    4. Adapter update probleme...
      bernd33-1 last edited by
      Systemdata Bitte Ausfüllen
      Hardwaresystem: PI4
      Arbeitsspeicher: 4GB
      Festplattenart: HDD
      Betriebssystem: Raspi OS Buster 32Bit
      Node-Version: 10.x.x
      Nodejs-Version: 16.18.0
      NPM-Version: 8.19.2
      Installationsart: Skript
      Image genutzt: Ja/Nein
      Ort/Name der Imagedatei: Link
      wenn ich einen Adapter aktualisieren will, läuft das im IOB zwar durch, aber danach ist der Adapter auf demselben Stand.
      Hier das Log von "iobroker upgrade daswetter --debug"
      pi@E4310:~ $ iobroker upgrade daswetter --debug
      This upgrade of "daswetter" will introduce the following changes:
      -> 3.1.4:
      update dependencies
      Would you like to upgrade daswetter from @3.1.3 to @3.1.4 now? [(y)es, (n)o]: y
      Update daswetter from @3.1.3 to @3.1.4
      host.E4310 Adapter "system.adapter.daswetter.0" is stopped.
      NPM version: 8.19.2
      Installing iobroker.daswetter@3.1.4... (System call)
      npm WARN old lockfile
      npm WARN old lockfile The package-lock.json file was created with an old version of npm,
      npm WARN old lockfile so supplemental metadata must be fetched from the registry.
      npm WARN old lockfile This is a one-time fix-up, please be patient...
      npm WARN old lockfile Error: git dep preparation failed
      npm WARN old lockfile     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:63:27)
      npm WARN old lockfile     at ChildProcess.emit (node:events:513:28)
      npm WARN old lockfile     at maybeClose (node:internal/child_process:1100:16)
      npm WARN old lockfile     at Process.ChildProcess._handle.onexit (node:internal/child_process:304:5)
      npm WARN old lockfile  Could not fetch metadata for iobroker.esphome@git+ssh://git@github.com/DrozmotiX/ioBroker.esphome.git#b6adb149202b81607fe1d726bbe7ffa6717d2352 Error: git dep preparation failed
      npm WARN old lockfile     at Process.ChildProcess._handle.onexit (node:internal/child_process:304:5) {
      npm WARN old lockfile   cmd: '/usr/bin/node',
      npm WARN old lockfile   args: [
      npm WARN old lockfile     '/usr/lib/node_modules/npm/bin/npm-cli.js',
      npm WARN old lockfile     'install',
      npm WARN old lockfile     '--force',
      npm WARN old lockfile     '--cache=/home/iobroker/.npm',
      npm WARN old lockfile     '--prefer-offline=false',
      npm WARN old lockfile     '--prefer-online=false',
      npm WARN old lockfile     '--offline=false',
      npm WARN old lockfile     '--no-progress',
      npm WARN old lockfile     '--no-save',
      npm WARN old lockfile     '--no-audit',
      npm WARN old lockfile     '--include=dev',
      npm WARN old lockfile     '--include=peer',
      npm WARN old lockfile     '--include=optional',
      npm WARN old lockfile     '--no-package-lock-only',
      npm WARN old lockfile     '--no-dry-run'
      npm WARN old lockfile   ],
      npm WARN old lockfile   code: 1,
      npm WARN old lockfile   signal: null,
      npm WARN old lockfile   stdout: '\n' +
      npm WARN old lockfile     '> iobroker.esphome@0.2.4 install\n' +
      npm WARN old lockfile     '> npip install\n' +
      npm WARN old lockfile     '\n' +
      npm WARN old lockfile     'No python_modules directory; installing pip locally if needed.\n' +
      npm WARN old lockfile     'Successfully completed pip check.\n' +
      npm WARN old lockfile     'Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple\n' +
      npm WARN old lockfile     'Collecting esphome>=2021.8\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/esphome/esphome-2022.2.6-py2.py3-none-any.whl (2.1 MB)\n' +
      npm WARN old lockfile     'Collecting tornado>=3.2\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/tornado/tornado-6.2-cp37-abi3-linux_armv7l.whl (422 kB)\n' +
      npm WARN old lockfile     'Collecting PyYAML==6.0\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/pyyaml/PyYAML-6.0-cp37-cp37m-linux_armv7l.whl (45 kB)\n' +
      npm WARN old lockfile     'Collecting kconfiglib==13.7.1\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/kconfiglib/kconfiglib-13.7.1-py2.py3-none-any.whl (145 kB)\n' +
      npm WARN old lockfile     'Collecting paho-mqtt==1.6.1\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/paho-mqtt/paho_mqtt-1.6.1-py3-none-any.whl (75 kB)\n' +
      npm WARN old lockfile     'Collecting tzdata>=2021.1\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/tzdata/tzdata-2022.6-py2.py3-none-any.whl (338 kB)\n' +
      npm WARN old lockfile     'Collecting esphome-dashboard==20220209.0\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/esphome-dashboard/esphome_dashboard-20220209.0-py3-none-any.whl (592 kB)\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/tornado/tornado-6.1-cp37-cp37m-linux_armv7l.whl (428 kB)\n' +
      npm WARN old lockfile     'Collecting voluptuous==0.12.2\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/voluptuous/voluptuous-0.12.2-py3-none-any.whl (35 kB)\n' +
      npm WARN old lockfile     'Collecting colorama==0.4.4\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/colorama/colorama-0.4.4-py2.py3-none-any.whl (16 kB)\n' +
      npm WARN old lockfile     'Collecting click==8.0.3\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/click/click-8.0.3-py3-none-any.whl (97 kB)\n' +
      npm WARN old lockfile     'Collecting aioesphomeapi==10.8.2\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/aioesphomeapi/aioesphomeapi-10.8.2-py2.py3-none-any.whl (49 kB)\n' +
      npm WARN old lockfile     'Collecting tzlocal==4.1\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/tzlocal/tzlocal-4.1-py3-none-any.whl (19 kB)\n' +
      npm WARN old lockfile     'Collecting zeroconf==0.38.3\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/zeroconf/zeroconf-0.38.3-py3-none-any.whl (97 kB)\n' +
      npm WARN old lockfile     'Collecting pyserial==3.5\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/pyserial/pyserial-3.5-py2.py3-none-any.whl (90 kB)\n' +
      npm WARN old lockfile     'Collecting esptool==3.2\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/esptool/esptool-3.2-py3-none-any.whl (326 kB)\n' +
      npm WARN old lockfile     'Collecting platformio==5.2.5\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/platformio/platformio-5.2.5-py3-none-any.whl (343 kB)\n' +
      npm WARN old lockfile     'Collecting noiseprotocol<1.0,>=0.3.1\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/noiseprotocol/noiseprotocol-0.3.1-py3-none-any.whl (20 kB)\n' +
      npm WARN old lockfile     'Collecting protobuf<4.0,>=3.12.2\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/protobuf/protobuf-3.20.3-py2.py3-none-any.whl (162 kB)\n' +
      npm WARN old lockfile     'Collecting importlib-metadata\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/importlib-metadata/importlib_metadata-5.0.0-py3-none-any.whl (21 kB)\n' +
      npm WARN old lockfile     'Collecting reedsolo<=1.5.4,>=1.5.3\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/reedsolo/reedsolo-1.5.4-cp37-cp37m-linux_armv7l.whl (819 kB)\n' +
      npm WARN old lockfile     'Collecting bitstring>=3.1.6\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/bitstring/bitstring-4.0.1-py3-none-any.whl (45 kB)\n' +
      npm WARN old lockfile     'Collecting ecdsa>=0.16.0\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/ecdsa/ecdsa-0.18.0-py2.py3-none-any.whl (142 kB)\n' +
      npm WARN old lockfile     'Requirement already satisfied: cryptography>=2.1.4 in /usr/lib/python3/dist-packages (from esptool==3.2->esphome>=2021.8) (2.6.1)\n' +
      npm WARN old lockfile     'Collecting bottle==0.12.*\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/bottle/bottle-0.12.23-py3-none-any.whl (90 kB)\n' +
      npm WARN old lockfile     'Collecting uvicorn==0.16.0\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/uvicorn/uvicorn-0.16.0-py3-none-any.whl (56 kB)\n' +
      npm WARN old lockfile     'Collecting wsproto==1.0.*\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/wsproto/wsproto-1.0.0-py3-none-any.whl (24 kB)\n' +
      npm WARN old lockfile     'Collecting marshmallow<4,>=2\n' +
      npm WARN old lockfile     '  Using cached marshmallow-3.19.0-py3-none-any.whl (49 kB)\n' +
      npm WARN old lockfile     'Collecting pyelftools<1,>=0.27\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/pyelftools/pyelftools-0.29-py2.py3-none-any.whl (174 kB)\n' +
      npm WARN old lockfile     'Collecting semantic-version==2.9.*\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/semantic-version/semantic_version-2.9.0-py2.py3-none-any.whl (19 kB)\n' +
      npm WARN old lockfile     'Requirement already satisfied: requests==2.* in /usr/lib/python3/dist-packages (from platformio==5.2.5->esphome>=2021.8) (2.21.0)\n' +
      npm WARN old lockfile     'Collecting tabulate==0.8.*\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/tabulate/tabulate-0.8.10-py3-none-any.whl (37 kB)\n' +
      npm WARN old lockfile     'Collecting aiofiles==0.8.*\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/aiofiles/aiofiles-0.8.0-py3-none-any.whl (13 kB)\n' +
      npm WARN old lockfile     'Collecting ajsonrpc==1.*\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/ajsonrpc/ajsonrpc-1.2.0-py3-none-any.whl (22 kB)\n' +
      npm WARN old lockfile     'Collecting starlette==0.18.*\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/starlette/starlette-0.18.0-py3-none-any.whl (59 kB)\n' +
      npm WARN old lockfile     'Collecting backports.zoneinfo\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/backports-zoneinfo/backports.zoneinfo-0.2.1-cp37-cp37m-linux_armv7l.whl (76 kB)\n' +
      npm WARN old lockfile     'Collecting pytz-deprecation-shim\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/pytz-deprecation-shim/pytz_deprecation_shim-0.1.0.post0-py2.py3-none-any.whl (15 kB)\n' +
      npm WARN old lockfile     'Collecting ifaddr>=0.1.7\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/ifaddr/ifaddr-0.2.0-py3-none-any.whl (12 kB)\n' +
      npm WARN old lockfile     'Collecting anyio<4,>=3.0.0\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/anyio/anyio-3.6.2-py3-none-any.whl (80 kB)\n' +
      npm WARN old lockfile     'Collecting typing-extensions\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/typing-extensions/typing_extensions-4.4.0-py3-none-any.whl (26 kB)\n' +
      npm WARN old lockfile     'Collecting asgiref>=3.4.0\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/asgiref/asgiref-3.5.2-py3-none-any.whl (22 kB)\n' +
      npm WARN old lockfile     'Collecting h11>=0.8\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/h11/h11-0.14.0-py3-none-any.whl (58 kB)\n' +
      npm WARN old lockfile     'Requirement already satisfied: six>=1.9.0 in /usr/lib/python3/dist-packages (from ecdsa>=0.16.0->esptool==3.2->esphome>=2021.8) (1.12.0)\n' +
      npm WARN old lockfile     'Collecting packaging>=17.0\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/packaging/packaging-21.3-py3-none-any.whl (40 kB)\n' +
      npm WARN old lockfile     'Collecting cryptography>=2.1.4\n' +
      npm WARN old lockfile     '  Using cached cryptography-38.0.3.tar.gz (599 kB)\n' +
      npm WARN old lockfile     '  Installing build dependencies: started\n' +
      npm WARN old lockfile     "  Installing build dependencies: finished with status 'done'\n" +
      npm WARN old lockfile     '  Getting requirements to build wheel: started\n' +
      npm WARN old lockfile     "  Getting requirements to build wheel: finished with status 'done'\n" +
      npm WARN old lockfile     '  Preparing metadata (pyproject.toml): started\n' +
      npm WARN old lockfile     "  Preparing metadata (pyproject.toml): finished with status 'done'\n" +
      npm WARN old lockfile     'Collecting cffi>=1.12\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/cffi/cffi-1.15.1-cp37-cp37m-linux_armv7l.whl (219 kB)\n' +
      npm WARN old lockfile     'Collecting zipp>=0.5\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/zipp/zipp-3.10.0-py3-none-any.whl (6.2 kB)\n' +
      npm WARN old lockfile     'Collecting idna>=2.8\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/idna/idna-3.4-py3-none-any.whl (61 kB)\n' +
      npm WARN old lockfile     'Collecting sniffio>=1.1\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/sniffio/sniffio-1.3.0-py3-none-any.whl (10 kB)\n' +
      npm WARN old lockfile     'Collecting pycparser\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/pycparser/pycparser-2.21-py2.py3-none-any.whl (119 kB)\n' +
      npm WARN old lockfile     'Collecting pyparsing!=3.0.5,>=2.0.2\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/pyparsing/pyparsing-3.0.9-py3-none-any.whl (98 kB)\n' +
      npm WARN old lockfile     'Building wheels for collected packages: cryptography\n' +
      npm WARN old lockfile     '  Building wheel for cryptography (pyproject.toml): started\n' +
      npm WARN old lockfile     "  Building wheel for cryptography (pyproject.toml): finished with status 'error'\n" +
      npm WARN old lockfile     'Failed to build cryptography\n',
      npm WARN old lockfile   stderr: 'npm WARN using --force Recommended protections disabled.\n' +
      npm WARN old lockfile     'npm WARN old lockfile \n' +
      npm WARN old lockfile     'npm WARN old lockfile The package-lock.json file was created with an old version of npm,\n' +
      npm WARN old lockfile     'npm WARN old lockfile so supplemental metadata must be fetched from the registry.\n' +
      npm WARN old lockfile     'npm WARN old lockfile This is a one-time fix-up, please be patient...\n' +
      npm WARN old lockfile     'npm WARN deprecated source-map-url@0.4.1: See https://github.com/lydell/source-map-url#deprecated\n' +
      npm WARN old lockfile     'npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated\n' +
      npm WARN old lockfile     'npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated\n' +
      npm WARN old lockfile     'npm WARN deprecated source-map-resolve@0.5.3: See https://github.com/lydell/source-map-resolve#deprecated\n' +
      npm WARN old lockfile     'npm WARN deprecated chokidar@2.1.8: Chokidar 2 does not receive security updates since 2019. Upgrade to chokidar 3 with 15x fewer dependencies\n' +
      npm WARN old lockfile     'Cache entry deserialization failed, entry ignored\n' +
      npm WARN old lockfile     '  Cache entry deserialization failed, entry ignored\n' +
      npm WARN old lockfile     '  error: subprocess-exited-with-error\n' +
      npm WARN old lockfile     '  \n' +
      npm WARN old lockfile     '  × Building wheel for cryptography (pyproject.toml) did not run successfully.\n' +
      npm WARN old lockfile     '  │ exit code: 1\n' +
      npm WARN old lockfile     '  ╰─> [191 lines of output]\n' +
      npm WARN old lockfile     '      running bdist_wheel\n' +
      npm WARN old lockfile     '      running build\n' +
      npm WARN old lockfile     '      running build_py\n' +
      npm WARN old lockfile     '      creating build\n' +
      npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37\n' +
      npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography\n' +
      npm WARN old lockfile     '      copying src/cryptography/utils.py -> build/lib.linux-armv7l-cpython-37/cryptography\n' +
      npm WARN old lockfile     '      copying src/cryptography/exceptions.py -> build/lib.linux-armv7l-cpython-37/cryptography\n' +
      npm WARN old lockfile     '      copying src/cryptography/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography\n' +
      npm WARN old lockfile     '      copying src/cryptography/__about__.py -> build/lib.linux-armv7l-cpython-37/cryptography\n' +
      npm WARN old lockfile     '      copying src/cryptography/fernet.py -> build/lib.linux-armv7l-cpython-37/cryptography\n' +
      npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/_oid.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat\n' +
      npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/x509\n' +
      npm WARN old lockfile     '      copying src/cryptography/x509/ocsp.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509\n' +
      npm WARN old lockfile     '      copying src/cryptography/x509/general_name.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509\n' +
      npm WARN old lockfile     '      copying src/cryptography/x509/name.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509\n' +
      npm WARN old lockfile     '      copying src/cryptography/x509/base.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509\n' +
      npm WARN old lockfile     '      copying src/cryptography/x509/oid.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509\n' +
      npm WARN old lockfile     '      copying src/cryptography/x509/certificate_transparency.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509\n' +
      npm WARN old lockfile     '      copying src/cryptography/x509/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509\n' +
      npm WARN old lockfile     '      copying src/cryptography/x509/extensions.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509\n' +
      npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/bindings/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings\n' +
      npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends\n' +
      npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/hashes.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/constant_time.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/keywrap.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/padding.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/poly1305.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/_serialization.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/_asymmetric.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/hmac.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/_cipheralgorithm.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/cmac.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives\n' +
      npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/openssl\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/bindings/openssl/_conditional.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/openssl\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/bindings/openssl/binding.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/openssl\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/bindings/openssl/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/openssl\n' +
      npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/backend.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/x509.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/utils.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/hashes.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/ec.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/aead.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/ed448.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/rsa.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/decode_asn1.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/poly1305.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/ed25519.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/dsa.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/x448.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/x25519.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/hmac.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/cmac.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/dh.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/ciphers.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl\n' +
      npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/twofactor\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/twofactor/totp.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/twofactor\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/twofactor/hotp.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/twofactor\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/twofactor/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/twofactor\n' +
      npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/ciphers/aead.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/ciphers/algorithms.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/ciphers/base.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/ciphers/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/ciphers/modes.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers\n' +
      npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/kdf/hkdf.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/kdf/pbkdf2.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/kdf/x963kdf.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/primitiv'... 9204 more characters
      npm WARN old lockfile }
      npm ERR! code 1
      npm ERR! git dep preparation failed
      npm ERR! command /usr/bin/node /usr/lib/node_modules/npm/bin/npm-cli.js install --force --cache=/home/iobroker/.npm --prefer-offline=false --prefer-online=false --offline=false --no-progress --no-save --no-audit --include=dev --include=peer --include=optional --no-package-lock-only --no-dry-run
      npm ERR! > iobroker.esphome@0.2.4 install
      npm ERR! > npip install
      npm ERR!
      npm ERR! No python_modules directory; installing pip locally if needed.
      npm ERR! Successfully completed pip check.
      npm ERR! Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
      npm ERR! Collecting esphome>=2021.8
      npm ERR!   Using cached https://www.piwheels.org/simple/esphome/esphome-2022.2.6-py2.py3-none-any.whl (2.1 MB)
      npm ERR! Collecting tornado>=3.2
      npm ERR!   Using cached https://www.piwheels.org/simple/tornado/tornado-6.2-cp37-abi3-linux_armv7l.whl (422 kB)
      npm ERR! Collecting PyYAML==6.0
      npm ERR!   Using cached https://www.piwheels.org/simple/pyyaml/PyYAML-6.0-cp37-cp37m-linux_armv7l.whl (45 kB)
      npm ERR! Collecting colorama==0.4.4
      npm ERR!   Using cached https://www.piwheels.org/simple/colorama/colorama-0.4.4-py2.py3-none-any.whl (16 kB)
      npm ERR!   Using cached https://www.piwheels.org/simple/tornado/tornado-6.1-cp37-cp37m-linux_armv7l.whl (428 kB)
      npm ERR! Collecting esphome-dashboard==20220209.0
      npm ERR!   Using cached https://www.piwheels.org/simple/esphome-dashboard/esphome_dashboard-20220209.0-py3-none-any.whl (592 kB)
      npm ERR! Collecting voluptuous==0.12.2
      npm ERR!   Using cached https://www.piwheels.org/simple/voluptuous/voluptuous-0.12.2-py3-none-any.whl (35 kB)
      npm ERR! Collecting aioesphomeapi==10.8.2
      npm ERR!   Using cached https://www.piwheels.org/simple/aioesphomeapi/aioesphomeapi-10.8.2-py2.py3-none-any.whl (49 kB)
      npm ERR! Collecting zeroconf==0.38.3
      npm ERR!   Using cached https://www.piwheels.org/simple/zeroconf/zeroconf-0.38.3-py3-none-any.whl (97 kB)
      npm ERR! Collecting paho-mqtt==1.6.1
      npm ERR!   Using cached https://www.piwheels.org/simple/paho-mqtt/paho_mqtt-1.6.1-py3-none-any.whl (75 kB)
      npm ERR! Collecting tzdata>=2021.1
      npm ERR!   Using cached https://www.piwheels.org/simple/tzdata/tzdata-2022.6-py2.py3-none-any.whl (338 kB)
      npm ERR! Collecting platformio==5.2.5
      npm ERR!   Using cached https://www.piwheels.org/simple/platformio/platformio-5.2.5-py3-none-any.whl (343 kB)
      npm ERR! Collecting click==8.0.3
      npm ERR!   Using cached https://www.piwheels.org/simple/click/click-8.0.3-py3-none-any.whl (97 kB)
      npm ERR! Collecting esptool==3.2
      npm ERR!   Using cached https://www.piwheels.org/simple/esptool/esptool-3.2-py3-none-any.whl (326 kB)
      npm ERR! Collecting tzlocal==4.1
      npm ERR!   Using cached https://www.piwheels.org/simple/tzlocal/tzlocal-4.1-py3-none-any.whl (19 kB)
      npm ERR! Collecting pyserial==3.5
      npm ERR!   Using cached https://www.piwheels.org/simple/pyserial/pyserial-3.5-py2.py3-none-any.whl (90 kB)
      npm ERR! Collecting kconfiglib==13.7.1
      npm ERR!   Using cached https://www.piwheels.org/simple/kconfiglib/kconfiglib-13.7.1-py2.py3-none-any.whl (145 kB)
      npm ERR! Collecting protobuf<4.0,>=3.12.2
      npm ERR!   Using cached https://www.piwheels.org/simple/protobuf/protobuf-3.20.3-py2.py3-none-any.whl (162 kB)
      npm ERR! Collecting noiseprotocol<1.0,>=0.3.1
      npm ERR!   Using cached https://www.piwheels.org/simple/noiseprotocol/noiseprotocol-0.3.1-py3-none-any.whl (20 kB)
      npm ERR! Collecting importlib-metadata
      npm ERR!   Using cached https://www.piwheels.org/simple/importlib-metadata/importlib_metadata-5.0.0-py3-none-any.whl (21 kB)
      npm ERR! Requirement already satisfied: cryptography>=2.1.4 in /usr/lib/python3/dist-packages (from esptool==3.2->esphome>=2021.8) (2.6.1)
      npm ERR! Collecting bitstring>=3.1.6
      npm ERR!   Using cached https://www.piwheels.org/simple/bitstring/bitstring-4.0.1-py3-none-any.whl (45 kB)
      npm ERR! Collecting reedsolo<=1.5.4,>=1.5.3
      npm ERR!   Using cached https://www.piwheels.org/simple/reedsolo/reedsolo-1.5.4-cp37-cp37m-linux_armv7l.whl (819 kB)
      npm ERR! Collecting ecdsa>=0.16.0
      npm ERR!   Using cached https://www.piwheels.org/simple/ecdsa/ecdsa-0.18.0-py2.py3-none-any.whl (142 kB)
      npm ERR! Collecting bottle==0.12.*
      npm ERR!   Using cached https://www.piwheels.org/simple/bottle/bottle-0.12.23-py3-none-any.whl (90 kB)
      npm ERR! Collecting ajsonrpc==1.*
      npm ERR!   Using cached https://www.piwheels.org/simple/ajsonrpc/ajsonrpc-1.2.0-py3-none-any.whl (22 kB)
      npm ERR! Collecting tabulate==0.8.*
      npm ERR!   Using cached https://www.piwheels.org/simple/tabulate/tabulate-0.8.10-py3-none-any.whl (37 kB)
      npm ERR! Collecting pyelftools<1,>=0.27
      npm ERR!   Using cached https://www.piwheels.org/simple/pyelftools/pyelftools-0.29-py2.py3-none-any.whl (174 kB)
      npm ERR! Collecting aiofiles==0.8.*
      npm ERR!   Using cached https://www.piwheels.org/simple/aiofiles/aiofiles-0.8.0-py3-none-any.whl (13 kB)
      npm ERR! Collecting uvicorn==0.16.0
      npm ERR!   Using cached https://www.piwheels.org/simple/uvicorn/uvicorn-0.16.0-py3-none-any.whl (56 kB)
      npm ERR! Collecting marshmallow<4,>=2
      npm ERR!   Using cached marshmallow-3.19.0-py3-none-any.whl (49 kB)
      npm ERR! Collecting wsproto==1.0.*
      npm ERR!   Using cached https://www.piwheels.org/simple/wsproto/wsproto-1.0.0-py3-none-any.whl (24 kB)
      npm ERR! Collecting semantic-version==2.9.*
      npm ERR!   Using cached https://www.piwheels.org/simple/semantic-version/semantic_version-2.9.0-py2.py3-none-any.whl (19 kB)
      npm ERR! Collecting starlette==0.18.*
      npm ERR!   Using cached https://www.piwheels.org/simple/starlette/starlette-0.18.0-py3-none-any.whl (59 kB)
      npm ERR! Requirement already satisfied: requests==2.* in /usr/lib/python3/dist-packages (from platformio==5.2.5->esphome>=2021.8) (2.21.0)
      npm ERR! Collecting pytz-deprecation-shim
      npm ERR!   Using cached https://www.piwheels.org/simple/pytz-deprecation-shim/pytz_deprecation_shim-0.1.0.post0-py2.py3-none-any.whl (15 kB)
      npm ERR! Collecting backports.zoneinfo
      npm ERR!   Using cached https://www.piwheels.org/simple/backports-zoneinfo/backports.zoneinfo-0.2.1-cp37-cp37m-linux_armv7l.whl (76 kB)
      npm ERR! Collecting ifaddr>=0.1.7
      npm ERR!   Using cached https://www.piwheels.org/simple/ifaddr/ifaddr-0.2.0-py3-none-any.whl (12 kB)
      npm ERR! Collecting anyio<4,>=3.0.0
      npm ERR!   Using cached https://www.piwheels.org/simple/anyio/anyio-3.6.2-py3-none-any.whl (80 kB)
      npm ERR! Collecting typing-extensions
      npm ERR!   Using cached https://www.piwheels.org/simple/typing-extensions/typing_extensions-4.4.0-py3-none-any.whl (26 kB)
      npm ERR! Collecting h11>=0.8
      npm ERR!   Using cached https://www.piwheels.org/simple/h11/h11-0.14.0-py3-none-any.whl (58 kB)
      npm ERR! Collecting asgiref>=3.4.0
      npm ERR!   Using cached https://www.piwheels.org/simple/asgiref/asgiref-3.5.2-py3-none-any.whl (22 kB)
      npm ERR! Requirement already satisfied: six>=1.9.0 in /usr/lib/python3/dist-packages (from ecdsa>=0.16.0->esptool==3.2->esphome>=2021.8) (1.12.0)
      npm ERR! Collecting packaging>=17.0
      npm ERR!   Using cached https://www.piwheels.org/simple/packaging/packaging-21.3-py3-none-any.whl (40 kB)
      npm ERR! Collecting cryptography>=2.1.4
      npm ERR!   Using cached cryptography-38.0.3.tar.gz (599 kB)
      npm ERR!   Installing build dependencies: started
      npm ERR!   Installing build dependencies: finished with status 'done'
      npm ERR!   Getting requirements to build wheel: started
      npm ERR!   Getting requirements to build wheel: finished with status 'done'
      npm ERR!   Preparing metadata (pyproject.toml): started
      npm ERR!   Preparing metadata (pyproject.toml): finished with status 'done'
      npm ERR! Collecting cffi>=1.12
      npm ERR!   Using cached https://www.piwheels.org/simple/cffi/cffi-1.15.1-cp37-cp37m-linux_armv7l.whl (219 kB)
      npm ERR! Collecting zipp>=0.5
      npm ERR!   Using cached https://www.piwheels.org/simple/zipp/zipp-3.10.0-py3-none-any.whl (6.2 kB)
      npm ERR! Collecting idna>=2.8
      npm ERR!   Using cached https://www.piwheels.org/simple/idna/idna-3.4-py3-none-any.whl (61 kB)
      npm ERR! Collecting sniffio>=1.1
      npm ERR!   Using cached https://www.piwheels.org/simple/sniffio/sniffio-1.3.0-py3-none-any.whl (10 kB)
      npm ERR! Collecting pycparser
      npm ERR!   Using cached https://www.piwheels.org/simple/pycparser/pycparser-2.21-py2.py3-none-any.whl (119 kB)
      npm ERR! Collecting pyparsing!=3.0.5,>=2.0.2
      npm ERR!   Using cached https://www.piwheels.org/simple/pyparsing/pyparsing-3.0.9-py3-none-any.whl (98 kB)
      npm ERR! Building wheels for collected packages: cryptography
      npm ERR!   Building wheel for cryptography (pyproject.toml): started
      npm ERR!   Building wheel for cryptography (pyproject.toml): finished with status 'error'
      npm ERR! Failed to build cryptography
      npm ERR! npm WARN using --force Recommended protections disabled.
      npm ERR! npm WARN old lockfile
      npm ERR! npm WARN old lockfile The package-lock.json file was created with an old version of npm,
      npm ERR! npm WARN old lockfile so supplemental metadata must be fetched from the registry.
      npm ERR! npm WARN old lockfile This is a one-time fix-up, please be patient...
      npm ERR! npm WARN deprecated source-map-url@0.4.1: See https://github.com/lydell/source-map-url#deprecated
      npm ERR! npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated
      npm ERR! npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated
      npm ERR! npm WARN deprecated source-map-resolve@0.5.3: See https://github.com/lydell/source-map-resolve#deprecated
      npm ERR! npm WARN deprecated chokidar@2.1.8: Chokidar 2 does not receive security updates since 2019. Upgrade to chokidar 3 with 15x fewer dependencies
      npm ERR! Cache entry deserialization failed, entry ignored
      npm ERR!   WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'ProtocolError('Connection aborted.', RemoteDisconnected('Remote end closed connection without response'))': /simple/zipp/zipp-3.10.0-py3-none-any.whl
      npm ERR!   error: subprocess-exited-with-error
      npm ERR!
      npm ERR!   × Building wheel for cryptography (pyproject.toml) did not run successfully.
      npm ERR!   │ exit code: 1
      npm ERR!   ╰─> [191 lines of output]
      npm ERR!       running bdist_wheel
      npm ERR!       running build
      npm ERR!       running build_py
      npm ERR!       creating build
      npm ERR!       creating build/lib.linux-armv7l-cpython-37
      npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography
      npm ERR!       copying src/cryptography/utils.py -> build/lib.linux-armv7l-cpython-37/cryptography
      npm ERR!       copying src/cryptography/exceptions.py -> build/lib.linux-armv7l-cpython-37/cryptography
      npm ERR!       copying src/cryptography/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography
      npm ERR!       copying src/cryptography/__about__.py -> build/lib.linux-armv7l-cpython-37/cryptography
      npm ERR!       copying src/cryptography/fernet.py -> build/lib.linux-armv7l-cpython-37/cryptography
      npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat
      npm ERR!       copying src/cryptography/hazmat/_oid.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat
      npm ERR!       copying src/cryptography/hazmat/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat
      npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/x509
      npm ERR!       copying src/cryptography/x509/ocsp.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
      npm ERR!       copying src/cryptography/x509/general_name.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
      npm ERR!       copying src/cryptography/x509/name.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
      npm ERR!       copying src/cryptography/x509/base.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
      npm ERR!       copying src/cryptography/x509/oid.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
      npm ERR!       copying src/cryptography/x509/certificate_transparency.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
      npm ERR!       copying src/cryptography/x509/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
      npm ERR!       copying src/cryptography/x509/extensions.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
      npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings
      npm ERR!       copying src/cryptography/hazmat/bindings/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings
      npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends
      npm ERR!       copying src/cryptography/hazmat/backends/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends
      npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
      npm ERR!       copying src/cryptography/hazmat/primitives/hashes.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
      npm ERR!       copying src/cryptography/hazmat/primitives/constant_time.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
      npm ERR!       copying src/cryptography/hazmat/primitives/keywrap.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
      npm ERR!       copying src/cryptography/hazmat/primitives/padding.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
      npm ERR!       copying src/cryptography/hazmat/primitives/poly1305.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
      npm ERR!       copying src/cryptography/hazmat/primitives/_serialization.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
      npm ERR!       copying src/cryptography/hazmat/primitives/_asymmetric.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
      npm ERR!       copying src/cryptography/hazmat/primitives/hmac.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
      npm ERR!       copying src/cryptography/hazmat/primitives/_cipheralgorithm.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
      npm ERR!       copying src/cryptography/hazmat/primitives/cmac.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
      npm ERR!       copying src/cryptography/hazmat/primitives/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
      npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/openssl
      npm ERR!       copying src/cryptography/hazmat/bindings/openssl/_conditional.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/openssl
      npm ERR!       copying src/cryptography/hazmat/bindings/openssl/binding.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/openssl
      npm ERR!       copying src/cryptography/hazmat/bindings/openssl/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/openssl
      npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
      npm ERR!       copying src/cryptography/hazmat/backends/openssl/backend.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
      npm ERR!       copying src/cryptography/hazmat/backends/openssl/x509.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
      npm ERR!       copying src/cryptography/hazmat/backends/openssl/utils.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
      npm ERR!       copying src/cryptography/hazmat/backends/openssl/hashes.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
      npm ERR!       copying src/cryptography/hazmat/backends/openssl/ec.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
      npm ERR!       copying src/cryptography/hazmat/backends/openssl/aead.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
      npm ERR!       copying src/cryptography/hazmat/backends/openssl/ed448.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
      npm ERR!       copying src/cryptography/hazmat/backends/openssl/rsa.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
      npm ERR!       copying src/cryptography/hazmat/backends/openssl/decode_asn1.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
      npm ERR!       copying src/cryptography/hazmat/backends/openssl/poly1305.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
      npm ERR!       copying src/cryptography/hazmat/backends/openssl/ed25519.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
      npm ERR!       copying src/cryptography/hazmat/backends/openssl/dsa.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
      npm ERR!       copying src/cryptography/hazmat/backends/openssl/x448.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
      npm ERR!       copying src/cryptography/hazmat/backends/openssl/x25519.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
      npm ERR!       copying src/cryptography/hazmat/backends/openssl/hmac.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
      npm ERR!       copying src/cryptography/hazmat/backends/openssl/cmac.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
      npm ERR!       copying src/cryptography/hazmat/backends/openssl/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
      npm ERR!       copying src/cryptography/hazmat/backends/openssl/dh.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
      npm ERR!       copying src/cryptography/hazmat/backends/openssl/ciphers.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
      npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/twofactor
      npm ERR!       copying src/cryptography/hazmat/primitives/twofactor/totp.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/twofactor
      npm ERR!       copying src/cryptography/hazmat/primitives/twofactor/hotp.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/twofactor
      npm ERR!       copying src/cryptography/hazmat/primitives/twofactor/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/twofactor
      npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers
      npm ERR!       copying src/cryptography/hazmat/primitives/ciphers/aead.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers
      npm ERR!       copying src/cryptography/hazmat/primitives/ciphers/algorithms.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers
      npm ERR!       copying src/cryptography/hazmat/primitives/ciphers/base.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers
      npm ERR!       copying src/cryptography/hazmat/primitives/ciphers/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers
      npm ERR!       copying src/cryptography/hazmat/primitives/ciphers/modes.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers
      npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
      npm ERR!       copying src/cryptography/hazmat/primitives/kdf/hkdf.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
      npm ERR!       copying src/cryptography/hazmat/primitives/kdf/pbkdf2.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
      npm ERR!       copying src/cryptography/hazmat/primitives/kdf/x963kdf.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
      npm ERR!       copying src/cryptography/hazmat/primitives/kdf/concatkdf.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
      npm ERR!       copying src/cryptography/hazmat/primitives/kdf/kbkdf.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
      npm ERR!       copying src/cryptography/hazmat/primitives/kdf/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
      npm ERR!       copying src/cryptography/hazmat/primitives/kdf/scrypt.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
      npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/serialization
      npm ERR!       copying src/cryptography/hazmat/primitives/serialization/pkcs12.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/serialization
      npm ERR!       copying src/cryptography/hazmat/primitives/serialization/pkcs7.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/serialization
      npm ERR!       copying src/cryptography/hazmat/primitives/serialization/base.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/serialization
      npm ERR!       copying src/cryptography/hazmat/primitives/serialization/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/serialization
      npm ERR!       copying src/cryptography/hazmat/primitives/serialization/ssh.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/serialization
      npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
      npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/types.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
      npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/utils.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
      npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/ec.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
      npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/ed448.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
      npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/rsa.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
      npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/padding.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
      npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/ed25519.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
      npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/dsa.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
      npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/x448.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
      npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/x25519.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
      npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
      npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/dh.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
      npm ERR!       running egg_info
      npm ERR!       writing src/cryptography.egg-info/PKG-INFO
      npm ERR!       writing dependency_links to src/cryptography.egg-info/dependency_links.txt
      npm ERR!       writing requirements to src/cryptography.egg-info/requires.txt
      npm ERR!       writing top-level names to src/cryptography.egg-info/top_level.txt
      npm ERR!       reading manifest file 'src/cryptography.egg-info/SOURCES.txt'
      npm ERR!       reading manifest template 'MANIFEST.in'
      npm ERR!       no previously-included directories found matching 'docs/_build'
      npm ERR!       warning: no previously-included files found matching 'vectors'
      npm ERR!       warning: no previously-included files matching '*' found under directory 'vectors'
      npm ERR!       warning: no previously-included files matching '*' found under directory '.github'
      npm ERR!       warning: no previously-included files found matching 'release.py'
      npm ERR!       warning: no previously-included files found matching '.readthedocs.yml'
      npm ERR!       warning: no previously-included files found matching 'dev-requirements.txt'
      npm ERR!       warning: no previously-included files found matching 'tox.ini'
      npm ERR!       warning: no previously-included files found matching 'mypy.ini'
      npm ERR!       warning: no previously-included files matching '*' found under directory '.circleci'
      npm ERR!       adding license file 'LICENSE'
      npm ERR!       adding license file 'LICENSE.APACHE'
      npm ERR!       adding license file 'LICENSE.BSD'
      npm ERR!       adding license file 'LICENSE.PSF'
      npm ERR!       writing manifest file 'src/cryptography.egg-info/SOURCES.txt'
      npm ERR!       copying src/cryptography/py.typed -> build/lib.linux-armv7l-cpython-37/cryptography
      npm ERR!       copying src/cryptography/hazmat/bindings/_openssl.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings
      npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
      npm ERR!       copying src/cryptography/hazmat/bindings/_rust/__init__.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
      npm ERR!       copying src/cryptography/hazmat/bindings/_rust/asn1.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
      npm ERR!       copying src/cryptography/hazmat/bindings/_rust/ocsp.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
      npm ERR!       copying src/cryptography/hazmat/bindings/_rust/x509.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
      npm ERR!       running build_ext
      npm ERR!       running build_rust
      npm ERR!       /tmp/pip-build-env-n92amxgl/overlay/lib/python3.7/site-packages/setuptools/command/build_py.py:202: SetuptoolsDeprecationWarning:     Installing 'cryptography.hazmat.bindings._rust' as data is deprecated, please list it in `packages`.
      npm ERR!           !!
      npm ERR!
      npm ERR!
      npm ERR!           ############################
      npm ERR!           # Package would be ignored #
      npm ERR!           Python recognizes 'cryptography.hazmat.bindings._rust' as an importable package,
      npm ERR!           but it is not listed in the `packages` configuration of setuptools.
      npm ERR!
      npm ERR!           'cryptography.hazmat.bindings._rust' has been automatically added to the distribution only
      npm ERR!           because it may contain data files, but this behavior is likely to change
      npm ERR!           in future versions of setuptools (and therefore is considered deprecated).
      npm ERR!
      npm ERR!           Please make sure that 'cryptography.hazmat.bindings._rust' is included as a package by using
      npm ERR!           the `packages` configuration field or the proper discovery methods
      npm ERR!           (for example by using `find_namespace_packages(...)`/`find_namespace:`
      npm ERR!           instead of `find_packages(...)`/`find:`).
      npm ERR!
      npm ERR!           You can read more about "package discovery" and "data files" on setuptools
      npm ERR!           documentation page.
      npm ERR!
      npm ERR!
      npm ERR!       !!
      npm ERR!
      npm ERR!         check.warn(importable)
      npm ERR!
      npm ERR!           =============================DEBUG ASSISTANCE=============================
      npm ERR!           If you are seeing a compilation error please try the following steps to
      npm ERR!           successfully install cryptography:
      npm ERR!           1) Upgrade to the latest pip and try again. This will fix errors for most
      npm ERR!              users. See: https://pip.pypa.io/en/stable/installing/#upgrading-pip
      npm ERR!           2) Read https://cryptography.io/en/latest/installation/ for specific
      npm ERR!              instructions for your platform.
      npm ERR!           3) Check our frequently asked questions for more information:
      npm ERR!              https://cryptography.io/en/latest/faq/
      npm ERR!           4) Ensure you have a recent Rust toolchain installed:
      npm ERR!              https://cryptography.io/en/latest/installation/#rust
      npm ERR!
      npm ERR!           Python: 3.7.3
      npm ERR!           platform: Linux-5.10.103-v7l+-armv7l-with-debian-10.13
      npm ERR!           pip: n/a
      npm ERR!           setuptools: 65.6.0
      npm ERR!           setuptools_rust: 1.5.2
      npm ERR!           rustc: n/a
      npm ERR!
      npm ERR!       error: can't find Rust compiler
      npm ERR!
      npm ERR!       If you are using an outdated pip version, it is possible a prebuilt wheel is available for this package but pip is not able to install from it. Installing from the wheel would avoid the need for a Rust compiler.
      npm ERR!
      npm ERR!       To update pip, run:
      npm ERR!
      npm ERR!           pip install --upgrade pip
      npm ERR!
      npm ERR!       and then retry package installation.
      npm ERR!
      npm ERR!       If you did intend to build this package from source, try installing a Rust compiler from your system package manager and ensure it is on the PATH during installation. Alternatively, rustup (available at https://rustup.rs) is the recommended way to download and update the Rust compiler toolchain.
      npm ERR!
      npm ERR!       This package requires Rust >=1.48.0.
      npm ERR!       [end of output]
      npm ERR!
      npm ERR!   note: This error originates from a subprocess, and is likely not a problem with pip.
      npm ERR!   ERROR: Failed building wheel for cryptography
      npm ERR! ERROR: Could not build wheels for cryptography, which is required to install pyproject.toml-based projects
      npm ERR! npm ERR! code 1
      npm ERR! npm ERR! path /home/iobroker/.npm/_cacache/tmp/git-cloneW47Lho
      npm ERR! npm ERR! command failed
      npm ERR! npm ERR! command sh -c -- npip install
      npm ERR!
      npm ERR! npm ERR! A complete log of this run can be found in:
      npm ERR! npm ERR!     /home/iobroker/.npm/_logs/2022-11-20T17_39_29_374Z-debug-0.log
      npm ERR!     /home/iobroker/.npm/_logs/2022-11-20T17_37_07_823Z-debug-0.log
      upload [479] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/daswettercom.png daswettercom.png image/png
      upload [450] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/8.png icons/luna-moon/8.png image/png
      upload [400] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria3/19.png icons/tiempo-weather/galeria3/19.png image/png
      upload [350] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria5/PNG/White/1.png icons/tiempo-weather/galeria5/PNG/White/1.png image/png
      upload [300] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria5/SVG/White/15.svg icons/tiempo-weather/galeria5/SVG/White/15.svg image/svg+xml
      upload [250] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria6/5.png icons/tiempo-weather/galeria6/5.png image/png
      upload [200] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/Beaufort-White/41.png icons/viento-wind/Beaufort-White/41.png image/png
      upload [150] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/Beaufort-White/87.png icons/viento-wind/Beaufort-White/87.png image/png
      upload [100] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/104.png icons/viento-wind/galeria2-Beaufort/104.png image/png
      upload [90] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/2.png icons/viento-wind/galeria2-Beaufort/2.png image/png
      upload [80] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/29.png icons/viento-wind/galeria2-Beaufort/29.png image/png
      upload [70] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/38.png icons/viento-wind/galeria2-Beaufort/38.png image/png
      upload [60] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/47.png icons/viento-wind/galeria2-Beaufort/47.png image/png
      upload [50] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/56.png icons/viento-wind/galeria2-Beaufort/56.png image/png
      upload [40] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/65.png icons/viento-wind/galeria2-Beaufort/65.png image/png
      upload [30] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/74.png icons/viento-wind/galeria2-Beaufort/74.png image/png
      upload [20] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/83.png icons/viento-wind/galeria2-Beaufort/83.png image/png
      upload [19] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/84.png icons/viento-wind/galeria2-Beaufort/84.png image/png
      upload [18] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/85.png icons/viento-wind/galeria2-Beaufort/85.png image/png
      upload [17] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/86.png icons/viento-wind/galeria2-Beaufort/86.png image/png
      upload [16] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/87.png icons/viento-wind/galeria2-Beaufort/87.png image/png
      upload [15] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/88.png icons/viento-wind/galeria2-Beaufort/88.png image/png
      upload [14] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/89.png icons/viento-wind/galeria2-Beaufort/89.png image/png
      upload [13] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/9.png icons/viento-wind/galeria2-Beaufort/9.png image/png
      upload [12] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/90.png icons/viento-wind/galeria2-Beaufort/90.png image/png
      upload [11] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/91.png icons/viento-wind/galeria2-Beaufort/91.png image/png
      upload [10] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/92.png icons/viento-wind/galeria2-Beaufort/92.png image/png
      upload [9] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/93.png icons/viento-wind/galeria2-Beaufort/93.png image/png
      upload [8] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/94.png icons/viento-wind/galeria2-Beaufort/94.png image/png
      upload [7] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/95.png icons/viento-wind/galeria2-Beaufort/95.png image/png
      upload [6] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/96.png icons/viento-wind/galeria2-Beaufort/96.png image/png
      upload [5] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/97.png icons/viento-wind/galeria2-Beaufort/97.png image/png
      upload [4] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/98.png icons/viento-wind/galeria2-Beaufort/98.png image/png
      upload [3] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/99.png icons/viento-wind/galeria2-Beaufort/99.png image/png
      upload [2] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/index_m.html index_m.html text/html
      upload [1] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/jsonConfig.json jsonConfig.json application/json
      upload [0] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/words.js words.js application/javascript
      host.E4310 Adapter "system.adapter.daswetter.0" is started
      pi@E4310:~ $
      Hat jemand eine Idee was ich tun könnte?
      Danke und Grüße, Bernd
      • crunchip
        crunchip Forum Testing Most Active @bernd33-1 last edited by
        @bernd33-1 möglich das dir da ne installierte git version/esphome in die Suppe spuckt
          bernd33-1 @crunchip last edited by
          @crunchip Jo, irgendwas ist da ziemlich "defekt". Ich mach ein Backup und setz den Pi komplett neu auf.
          Ist somit erledigt.
          81.0k
