    4. [Gelöst:] Adjust settings in the .env File
      Steinmetz_4 last edited by Steinmetz_4
      Servus,
      ich wollte heute den Ds18b20 die Sensoren auf einem anderen System anzeigen lassen.
      Soweit bin ich bisher, aber ich kann mir keinen Reim auf "Please adjust the settings in the .env file." machen.
      Kann mir jemand weiterhelfen?
      pi@pi4-Master:~ $ mkdir ~/ds18b20-remote
      pi@pi4-Master:~ $ cd ~/ds18b20-remote
      pi@pi4-Master:~/ds18b20-remote $ wget -O remote-client-setup.js http://192.168.178.68:8081/adapter/ds18b20/remote-client-setup.js
      --2022-11-23 09:48:58--  http://192.168.178.68:8081/adapter/ds18b20/remote-client-setup.js
      Connecting to 192.168.178.68:8081... connected.
      HTTP request sent, awaiting response... 200 OK
      Length: 39797 (39K) [application/javascript]
      Saving to: ‘remote-client-setup.js’
      remote-client-setup 100%[===================>]  38.86K  --.-KB/s    in 0.003s
      2022-11-23 09:48:58 (14.5 MB/s) - ‘remote-client-setup.js’ saved [39797/39797]
      pi@pi4-Master:~/ds18b20-remote $ node remote-client-setup.js
      - ioBroker.ds18b20 remote client -
      Basic setup done.
      To manually start the client just run:
        node ds18b20-remote-client.js
      To setup the SystemD service, please run:
        sudo cp iobroker-ds18b20-remote.service /etc/systemd/system/iobroker-ds18b20-remote.service
        sudo systemctl daemon-reload
        sudo systemctl enable iobroker-ds18b20-remote.service
        sudo systemctl start iobroker-ds18b20-remote.service
      pi@pi4-Master:~/ds18b20-remote $ sudo nano remote-client-setup.js
      "use strict";
      Object.defineProperty(exports, "__esModule", { value: true });
      const fs = require("fs");
      const os = require("os");
      const path = require("path");
      const SYSTEMD_SERVICE_NAME = 'iobroker-ds18b20-remote.service';
      const files = {
          'common.js': 'InVzZSBzdHJpY3QiOwpPYmplY3QuZGVmaW5lUHJvcGVydHkoZXhwb3J0cywgIl9fZXNNb2R1bGUiLCB7IHZhbHVlOiB0cnVlIH0pOwpleHBvcnRzLmRlY3J5cHQgPSBleHBvcnRzLmVuY3J5cHQgPSBleHBvcnRzLlJFTU9URV9QUk9UT0NPTF9WRVJTSU9OID0gdm9pZCAwOwpjb25zdCBjcnlwdG8gPSByZXF1aXJlKCJjcnlwdG8iKTsKZ>
      'ds18b20-remote-client.js': 'InVzZSBzdHJpY3QiOwp2YXIgX19hd2FpdGVyID0gKHRoaXMgJiYgdGhpcy5fX2F3YWl0ZXIpIHx8IGZ1bmN0aW9uICh0aGlzQXJnLCBfYXJndW1lbnRzLCBQLCBnZW5lcmF0b3IpIHsKICAgIGZ1bmN0aW9uIGFkb3B0KHZhbHVlKSB7IHJldHVybiB2YWx1ZSBpbnN0YW5jZW9mIFAgPyB2YWx1ZSA6IG5ldyBQKGZ1bmN0aW>
      'logger.js': 'InVzZSBzdHJpY3QiOwpPYmplY3QuZGVmaW5lUHJvcGVydHkoZXhwb3J0cywgIl9fZXNNb2R1bGUiLCB7IHZhbHVlOiB0cnVlIH0pOwpleHBvcnRzLkxvZ2dlciA9IHZvaWQgMDsKY2xhc3MgTG9nZ2VyIHsKICAgIGxvZyguLi5hcmdzKSB7CiAgICAgICAgY29uc29sZS5sb2coLi4uYXJncyk7CiAgICB9CiAgICBkZWJ1ZyguLi5hcmdzKSB7C>
      for (const f in files) {
          const content = Buffer.from(files[f], 'base64').toString('utf-8');
          fs.writeFileSync(f, content, { encoding: 'utf-8' });
      const systemDContent = `[Unit]
      Description=ioBroker.ds18b20 remote client
      Documentation=https://github.com/crycode-de/ioBroker.ds18b20
      After=network.target
      [Service]
      Type=simple
      User=${os.userInfo().username}
      WorkingDirectory=${__dirname}
      ExecStart=${process.execPath} ${path.join(__dirname, 'ds18b20-remote-client.js')}
      Restart=on-failure
      [Install]
      WantedBy=multi-user.target
      const systemDFile = path.join(__dirname, SYSTEMD_SERVICE_NAME);
      fs.writeFileSync(systemDFile, systemDContent, { encoding: 'utf-8' });
      const dotEnvContent = `# Settings for the ioBroker.ds18b20 remote client
      # Unique ID for this remote system
      SYSTEM_ID=my-remote
      # IP or hostname of the ioBroker host running the adapter
      ADAPTER_HOST=192.168.178.68
      # Port from the adapter config
      ADAPTER_PORT=1820
      # Encryption key from the adapter config
      ADAPTER_KEY=35305d096dc8eef7db46d575417926bafxxxxxxxxxxxxxxxxxxxxxx
      # Enable debug log output
      #DEBUG=1
      # System path of the 1-wire devices
      #W1_DEVICES_PATH=/sys/bus/w1/devices
      const dotEnvFile = path.join(__dirname, '.env');
      if (!fs.existsSync(dotEnvFile)) {
          fs.writeFileSync(dotEnvFile, dotEnvContent, { encoding: 'utf-8' });
      console.log(`- ioBroker.ds18b20 remote client -
      Basic setup done.
        sudo cp ${SYSTEMD_SERVICE_NAME} /etc/systemd/system/${SYSTEMD_SERVICE_NAME}
        sudo systemctl enable ${SYSTEMD_SERVICE_NAME}
        sudo systemctl start ${SYSTEMD_SERVICE_NAME}
      //# sourceMappingURL=data:application/json;base64,eyJ2ZXJzaW9uIjozLCJmaWxlIjoic2V0dXAuanMiLCJzb3VyY2VSb290IjoiIiwic291cmNlcyI6WyIuLi8uLi9zcmMvcmVtb3RlL3NldHVwLnRzIl0sIm5hbWVzIjpbXSwibWFwcGluZ3MiOiI7O0FBTUEseUJBQXlCO0FBQ3pCLHlCQUF5QjtBQUN6Qiw2QkFBNkI7QUFFN0IsTUFBTSxvQkFBb>
      pi@pi4-Master:~/ds18b20-remote $ node ds18b20-remote-client.js
      [Error] No ADAPTER_HOST given!
      pi@pi4-Master:~/ds18b20-remote $ sudo systemctl status iobroker-ds18b20-remote.service
      ● iobroker-ds18b20-remote.service - ioBroker.ds18b20 remote client
           Loaded: loaded (/etc/systemd/system/iobroker-ds18b20-remote.service; enabled; vendor preset: enabled)
           Active: failed (Result: exit-code) since Wed 2022-11-23 10:56:00 CET; 23s ago
             Docs: https://github.com/crycode-de/ioBroker.ds18b20
          Process: 10290 ExecStart=/usr/bin/node /home/pi/ds18b20-remote/ds18b20-remote-client.js (code=exited, status=1/FAILURE)
         Main PID: 10290 (code=exited, status=1/FAILURE)
              CPU: 183ms
      Nov 23 10:56:00 pi4-Master systemd[1]: iobroker-ds18b20-remote.service: Scheduled restart job, restart counter is at 5.
      Nov 23 10:56:00 pi4-Master systemd[1]: Stopped ioBroker.ds18b20 remote client.
      Nov 23 10:56:00 pi4-Master systemd[1]: iobroker-ds18b20-remote.service: Start request repeated too quickly.
      Nov 23 10:56:00 pi4-Master systemd[1]: iobroker-ds18b20-remote.service: Failed with result 'exit-code'.
      Nov 23 10:56:00 pi4-Master systemd[1]: Failed to start ioBroker.ds18b20 remote client.
      Für alle die auch nicht so gut auf Linux sind, die Lösung ist:
      pi@pi4-Master:~/ds18b20-remote $ sudo nano .env
      sieht dann so aus:
      SYSTEM_ID=Pi-4-Master
      ADAPTER_PORT=1820
      ADAPTER_KEY=dea3458098c294f22546bbd5367a224a4b9082808xxxxxxxxx
      #DEBUG=1
      Mfg
      Tom
