raspberrypi                              - disabled
        system.adapter.devices.0                : devices               : raspberrypi                              - disabled
        system.adapter.dwd.0                    : dwd                   : raspberrypi                              - disabled
        system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : raspberrypi                              - disabled
      + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
      + system.adapter.govee.0                  : govee                 : raspberrypi                              -  enabled
        system.adapter.gruenbeck.0              : gruenbeck             : raspberrypi                              - disabled
        system.adapter.history.0                : history               : raspberrypi                              - disabled
      + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, port: 443
        system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi                              - disabled
      + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
        system.adapter.mielecloudservice.0      : mielecloudservice     : raspberrypi                              - disabled
      + system.adapter.musiccast.0              : musiccast             : raspberrypi                              -  enabled
        system.adapter.net-tools.0              : net-tools             : raspberrypi                              - disabled
        system.adapter.netatmo.0                : netatmo               : raspberrypi                              - disabled
        system.adapter.ping.0                   : ping                  : raspberrypi                              - disabled
        system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              - disabled
      + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
        system.adapter.schoolfree.0             : schoolfree            : raspberrypi                              -  enabled
      + system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi                              -  enabled
        system.adapter.smartcontrol.0           : smartcontrol          : raspberrypi                              - disabled
      + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.sonos.0                  : sonos                 : raspberrypi                              -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
        system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              - disabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              - disabled
        system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
        system.adapter.vis-players.0            : vis-players           : raspberrypi                              - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
        system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              - disabled
        system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              - disabled
      + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyACM0
      + instance is alive
      pi@raspberrypi:~ $
        Thomas Braun Most Active @gluecksmann last edited by
        @gluecksmann
        Wie stellt sich der Adapter bei einem (Neu)-Start im log file dar?
        Mit
        iobroker logs --watch | uniq
        kann man das beobachten.
        • G
          gluecksmann @Thomas Braun last edited by
          warum auch imer...ist er jetzt grün geworden...
          Jetzt muß ich nur noch meine alte VIS wiederherstellen... oder ich versuche mal die von Sigi aus... wie würde es ablaufen wenn ich meine wiederherstellen möchte? war ja was mit extrahieren?!
            @gluecksmann
            Vermutlich hat sich der zigbee-Adapter in der Zwischenzeit selber 'neugebaut'.
            Zu vis kann ich dir nix sagen, hier läuft keine.
            • crunchip
              @gluecksmann dein backup entpacken und die vis-view-json wieder reinladen
              • G
                gluecksmann @crunchip last edited by
                @crunchip
                Und jetzt noch mal für DAUs ... ich gehe in den Backup Adapter.. da kann ich die entsprechende Backupdatei runterladen? Und dann weiter?
                • crunchip
                  crunchip Forum Testing Most Active @gluecksmann last edited by
                  @gluecksmann du holst dir deine tar.gz auf deinen Rechner, entpackst diese mit einem zip Programm, darin enthalten sind dann deine einzelnen Dateien, die vis-view-json musst du dann in deinen iobroker wieder hochladen per Dateimanager
                  • G
                    @crunchip
                    Scheitere am entpacken...hab 7 Zip runtergeladen...
                    Thomas Braun crunchip 2 Replies Last reply Reply Quote 0
                      Thomas Braun Most Active @gluecksmann last edited by Thomas Braun
                      @gluecksmann sagte in *gelöst* Zigbee Adapter läuft nicht mehr nach:
                      7zip kann prinzipiell mit tar.gz umgehen.
                      Obacht, das sind ggf. zwei Dateien, das gz entpackt zu einem tar, das muss dann nochmal entpackt werden.
                      Einfacher ist die Konsole:
                      tar xzvf dein_backup.tar.gz
                      • crunchip
                        crunchip Forum Testing Most Active @gluecksmann last edited by crunchip
                        @gluecksmann geht doch, habs grad probiert, die Datei entpacken, dann wird ein Ordner erstellt, darin diese Datei nochmal entpacken, danach sind in dem Ordner alle Dateien, danach im Ordner files findest du den Ordner vis.0
                        • G
                          @crunchip
                          Die DAtei habe ich inzwischen... aber wie/wo ist der DAteimanager?
                          • crunchip
                            https://forum.iobroker.net/post/888878
                            dein vis editor
                            • G
                              @crunchip
                              er sagt ich kann nur in vis.0 hochladen... mache ich dieses, sehe ich aber die Datei nicht...
                              • crunchip
                                @gluecksmann hast du ein vorhandenes Projekt? (in der Regel main)
                                • G
                                  @crunchip
                                  Ja, aber das kann weg..bzw überschrieben werden...was auch immer
                                  • crunchip
                                    @gluecksmann du kannst auch dein komplettes Projekt aus der Datei importieren
                                    • G
                                      @crunchip
                                      meinst alle views? wäre schön
                                      • crunchip
                                        @gluecksmann na freilich, dafür machen wir das doch gerade
                                        in deinem Ordner xyz\backup\files\vis.0 liegen doch alle Dateien, dort auch dein komplettes Projekt, dies kannst du importieren
                                        G 2 Replies Last reply Reply Quote 0
                                        • G
                                          @crunchip
                                          bleibt immer noch die Frage, wie.... die von mir ins Mainverzeichnis geladene DAtei taucht nicht auf...
                                          • crunchip
                                            @gluecksmann d6d726df-4a06-4dae-b25b-6d1aa19feadd-image.png 52c755ce-b74d-462d-9287-864bc6c5f0e1-image.png
                                            6164
